Cisco Swicthes Configuration
Muhammad Haseeb
I want to know that do CISCO Swithes have Startup config, Running config and Backup and Restoring IOS FEatures like CISCO ROUTERS ?
Leo Laohoo
Cisco switches have startup config, running-config.
I don't know what you mean by the rest.
If your switch has adequate flash space for multiple IOS then it is possible.
I think he probably means tftp for downloading and uploading firmware and config files.
Well, if so, yes, the switches support tftp.
