Cisco Nexus 7000 password encryption ?
JY
We are using a Nexus 7004
The ver information is as follows.
Software
BIOS: version 2.12.0
kickstart: version 6.2(16)
system: version 6.2(16)
BIOS compile time: 05/29/2013
kickstart image file is: bootflash:///n7000-s2-kickstart.6.2.16.bin
kickstart compile time: 1/27/2016 9:00:00 [04/06/2016 06:13:37]
system image file is: bootflash:///n7000-s2-dk9.6.2.16.bin
system compile time: 1/27/2016 9:00:00 [04/06/2016 07:16:06]
The customer wants to apply sha256 to the username password part.
No matter how much I search the documentation, it seems that sha256 is not supported,
It seems to support ase, but this part is also not clear.
Is there a part that can be set with ase and checked through show run?
Is there any part that can solve this part through os upgrade?
I checked the syntax on the NX7K, it looks like AES is the only option:
N7K(config)# feature password encryption aes
Thanks for your reply.
So, is there a command to check whether ase is applied?
