Cisco Nexus switches and jumbo frames
flyerhawk
Perhaps someone can help us out a little bit.
We have a Nexus switch that is connected to a bunch of servers and has an upstream connection to our core.
For some reason we see the switch transmitting a lot of jumbo packets despite the fact that none of the servers are sending jumbo packets. In fact the egress port doesn't see any inbound jumbo packets..
Ethernet1/15 is up
  Hardware: 1000/10000 Ethernet, address: f866.f27d.6fe4 (bia f866.f27d.6fe4)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10g
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  Last link flapped 1week(s) 3day(s)
  1 minute input rate 30267072 bits/sec, 21384 packets/sec
  1 minute output rate 41052528 bits/sec, 20295 packets/sec
  Rx
    141428733917 input packets 117006081538 unicast packets 24404722805 multicast packets
    17933114 broadcast packets 0 jumbo packets 0 storm suppression packets
    20710996269479 bytes
  Tx
    134309200288 output packets 15170283276 multicast packets
    32333 broadcast packets 3234301155 jumbo packets
    23749465522981 bytes
    0 input error 0 short frame 0 watchdog
    0 no buffer 0 runt 0 CRC 0 ecc
    0 overrun  0 underrun 0 ignored 0 bad etype drop
    0 bad proto drop 0 if down drop 0 input with dribble
    76208 input discard
    0 output error 0 collision 0 deferred
    0 late collision 0 lost carrier 0 no carrier
    0 babble
    0 Rx pause 0 Tx pause
How can this be?  Why is it sending jumbo packets?  Is it somehow combing multiple Ethernet packets together?
yaron.abo
did you solve the issue?
i have the same problem with the Nexus 4001i switch.
thanks,
Yaron
