Cisco ISE
eldosegeorge
Hi All,
I am looking forward to have ISE in my network. The biggest challenge for is my network is mixed with Cisco 3560 which is end-of-life and the new series of Cisco switches (3850).
Can any one assist  to clarify that ISE  can use the old end-of-life products like 3560 switches.
Thanks in advance,
Eldo
Reza Sharifi
Have a look at this link. The compatibility list shows that the 3560-C, 3560-E and 3650-X all support ICE as long as you are running IOS v 15.0.2-SE2
See table-1 in this link:
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/compatibility/ise_sdt.html
