Cisco IE 3000 - changing default ssh auth method
juleedev
hi there.
is there any way to set  the default ssh authentication method on the cisco ie 3000 to be "password"?
I'd like to be able to just log on using username / password by running the following on a command line:
ssh username@10.10.10.10
And then, when prompted, specify my password.
However, right now, when I run the initial connection command, I'm prompted for my key... and then my password.
I know I can do something like this:
ssh -o PreferredAuthentication=password username@10.10.10.10
and then it does what I want it to do.  but I'd like to somehow change the ssh server running on the switch so that I don't have to specify this option each time.
thanks.
0 Replies 0
