Cisco Catalyst 4500E Supervisor Engine 7L-E and GLC-GE-100FX
pbogaerts
I was checking the compatibility matrix http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL632702.pdf
and could not find an answer, is the GLC-GE-100FX supported on the Cisco Catalyst 4500E Supervisor Engine 7L-E ?
sgouldbo
100 Mbps media is not supported on SUP 7L-E.
"The Supervisor Engine 7L-E has four uplink ports. Ports 1 and 2 support either 10GBASE SFP+ transceivers or 1000BASE SFP transceivers. Ports 3 and 4 support only 1000BASE SFP transceivers. There are restrictions on the use of the uplink ports in both single supervisor engine and redundant supervisor engine configurations and both 10-G and 1-G operation."
Table 2.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/configuration/notes/OL_25750.html
