12-12-2012 02:14 AM - edited 03-07-2019 10:33 AM
I have a Cisco Nexus Datacenter solution with this design:
Every Nexus 5K is connected with every Nexus 2K with a Port-Channel and vPC.
What is the best way,to keep the configurations of the nexus switches synchronous? I have no DCNM (Mgmt.-Tool).
My problem is if I configure for example a Nexus2K-host port on one Nexus 5K, the change has no effect. Only when I make the same change on
the second N5K the port-config really changes.
12-12-2012 05:01 AM
You can use config Sync:
See this link;
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/operations/n5k_config_sync_ops.html
12-27-2012 02:36 AM
Hi Heiko
To add to Reza's link - you can check following videos, recorded by our specialist about config-sync configuration and implementation:
https://supportforums.cisco.com/videos/1848
https://supportforums.cisco.com/videos/1852
https://supportforums.cisco.com/videos/1853
https://supportforums.cisco.com/videos/1856
HTH,
Alex
