Cisco IP Phone Issue
On occasion a Cisco IP phone would disconnect and re-register. It would take anywhere from a minute to a few minutes. Sometimes physical disconnecting or reconnecting is required.
Phones: 7841 or 7861
CM - 11.5.1
Firmware on Phones - sip 12-5-1sr1-4
Logs on 2960 Stack when issue occured
050255: Sep 28 08:29:59.365 EDT: %SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Gi1/0/31, operational port trust state is now untrusted.
050260: Sep 28 08:39:26.906 EDT: %SWITCH_QOS_TB-5-TRUST_DEVICE_DETECTED: cisco-phone detected on port Gi1/0/31, port's configured trust state is now operational.
Switch port configuration
switchport access vlan 2
switchport mode access
switchport voice vlan 221
srr-queue bandwidth share 1 30 35 5
priority-queue out
no snmp trap link-status
mls qos trust device cisco-phone
mls qos trust cos
spanning-tree portfast edge
spanning-tree bpduguard enable
Any help or suggestions would be greatly appreciated.
Leo Laohoo
  1. What is the exact firmware version of the switch?
  2. Post the complete output to the command "sh interface Gi1/0/31 controller".
1.  15.2(7)E4
2. The port phone has since been moved to another port but here is the info
GigabitEthernet1/0/31 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is e0d1.7312.891f (bia e0d1.7312.891f)
Description: INSTRUCT
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 17:41:16, output 17:39:54, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1193020
Queueing strategy: fifo
Output queue: 0/40 (size/max)
4546398 packets input, 1038758053 bytes, 0 no buffer
Received 113170 broadcasts (113039 multicasts)
3 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 113039 multicast, 0 pause input
41783758 packets output, 6317533455 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Transmit GigabitEthernet1/0/31 Receive
2022568003 Bytes 1038758053 Bytes
8647216 Unicast frames 4433228 Unicast frames
12209751 Multicast frames 113039 Multicast frames
20926807 Broadcast frames 131 Broadcast frames
0 Too old frames 992488484 Unicast bytes
0 Deferred frames 28734284 Multicast bytes
0 MTU exceeded frames 10586 Broadcast bytes
0 1 collision frames 0 Alignment errors
0 2 collision frames 1 FCS errors
0 3 collision frames 0 Oversize frames
0 4 collision frames 0 Undersize frames
0 5 collision frames 0 Collision fragments
0 6 collision frames
0 7 collision frames 52540 Minimum size frames
0 8 collision frames 121768 65 to 127 byte frames
0 9 collision frames 4249869 128 to 255 byte frames
0 10 collision frames 58287 256 to 511 byte frames
0 11 collision frames 2883 512 to 1023 byte frames
0 12 collision frames 60260 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 2 Symbol error frames
0 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 794 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
18488372 64 byte frames 0 Valid frames, too small
13803310 127 byte frames
6908441 255 byte frames 0 Too old frames
727899 511 byte frames 0 Valid oversize frames
536612 1023 byte frames 0 System FCS error frames
1317753 1518 byte frames 0 RxPortFifoFull drop frame
1387 Too large frames
0 Good (1 coll) frames
0 Good (>1 coll) frames
