Cisco Nexus 7000 duplicate IP HSRP %ARP-3-DUP_VADDR_SRC_IP
vuonghongvu
Dear all
i had config HSRP on 2 switches cisco Nexus 7000 non vPC:
SW_N7K_01# show run interface vlan111
version 6.2(2)
interface Vlan111
  no ip redirects
  ip address 172.16.33.245/28
  ip router ospf 1 area 0.0.0.0
  hsrp version 2
  hsrp 1
    preempt
    priority 150
    ip 172.16.33.244
  no shutdown
SW_N7K_02# show run interface vlan 111
version 6.2(2)
interface Vlan111
  no ip redirects
  ip address 172.16.33.246/28
  hsrp version 2
  hsrp 1
    ip 172.16.33.244
  no shutdown
But when I check logging on Cisco Nexus. It display then messages:
2016 Jul 18 16:20:49 SW_N7K_01 %ARP-3-DUP_VADDR_SRC_IP:  arp [5534]  Source addr
ess of packet received from 0000.0c9f.f001 on Vlan111(port-channel2) is duplicat
e of local virtual ip, 172.16.33.244
This is debug hsrp hello on Switch Nexus 01:
2016 Jul 18 16:19:49.201476 hsrp: Vlan111[1/V4]: Hello out Active pri 150 ip 172
.16.33.244
2016 Jul 18 16:19:49.201535 hsrp: Vlan111[1/V4]: hel 3000 hol 10000 id e8ed.f325
.70c1
2016 Jul 18 16:19:50.674917 hsrp: Vlan111[1/V4]: Hello in from 172.16.33.246 Pee
r/My State Standby/Active pri 100 ip 172.16.33.244
2016 Jul 18 16:19:50.674950 hsrp: Vlan111[1/V4]: hel 3000 hol 10000 auth cisco
2016 Jul 18 16:19:51.862090 hsrp: Vlan111[1/V4]: Hello out Active pri 150 ip 172
.16.33.244
2016 Jul 18 16:19:51.862101 hsrp: Vlan111[1/V4]: hel 3000 hol 10000 id e8ed.f325
.70c1
2016 Jul 18 16:19:53.622423 hsrp: Vlan111[1/V4]: Hello in from 172.16.33.246 Pee
2016 Jul 18 16:19:53.622469 hsrp: Vlan111[1/V4]: hel 3000 hol 10000 auth cisco
--------------------------------------This is " show hsrp interface vlan on 2 switch"-------------------
SW_N7K_01# show hsrp interface vlan 111
Vlan111 - Group 1 (HSRP-V2) (IPv4)
  Local state is Active, priority 150 (Cfged 150), may preempt
    Forwarding threshold(for vPC), lower: 1 upper: 150
  Hellotime 3 sec, holdtime 10 sec
  Next hello sent in 1.888000 sec(s)
  Virtual IP address is 172.16.33.244 (Cfged)
  Active router is local
  Standby router is 172.16.33.246 , priority 100 expires in 6.421000 sec(s)
  Authentication text "cisco"
  Virtual mac address is 0000.0c9f.f001 (Default MAC)
  1 state changes, last state change 44w0d
  IP redundancy name is hsrp-Vlan111-1 (default)
SW_N7K_02# show hsrp interface vlan 111
  Local state is Standby, priority 100 (Cfged 100)
    Forwarding threshold(for vPC), lower: 1 upper: 100
  Next hello sent in 2.589000 sec(s)
  Active router is 172.16.33.245, priority 150 expires in 1.492000 sec(s)
  Standby router is local
I don't know why do  virtual ip address send HSRP hello meassege. How to resolve the issue ? I don't want receipt duplicate ip address message.
Please help me !
Thanks you so much !
esa_fresa
You can ignore the alerts with the SVI interface level command "no ip arp gratuitous hsrp duplicate".
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/unicast/command/reference/n7k_unicast_cmds/l3_cmds_i.html
So you can ignore the alerts by how come the two gateways are showing active?  I'm having this same problem.  When I do a show hsrp bri on both of them it tells me this:
Interface Grp Prio P State Active addr Standby addr Group addr
Vlan3       10 110 P Active local              unknown       X.X.X.X
It says this for all of my VPC's.  I also have those same log messages.  Here's the config on my VPC domain:
vpc domain 751
peer-switch
role priority 1000
system-priority 4000
peer-keepalive destination X.X.X.X source X.X.X.X
no layer3 peer-router syslog
peer-gateway
ipv6 nd synchronize
ip arp synchronize
The other side is the exact same.
