Need help with 1811W configuration - over my head
ScottKelley4444
Either gonna shoot this router or myself - not yet sure which...
Cisco 1811W
Configuration Pro Express is NOT installed
I do not have a service contract with Cisco, so cannot download CPE
sdmconfig-1811-1812.cfg file exists in Flash - have moved it to nvram
I have spent most of the weekend trying everything I can find to get this working but have not been able to.  The biggest issue that I need to get over is establishing a connection with Configuration Pro.  I presume something is missing in the networking setup, but have not yet been able to get everything right.
Anybody out there who knows these things want to do some phone consulting?
Below is the last configuration I used:
         --- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: yes
At any point you may enter a question mark '?' for help.
Use ctrl-c to abort configuration dialog at any prompt.
Default settings are in square brackets '[]'.
Basic management setup configures only enough connectivity
for management of the system, extended setup will ask you
to configure each interface on the system
Would you like to enter basic management setup? [yes/no]: y
Configuring global parameters:
  Enter host name [Router]: Cisco1811W_1
  The enable secret is a password used to protect access to
  privileged EXEC and configuration modes. This password, after
  entered, becomes encrypted in the configuration.
  Enter enable secret: scottk
  The enable password is used when you do not specify an
  enable secret password, with some older software versions, and
  some boot images.
  Enter enable password: scott
  The virtual terminal password is used to protect
  access to the router over a network interface.
  Enter virtual terminal password: rrt93m
  Configure SNMP Network Management? [yes]: y
    Community string [public]: LSDTHK87
Current interface summary
Any interface listed with OK? value "NO" does not have a valid configuration
Interface                  IP-Address      OK? Method Status                Prot
ocol
FastEthernet0              unassigned      NO  unset  up                    down
FastEthernet1              unassigned      NO  unset  up                    down
FastEthernet2              unassigned      YES unset  initializing          down
FastEthernet3              unassigned      YES unset  initializing          down
FastEthernet4              unassigned      YES unset  initializing          down
FastEthernet5              unassigned      YES unset  initializing          down
FastEthernet6              unassigned      YES unset  initializing          down
FastEthernet7              unassigned      YES unset  initializing          down
FastEthernet8              unassigned      YES unset  initializing          down
FastEthernet9              unassigned      YES unset  initializing          down
Dot11Radio0                unassigned      NO  unset  initializing          down
Dot11Radio1                unassigned      NO  unset  initializing          down
Vlan1                      unassigned      YES unset  up                    down
Async1                     unassigned      YES unset  down                  down
Enter interface name used to connect to the
management network from the above interface summary: FastEthernet0
Configuring interface FastEthernet0:
  Use the 100 Base-TX (RJ-45) connector? [yes]: y
  Operate in full-duplex mode? [no]: n
  Configure IP on this interface? [yes]: y
    IP address for this interface: 192.168.0.1
    Subnet mask for this interface [255.255.255.0] :
    Class C network is 192.168.0.0, 24 subnet bits; mask is /24
The following configuration command script was created:
hostname Cisco1811W_1
enable secret 5 $1$Y09a$AcuXoBZNwrMZSJvwlcl9M.
enable password scott
line vty 0 4
password rrt93m
snmp-server community LSDTHK87
no ip routing
no shutdown
media-type 100BaseX
half-duplex
ip address 192.168.0.1 255.255.255.0
interface FastEthernet1
shutdown
no ip address
interface FastEthernet2
shutdown
no ip address
interface FastEthernet3
shutdown
no ip address
interface FastEthernet4
shutdown
no ip address
interface FastEthernet5
shutdown
no ip address
interface FastEthernet6
shutdown
no ip address
interface FastEthernet7
shutdown
no ip address
interface FastEthernet8
shutdown
no ip address
interface FastEthernet9
shutdown
no ip address
interface Dot11Radio0
shutdown
no ip address
interface Dot11Radio1
shutdown
no ip address
interface Vlan1
shutdown
no ip address
end
[0] Go to the IOS command prompt without saving this config.
[1] Return back to the setup without saving this config.
[2] Save this configuration to nvram and exit.
Enter your selection [2]: 2
media-type 100BaseX
% Invalid input detected at '^' marker.
Building configuration...
Use the enabled mode 'configure' command to modify this configuration.
Press RETURN to get started!
*Apr 22 07:13:04.635: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State change
d to: Initialized
*Apr 22 07:13:04.647: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State change
d to: Enabled
*Apr 22 07:13:13.375: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
up
*Apr 22 07:13:13.375: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to
up
*Apr 22 07:13:14.375: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to down
et1, changed state to down
*Apr 22 07:13:15.399: USB init complete.
*Apr 22 07:16:34.595: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to a
dministratively down
*Apr 22 07:16:34.595: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to a
*Apr 22 07:16:35.055: %LINK-5-CHANGED: Interface FastEthernet1, changed state to
administratively down
*Apr 22 07:16:35.595: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Apr 22 07:16:36.055: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to up
*Apr 22 07:16:36.403: %LINK-5-CHANGED: Interface FastEthernet2, changed state to
*Apr 22 07:16:36.403: %LINK-5-CHANGED: Interface FastEthernet3, changed state to
*Apr 22 07:16:36.403: %LINK-5-CHANGED: Interface FastEthernet4, changed state to
*Apr 22 07:16:36.403: %LINK-5-CHANGED: Interface FastEthernet5, changed state to
*Apr 22 07:16:36.407: %LINK-5-CHANGED: Interface FastEthernet6, changed state to
*Apr 22 07:16:36.407: %LINK-5-CHANGED: Interface FastEthernet7, changed state to
*Apr 22 07:16:36.407: %LINK-5-CHANGED: Interface FastEthernet8, changed state to
*Apr 22 07:16:36.407: %LINK-5-CHANGED: Interface FastEthernet9, changed state to
*Apr 22 07:16:36.427: %LINK-5-CHANGED: Interface Vlan1, changed state to adminis
tratively down
*Apr 22 07:16:37.403: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et2, changed state to down
et3, changed state to down
et4, changed state to down
et5, changed state to down
*Apr 22 07:16:37.407: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et6, changed state to down
et7, changed state to down
et8, changed state to down
et9, changed state to down
*Apr 22 07:16:37.427: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, cha
nged state to down
*Apr 22 07:16:44.739: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 12.4(6)T2,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 16-May-06 12:21 by kellythw
*Apr 22 07:16:44.739: %SNMP-5-COLDSTART: SNMP agent on host Cisco1811W_1 is unde
rgoing a cold start
*Apr 22 07:16:44.791: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
*Apr 22 07:16:44.803: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Apr 22 07:16:46.635: %LINK-5-CHANGED: Interface Virtual-Dot11Radio0, changed st
ate to administratively down
*Apr 22 07:16:46.635: %LINK-5-CHANGED: Interface Virtual-Dot11Radio1, changed st
*Apr 22 07:16:47.635: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Do
t11Radio0, changed state to down
t11Radio1, changed state to down
*Apr 22 07:17:24.667: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
6 Replies 6
cadet alain
Could you explain more precisely what you are trying to achieve?
Alain
Ultimately need to configure for a home business - 1 router, wifi, static IP, firewall - nothing special.
The issue at the moment is that I have not been able to establish a connection with Configuration Pro.
Cisco 1811W
liam onions
if you send me your details for wam, wifi and etc i will do a config so you can copy and paste!!!!
I appreciate that very much.  If I can't get CPE connected and figured out I'll take you up on it.  I really would like to figure out how to get the GUI working tho, as it seems that it would be the most helpful 2 years down the road when I have forgotten everything else.  Then again, now that I think about it, maybe a command line setup doc would be pretty self explanitory and easier in the long run...  What do you think?
I have to run & don't have time to pull together all the details right now & probably can't until late tonight.  Could you send me a sample config file in the meantime?
Either way, I still want to figure out how to get CPE connected so that I can at least try it...
Thx
Scott
Sorry, when I said "CPE", I meant to refer to Cisco Config Pro "CCP".  This router does NOT have Config Pro Express installed.
Liam
Every turn there's something new to stumble over...  I'm convinced - command line is the way to go (at least I'm convinced that CP is NOT the way to go...).  I'd love to take you up on your offer.  Will send info via email.
SK
