Cisco ISR4321 with NIM-4G-LTE-GA Module Configuration assistance.
Hi All,
I am new to the cellular configuration and my configuration doesn't seem to work.
The SIM card is a data only (Telstra- Australia) and works on my phone, but when I put it in the Module, The physical LED status is as
EN: Green
WWAN : Green (Blinking at times)
Service: RED.
Configuration:
Current configuration : 1675 bytes
! Last configuration change at 03:48:04 UTC Wed Jun 13 2018
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
subscriber templating
license udi pid ISR4321/K9 sn xxxxxxxxx
license boot suite FoundationSuiteK9
redundancy
 mode none
controller Cellular 0/1/0
 lte sim data-profile 1 attach-profile 1
 lte modem link-recovery rssi onset-threshold -110
 lte modem link-recovery monitor-timer 20
 lte modem link-recovery wait-timer 10
 lte modem link-recovery debounce-count 6
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/1
 no ip address
 shutdown
 negotiation auto
interface Cellular0/1/0
 ip address negotiated
 ip nat outside
interface Cellular0/1/1
 no ip address
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
interface Vlan1
 no ip address
 shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 Cellular0/1/0
dialer-list 1 protocol ip permit
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login
end
Outputs:
Router#show cellular 0/1/0 profile
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = telstra.internet
Authentication = None
Profile 2 = INACTIVE
  * - Default profile
 ** - LTE attach profile
Additional things I can't get straight.
1- All the encapsulation in the configuration docs that i found had SLIP but on this router there isn't any available.
Router(config)#int cell 0/1/0
Router(config-if)#en
Router(config-if)#encapsulation slip
% Invalid input detected at '^' marker.
Router(config-if)#encapsulation ?
  atm-dxi         ATM-DXI encapsulation
  bstun           Block Serial tunneling (BSTUN)
  frame-relay     Frame Relay networks
  hdlc            Serial HDLC synchronous
  lapb            LAPB (X.25 Level 2)
  ppp             Point-to-Point protocol
  sdlc            SDLC
  sdlc-primary    SDLC (primary)
  sdlc-secondary  SDLC (secondary)
  smds            Switched Megabit Data Service (SMDS)
  stun            Serial tunneling (STUN)
  x25             X.25
Router(config-if)#end
Debugs:
Router#
Router#
*Jun 13 02:36:16.832: ecell_ipc_rx_handler: IPC RX [20]:
*Jun 13 02:36:16.832: IPC  (40 bytes):
 04 00 00 14 00 00 00 00 01 01 00 00 00 01 00 01
 00 10 00 00 00 00 00 00 00 00 00 02 00 00 00 00
 00 00 00 04 00 00 00 00
*Jun 13 02:36:16.833: ecell_mgmt_process_ipc_event: IPC Message [400] Received
*Jun 13 02:36:16.833: [Cellular0/1/0]:MGMT RX (HEARTBEAT_NOTIFY) (16 bytes):
 00 00 00 00 01 01 00 00 00 01 00 01 00 10 00 00
*Jun 13 02:36:16.833: [Cellular0/1/0]:MGMT TX (CONN_RATE_GET Non-b
Router#lock) (16 bytes):
 00 00 00 00 01 01 00 00 00 02 00 45 00 10 00 01
*Jun 13 02:36:16.833: ecell_set_gps_led: cw_mgmt->gps_info = 7FBFEBDE91E4
*Jun 13 02:36:16.833:  no change in GPS state 1
*Jun 13 02:36:16.843: ecell_ipc_rx_handler: IPC RX [36]:
*Jun 13 02:36:16.843: IPC  (40 bytes):
 04 00 00 24 00 00 00 00 01 01 00 00 00 03 00 45
 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
*Jun 13 02:36:16.844: ecell_mgmt_process_ipc_event: IPC Message [400] Received
*Jun 13 02:36:16.844: [Cellular0/1/0]:MGMT RX (GSM_CONN_RATE_GET_RESP) (32 bytes):
 00 00 00 00 01 01 00 00 00 03 00 45 00 20 00 00
 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
*Jun 13 02:36:22.131: [Cellular0/1/0]:MGMT TX (BAND_GET Non-block) (16 bytes):
 00 00 00 00 01 01 00 00 00 02 00 06 00 10 00 45
*Jun 13 02:36:22.132: [Cellular0/1/0]:MGMT TX (SYSTEM_STATS_GET Non-block) (16 bytes):
 00 00 00 00 01 01 00 00 00 02 00 D6 00 10 00 45
*Jun 13 02:36:22.132:  send system stats get msg rc 1
*Jun 13 02:36:22.166: ecell_ipc_rx_handler: IPC RX [20]:
*Jun 13 02:36:22.166: IPC  (40 bytes):
 04 00 00 14 00 00 00 00 01 01 00 00 00 06 00 00
 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
*Jun 13 02:36:22.167: ecell_mgmt_process_ipc_event: IPC Message [400] Received
*Jun 13 02:36:22.167: [Cellular0/1/0]:MGMT RX (ERROR) (16 bytes):
 00 00 00 00 01 01 00 00 00 06 00 00 00 10 00 00
*Jun 13 02:36:22.226: ecell_ipc_rx_handler: IPC RX [158]:
*Jun 13 02:36:22.226: IPC  (40 bytes):
 04 00 00 9E 00 00 00 00 01 01 00 00 00 01 00 09
 00 9A 00 00 00 00 00 00 00 00 00 02 00 00 00 00
*Jun 13 02:36:22.227: ecell_mgmt_process_ipc_event: IPC Message [400] Received
*Jun 13 02:36:22.227: [Cellular0/1/0]:MGMT RX (SYS_STATUS_NOTIFY) (154 bytes):
 00 00 00 00 01 01 00 00 00 01 00 09 00 9A 00 00
 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 04
 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00
 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
*Jun 13 02:36:22.228: Cellular0/1/0: callbak_flag 1 service_status 2 channel number 0
Router#
Router#
Router#
Router#
*Jun 13 02:36:26.830: ecell_ipc_rx_handler: IPC RX [20]:
*Jun 13 02:36:26.830: IPC  (40 bytes):
*Jun 13 02:36:26.830: ecell_mgmt_process_ipc_event: IPC Message [400] Received
*Jun 13 02:36:26.830: [Cellular0/1/0]:MGMT RX (HEARTBEAT_NOTIFY) (16 bytes):
*Jun 13 02:36:26.830: [Cellular0/1/0]:MGMT TX (CONN_RATE_GET Non-b
Router#
Router#
Router#
Router#
*Jun 13 02:36:26.831: ecell_set_gps_led: cw_mgmt->gps_info = 7FBFEBDE91E4
*Jun 13 02:36:26.831:  no change in GPS state 1
*Jun 13 02:36:26.840: ecell_ipc_rx_handler: IPC RX [36]:
*Jun 13 02:36:26.840: IPC  (40 bytes):
*Jun 13 02:36:26.841: ecell_mgmt_process_ipc_event: IPC Message [400] Received
*Ju
Router#
Router#
Router#n 13 02:36:26.841: [Cellular0/1/0]:MGMT RX (GSM_CONN_RATE_GET_RESP) (32 bytes):
un all
 Parameter map cws-tunnel global not configured
All possible debugging has been turned off
Router#sh ip int brief
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0/0   unassigned      YES unset  administratively down down
GigabitEthernet0/0/1   unassigned      YES unset  administratively down down
Cellular0/1/0          unassigned      YES manual up                    up <<<<------------
Cellular0/1/1          unassigned      YES unset  down                  down
GigabitEthernet0       unassigned      YES unset  administratively down down
Vlan1                  unassigned      YES unset  administratively down down
Router(config-if)#encapsulation ppp
Router(config-if)#
*Jun 13 03:48:02.573: Cellular0/1/0: Unsupported encap typeend
Router#
*Jun 13 03:48:04.815: %SYS-5-CONFIG_I: Configured from console by console
Router#sh inte cellular 0/1/0
  Hardware is 4G WWAN NIM - Global Multimode(Europe) LTE/DC-HSPA+/HSPA+/HSPA/UMTS/EDGE/GPRS
  Internet address will be negotiated using IPCP
  MTU 1500 bytes, BW 50000 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive not supported
  Last input never, output never, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
I've asked for an encapsulation method from the provider and authentication username password.
Need help on this if someone can point me to the right link or what configuration am i missing.
Ab
I got the 4G module working.
There are 2 parts to it.
  1. ISP Side configuration (get the below from your ISP)
    1. Username
    2. Password
    3. Authentication method
    4. APN
  2. Configuration on the router.
 Below is the configuration that needs to be done on the router.
Physical bit:
Make sure the antennas are connected to both the  M0 Main and M1 DIV.
The WWAN is static green with the SIM in.
Service LED – static Blue (2G) or Green
Configuration:
  1. Create the cellular profile
  2. Bind it to the controller
  3. Configure cellular interface.
  4. Perform nat statements
  5. Give a static route for the cellular interface.
  6. Access-lists
  7. Loopback interface is a must (any ip on /32). Mine only worked after the loopback interface.
  8. Once done, do a ping to 8.8.8.8 or any public or MPLS IP(if the sim is MPLS enabled).
Configuration
Router# cellular <interface number> lte profile create <profile number 1-16> APN <myisp.apn> authentication <chap/pap/none> username password
Router# cellular 0/1/0 lte profile create 10  myisp.apn chap username password
Router (config)#
lte sim data-profile 10 attach-profile  10
lte modem dm-log output local-uf
lte modem dm-log rotation
lte modem link-recovery monitor-timer 30
lte modem link-recovery wait-timer 30
lte modem link-recovery debounce-count 20
description Cellular-link
bandwidth 2000
ip nat outside
dialer in-band
dialer idle-timeout 0
dialer-group 1
pulse-time 1
ip nat inside source list 2 interface Cellular0/1/0 overload
access-list 1 permit any
access-list 2 permit any
interface Loopback0
ip address 192.168.1.1 255.255.255.255
Do a PING and interface will come up with an IP as you will have to initiate the traffic for the interface cellular to obtain an IP.
ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
*Oct 30 23:04:49.007: %LINK-3-UPDOWN: Interface Cellular0/1/0, changed state to up
*Oct 30 23:04:50.007: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/0, changed state to up.!!!
Success rate is 60 percent (3/5), round-trip min/avg/max = 24/77/177 ms
Outputs:
sh ip int br | e una
Cellular0/1/0          10.102.XX.YY   YES IPCP   up                    up
Loopback0              192.168.1.1     YES NVRAM  up                    up
Router#sh cellular 0/1/0 profile
PDP Type = IPv4
Profile 10 = ACTIVE* **
PDP Type = IPv4
PDP address = 10.102.xx.yy
Authentication = CHAP
Username: admin
Password: admin
        Primary DNS address = 10.a.b.c
        Secondary DNS address = 10.d.e.f
        Primary DNS IPV6 address = 0
        Secondary DNS IPV6 address = 0
  * - Default profile
Hope that works for you!
Ab
5 Replies 5
peterdervan
Did you ever get this working ? I have an ISR 4221 with a 4g NIM card but also cannot get it working. Looking for a base config if anyone has one - as the configs i have used to date are on 800 and 1900 and IOS 15 etc. I had two types of config - one using a dialer, one directly under cellular 0 - but neither of these seem applicable to the 4221 / IOS-XE etc
Any help would be much appreciated.
Peter
    1. Username
    2. Password
    4. APN
Physical bit:
Configuration:
  6. Access-lists
Configuration
Router (config)#
bandwidth 2000
ip nat outside
dialer in-band
dialer-group 1
pulse-time 1
interface Loopback0
ping 8.8.8.8
Outputs:
PDP Type = IPv4
PDP Type = IPv4
Username: admin
Password: admin
  * - Default profile
Ab
I used this configuration 1:1 and it works instantly. Thank you
Ben14
Hi I know this is an old thread but its been amazingly helpful hopefully this will bump it and someone more knowledgeable can contribute.
To cut a long story short basically the rundown provided by abhishekpurohit2010 works and I can see from the reply is working for others. Here is the thing I have tried many APN settings \ combos - Auth - not auth CHAP \ PAP username - blank username ect for TELSTRA nothing? and why do I want to use this provider? Basically coverage we have remote sites I'd love to deploy this too.
I know my config is working because I can use my own Optus SIM - PAP + Username - but leave the PW empty and yes it behaves as expected - connects NAT works can surf the internet.
Profile 3 = ACTIVE
PDP Type = IPv4
Access Point Name (APN) = yesinternet
Authentication = PAP
Username: admin
Password:
My question is what APN settings are working for people out there?
First time posting here - so I'll jump on and search to see if anything pops up for Telstra APN on this forum. However I'd like to say super grateful I'm half way there
Hi Ben,
There is a catch to my config, wherein the APN settings are for an LTE based MPLS connection, if i use it without the ISP provided APN settings, the connectivity is there but only internet, to which you can use a VPN connection (Hub-Spoke) or L2L of preference.
Glad the article helped.
Ab
