Cisco NX-OS CoPP Exemptions
Lyphiard
I currently have a public-facing switch configured with many constantly-changing VLANS with SVI. I've recently been facing an issue where multiple IP's are trying to bruteforce my SSH login. Having some kind of firewall in front of the switch currently is not an option.
I've been looking into using CoPP to allow SSH only from certain IP addresses. Since I have multiple SVI's, I'd like to use CoPP to enable me to block SSH on all IP's instead of needing to apply an ACL to each individual VLAN.
Here's my current configuration:
ip access-list copp-global
  10 permit tcp addrgroup management-ip any eq 22
  20 deny tcp any any eq 22
class-map type control-plane match-any copp-global
  match access-group name copp-global
policy-map type control-plane copp-global
  class copp-global
    police pps 0
control-plane
  service-policy input copp-global
Essentially, I want to allow anyone in management-ip to access port 22, but block everyone else. However, the documentation for class-map states that the permit and deny clauses are ignored. This causes both 10 and 20 to be recognized as "deny" statements.
What would be the best way to go about accomplishing this?
Reza Sharifi
You need an inbound access list on the interface facing the outside that has a public IP address with permits and denies statements.
