06-02-2016 01:39 AM - edited 03-08-2019 06:02 AM
Hello All,
Am using 2 units of Cisco Catalyst C3750X-48 as core switch in my network for Virtual interfaces (VLANs), and am facing some issues with it like when any of my users downloading big files will face some time out in the network it's like forwarding performance not meeting my network environment as the Maximum forwarding performance (IPv4) for Catalyst C3750X-48 is 101.2 Mpps.
So if I apply stacking will it increase the forwarding performance?
Thank You
06-02-2016 01:59 AM
You should stack the switches anyway - but I highly doubt this will be your issue.
06-07-2016 06:54 PM
Hi Philip,
Thanks for your answer,
what do you mean by this might be my issue?
Kindly advice.
06-07-2016 10:17 PM
I think that having the switches either stack or not stack will have any impact on your problem. Stacking should not change the problem.
