Cisco Catalyst 4000 Switch Console
alfredmorel23
I have a dumb Question what type of connection is this console connection?  I thought this switch used a RJ45 + Serial so I plugged into the ethernet jack next console console not noticing its just a regular 10 base-t could this be used to console into this switch?  I have attached an image below.
6 Replies 6
Ganesh Hariharan
A console connection is a  service that provides access to the system console of a computing device via networking technologies.
Check out the below link for console connection using PC on cisco devices.
http://www-tss.cisco.com/eservice/compass/common/tasks/task_console_port_connect.htm
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
I know what a console connection is; but the pic attached on my first post their it looks like a maybe 20 or 25 pin connector that says console does anyone know what the used called also I see 10-t jack beside it.
beside it.
The port shown in the picture supports DCE       DB-25 receptacle that supports a DCE EIA/TIA-232 interface.
Check out the below link hope to help !!
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008010ff7a.shtml#contermtocat4003
Ganesh.H
Jon Marshall
Edit - apologies think i may be mistaken.
What supervisor model is it ie. "sh module" on the switch.
Jon
For that , you need Serial male to crossover converter. i put the link below.
http://www.provantage.com/perle-systems-04031250~7CHSE0CP.htm
glen.grant
It is the ME1 interface .  Do a search on the ME1 interface and catos, too long to print here what it is used for.
