891W wireless radio showing as 802.11b and inop
Brian Rapier
I have an 891w that started acting up recently.  Radio dot11 0 is reporting its a b radio.  When it is actually an n 2.4 radio.  Of course that radio is not allowing any clients to connect to it at this time.  I have tried updating the firmware to the latest, tried a hardware reset but still a nogo.  Any other ideas out there?
sh interface output.
Dot11Radio0 is up, line protocol is down
  Hardware is 802.11B Radio, address is 0000.0000.0000 (bia 0000.0000.0000)
  MTU 1500 bytes, BW 11000 Kbit/sec, DLY 1000 usec,
  Keepalive set (10 sec)
  Last input never, output never, output hang never
  Input queue: 0/3000/0/0 (size/max/drops/flushes); Total output drops: 2
  Queueing strategy: fifo
  Output queue: 0/30 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
Dot11Radio0.1 is up, line protocol is down
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1.
sh ver
Cisco IOS Software, AP801 Software (AP801-K9W7-M), Version 15.2(2)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 23-Aug-12 06:16 by prod_rel_team
ROM: Bootstrap program is AP801 boot loader
BOOTLDR: AP801 Boot Loader (AP801-BOOT-M) Version 12.4(23c)JX, RELEASE SOFTWARE (fc1)
Crisis-Whitby-ap uptime is 1 hour, 41 minutes
System image file is "flash:/ap801-k9w7-mx.152-2.JA/ap801-k9w7-mx.152-2.JA"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AP801AGN-A-K9        (PowerPC 8343) processor (revision B0) with 49142K/16384K bytes of memory.
Processor board ID FTX161683HL
PowerPC 8343 CPU at 400Mhz, revision number 0x0031
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 64:00:F1:CF:10:CA
Part Number                          : 73-11027-11
PCA Assembly Number                  : 800-28808-11
PCA Revision Number                  : B0
PCB Serial Number                    : FOC161271MJ
Top Assembly Part Number             : 800-29576-05
Top Assembly Serial Number           : FTX161683HL
Top Revision Number                  : B0
Product/Model Number                 : AP801AGN-A-K9
Configuration register is 0xF
6 Replies 6
Leo Laohoo
Dot11Radio0 is 2.4 Ghz.  As to the "n", it's not.  You can only enable 802.11n on the 5.0 Ghz.
You're not running the "latest" firmware.  JA has a dot1q trunk bug and has been fixed in JB.
Post the config of your AP.
Here is the dot11 radio from a working 891w, must be where my confusion is coming from.
Dot11Radio0 is up, line protocol is up
  Hardware is 802.11N 2.4GHz Radio
I will update to JB see if it makes a difference.
Brian Rapier
Firmware update did nothing to resolve the issue.  Only solution so far that has worked was removing the power from the router completely and plugging it back in.
This seems to have resolved the issue for now.  I will monitor the issue to see if it pops up again.
I've got some 890W and I've never seen something like this.
Me either, I have 9 others running without issue.  This one just decided to start acting up.
I will just have to monitor it to see if it comes back.
I am thinking it was either a power blip (which should not happen as its on a UPS) or one of the users at the location repeatedly unplugged it to fix some issue they thought it would solve.
Just RMA it.
