Cisco SG550X switch - Configuration for Removing Vlan 1 Interface Ip Address
Yasmeen
Hi Team,
          we have one SG550X SMB switch - how do i remove the Vlan 1 Interface IP Address due this IP Address i am getting Conflict on my network
switchf8ec2b#show ip interface Vlan1
IP Address              I/F I/F Status Type Directed Prec Redirect Status      admin/oper Broadcast
0.0.0.0/32                vlan 1 UP/UP         DHCP        disable   No enable        Not received
192.168.1.254/24      vlan 1 UP/UP     Default         disable     No enable         Valid
Please help on this to remove Vlan 1 interface IP address as well as DHCP
Yasmeen Shaul Hameed.
Mark Elsen
 - That's the default address , check this guide for configuration guidelines :
  https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xg/admin_guide/AG_Tesla_350_550.pdf
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Due to Default Configuration i am Getting Issue on my Network Subnet (IP Conflict) please let me know the Alternate Solution to delete that IP Address
Do you need VLAN 1 Interface ?
how about going in to command level and shutdown the VLAN interface 1 ?
Example :
1. enable
2. conf t
3. inter vlan 1
4 ip address X.X.X.X X.X.X.X ( change to new IP address you looking for Management)  or remove the address
5. allocate same to different interface.
BB
Hi Balaji,
          I have down the Vlan 1 interface and also try to remove the Vlan 1 Interface - as well - but its not deleting the Vlan 1 interface IP address
           As you said will try with another IP Address will assign to it
          Thanks for the Info
