cisco nexus 7710 power
CSCO10675262_2
I have a Cisco Nexus 7710 using the 3KW AC power supplies. Based on http://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/data_sheet_c78-729141.html?cachemode=refresh , it seems that the maximum input current is 20A while the power cord indicated on the link is  rated 16A; I was wondering if a 20A power cord may be required instead since the maximum input current is 20A?
For the circuit, not too sure if it can be connected to a 16A circuit?
Any suggestion is appreciated.
jkilleda
Level 3
Level 3
Hello Choong Whye,
It's ok if you connect a 16A power cord
