Cisco Catalyst 9400 Switch Fabric
UMARSIDDIQUI
I have a requirement where the customer is requesting a Core Switch with redundant switch fabrics.
Does the Cisco Catalyst 9400 series switches support redundant switch fabric?
If not? Which series of switches support redundant switch fabrics?
Joseph W. Doherty
I believe the answer is yes, if you have dup sup cards installed, as the fabric is on the sup card.
Joseph W. Doherty
Reza Sharifi
As Joe also noted, the answer is yes. You can have dual sups on the 9400 configured as SSO.
