Cisco Catalyst 4900M Serial number issue
nmccontent
We need help to confirm which serial number should be used as device serial number for Cisco Catalyst 4900M devices.
We were reporting Supervisor(Slot 1) serial number as special case for 4900M device but customer is complaining for that.
I couldn't find the reason why 4900M is treated differently than other catalyst models.
Here is the command output from the device:
show inventory
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4900M 3 slot switch "
PID: MIDPLANE          , VID:      , SN: XXX12345678
NAME: "Supervisor(slot 1)", DESCR: "4900M 10GE (X2) with 8 10GE X2 ports"
PID: WS-C4900M         , VID: V07  , SN: YYY12345678
Show version
cisco WS-C4900M (MPC8548) processor (revision 2) with 524288K bytes of memory.
Processor board ID XXX12345678
MPC8548 CPU at 1.33GHz, Cisco Catalyst 4900M
Show hardware
All these command output contains serial number that matches MIDPLANE’s serial number in the ‘show inventory’ output.
My customer is saying MIDPLANE's serial number should be used as device serial number.
I also found that there is another command “sh idprom chassis” gives serial number information and that also matches MIDPLANE’s serial number.
I need your expert opinion on this.
8 Replies 8
Reza Sharifi
How about "sh ver"?
Thanks for your response.
Here is the complete sh ver output: [I have changed actual serial number with XXX123456 ]
show version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 15.2(4)E2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 27-Jun-16 10:02 by prod_rel_team
ROM: 12.2(44r)SG5
ASEP105A uptime is 3 years, 33 weeks, 4 days, 7 hours, 24 minutes
System returned to ROM by reload
System restarted at 08:04:21 GMT Tue Sep 6 2016
System image file is "bootflash:cat4500e-entservicesk9-mz.152-4.E2.bin"
Sushi Revision 11, Tatooine Revision 141, Forerunner Revision 1.83
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Last reset from Reload
1 Virtual Ethernet interface
40 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
[done]
To confirm, you may want to look at the actual chassis S/N, which is also located in the front of the chassis.
This link show where it is located.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4900/4900M/installation/guide/4900Mod/01intro.html
Thanks for pointing me to the link.
I don't have physical device access to check serial number. Is there a way to validate using CLI? I can provide complete command output if needed.
 I can still ask customer to check on the physical device. but not sure if he can gets it.
Shikha
Leo Laohoo
4900M is a chassis system. The serial number of the chassis is the one that counts.
Anything else is a "child" of the chassis.
Could you help me to point which one is correct serial number in the below output that should be used as device serial  number? Others are clear to identify but between "Switch System" and "Supervisor(slot 1)" which one is the device serial number is my query.
show inventory
NAME: "TenGigabitEthernet1/1", DESCR: "10Gbase-SR"
PID: X2-10GB-SR , VID: V04 , SN: FNS12345678
NAME: "TenGigabitEthernet1/2", DESCR: "10Gbase-SR"
PID: X2-10GB-SR , VID: V04 , SN: FNS12345679
NAME: "Linecard(slot 2)", DESCR: "10/100/1000BaseT (RJ45) with 20 10/100/1000 baseT "
PID: WS-X4920-GB-RJ45 , VID: V02 , SN: JAE12345678
NAME: "Linecard(slot 3)", DESCR: "10/100/1000BaseT (RJ45) with 20 10/100/1000 baseT "
PID: WS-X4920-GB-RJ45 , VID: V02 , SN: JAE12345666
NAME: "FanTray 1", DESCR: "FanTray"
PID: WS-X4992 , VID: V02 , SN: FOX12345678
NAME: "Power Supply 1", DESCR: "Power Supply ( AC 960W )"
PID: PWR-C49M-1000AC , VID: V01 , SN: SN12345678
NAME: "Power Supply 2", DESCR: "Power Supply ( AC 960W )"
PID: PWR-C49M-1000AC , VID: V01 , SN: SN12345655
To me, above S/N the closest to be a chassis S/N. And if someone can match this with the one in front of the switch, than you are good to go.
 Appreciate your response. Thank you.
I will get this confirmed from customer too by checking on the physical device directly.
