Cisco Catalyst 6509 - Show etherchannel summary
TCCS TCS
Hello Experts,
When I run the show IP protocol command on Agg switch which are in VSS I see below output. Can you help us understand why some port-channel show (RU) and some show (SU). What does the output mean. Sorry being new to Cisco 6509 thought to check with experts. Please help
Agg#sh etherchannel summary
Group  Port-channel  Protocol    Ports
1      Po1(RU)          -        Te1/5/4(P)     Te1/5/5(P)
2      Po2(RU)          -        Te2/5/4(P)     Te2/5/5(P)
3      Po3(SU)         PAgP      Te1/2/1(P)     Te2/2/1(P)
121    Po121(SU)        -        Te1/2/3(P)     Te2/2/3(P)
Mark Malone
hi
RU is a routed port-channel with an ip address layer 3 port-channel
SU is a layer 2 switched / trunked or access port-channel with no ip address
actually it should show you when you run that command
example
xxxxxxxx#sh etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      N - not in use, no aggregation
        f - failed to allocate aggregator
        M - not in use, no aggregation due to minimum links not met
        m - not in use, port not aggregated due to minimum links not met
        u - unsuitable for bundling
        d - default port
        w - waiting to be aggregated
Number of channel-groups in use: 17
Number of aggregators:           17
4      Po4(RU)         LACP      Gi1/7/1(P)     Gi1/8/1(P)     Gi2/7/1(P)
                                 Gi2/8/1(P)
5      Po5(RU)         LACP      Gi1/7/46(P)    Gi1/8/46(P)    Gi2/7/46(P)
                                 Gi2/8/46(P)
6      Po6(SD)         LACP      Gi1/7/12(D)    Gi2/7/12(D)
Thanks Mark. Appreciated.
