Cisco nexus packet capture for VRF vlan interface
MonkeyBear007
Need to packet capture a vrf vlan interface for traffic what is the best way
5 Replies 5
pieterh
I do not understand the question
vlan interface is Layer-2, vfr is Layer-3.
-> just specify vlan as monitor source?
nexus doesn't let use the VRF vlan at layer 3
pieterh
cna you publish the command you used and the response you got?
you need to specify the type of interface
     source interface type slot/port [rx | tx | both]
or specify the vrf in the monitor session command
monitor session <id> source vrf <name>
I opened a ticket with support, and they didn't see it, so I need to open another one to figure out why.
