Cisco lan interface pinging inside but with cisco interface can't ping lan
Hello
i have a problem with ping isnide network wich connected cisco lan interface there my topology how i want to use cisco router
i have csico router wich have one ips interface f0/0 and lan interface  f0/1 (192.168.247.0). lan interface connecet onther router with other lan (192.168.250.0) i can ping in 250.0 lan 247 but 247 can't ping 250 lan devices
Current configuration : 1766 bytes
version 12.4
hostname doso
boot-start-marker
boot-end-marker
enable secret 5 $1$TFVW$jcIdNpb8rMm9pWZN5Lnns/
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
crypto isakmp policy 10
 encr 3des
 authentication pre-share
 group 2
crypto isakmp key address
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
crypto map PRIMEVPN 15 ipsec-isakmp
 set peer
 set transform-set 3DES-SHA
 set pfs group2
 match address 100
interface FastEthernet0/0
 mac-address 0023.5e39.20b7
 ip address dhcp
 ip access-group 102 in
 ip nat outside
 ip virtual-reassembly
 ip policy route-map NONAT
 duplex auto
 speed auto
 crypto map PRIMEVPN
interface FastEthernet0/1
 ip address 192.168.247.254 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
no ip http secure-server
ip nat inside source static tcp 192.168.250.12 3389 interface FastEthernet0/0 3389
ip nat inside source route-map NONAT interface FastEthernet0/0 overload
access-list 100 permit ip 192.168.247.0 0.0.0.255 10.130.130.0 0.0.0.255
access-list 100 permit ip 10.130.130.0 0.0.0.255 192.168.247.0 0.0.0.255
access-list 103 permit tcp any eq 3389 any
access-list 110 deny   ip 192.168.247.0 0.0.0.255 10.130.130.0 0.0.0.255
access-list 110 permit ip 192.168.247.0 0.0.0.255 any
route-map NONAT permit 10
 match ip address 110
control-plane
line con 0
line aux 0
line vty 0 4
 password
 login
end
Reza Sharifi
Can you post "sh run" from the other router?
Also, are the interfaces up and running?
Can you post the output of "sh ip int bri" from the other router?
The other router is openwrt opensource linksys rotuter , i can ping openwrt router to cisco router interface ip address but with cisco can't ping inside this openwrt interface
