Cisco IE 4010, default credentials to Web UI, did not work.
lettucemarcvel
Hi Collegues,
We did an Express Setup reset, after the switch rebooted, using CLI we changed the hostname and IP address, now we want to use the Web UI, in the browser typing the IP Address appears the pop-up window asking for the credentials. (My understanding is that are: User > admin and Password > cisco) but does not work.
If I do "show run | i ip http" I receive:
ip http server
ip http secure-server
Also, if I do "show run | i user" I receive:
username admin privilege 15 secret 5 X.X.X
That encrypted password I know which is, but when I use it in the WebUI does not work.
Mark Elsen
     - Check logs on the device just after a GUI logon is attempted ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
