cisco ME 3800x
Abhishek Nanda
I found a new problem in a new L3 Switch ME 3800X. It repeatedly restarts while I am swiching it on. Through the consol its showing errors after flash initialization. If Im breaking the operation it redirects it to switch prompt (switch:).
Errors:
1.Asic1, PB0 Training Failed.
2.ASIC Post initialization failed
3.driver class subsystem initialization failed
If anyone has a solution please help me.
Abhishek
Reza Sharifi
Usually when the device repeatedly restarts, it is an indication that you have installed the wrong image on that platform, but that is not always the case. So the first thing to try is to load a new image and go from there.
