Cisco logging events on a seperate VLAN
vin4510596
When I type  #sh log    it shows events happened to the switch.  I plan on setting up a syslog server and would like the log events to be passed on it's own vlan. For example:  want log events data be passed on vlan 20 and the syslog server connected to the port on the switch with vlan 20 set as a tagged port. I am trying to secure the data so it won't go thru the same vlan as the customers(vlan 1) use. Is that possible? If so, what is/are the command for it? Any suggestion would be greatly appreciated.
Thank you,
Vincent Lagrotteria
Bilal Nawaz
Please see: http://www.cisco.com/en/US/docs/ios/netmgmt/command/reference/nm_09.html#wp1082864
logging source-interface xxxxxxx
logging host x.x.x.x
You can put an ACL to block your customer from coming to your vlan.
e.g. your customers are in vlan 1 and your syslog server is in vlan 20.
conf t
ip access-list extended PROTECT_LOG
deny ip any
permit ip any any
interface vlan 20
ip access-group PROTECT_LOG in
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
