cisco layer 2 switch
Nizam.Ahmed
Dear Expert,
Please suggest me for choosing layer 2 switch and part number with most low price.
My requirement is:
1. port: 24 GB
no SFP port
No PoE
LAN Base + LAN Lite
2. port: 48 GB
no SFP port
No PoE
LAN Base + LAN Lite
Thanks in advance
Reagards
Nizam
Leo Laohoo
And your budget is?????
Hi Laohoo,
Please suggest me only.
Actually I've already selected a switch which of model 2960-x. But all of those are have minimum 2 SFP ports and PoE which I don't need. Hope you understand.
NB: Is there any way to remove SFP port from CCW?
Thanks for your response.
There is no such 2960/G/S/X/XR model with 24- or 48-port 1 Gbps without any SFP port.
The only "closest" model is 2960-24TT-L (Refurbished) or 2960-48TT-L (Refurbished) and these ports are only 10/100Mbps.
The other option is to look at the Cisco SMB switches.
salemmahara
Level 3
Level 3
Hello The most common L2 series is 2960. Know a days you can choose 2960X. Notice, All new Cisco switches use Fiber Uplink and there is no copper uplink anymore . If your backbone is copper, You need a model which is compatible with GLC-T SFP module. BTW, I suggest these ones:
Cisco Catalyst 2960X-24TD-L ( 95Mpps Forwarding rate )
Cisco Catalyst 2960X-48TD-L ( 130Mpps Forwarding rate )
But if you are looking for cheaper ones without Stack option you can buy 2960-L series ( LAN Lite only and with almost a quarter of forwarding rate of X series in 24 Port model and half of it on 48 Port models ) .
Cisco also had produced 2960S series which are End-of-Sale but you might find them .
please pay extra extra extra attention about Uplink ports and compatibility with modules . Let me explain with an example : Cisco has WS-C2960S-48TD-L and 24TD-L but they both don't support GLC-T!
Let us help you after choosing model and before buying ( Select your model , come here, let's discuss about buying or not )
