Cisco HP Comware PVST to MST (root bridge problem)
CISCOPORT007
Hello everyone
I have backbone Cisco 4500 series and Just only one core switch , I have star topology and access switches are Cisco 2960.
Every SFP module connected to 2960 and It has connection from Linksys SRW248G4, and from Linksys to HP 1910
So I had PVST configuration then I have changed it to MST
But now, When I have check with show spanning-tree summary core switch shows that its root bridge for MST1 and MST0
My vlan's on MST1 and when I have checked from access switch it also shows that root bridge for MST1,
From Core switch
Summary
Switch is in mst mode
Root bridge for: MST00-MST01
Extended system ID           is enabled
Portfast Default             is disabled
PortFast BPDU Guard Default  is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default            is disabled
EtherChannel misconfig guard is enabled
UplinkFast                   is disabled
BackboneFast                 is disabled
Configured Pathcost method used is short (Operational value is long)
Name                   Blocking Listening Learning Forwarding STP Active
MST00                        0         0        0         32         32
MST01                        0         0        0         32         32
2 msts                       0         0        0         64         64
From Core Switch (mst detail)
###### MST00        vlans mapped:   101-4094
Bridge      address 0019.aa37.8085 priority  4096  (4096 sysid 0)
Root        this switch for CST and IST
Configured  hello time 2, forward delay 15, max age 20, max hops 20
###### MST01        vlans mapped:   1-100
Bridge      address 0019.aa37.8085  priority  1     (0 sysid 1)
Root        this switch for MST01
From Core switch MST1 detail
Gi1/3            Desg FWD 20000     128.3    P2p
Gi1/4            Desg FWD 20000     128.4    P2p
Gi1/5            Desg FWD 20000     128.5    P2p
Gi1/6            Desg FWD 20000     128.6    P2p
Gi1/7            Desg FWD 20000     128.7    P2p
Gi1/8            Desg FWD 200000    128.8    P2p
Gi1/9            Desg FWD 20000     128.9    P2p
Gi1/10           Desg FWD 20000     128.10   P2p
Gi1/11           Desg FWD 200000    128.11   P2p
Gi1/12           Desg FWD 20000     128.12   P2p
From core switch show spanning tree bridge
                                                  Hello  Max  Fwd
MST Instance                 Bridge ID              Time  Age  Dly  Protocol
MST00             4096 ( 4096,   0) 0019.aa37.8085    2    20   15  mstp
MST01                1 (    0,   1) 0019.aa37.8085    2    20   15  mstp
And this one from access switch
Summary
Switch is in mst mode (IEEE Standard)
Root bridge for: MST1
Loopguard Default            is enabled
MST0                         0         0        0         34         34
MST1                         0         0        0         34         34
2 msts                       0         0        0         68         68
mst1 detail
##### MST1    vlans mapped:   1-100
Bridge        address 0019.e79b.8090  priority      4097  (4096 sysid 1)
Root          this switch for MST1
mst 0 detail
##### MST0    vlans mapped:   101-4094
Bridge        address 0019.e79b.8090  priority      32768 (32768 sysid 0)
Root          address 0019.aa37.8085  priority      4096  (4096 sysid 0)
              port    Gi0/1           path cost     20000
Regional Root address ec44.76d3.8091  priority      32768 (32768 sysid 0)
                                      internal cost 20000     rem hops 19
Operational   hello time 2 , forward delay 15, max age 20, txholdcount 6
Configured    hello time 2 , forward delay 15, max age 20, max hops    20
I had same mst configuration core and access switches same region name, instance 1,revision same. Im sure about this,  I have checked many time.
Whats Wrong ?
Im waiting for answer
Best Regards.
0 Replies 0
