04-26-2019 02:53 PM
We are planning to connect 2 stacked Catalyst 9300 to a Nutanix Cluster. While doing research I found a document recommending the Nexus 9300 and specifying that the Catalyst 9300 wouldn't meet requirements for the Data Center. There was no reasoning for this and I would like to know why the Catalyst 9300 switches are not recommended.
Thanks in advance,
Ingrid
04-26-2019 03:05 PM
Cisco part of design recomend to have nexus switches for DC Environment.
04-26-2019 03:12 PM
Hi BB,
What is the reasoning behind that statement? Catalyst 9300 switches have the bandwidth required and I would like to know why they are not recommended
Ingrid
04-26-2019 03:18 PM - edited 04-26-2019 03:19 PM
Cat 9300 is meant to be designed for Accesss switches in the Enterprise environment.
Nexus Switch designed to is more of Server traffic environemnt.
Some feature which has Cat 9300 may have built in nexus and also have more advanced features in Nexus.
But this does not mean you should not use Cat 9300 in server enviroment, they do use in small environment.
Some good feature in related to nexus
04-26-2019 04:30 PM
Hi BB,
Thanks for the link
04-26-2019 03:44 PM
Hi @iwarn2019 ,
Maybe this links can give some help:
https://learningnetwork.cisco.com/thread/102745
04-26-2019 04:35 PM
Hi Luis,
Thanks for the comparison link, we have a small-medium environment and the two catalyst switches should work. I was worried there was something specific that would cause problems if we used the Catalyst switches with Nutanix
Best Regards,
Ingrid
