ACL not working on 3750 Switch Stack on a trunk port
Mark Gross
I cannot figure out why the ACL is not working on a 3750 running 12.2 (55)SE on a trunk port.  For testing, there is 1 x IP (10.101.15.13) that should be denied to all VLANs on the trunk.  I have tried standard and extended list, but neither seem to work.
What am I doing wrong?
Access-List:
Standard IP access list 10
    10 deny   10.101.15.13 log
    20 permit any log
Access-List Interface:
interface GigabitEthernet7/0/10
 description ESX Trunk
 switchport trunk allowed vlan 1,2,60-63
 switchport mode trunk
 ip access-group 10 in
Mac-Address on the Switch Port:
63    0050.569a.6d9f    DYNAMIC     Gi7/0/10
Windows Machine MAC:
Description . . . . . . . . . . . : vmxnet3 Ethernet Adapter #4
Physical Address. . . . . . . . . : 00-50-56-9A-6D-9F
Windows Connection (which should be denied):
 TCP    10.20.63.4:3389        10.101.15.13:21289     ESTABLISHED     InHost
Mark Gross
bump.
Must be a real nutcracker.  No responses.
PACL only apply to an L2 interface.  On an L2 interface the only direction that can be applied is INBOUND.  On an L3 interface INBOUND or OUTBOUND can be specified.
In any case, I have worked around the issue by applying VACLs. Marking this as resolved.
jonasvanraes1
Maybe it's because your ACL is inbound, he only looks at the traffic coming from that trunk line?
