Cisco static nat issue
Hello everyone. I just did configuration on Cisco 892F router. Everything works fine, but static nat is not working. I create static nat on tcp port 80 (http). I don't know where is the problem. All nats working fine except static nat. Even though internet connection is ok in my lan,
i cannot access my router from the internet. Does anyone have an idea on that?
6 Replies 6
i attached router's show run log.
hi,
could you add ACE:
access-list 101 permit tcp any host 10.0.0.3 eq 80
Hi, John Lloyd
Thanks for your quick response.I tried this. But it's still not working.
Now this router is working. My Lan has an Internet connection. But ping is not going to my router from the internet. I think this is the problem. IP address is 202.55.183.82, you can ping it.
Try instead
this rule:
access-list 101 permit tcp any host 202.55.183.85 eq 80
I think you have to list public IP address instead of private address, but I am not sure. Please try it and let us know
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
can you do this in addition to the ACL referencing the public IP posted by blau grana:
EDIT: in zone based firewall you must reference the inside address and not the outside address so leave the ACL 101 as it was originally and add this command to global config
ip http port 8080
Alain
