Cisco model types
pdub206
I'm trying to figure out which switch model I have.  The packing list that I received indicates it is part number C1-WS3650-48PD/K9, item description Cisco ONE Catalyst 3650 48 port poe 2x10g uplink.
Searching under all Products on Cisco's website shows a
3650-PD-E
3650-PD-L
3650-PD-S
Which version do I have, and what do the -E -L and -S options mean?
Throwing packets since 2012
Carlos Villagran
Hi!
It is based on license:
E - IP Services
S - IP Base
L - LAN Base
The version you have depends in the license of the switch.
Hope it helps, best regards!
JC
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Usually that suffix indicates factory licensing.
-L = LanBase - L2 or simple L3
-S = Standard (IPBase) - basic L3
-E = Ehanced (IPServices) - advanced L3
Carlos Villagran
Hi!
E - IP Services
S - IP Base
L - LAN Base
JC
