Cisco SMB 110
prashanma
Hi Team,
Can we create Vlans in Cisco SMB 110 Series switches ?
In spec it mentions that "Layer 2 Switching" is supported. Does it mean it supported vlans ?
Jaderson Pessoa
Dear prashanma,
This devices doesn't support vlan configuration.
Check datasheet for resources supported on it: https://www.cisco.com/c/en/us/products/collateral/switches/110-series-unmanaged-switches/datasheet-c78-734450.html
Thanks in advance.
Jaderson Pessoa
*** Rate All Helpful Responses ***
5 Replies 5
Jaderson Pessoa
Dear prashanma,
Thanks in advance.
Jaderson Pessoa
Thank you. I hope Cisco 350X series support for vlan configuration
Thanks you too.
Yes, cisco 350x support vlan as mentioned at datasheet sent earlier.
Good lucky.
If possible, mark it as ansewered.
Thanks in advance.
Jaderson Pessoa
Hi Jaderson,
One thing to clarify. In datasheet, for SG110-24HP PoE supported ports are 12, but poe power is 100W. So that is mean only 6 port can support PoE at given time right ? Or does at given time all the 12 ports are support PoE at the given time
All ports are supported with PoE with max 100W usage. So, depends what means of devices that you will input on this switch. You have a limit of 100W, but all ports can be used with PoE
Jaderson Pessoa
