Disable power to line cards on 4510R+E
steven.t27
Hi All
I have a 4510R+E with 4 48 PoE switch port line cards and 2 supp engine.
In an event of a power failure. Is there a command that I can shut down lower priority line card to save power on the UPS?
From the output below, I have lost PS1-2 and PS2-2.
#sh power deta
Power                                             Fan      Inline
Supply  Model No          Type       Status       Sensor   Status
PS1     PWR-C45-6000ACV   AC 6000W   good         good     good
PS1-1                         220V   good
PS1-2                                off
PS2     PWR-C45-6000ACV   AC 6000W   good         good     good
PS2-1                         220V   good
PS2-2                                off
Power supplies needed by system    : 1
Power supplies currently available : 2
Power Summary                      Maximum
 (in Watts)              Used     Available
System Power (12V)       1140        2200
Inline Power (-50V)       218        1820
Backplane Power (3.3V)     40          40
Total                    1398 (not to exceed Total Maximum Available = 3000)
                             Output Power To Chassis            Input Power
Power Measurement   System Power (12V)  Inline Power (-50V)
(in Watts)                (+/- 12W)        (+/- 50W)              (+/- 5%)
PS1                        270                  100                  493
PS2                        267                   65                  454
Total                      537                  165                  947
Note: System power budget is 1140 Watts to accommodate peak power utilization.
Power fail interrupts received on slot 1: 0
Power fail interrupts received on slot 2: 0
Debounce value for power fail status: 0 microseconds
                             Watts Used of System Power(12V)
Mod   Model                 budgeted instantaneous  peak   out of reset  in reset
 1    WS-X4748-RJ45V+E          55          26        28        55          35
 2    WS-X4748-RJ45V+E          55          26        28        55          35
 3    WS-X4748-RJ45V+E          55          28        29        55          35
 4    WS-X4748-RJ45V+E          55          26        29        55          35
 5    WS-X45-SUP8-E            400         202       209       400         205
 6    WS-X45-SUP8-E            265         198       203       265         205
 --   Fan Tray                 255         --        --        --          --
       Total                  1140         506       526       885         550
                        Watts used of Chassis Inline Power (-50V)
                        Inline Power Admin  Inline Power Oper
Mod   Model                PS     Device       PS     Device     Efficiency
 1    WS-X4748-RJ45V+E         0        0         12       11          95
 2    WS-X4748-RJ45V+E        67       64         32       30          95
 3    WS-X4748-RJ45V+E       118      112         47       45          95
 4    WS-X4748-RJ45V+E        34       32         20       19          95
 5    WS-X45-SUP8-E            -        -          -        -           -
 6    WS-X45-SUP8-E            -        -          -        -           -
       Total                 219      208        111      105
I would like to shut down Line card 1 and 3 for example. Can I do that?
ST
10 Replies 10
InayathUlla Sharieff
ST,
I have never seen the command to achieve this.
Inayath
Bilal Nawaz
Maybe it works for the 6500, but not 100% sure about the 4500's
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/interface/command/ir-cr-book/ir-f1.html#wp2960289942
https://supportforums.cisco.com/discussion/9761481/cat6500-ios-how-power-linecard
hth
Bilal
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hello
Not sure if I have misinterpreted your query here? - "I would like to shut down Line card 1 and 3 for example. Can I do that?"
hw-module module 1 shutdown
hw-module module 3 shutdown
res
paul
Kind Regards
Paul
Hello Paul,
The links I have provided pretty much state what you have stated in your post. Could you confirm if this works on the 4500 platform?
Hello Bilal
Nice to see you on here gain - you've been busy?
Please check out 4500 cco  doc it seems to suggests it does.
res
Paul
Kind Regards
Paul
Hey Paul, yes been busy lately due to a new member of the family :)
Awesome! I didn't know. Learnt something new, thanks Paul.
Hello
Wow been a busy 12 months for you - becoming CCIE and a new family member!
congrats -  very well deserved!
res
Paul
Kind Regards
Paul
Thanks Paul :)
Hi Paul
4510#hw-module module 1 shutdo
4510#hw-module module 1 ?
  reset  Reset module in specified slot
No shutdown options
Try this...
as1-idf1-ara#hw-module mod 5 reset ?
power-cycle Turn module power off then on
<cr>
as1-idf1-ara#
as1-idf1-ara#hw-mod module 5 reset power-cycle ?
<cr>
as1-idf1-ara#
