Cisco Layer 3 Switch
Brombeee
Can somebody explain to me what is use of default ACL and QOS in layer 3 switches. I am just new to networking i tried to research it but can't find the exact answer. Thanks!
Francesco Molino
Not sure I'm getting your point here.
If you're asking why we use acl for qos, it's to classify the traffic on which we want to apply some qos settings like dscp value or guaranteed bandwidth...
If that wasn't your question, can you be a bit more precise?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Julio E. Moisa
Is possible to share the mentioned configuration?
Thank you in advance.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
