Cisco equivalent or Nortels/Avay's 5520?
Andy White
Level 3
Level 3
We have a Nortel (now Avaya) 5520 48port gigabit switch, but want to replace it with the Cisco equivalent, can advise what model this would be?
Avaya Ethernet Routing Switch 5520-48T-PWR
This switch is ideally suited as a high-density option in the high-performance, convergence-centric wiring closet. It offers 48 concurrent network interfaces: 48 ports of 10/100/1000 with 802.3af Power-over-Ethernet, including four in a combo configuration with 1000BASE-X SFP uplink ports.
Amit Singh
Andy,
Not specifically the 3750-X series but any 3750G switch should be able to offer you the same configruation.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/product_data_sheet0900aecd80371991.html
HTH,
-amit singh
