Cisco Packet Tracer assignment. Help, please
Twina1111
Please See attached pkt
I did not understand the topology
I do not understand how should ‘TEST PCs’ communicate w/ any VLAN
Guidelines to follow
-Each PC should be on the VLAN specified
-The access point should be on VLAN 40, and secured using WPA2
-Router0 should be the gateway for VLANs 10 and 30
-Router1 should be the gateway for VLANs 20 and 40
-OSPF should be implemented on all routers
-IP addresses to start w/:
*VLANs subnetted from the 192.168.0.0 /16 range
*Serial links subnetted from 10.0.0.0 /8 range
*Test PC networks from the 172.16.0.0 /16 range
I will really appreciate
Good life to u all! :)
Jon Marshall
Most of us don't use PT so you need to post the topology as a diagram.
However if you are asking us to do the assignment for you then I doubt anyone will do that.
If you have tried to set it up and can't get it working then we may be able to help.
Jon
