Cisco nexus 9k + interface error disable issue
vinayjaiswal
Level 3
Level 3
Hi Team,
We have nexus 9k ( N9K-C93180YCEXB18Q) standalone device. We have configured po (2 links) between nexus and server.
All interfaces will flap and go into Internal-Fail errDisable state.  Pls suggest how to fix this issue.
TCLBLRCORPSRVSW001# show interface ethernet 1/18
Ethernet1/18 is down (Internal-Fail errDisable)
admin state is up, Dedicated Interface
Belongs to Po13
Hardware: 1000/10000/25000 Ethernet, address: 70db.9856.0a81 (bia 70db.9856.0a81)
TCLBLRCORPSRVSW001# show interface ethernet 1/17
Ethernet1/17 is down (Internal-Fail errDisable)
Belongs to Po13
Hardware: 1000/10000/25000 Ethernet, address: 70db.9856.0a80 (bia 70db.9856.0a80)
TCLBLRCORPSRVSW001# show interface ethernet 1/16
Ethernet1/16 is down (Internal-Fail errDisable)
Belongs to Po12
Hardware: 1000/10000/25000 Ethernet, address: 70db.9856.0a7f (bia 70db.9856.0a7f)
Description: ***SAP_SERVER_1***
TCLBLRCORPSRVSW001# show interface ethernet 1/15
Ethernet1/15 is down (Internal-Fail errDisable)
Belongs to Po12
Hardware: 1000/10000/25000 Ethernet, address: 70db.9856.0a7e (bia 70db.9856.0a7e)
MTU 1500 bytes, BW 25000000 Kbit, DLY 10 usec
Software
BIOS: version 07.56
NXOS: version 7.0(3)I4(3)
BIOS compile time: 06/08/201
Thanks in advance.
Vijay
Mark Malone
is the server side setup to bond/teaming on a PO could be causing a loop if not and nx is shutting it down as a precaution to prevent it
