Cisco serial console periodically ssends @ character
Filip Maroul
Hello comunity,
I have problem witch Cisco serial console on awitch 9200L. I am connecting from Debian 12 with gnome. When I login to cisco via serial console with usb-serial reduction, the console start automatically entering this charecter "@" like so:
switch>^@
switch>^@
And this was repeating every 3s. So I cant type any commands. Does anyone knows wheres could be the problem ?
Thank you for any advice.
5 Replies 5
Blue_Bird
Try to change speed....
You  try to test with  these speeds: 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200
Your problem might fix with any one of the speed....
Best regards
******* If This Helps, Please Rate *******
thank you for your respond. I try all speed with no effect.
Try with following key board settings with putty....for some scenario's/people issue is resolved with these settings..
Hello and thank you lot for help.
I must apologize, It was my system problem. I had running "pwrstatd" service which thinks the new serial device is UPS. After disabled this service all working.
ok...Thanks for the confirmation...
