Cisco SG350
Hello I have been told that the switch is 192.168.33.251 I have setup my network adapter
to 192.168.33.250 I’m have no cable connected and I can’t seem to be able to log in any help would be mostly appreciated,
kind regards
Benjamin
Blue_Bird
Hello robinsonbenjamin82,
To configure the switch using the web-based interface:
STEP 1 Power on the computer and your switch.
STEP 2 Connect the computer to any network port.
STEP 3 Set up the IP configuration on your computer.
a. If the switch is using the default static IP address of 192.168.1.254/24, you must choose an IP address for the
computer in the range of 192.168.1.2 to 192.168.1.253 that is not already in use.
b. If the IP addresses will be assigned by DHCP, make sure that your DHCP server is running and can be reached from the
switch and the computer. You may need to disconnect and reconnect the devices for them to discover their new IP
addresses from the DHCP server.
STEP 4 Open a web browser window. If you are prompted to install an ActiveX plug-in when connecting to the device, follow the prompts to accept the plug-in.
STEP 5 Enter the switch IP address in the address bar and press Enter. For example, http://192.168.1.254.
STEP 6 When the login page appears, choose the language that you prefer to use in the web-based interface and enter the username and password. The default username is cisco. The default password is cisco. Usernames and passwords are both case sensitive.
STEP 7 Click Log In.
If this is the first time that you have logged on with the default username and password, the Change Password page opens. The rules for constructing a new password are displayed on the page.
STEP 8 Enter a new password and confirm the password.
STEP 9 Click Apply.
CAUTION Make sure that any configuration changes made are saved before exiting from the web-based interface by clicking on the Save icon. Exiting before you save your configuration results in all changes being lost.
Reference: https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350_/2_3/quick_start/guide/en-US/Cisco350-QSG-en-US.pdf
Best regards
******* If This Helps, Please Rate *******
