Cisco Catalyst IP DEVICE TRACKING
jspichalla
Frequent Visitor
Frequent Visitor
Hi All,
I want to disable the device tracking on my Access Switches 3650 with software version 16.3.6
I don´t unterstand the documentation of the following link
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/16-1/configuration_guide/b_161_consolidated_3650_cg/b_161_consolidated_3650_cg_chapter_01001010.html#reference_xfl_qx1_xcb
If I turn off this feature, I must configure a policy-map? And on with interfaces I must apply this policy-map?
Many Thanks
Jens
andresfr
Hello Js,
The documentation is correct.
* We used the steps below to disable the IPDT in the trunk ports (uplinks)
  1. Define a policy.
    Device# config terminal
    Device(config)# device-tracking policy DT_trunk_policy
    Device(config-device-tracking)# trusted-port
    Device(config-device-tracking=# device-role switch
  2. Attach the policy to the trunk port. You can apply the policy to an interface as well, if required.
    Device(config)# interface <trunk-port-interface>
    Device(config-if)# device-tracking attach-policy DT_trunk_policy
You can then check with the show device-tracking database command.
Leo Laohoo
IP Device Tracking is disabled, globally and interface-level, by default. If the command is not present in the configuration then it's not enabled.
No, a policy-map is not required to use this feature.
Hi Leo,
thanks for your response. The customer see a lot of entries under the command "show ip device tracking".
br
Jens
Maybe it's because the client didn't specify the interface.
andresfr
Hello Js,
  1. Define a policy.
