Cisco Nexus 5596 Running-Config file issue
Saeedullah Khan
Can anyone tell me how to delete the running-config /startup-config files on the nexus 5596k model.
I have done write erase but config files is still there and my task is to default factory resetting the switch.
In nexus, where cisco is saved running/startup config files?
regards,
M02@rt37
Hello @Saeedullah Khan,
do "#write erase" and "#reload". write erase command will erase the startup-config. After reload command, if it tell you to save the runn into the startup, say [No].
Best regards
