Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco IE-3000 8TC doesn't recogze 4SM fiber sfp module
edhanna0622
Have a few Cisco IE-3000 8TC switches with the  4SM FIber SFP expansion modules. The switches do not discover these ports at all. I'm assuming that thhere is a fix or firmware upgrade, would appreciate any help.
6 Replies 6
LJ Gabrillo
Level 5
Level 5
Can you give us the following? If possible, have the SFPs plugged-in on the IE
#show inventory
#dir flash:
#show version
Additionally, can you give us the complete PID of your SFP?
To give you an overview, the link below are the supported SFPs that the IE-3000 can handle
If your SFP is not on the list, well sadly it can't support that
http://www.cisco.com/c/en/us/products/collateral/switches/industrial-ethernet-3000-series-switches/data_sheet_c78-440930.html
LOOK AT: SFP Transceivers Support for Cisco IE 3000 Series Switch
Isgabrillo, Please see below.
I wasn't able to see a PID for the SFP's, but they are Cisco GLC-FE-100LX
THe switch doesn't seem to recognize the 4SM module that is currently attached. As I stated, I have a few already installed in the field that I am not able to contact right now, but have the same issue. I think I read in a blog somewhere that someone had the same issue and there was an IOS update that cured it.
Switch#sh inv
NAME: "1", DESCR: "IE-3000-8TC"
PID: IE-3000-8TC       , VID: V03  , SN: FOC1826Y36B
NAME: "IE-3000-8TC - Module in slot 1", DESCR: "IE-3000-8TC - Module in slot 1"
Switch#dir flash
%Error opening flash:/flash (No such file or directory)
Switch#sh version
Cisco IOS Software, IES Software (IES-LANBASEK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 00:59 by prod_rel_team
ROM: Bootstrap program is Xmen2 boot loader
BOOTLDR: IES Boot Loader (IES-HBOOT-M) Version 12.2(44r)EX5, RELEASE SOFTWARE (fc1)
Switch uptime is 4 minutes
System image file is "flash:/ies-lanbasek9-mz.122-58.SE2/ies-lanbasek9-mz.122-58.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco IE-3000-8TC (PowerPC405) processor (revision S0) with 131072K bytes of memory.
Processor board ID FOC1826Y36B
Last reset from power-on
1 Virtual Ethernet interface
8 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 50:67:AE:72:AE:00
Motherboard assembly number     : 73-15595-01
Motherboard serial number       : FOC18258RWT
Model revision number           : S0
Motherboard revision number     : A0
Model number                    : IE-3000-8TC
System serial number            : FOC1826Y36B
Top Assembly Part Number        : 800-28538-03
Top Assembly Revision Number    : A0
Version ID                      : V03
CLEI Code Number                : CMMFE00ARB
Hardware Board Revision Number  : 0x02
CIP Serial Number               : 0x8E72AE00
SKU Brand Name                  : Cisco
Switch Ports Model              SW Version            SW Image
*    1 10    IE-3000-8TC        12.2(58)SE2           IES-LANBASEK9-M
Configuration register is 0xF
Switch#exit
Switch#dir flash:
Directory of flash:/
  736  -rwx        3096   Mar 1 1993 00:00:55 +00:00  multiple-fs
    2  drwx        1024   Mar 1 1993 00:06:38 +00:00  ies-lanbasek9-mz.122-58.SE2
  732  -rwx         676   Mar 1 1993 00:07:33 +00:00  vlan.dat
  733  -rwx        1915   Mar 1 1993 00:00:58 +00:00  private-config.text
  735  -rwx        1424   Mar 1 1993 00:00:58 +00:00  config.text
64094208 bytes total (45407744 bytes free)
Switch#exit
*Edited: Was looking at the wrong SFP
Here is the full compatibility list for the 100FE GLC
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL632702.html#88805
And here is for the module installed
http://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie3000/software/release/15-0_2_ey/release/notes/OL27304.html
Cisco IEM-3000-4SM
Expansion module with 4 100BASE-FX fiber-optic Ethernet ports
Note The base switch supports up to two expansion modules with various combinations including the IEM-3000-8FM, IEM-3000-8TM and the PoE/PoE+ modules IEM-3000-4PC and IEM-3000-4PC-4TC. An exception to the combination is that if you install an 8-port IEM-3000-8FM or IEM-3000-8SM right after the base switch, then you can install only one expansion module.
Cisco IOS Release 15.0(2)EY
Thank you all, turned out to be a IOS upgrade. Resolved. Thank you for your help.
Kindly mark as answer or rate the replies to close this question :D
Your SFP seems to be listed in the table.
Try upgrading the firmware,
Here's a link for your reference. I would recommend to download the stable release of v15. Typically marked with a star :D
https://software.cisco.com/download/release.html?mdfid=282118652&flowid=3096&softwareid=280805680&release=15.0.2-EY3&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Oh yeah, choose LAN BASE image to be uniform with your current
