ā11-19-2016 02:50 AM - edited ā03-08-2019 08:13 AM
Dears
There are a number of one Cisco switch 3850 POE+ and 10 Cisco IP phones
It was installed 10 phones in cisco switch, but who works with POE only four have been making sure that all interface are working POE but the problem is when shutdown IP Phone of the four is one of the six IP phones get up and in attached files show techs support from cisco switch
Please provide us with solutions
TBRSCODSW05#sh run
Building configuration...
Current configuration : 9560 bytes
! Last configuration change at 23:01:02 UTC Wed Nov 16 2016
version 15.0
no service pad
service compress-config
hostname TBRSCODSW05
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging console emergencies
username rslf privilege 15 secret 4 0/g8BZq.oxV4BP92O.SOVuPNJuenvNqhSHVlzXprvaM
no aaa new-model
switch 1 provision ws-c3850-48p
qos wireless-default-untrust
crypto pki trustpoint TP-self-signed-4273662774
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4273662774
revocation-check none
rsakeypair TP-self-signed-4273662774
crypto pki certificate chain TP-self-signed-4273662774
certificate self-signed 01
3082023E 308201A7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 34323733 36363237 3734301E 170D3136 31313136 32323536
32395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 32373336
36323737 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C675 F6E04EB5 B0C63CEE 2ACDDB55 98E52F0A 08E53ADD 10CB324E 7F1DC362
AACAD960 3F6A88CF 4B267E36 16B6BFB9 20CF2B6D 4A9558B0 EF4A8149 698B4AB1
D0EEF555 70B7679D E1ACE5F0 B51EF3E9 B39BE0DE 3F1EACCD 02F40A85 47FFDEE4
79CEF56C 7C5CACC7 0D9DFC4E B4E3AD06 DA0FC825 04179C2D 87084CFF 7897EB15
B7D90203 010001A3 66306430 0F060355 1D130101 FF040530 030101FF 30110603
551D1104 0A300882 06537769 74636830 1F060355 1D230418 30168014 B98A66E3
01034AC1 D6574A40 BCA67C09 B2F5A2A8 301D0603 551D0E04 160414B9 8A66E301
034AC1D6 574A40BC A67C09B2 F5A2A830 0D06092A 864886F7 0D010104 05000381
81000647 D53FBE8A A337FB63 781C07ED DF49F100 F6EE72C4 F218C28B 135771A1
9AB58A5F B7C09BAD 348B6BC6 8DB8DAEF 95D36F69 60CC059B 3866E70E 0B716CF6
00CD1732 65896A45 E7D3CFF8 4FE34233 52D9CAB0 C583E2FC 8B546159 9864E591
934545D9 89F37CD6 4A4690C6 4D78EFE8 DD209ECD 49BFDE0E A49AA092 090858BB CE5D
quit
diagnostic bootup level minimal
identity policy webauth-global-inactive
inactivity-timer 3600
spanning-tree mode pvst
redundancy
mode sso
class-map match-any non-client-nrt-class
match non-client-nrt
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface GigabitEthernet1/0/1
switchport access vlan 30
switchport voice vlan 31
spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
switchport mode trunk
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
no ip address
shutdown
interface Vlan100
ip address 10.24.100.34 255.255.255.0
ip default-gateway 10.24.100.254
no ip http server
ip http secure-server
snmp-server community public RO
snmp-server community Private RW
line con 0
exec-timeout 0 0
logging synchronous
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
line vty 5 15
login
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap dot11 24ghz rrm channel dca 1
ap dot11 24ghz rrm channel dca 6
ap dot11 24ghz rrm channel dca 11
ap dot11 5ghz rrm channel dca 36
ap dot11 5ghz rrm channel dca 40
ap dot11 5ghz rrm channel dca 44
ap dot11 5ghz rrm channel dca 48
ap dot11 5ghz rrm channel dca 52
ap dot11 5ghz rrm channel dca 56
ap dot11 5ghz rrm channel dca 60
ap dot11 5ghz rrm channel dca 64
ap dot11 5ghz rrm channel dca 149
ap dot11 5ghz rrm channel dca 153
ap dot11 5ghz rrm channel dca 157
ap dot11 5ghz rrm channel dca 161
ap group default-group
end
TBRSCODSW05#$
TBRSCODSW05#
TBRSCODSW05#
TBRSCODSW05#
TBRSCODSW05#sh tech su
TBRSCODSW05#sh tech sup
TBRSCODSW05#sh
TBRSCODSW05#sh te
TBRSCODSW05#sh tec
TBRSCODSW05#sh tech-support
------------------ show clock ------------------
*23:04:51.075 UTC Wed Nov 16 2016
------------------ show version ------------------
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.02.03.SE RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 23-Sep-13 18:24 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
TBRSCODSW05 uptime is 8 minutes
Uptime for this control processor is 11 minutes
System returned to ROM by reload
System image file is "flash:packages.conf"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Lanbase
License Type: Permanent
Next reload license Level: Lanbase
cisco WS-C3850-48P (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FCW1912C0MB
2 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of at webui:.
Base Ethernet MAC Address : 88:90:8d:1b:59:00
Motherboard Assembly Number : 73-14442-10
Motherboard Serial Number : FOC191269LA
Model Revision Number : S0
Motherboard Revision Number : A0
Model Number : WS-C3850-48P
System Serial Number : FCW1912C0MB
Switch Ports Model SW Version SW Image Mode
1 56 WS-C3850-48P 03.02.03.SE cat3k_caa-universalk9 INSTALL
Configuration register is 0x102
------------------ show running-config ------------------
Current configuration : 9531 bytes
version 15.0
no service pad
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
username rslf privilege 15 secret 4 <removed>
no aaa new-model
quit
redundancy
mode sso
no ip address
negotiation auto
interface Vlan1
no ip address
shutdown
interface Vlan100
no ip http server
snmp-server community <removed> RO
snmp-server community <removed> RW
line con 0
exec-timeout 0 0
logging synchronous
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
line vty 5 15
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
transport http
transport https
end
------------------ show stacks ------------------
Minimum process stacks:
Free/Size Name
17312/18000 IPC Zone Manager
30072/36000 IOSd shutdown SPI init process
12104/18000 QEMU CI platform comm process
11944/18000 QEMU CI oir process
29352/36000 CHKPT IOSd SPI process
11336/18000 reregister_flags
16176/18000 OIRLIB-SENDCB-THREAD
17424/18000 ISSU Infra API Delayed Registration Process
12120/18000 IOSd dbflags client process
17424/18000 CDP BLOB
14384/18000 MGMT VRF Process
12200/18000 diag n3k spi Init
15936/18000 EEM Shell Director
17424/18000 AAA HA Acct Proc
12248/18000 SPI PLOGD SERVER process
12104/18000 MgmtE HA role reg
30184/36000 OSINFO SPI process
12264/18000 External HTTP App Handler process
12200/18000 FTS conf server process
30072/36000 ISSU IOSd client init process
12200/18000 QoS TAM SPI Helper
35424/36000 ISSU IOSd ce image MIB update process
10984/18000 pr session thread
17312/18000 event session thread
12152/18000 RSMP Init
12216/18000 TACTIC Nova Server Init
17136/18000 diag n3k oir event
14344/18000 MgmtE relay server response
15200/18000 cl session thread
33000/36000 IOSd LIIN config
17264/18000 SPAN Subsystem
70656/72000 EEM Auto Registration Proc
17152/18000 SASL MAIN
14144/15000 LIM WAVL
20416/21000 cdp init process
18736/24000 HTTP SSL PKI CERTIFICATE CREATE PROC
18296/33000 Init
17072/18000 RADIUS INITCONFIG
11560/15000 Rom Random Update Process
Interrupt level stacks:
Level Called Unused/Size Name
2 0 253072/262144 Network Interrupt
3 0 248712/262144 Aux Thread
------------------ show interfaces ------------------
Vlan1 is administratively down, line protocol is down
Hardware is Ethernet SVI, address is 8890.8d1b.5947 (bia 8890.8d1b.5947)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
267 packets input, 22284 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 packets output, 0 bytes, 0 underruns
0 output errors, 1 interface resets
0 unknown protocol drops
Vlan100 is up, line protocol is up
Hardware is Ethernet SVI, address is 8890.8d1b.5951 (bia 8890.8d1b.5951)
Internet address is 10.24.100.34/24
Last input 00:00:06, output never, output hang never
305 packets input, 29029 bytes, 0 no buffer
73 packets output, 7705 bytes, 0 underruns
GigabitEthernet0/0 is down, line protocol is down
Hardware is RP management port, address is 8890.8d1b.5900 (bia 8890.8d1b.5900)
Keepalive set (10 sec)
Unknown, Unknown, link type is auto, media type is 100BaseTX
output flow-control is unsupported, input flow-control is unsupported
Output queue: 0/0 (size/max)
0 packets input, 0 bytes, 0 no buffer
0 watchdog, 0 multicast, 0 pause input
0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet1/0/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5901 (bia 8890.8d1b.5901)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Received 0 broadcasts (0 multicasts)
0 output errors, 0 collisions, 1 interface resets
GigabitEthernet1/0/2 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5902 (bia 8890.8d1b.5902)
GigabitEthernet1/0/3 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5903 (bia 8890.8d1b.5903)
GigabitEthernet1/0/4 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5904 (bia 8890.8d1b.5904)
GigabitEthernet1/0/5 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5905 (bia 8890.8d1b.5905)
GigabitEthernet1/0/6 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5906 (bia 8890.8d1b.5906)
GigabitEthernet1/0/7 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5907 (bia 8890.8d1b.5907)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
Last input 00:00:25, output never, output hang never
5 minute output rate 2000 bits/sec, 3 packets/sec
45 packets input, 9788 bytes, 0 no buffer
Received 15 broadcasts (12 multicasts)
0 watchdog, 12 multicast, 0 pause input
557 packets output, 52521 bytes, 0 underruns
1 unknown protocol drops
GigabitEthernet1/0/8 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5908 (bia 8890.8d1b.5908)
GigabitEthernet1/0/9 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5909 (bia 8890.8d1b.5909)
GigabitEthernet1/0/10 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.590a (bia 8890.8d1b.590a)
GigabitEthernet1/0/11 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.590b (bia 8890.8d1b.590b)
GigabitEthernet1/0/12 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.590c (bia 8890.8d1b.590c)
GigabitEthernet1/0/13 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.590d (bia 8890.8d1b.590d)
GigabitEthernet1/0/14 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.590e (bia 8890.8d1b.590e)
GigabitEthernet1/0/15 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.590f (bia 8890.8d1b.590f)
GigabitEthernet1/0/16 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5910 (bia 8890.8d1b.5910)
GigabitEthernet1/0/17 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5911 (bia 8890.8d1b.5911)
GigabitEthernet1/0/18 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5912 (bia 8890.8d1b.5912)
GigabitEthernet1/0/19 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5913 (bia 8890.8d1b.5913)
GigabitEthernet1/0/20 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5914 (bia 8890.8d1b.5914)
GigabitEthernet1/0/21 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5915 (bia 8890.8d1b.5915)
GigabitEthernet1/0/22 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5916 (bia 8890.8d1b.5916)
GigabitEthernet1/0/23 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5917 (bia 8890.8d1b.5917)
GigabitEthernet1/0/24 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5918 (bia 8890.8d1b.5918)
GigabitEthernet1/0/25 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5919 (bia 8890.8d1b.5919)
GigabitEthernet1/0/26 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.591a (bia 8890.8d1b.591a)
GigabitEthernet1/0/27 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.591b (bia 8890.8d1b.591b)
GigabitEthernet1/0/28 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.591c (bia 8890.8d1b.591c)
GigabitEthernet1/0/29 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.591d (bia 8890.8d1b.591d)
GigabitEthernet1/0/30 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.591e (bia 8890.8d1b.591e)
GigabitEthernet1/0/31 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.591f (bia 8890.8d1b.591f)
GigabitEthernet1/0/32 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5920 (bia 8890.8d1b.5920)
GigabitEthernet1/0/33 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5921 (bia 8890.8d1b.5921)
GigabitEthernet1/0/34 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5922 (bia 8890.8d1b.5922)
GigabitEthernet1/0/35 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5923 (bia 8890.8d1b.5923)
GigabitEthernet1/0/36 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5924 (bia 8890.8d1b.5924)
GigabitEthernet1/0/37 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5925 (bia 8890.8d1b.5925)
GigabitEthernet1/0/38 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5926 (bia 8890.8d1b.5926)
GigabitEthernet1/0/39 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5927 (bia 8890.8d1b.5927)
GigabitEthernet1/0/40 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5928 (bia 8890.8d1b.5928)
GigabitEthernet1/0/41 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5929 (bia 8890.8d1b.5929)
GigabitEthernet1/0/42 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.592a (bia 8890.8d1b.592a)
GigabitEthernet1/0/43 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.592b (bia 8890.8d1b.592b)
GigabitEthernet1/0/44 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.592c (bia 8890.8d1b.592c)
GigabitEthernet1/0/45 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.592d (bia 8890.8d1b.592d)
GigabitEthernet1/0/46 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.592e (bia 8890.8d1b.592e)
GigabitEthernet1/0/47 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.592f (bia 8890.8d1b.592f)
GigabitEthernet1/0/48 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5930 (bia 8890.8d1b.5930)
GigabitEthernet1/1/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5931 (bia 8890.8d1b.5931)
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
Last input 00:00:01, output never, output hang never
5 minute input rate 14000 bits/sec, 20 packets/sec
6975 packets input, 600823 bytes, 0 no buffer
Received 6788 broadcasts (5700 multicasts)
0 watchdog, 5700 multicast, 0 pause input
183 packets output, 32365 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
90 unknown protocol drops
GigabitEthernet1/1/2 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5932 (bia 8890.8d1b.5932)
Auto-duplex, Auto-speed, link type is auto, media type is unknown
GigabitEthernet1/1/3 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5933 (bia 8890.8d1b.5933)
GigabitEthernet1/1/4 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 8890.8d1b.5934 (bia 8890.8d1b.5934)
TenGigabitEthernet1/1/1 is down, line protocol is down (notconnect)
Hardware is not present
Hardware is Ten Gigabit Ethernet, address is 8890.8d1b.5935 (bia 8890.8d1b.5935)
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
TenGigabitEthernet1/1/2 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is 8890.8d1b.5936 (bia 8890.8d1b.5936)
TenGigabitEthernet1/1/3 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is 8890.8d1b.5937 (bia 8890.8d1b.5937)
TenGigabitEthernet1/1/4 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is 8890.8d1b.5938 (bia 8890.8d1b.5938)
------------------ show interfaces history ------------------
------------------ show controllers ------------------
Transmit GigabitEthernet1/0/1 Receive
0 Total bytes 0 Total bytes
0 Unicast frames 0 Unicast frames
0 Unicast bytes 0 Unicast bytes
0 Multicast frames 0 Multicast frames
0 Multicast bytes 0 Multicast bytes
0 Broadcast frames 0 Broadcast frames
0 Broadcast bytes 0 Broadcast bytes
0 System FCS error frames 0 IpgViolation frames
0 MacUnderrun frames 0 MacOverrun frames
0 Pause frames 0 Pause frames
0 Cos 0 Pause frames 0 Cos 0 Pause frames
0 Cos 1 Pause frames 0 Cos 1 Pause frames
0 Cos 2 Pause frames 0 Cos 2 Pause frames
0 Cos 3 Pause frames 0 Cos 3 Pause frames
0 Cos 4 Pause frames 0 Cos 4 Pause frames
0 Cos 5 Pause frames 0 Cos 5 Pause frames
0 Cos 6 Pause frames 0 Cos 6 Pause frames
0 Cos 7 Pause frames 0 Cos 7 Pause frames
0 Oam frames 0 OamProcessed frames
0 Oam frames 0 OamDropped frames
0 Minimum size frames 0 Minimum size frames
0 65 to 127 byte frames 0 65 to 127 byte frames
0 128 to 255 byte frames 0 128 to 255 byte frames
0 256 to 511 byte frames 0 256 to 511 byte frames
0 512 to 1023 byte frames 0 512 to 1023 byte frames
0 1024 to 1518 byte frames 0 1024 to 1518 byte frames
0 1519 to 2047 byte frames 0 1519 to 2047 byte frames
0 2048 to 4095 byte frames 0 2048 to 4095 byte frames
0 4096 to 8191 byte frames 0 4096 to 8191 byte frames
0 8192 to 16383 byte frames 0 8192 to 16383 byte frames
0 16384 to 32767 byte frame 0 16384 to 32767 byte frame
0 > 32768 byte frames 0 > 32768 byte frames
0 Late collision frames 0 SymbolErr frames
0 Excess Defer frames 0 Collision fragments
0 Good (1 coll) frames 0 ValidUnderSize frames
0 Good (>1 coll) frames 0 InvalidOverSize frames
0 Deferred frames 0 ValidOverSize frames
0 Gold frames dropped 0 FcsErr frames
0 Gold frames truncated
0 Gold frames successful
0 1 collision frames
0 2 collision frames
0 3 collision frames
0 4 collision frames
0 5 collision frames
0 6 collision frames
0 7 collision frames
0 8 collision frames
0 9 collision frames
0 10 collision frames
0 11 collision frames
0 12 collision frames
0 13 collision frames
0 14 collision frames
0 15 collision frames
0 Excess collision frames
LAST UPDATE 810380 msecs AGO
Transmit GigabitEthernet1/0/2 Receive
Transmit GigabitEthernet1/0/3 Receive
LAST UPDATE 822570 msecs AGO
Transmit GigabitEthernet1/0/4 Receive
LAST UPDATE 826830 msecs AGO
Transmit GigabitEthernet1/0/5 Receive
LAST UPDATE 831100 msecs AGO
Transmit GigabitEthernet1/0/6 Receive
LAST UPDATE 834830 msecs AGO
Transmit GigabitEthernet1/0/7 Receive
78369 Total bytes 20125 Total bytes
74 Unicast frames 50 Unicast frames
11521 Unicast bytes 17211 Unicast bytes
441 Multicast frames 14 Multicast frames
44098 Multicast bytes 1788 Multicast bytes
333 Broadcast frames 3 Broadcast frames
22750 Broadcast bytes 1126 Broadcast bytes
340 Minimum size frames 0 Minimum size frames
435 65 to 127 byte frames 45 65 to 127 byte frames
42 128 to 255 byte frames 8 128 to 255 byte frames
27 256 to 511 byte frames 1 256 to 511 byte frames
2 512 to 1023 byte frames 3 512 to 1023 byte frames
2 1024 to 1518 byte frames 8 1024 to 1518 byte frames
0 1519 to 2047 byte frames 2 1519 to 2047 byte frames
LAST UPDATE 4620 msecs AGO
Transmit GigabitEthernet1/0/8 Receive
LAST UPDATE 843360 msecs AGO
Transmit GigabitEthernet1/0/9 Receive
LAST UPDATE 847110 msecs AGO
Transmit GigabitEthernet1/0/10 Receive
LAST UPDATE 851310 msecs AGO
Transmit GigabitEthernet1/0/11 Receive
LAST UPDATE 855560 msecs AGO
Transmit GigabitEthernet1/0/12 Receive
LAST UPDATE 859300 msecs AGO
Transmit GigabitEthernet1/0/13 Receive
LAST UPDATE 863570 msecs AGO
Transmit GigabitEthernet1/0/14 Receive
LAST UPDATE 867830 msecs AGO
Transmit GigabitEthernet1/0/15 Receive
LAST UPDATE 871560 msecs AGO
Transmit GigabitEthernet1/0/16 Receive
LAST UPDATE 875830 msecs AGO
Transmit GigabitEthernet1/0/17 Receive
LAST UPDATE 880100 msecs AGO
Transmit GigabitEthernet1/0/18 Receive
LAST UPDATE 883830 msecs AGO
Transmit GigabitEthernet1/0/19 Receive
LAST UPDATE 888030 msecs AGO
Transmit GigabitEthernet1/0/20 Receive
LAST UPDATE 892300 msecs AGO
Transmit GigabitEthernet1/0/21 Receive
LAST UPDATE 896570 msecs AGO
Transmit GigabitEthernet1/0/22 Receive
LAST UPDATE 900300 msecs AGO
Transmit GigabitEthernet1/0/23 Receive
LAST UPDATE 904560 msecs AGO
Transmit GigabitEthernet1/0/24 Receive
LAST UPDATE 908830 msecs AGO
Transmit GigabitEthernet1/0/25 Receive
LAST UPDATE 912560 msecs AGO
Transmit GigabitEthernet1/0/26 Receive
LAST UPDATE 916830 msecs AGO
Transmit GigabitEthernet1/0/27 Receive
LAST UPDATE 921040 msecs AGO
Transmit GigabitEthernet1/0/28 Receive
LAST UPDATE 924760 msecs AGO
Transmit GigabitEthernet1/0/29 Receive
LAST UPDATE 929030 msecs AGO
Transmit GigabitEthernet1/0/30 Receive
LAST UPDATE 933290 msecs AGO
Transmit GigabitEthernet1/0/31 Receive
LAST UPDATE 937030 msecs AGO
Transmit GigabitEthernet1/0/32 Receive
LAST UPDATE 941300 msecs AGO
Transmit GigabitEthernet1/0/33 Receive
LAST UPDATE 945570 msecs AGO
Transmit GigabitEthernet1/0/34 Receive
LAST UPDATE 949300 msecs AGO
Transmit GigabitEthernet1/0/35 Receive
LAST UPDATE 953490 msecs AGO
Transmit GigabitEthernet1/0/36 Receive
LAST UPDATE 957760 msecs AGO
Transmit GigabitEthernet1/0/37 Receive
LAST UPDATE 961500 msecs AGO
Transmit GigabitEthernet1/0/38 Receive
LAST UPDATE 965770 msecs AGO
Transmit GigabitEthernet1/0/39 Receive
LAST UPDATE 970020 msecs AGO
Transmit GigabitEthernet1/0/40 Receive
LAST UPDATE 974290 msecs AGO
Transmit GigabitEthernet1/0/41 Receive
LAST UPDATE 978020 msecs AGO
Transmit GigabitEthernet1/0/42 Receive
LAST UPDATE 982300 msecs AGO
Transmit GigabitEthernet1/0/43 Receive
LAST UPDATE 986560 msecs AGO
Transmit GigabitEthernet1/0/44 Receive
LAST UPDATE 990220 msecs AGO
Transmit GigabitEthernet1/0/45 Receive
LAST UPDATE 994490 msecs AGO
Transmit GigabitEthernet1/0/46 Receive
LAST UPDATE 998760 msecs AGO
Transmit GigabitEthernet1/0/47 Receive
LAST UPDATE 1002490 msecs AGO
Transmit GigabitEthernet1/0/48 Receive
LAST UPDATE 1006760 msecs AGO
Transmit GigabitEthernet1/1/1 Receive
39754 Total bytes 1026909 Total bytes
186 Unicast frames 245 Unicast frames
31827 Unicast bytes 31996 Unicast bytes
35 Multicast frames 9621 Multicast frames
5909 Multicast bytes 821173 Multicast bytes
16 Broadcast frames 2022 Broadcast frames
2018 Broadcast bytes 173740 Broadcast bytes
73 Minimum size frames 285 Minimum size frames
137 65 to 127 byte frames 10914 65 to 127 byte frames
0 128 to 255 byte frames 549 128 to 255 byte frames
12 256 to 511 byte frames 72 256 to 511 byte frames
5 512 to 1023 byte frames 66 512 to 1023 byte frames
8 1024 to 1518 byte frames 2 1024 to 1518 byte frames
2 1519 to 2047 byte frames 0 1519 to 2047 byte frames
LAST UPDATE 290 msecs AGO
Transmit GigabitEthernet1/1/2 Receive
LAST UPDATE 1014750 msecs AGO
Transmit GigabitEthernet1/1/3 Receive
LAST UPDATE 1019020 msecs AGO
Transmit GigabitEthernet1/1/4 Receive
LAST UPDATE 1023230 msecs AGO
------------------ show user ------------------
Line User Host(s) Idle Location
* 0 con 0 idle 00:05:13
Interface User Mode Idle Peer Address
------------------ show logging ------------------
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level emergencies, 0 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 34 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Persistent logging: disabled
Trap logging: level informational, 36 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (16384 bytes):
*Nov 16 22:56:08.752: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Nov 16 22:56:09.637: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
*Nov 16 22:56:09.637: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Nov 16 22:56:09.658: %NGWC_PLATFORM_FEP-6-FRU_PS_OIR: Switch 1: FRU power supply A inserted
*Nov 16 22:56:10.635: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Nov 16 22:56:10.635: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Nov 16 22:56:13.152: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Nov 16 22:56:26.964: %SYS-5-CONFIG_I: Configured from memory by console
*Nov 16 22:56:27.118: %STACKMGR-1-ACTIVE_READY: 1 stack-mgr: Active switch 1 is ready. System has been configured
*Nov 16 22:56:27.416: %SYS-5-RESTART: System restarted --
*Nov 16 22:56:27.476: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Nov 16 22:56:27.798: %AUTHMGR_SPI-6-START: Auth Manager SPI server started
*Nov 16 22:56:28.972: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
*Nov 16 22:56:29.159: %PKI-6-AUTOSAVE: Running configuration saved to NVRAM
*Nov 16 22:56:30.863: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/1, changed state to down
*Nov 16 22:56:30.872: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/2, changed state to down
*Nov 16 22:56:30.872: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/3, changed state to down
*Nov 16 22:56:30.872: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/4, changed state to down
*Nov 16 22:56:30.872: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/1, changed state to down
*Nov 16 22:56:30.873: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/2, changed state to down
*Nov 16 22:56:30.873: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/3, changed state to down
*Nov 16 22:56:30.873: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/4, changed state to down
*Nov 16 22:56:30.956: %PLATFORM_PM-6-FRULINK_INSERTED: 4x1G uplink module inserted in the switch 1 slot 1
*Nov 16 22:56:31.168: %PLATFORM_PM-6-MODULE_INSERTED: SFP module inserted with interface name Gi1/1/1
*Nov 16 23:00:22.810: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan100, changed state to down
*Nov 16 23:00:52.739: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/1, changed state to up
*Nov 16 23:00:54.751: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/1, changed state to up
*Nov 16 23:01:02.260: %SYS-5-CONFIG_I: Configured from console by console
*Nov 16 23:01:26.751: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan100, changed state to up
*Nov 16 23:02:21.830: %ILPOWER-7-DETECT: Interface Gi1/0/7: Power Device detected: IEEE PD
*Nov 16 23:02:22.328: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/7: Power granted
*Nov 16 23:02:41.001: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/7, changed state to up
*Nov 16 23:02:41.998: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/7, changed state to up
------------------ show env all ------------------
Switch 1 FAN 1 is OK
Switch 1 FAN 2 is OK
Switch 1 FAN 3 is OK
FAN PS-1 is OK
FAN PS-2 is NOT PRESENT
Switch 1: SYSTEM TEMPERATURE is OK
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A PWR-C1-350WAC DCB1922H1EX OK Good Good 350
1B Not Present
------------------ show interfaces status ------------------
Port Name Status Vlan Duplex Speed Type
Gi1/0/1 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/2 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/3 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/4 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/5 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/6 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/7 connected 30 a-full a-1000 10/100/1000BaseTX
Gi1/0/8 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/9 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/10 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/11 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/12 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/13 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/14 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/15 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/16 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/17 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/18 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/19 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/20 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/21 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/22 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/23 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/24 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/25 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/26 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/27 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/28 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/29 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/30 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/31 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/32 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/33 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/34 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/35 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/36 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/37 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/38 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/39 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/40 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/41 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/42 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/43 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/44 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/45 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/46 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/47 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/0/48 notconnect 30 auto auto 10/100/1000BaseTX
Gi1/1/1 connected trunk full 1000 1000BaseLX SFP
Gi1/1/2 notconnect 1 auto auto unknown
Gi1/1/3 notconnect 1 auto auto unknown
Gi1/1/4 notconnect 1 auto auto unknown
------------------ show interfaces status err-disabled ------------------
------------------ show interfaces switchport ------------------
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 30 (VLAN0030)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: 31 (voice31)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Operational Mode: static access
Operational Trunking Encapsulation: native
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Operational Trunking Encapsulation: dot1q
Access Mode VLAN: 1 (default)
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
------------------ show interfaces trunk ------------------
Port Mode Encapsulation Status Native vlan
Gi1/1/1 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi1/1/1 1-4094
Port Vlans allowed and active in management domain
Gi1/1/1 1,30-31,100
Port Vlans in spanning tree forwarding state and not pruned
Gi1/1/1 1,30-31,100
------------------ show vlan ------------------
VLAN Name Status Ports
1 default active Gi1/1/2, Gi1/1/3, Gi1/1/4
30 VLAN0030 active Gi1/0/1, Gi1/0/2, Gi1/0/3
Gi1/0/4, Gi1/0/5, Gi1/0/6
Gi1/0/7, Gi1/0/8, Gi1/0/9
Gi1/0/10, Gi1/0/11, Gi1/0/12
Gi1/0/13, Gi1/0/14, Gi1/0/15
Gi1/0/16, Gi1/0/17, Gi1/0/18
Gi1/0/19, Gi1/0/20, Gi1/0/21
Gi1/0/22, Gi1/0/23, Gi1/0/24
Gi1/0/25, Gi1/0/26, Gi1/0/27
Gi1/0/28, Gi1/0/29, Gi1/0/30
Gi1/0/31, Gi1/0/32, Gi1/0/33
Gi1/0/34, Gi1/0/35, Gi1/0/36
Gi1/0/37, Gi1/0/38, Gi1/0/39
Gi1/0/40, Gi1/0/41, Gi1/0/42
Gi1/0/43, Gi1/0/44, Gi1/0/45
Gi1/0/46, Gi1/0/47, Gi1/0/48
31 voice31 active Gi1/0/1, Gi1/0/2, Gi1/0/3
100 Management active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
30 enet 100030 1500 - - - - - 0 0
31 enet 100031 1500 - - - - - 0 0
100 enet 100100 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
------------------ show spanning-tree ------------------
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 32769
Address 0008.e3ff.fc04
Cost 6
Port 49 (GigabitEthernet1/1/1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 8890.8d1b.5900
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Gi1/1/1 Root FWD 4 128.49 P2p
VLAN0030
Root ID Priority 32798
Address 40a6.e8de.8880
Cost 8
Bridge ID Priority 32798 (priority 32768 sys-id-ext 30)
Aging Time 300 sec
Gi1/0/7 Desg FWD 4 128.7 P2p Edge
VLAN0031
Root ID Priority 32799
Cost 8
Bridge ID Priority 32799 (priority 32768 sys-id-ext 31)
Aging Time 300 sec
VLAN0100
Root ID Priority 32868
Cost 6
Bridge ID Priority 32868 (priority 32768 sys-id-ext 100)
Aging Time 300 sec
------------------ show etherchannel summary ------------------
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 0
Number of aggregators: 0
Group Port-channel Protocol Ports
------------------ show cef linecard ------------------
Slot Flags
------------------ show data-corruption ------------------
No data inconsistency errors have been recorded.
------------------ show memory statistics ------------------
------------------ show process memory ------------------
System memory : 4004464K total, 1429608K used, 2574856K free, 150332K kernel reserved
Lowest(b) : 2166178780
PID Text Data Stack Heap RSS Total Process
1 320 372 88 268 1736 4596 init
2 0 0 0 0 0 0 kthreadd
3 0 0 0 0 0 0 migration/0
4 0 0 0 0 0 0 sirq-high/0
5 0 0 0 0 0 0 sirq-timer/0
6 0 0 0 0 0 0 sirq-net-tx/0
7 0 0 0 0 0 0 sirq-net-rx/0
8 0 0 0 0 0 0 sirq-block/0
9 0 0 0 0 0 0 sirq-block-iopo
10 0 0 0 0 0 0 sirq-tasklet/0
11 0 0 0 0 0 0 sirq-sched/0
12 0 0 0 0 0 0 sirq-hrtimer/0
13 0 0 0 0 0 0 sirq-rcu/0
14 0 0 0 0 0 0 desched/0
15 0 0 0 0 0 0 migration/1
16 0 0 0 0 0 0 sirq-high/1
17 0 0 0 0 0 0 sirq-timer/1
18 0 0 0 0 0 0 sirq-net-tx/1
19 0 0 0 0 0 0 sirq-net-rx/1
20 0 0 0 0 0 0 sirq-block/1
21 0 0 0 0 0 0 sirq-block-iopo
22 0 0 0 0 0 0 sirq-tasklet/1
23 0 0 0 0 0 0 sirq-sched/1
24 0 0 0 0 0 0 sirq-hrtimer/1
25 0 0 0 0 0 0 sirq-rcu/1
26 0 0 0 0 0 0 desched/1
27 0 0 0 0 0 0 migration/2
28 0 0 0 0 0 0 sirq-high/2
29 0 0 0 0 0 0 sirq-timer/2
30 0 0 0 0 0 0 sirq-net-tx/2
31 0 0 0 0 0 0 sirq-net-rx/2
32 0 0 0 0 0 0 sirq-block/2
33 0 0 0 0 0 0 sirq-block-iopo
34 0 0 0 0 0 0 sirq-tasklet/2
35 0 0 0 0 0 0 sirq-sched/2
36 0 0 0 0 0 0 sirq-hrtimer/2
37 0 0 0 0 0 0 sirq-rcu/2
38 0 0 0 0 0 0 desched/2
39 0 0 0 0 0 0 migration/3
40 0 0 0 0 0 0 sirq-high/3
41 0 0 0 0 0 0 sirq-timer/3
42 0 0 0 0 0 0 sirq-net-tx/3
43 0 0 0 0 0 0 sirq-net-rx/3
44 0 0 0 0 0 0 sirq-block/3
45 0 0 0 0 0 0 sirq-block-iopo
46 0 0 0 0 0 0 sirq-tasklet/3
47 0 0 0 0 0 0 sirq-sched/3
48 0 0 0 0 0 0 sirq-hrtimer/3
49 0 0 0 0 0 0 sirq-rcu/3
50 0 0 0 0 0 0 desched/3
51 0 0 0 0 0 0 events/0
52 0 0 0 0 0 0 events/1
53 0 0 0 0 0 0 events/2
54 0 0 0 0 0 0 events/3
55 0 0 0 0 0 0 khelper
58 0 0 0 0 0 0 netns
60 0 0 0 0 0 0 async/mgr
158 0 0 0 0 0 0 sync_supers
160 0 0 0 0 0 0 bdi-default
162 0 0 0 0 0 0 kblockd/0
163 0 0 0 0 0 0 kblockd/1
164 0 0 0 0 0 0 kblockd/2
165 0 0 0 0 0 0 kblockd/3
171 0 0 0 0 0 0 ata/0
172 0 0 0 0 0 0 ata/1
173 0 0 0 0 0 0 ata/2
174 0 0 0 0 0 0 ata/3
175 0 0 0 0 0 0 ata_aux
183 0 0 0 0 0 0 khubd
210 0 0 0 0 0 0 rpciod/0
211 0 0 0 0 0 0 rpciod/1
212 0 0 0 0 0 0 rpciod/2
213 0 0 0 0 0 0 rpciod/3
229 0 0 0 0 0 0 kswapd0
230 0 0 0 0 0 0 aio/0
231 0 0 0 0 0 0 aio/1
232 0 0 0 0 0 0 aio/2
233 0 0 0 0 0 0 aio/3
234 0 0 0 0 0 0 nfsiod
236 0 0 0 0 0 0 crypto/0
237 0 0 0 0 0 0 crypto/1
238 0 0 0 0 0 0 crypto/2
239 0 0 0 0 0 0 crypto/3
789 0 0 0 0 0 0 pata_octeon_cf
790 0 0 0 0 0 0 scsi_eh_0
796 0 0 0 0 0 0 mtdblockd
823 0 0 0 0 0 0 octeon-ethernet
857 0 0 0 0 0 0 kstriped
859 0 0 0 0 0 0 ksnapd
937 120 232 88 132 660 2320 udevd
1252 0 0 0 0 0 0 flush-8:0
1534 0 0 0 0 0 0 loop1
1559 0 0 0 0 0 0 loop2
1584 0 0 0 0 0 0 loop3
1609 0 0 0 0 0 0 loop4
1634 0 0 0 0 0 0 loop5
1679 0 0 0 0 0 0 loop6
2361 120 168 88 132 672 2256 udevd
2362 120 168 88 132 668 2256 udevd
3274 368 168 88 132 1236 2860 dbus-daemon
3652 24 836 88 740 1120 2576 klogd
3664 16 160 88 132 456 1892 portmap
3733 216 360 88 132 988 5420 sshd
3745 144 320 88 132 796 3316 xinetd
3749 144 320 88 132 796 3316 xinetd
3783 24 836 88 740 1120 2576 lockd
3784 16 160 88 132 456 1892 nfsd
3785 216 360 88 132 988 5420 nfsd
3786 144 320 88 132 796 3316 nfsd
3787 144 320 88 132 796 3316 nfsd
3788 0 0 0 0 0 0 nfsd
3789 0 0 0 0 0 0 nfsd
3790 0 0 0 0 0 0 nfsd
3791 0 0 0 0 0 0 nfsd
3797 76 188 88 132 332 2716 rpc.mountd
5347 1420 103752 88 2356 10548 171308 system_mgr
5576 104 40168 88 504 5512 58248 slproc
5652 15040 305396 92 3052 155448 626872 fed
5653 1120 172536 92 2524 17644 263712 platform_mgr
5654 836 159208 88 4116 72568 365176 stack-mgr
6146 4 94192 116 88480 95520 113164 idope.py
6296 20 63856 88 880 6016 119884 ns_oir_proxy
6297 84 101468 88 580 7452 163796 profiled
6298 752 548 88 500 1812 3576 oom_poll.sh
6299 1132 137512 88 3312 13928 216148 obfld
6300 40 101920 88 1032 7656 164184 consoled
6301 16 60272 88 920 7204 117848 console_relay
6302 44 101060 88 1180 7860 164736 csprovider
6303 48 118388 88 1068 8144 183344 system_mgr_cli
6304 44 115260 88 1712 10176 185524 plogd
6305 88 101064 88 1192 7984 227120 psdprov
6306 52 113756 88 580 24536 206764 pdsd
6307 164 98656 88 732 9380 173428 gold_slave
6308 1016 105800 88 580 8308 169888 osinfo-provider
6309 180 101060 88 1196 7800 163572 oscore_p
6310 28 88608 88 1048 7116 147976 netd
6311 60 98780 88 1488 9956 172884 mem_mgmt
6312 48 68104 88 896 23064 156168 mgmte_tap
6313 312 180980 88 2076 12256 258944 installer
6314 3532 135980 88 5996 39400 343048 ffm
6315 1232 248216 88 6524 31004 353752 eicored
6316 252 111376 88 5852 13688 200420 dtmgr
6317 208 106244 88 1052 8124 173804 cpumemd
6323 28 63844 88 732 22852 150592 liin_tap
6337 112 143592 88 6604 42056 215728 cli_agent
6339 856 172556 88 1700 18276 249384 snmp_subagent
6341 116 101080 88 1216 7692 163444 erm_p
6342 80 101696 88 612 7692 164028 ngdumper_provid
6343 36 101464 88 576 7584 163744 sysinfo_p
6354 8 9020 88 164 2620 23108 fs_cmd
8563 752 1936 88 1888 3184 4964 rollback_timer.
8670 752 1928 88 1880 2408 4956 rollback_timer.
8672 20 876 88 132 2956 19420 xlogger
8675 20 240 88 132 580 2072 inotifywait
8873 752 480 88 432 1736 3508 nova_sntp.sh
9024 752 480 88 432 952 3508 nova_sntp.sh
9025 20 876 88 132 2968 19420 xlogger
9028 56 160 88 132 720 3264 sntp
9248 192 143632 88 2372 12712 224272 table_mgr
9249 752 364 88 316 1604 3392 wnweb.sh
9250 48 106660 88 1656 9988 177028 iifd
9251 56944 33516 92 3488 188956 320376 iosd
9252 244 115572 88 2156 11872 193292 ha_mgr
10011 4 144756 236 17740 46208 241416 wnweb_paster.py
10012 20 1060 88 132 3692 23828 xlogger
10334 20 160 88 132 476 1896 sleep
------------------ show process cpu ------------------
Core 0: CPU utilization for five seconds: 12%; one minute: 14%; five minutes: 17%
Core 1: CPU utilization for five seconds: 37%; one minute: 34%; five minutes: 31%
Core 2: CPU utilization for five seconds: 8%; one minute: 8%; five minutes: 11%
Core 3: CPU utilization for five seconds: 6%; one minute: 5%; five minutes: 9%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 1640 1054 1555 0.00 0.00 0.01 0 init
2 0 124 0 0.00 0.00 0.00 0 kthreadd
3 0 1117 0 0.00 0.00 0.00 0 migration/0
4 0 3 0 0.00 0.00 0.00 0 sirq-high/0
5 740 95625 7 0.00 0.00 0.00 0 sirq-timer/0
6 0 10 0 0.00 0.00 0.00 0 sirq-net-tx/0
7 0 23 0 0.00 0.00 0.00 0 sirq-net-rx/0
8 250 3823 65 0.00 0.00 0.00 0 sirq-block/0
9 0 8 0 0.00 0.00 0.00 0 sirq-block-iopo
10 0 1230 0 0.00 0.00 0.00 0 sirq-tasklet/0
11 570 42866 13 0.00 0.00 0.00 0 sirq-sched/0
12 0 81 0 0.00 0.00 0.00 0 sirq-hrtimer/0
13 1850 88668 20 0.00 0.00 0.00 0 sirq-rcu/0
14 40 2277 17 0.00 0.00 0.00 0 desched/0
15 10 1087 9 0.00 0.00 0.00 0 migration/1
16 0 15 0 0.00 0.00 0.00 0 sirq-high/1
17 150 84675 1 0.00 0.00 0.00 0 sirq-timer/1
18 0 18 0 0.00 0.00 0.00 0 sirq-net-tx/1
19 0 40 0 0.00 0.00 0.00 0 sirq-net-rx/1
20 50 518 96 0.00 0.00 0.00 0 sirq-block/1
21 0 20 0 0.00 0.00 0.00 0 sirq-block-iopo
22 0 21 0 0.00 0.00 0.00 0 sirq-tasklet/1
23 30 37039 0 0.00 0.00 0.00 0 sirq-sched/1
24 0 45 0 0.00 0.00 0.00 0 sirq-hrtimer/1
25 310 78571 3 0.00 0.00 0.00 0 sirq-rcu/1
26 20 2302 8 0.00 0.00 0.00 0 desched/1
27 20 1589 12 0.00 0.00 0.00 0 migration/2
28 0 27 0 0.00 0.00 0.00 0 sirq-high/2
29 130 50138 2 0.00 0.00 0.01 0 sirq-timer/2
30 0 30 0 0.00 0.00 0.00 0 sirq-net-tx/2
31 0 85 0 0.00 0.00 0.00 0 sirq-net-rx/2
32 10 353 28 0.00 0.00 0.00 0 sirq-block/2
33 0 32 0 0.00 0.00 0.00 0 sirq-block-iopo
34 0 33 0 0.00 0.00 0.00 0 sirq-tasklet/2
35 40 14474 2 0.00 0.00 0.00 0 sirq-sched/2
36 0 68 0 0.00 0.00 0.00 0 sirq-hrtimer/2
37 20 47942 0 0.00 0.00 0.00 0 sirq-rcu/2
38 10 2858 3 0.00 0.00 0.00 0 desched/2
39 30 1360 22 0.00 0.00 0.00 0 migration/3
40 0 39 0 0.00 0.00 0.00 0 sirq-high/3
41 0 34399 0 0.00 0.00 0.00 0 sirq-timer/3
42 0 44 0 0.00 0.00 0.00 0 sirq-net-tx/3
43 0 63 0 0.00 0.00 0.00 0 sirq-net-rx/3
44 10 234 42 0.00 0.00 0.00 0 sirq-block/3
45 0 44 0 0.00 0.00 0.00 0 sirq-block-iopo
46 0 45 0 0.00 0.00 0.00 0 sirq-tasklet/3
47 0 17730 0 0.00 0.00 0.00 0 sirq-sched/3
48 0 59 0 0.00 0.00 0.00 0 sirq-hrtimer/3
49 0 33941 0 0.00 0.00 0.00 0 sirq-rcu/3
50 30 2683 11 0.00 0.00 0.00 0 desched/3
51 30 2834 10 0.00 0.00 0.00 0 events/0
52 10 1778 5 0.00 0.00 0.00 0 events/1
53 0 1521 0 0.00 0.00 0.00 0 events/2
54 0 1452 0 0.00 0.00 0.00 0 events/3
55 80 2964 26 0.00 0.00 0.00 0 khelper
58 0 55 0 0.00 0.00 0.00 0 netns
60 0 60 0 0.00 0.00 0.00 0 async/mgr
158 10 241 41 0.00 0.00 0.00 0 sync_supers
160 0 283 0 0.00 0.00 0.00 0 bdi-default
162 0 545 0 0.00 0.00 0.00 0 kblockd/0
163 0 155 0 0.00 0.00 0.00 0 kblockd/1
164 0 143 0 0.00 0.00 0.00 0 kblockd/2
165 0 96 0 0.00 0.00 0.00 0 kblockd/3
171 0 69 0 0.00 0.00 0.00 0 ata/0
172 0 68 0 0.00 0.00 0.00 0 ata/1
173 0 65 0 0.00 0.00 0.00 0 ata/2
174 0 66 0 0.00 0.00 0.00 0 ata/3
175 0 67 0 0.00 0.00 0.00 0 ata_aux
183 0 70 0 0.00 0.00 0.00 0 khubd
210 0 88 0 0.00 0.00 0.00 0 rpciod/0
211 0 88 0 0.00 0.00 0.00 0 rpciod/1
212 0 75 0 0.00 0.00 0.00 0 rpciod/2
213 0 78 0 0.00 0.00 0.00 0 rpciod/3
229 0 77 0 0.00 0.00 0.00 0 kswapd0
230 0 78 0 0.00 0.00 0.00 0 aio/0
231 0 79 0 0.00 0.00 0.00 0 aio/1
232 0 80 0 0.00 0.00 0.00 0 aio/2
233 0 81 0 0.00 0.00 0.00 0 aio/3
234 0 82 0 0.00 0.00 0.00 0 nfsiod
236 0 83 0 0.00 0.00 0.00 0 crypto/0
237 0 84 0 0.00 0.00 0.00 0 crypto/1
238 0 85 0 0.00 0.00 0.00 0 crypto/2
239 0 86 0 0.00 0.00 0.00 0 crypto/3
789 0 825 0 0.00 0.00 0.00 0 pata_octeon_cf
790 0 99 0 0.00 0.00 0.00 0 scsi_eh_0
796 1660 314 5286 0.00 0.00 0.00 0 mtdblockd
823 30 1290 23 0.00 0.00 0.00 0 octeon-ethernet
857 0 96 0 0.00 0.00 0.00 0 kstriped
859 0 97 0 0.00 0.00 0.00 0 ksnapd
937 310 1222 253 0.00 0.00 0.00 0 udevd
1252 0 332 0 0.00 0.00 0.00 0 flush-8:0
1534 160 4368 36 0.00 0.00 0.00 0 loop1
1559 110 4218 26 0.00 0.00 0.00 0 loop2
1584 10 2117 4 0.00 0.00 0.00 0 loop3
1609 30 2894 10 0.00 0.00 0.00 0 loop4
1634 30 1704 17 0.00 0.00 0.00 0 loop5
1679 10 559 17 0.00 0.00 0.00 0 loop6
2361 0 1001 0 0.00 0.00 0.00 0 udevd
2362 0 977 0 0.00 0.00 0.00 0 udevd
3274 150 1113 134 0.00 0.00 0.00 0 dbus-daemon
3652 130 1190 109 0.00 0.00 0.00 0 klogd
3664 0 977 0 0.00 0.00 0.00 0 portmap
3733 0 958 0 0.00 0.00 0.00 0 sshd
3745 0 949 0 0.00 0.00 0.00 0 xinetd
3749 0 950 0 0.00 0.00 0.00 0 xinetd
3783 0 112 0 0.00 0.00 0.00 0 lockd
3784 0 114 0 0.00 0.00 0.00 0 nfsd
3785 0 115 0 0.00 0.00 0.00 0 nfsd
3786 0 116 0 0.00 0.00 0.00 0 nfsd
3787 0 117 0 0.00 0.00 0.00 0 nfsd
3788 0 118 0 0.00 0.00 0.00 0 nfsd
3789 0 119 0 0.00 0.00 0.00 0 nfsd
3790 0 120 0 0.00 0.00 0.00 0 nfsd
3791 0 120 0 0.00 0.00 0.00 0 nfsd
3797 0 980 0 0.00 0.00 0.00 0 rpc.mountd
5347 870 19624 44 0.00 0.01 0.03 0 system_mgr
5576 690 18171 37 0.00 0.00 0.00 1088 slproc
5652 65880 715344 92 0.80 0.92 0.94 1088 fed
5653 4730 1983030 2 0.09 0.08 0.08 0 platform_mgr
5654 5410 80100 67 0.05 0.04 0.04 0 stack-mgr
6146 18900 5205 3631 0.00 0.02 0.65 0 idope.py
6296 310 23990 12 0.00 0.00 0.00 0 ns_oir_proxy
6297 400 32766 12 0.00 0.01 0.03 0 profiled
6298 230 1486 154 0.00 0.01 0.09 0 oom_poll.sh
6299 1430 53143 26 0.00 0.00 0.02 0 obfld
6300 310 32861 9 0.00 0.01 0.15 0 consoled
6301 550 23874 23 0.00 0.06 0.14 0 console_relay
6302 410 32842 12 0.00 0.01 0.03 0 csprovider
6303 440 32845 13 0.00 0.02 0.00 0 system_mgr_cli
6304 600 39402 15 0.00 0.00 0.01 0 plogd
6305 380 32809 11 0.00 0.02 0.00 0 psdprov
6306 790 63343 12 0.00 0.00 0.02 0 pdsd
6307 830 30732 27 0.00 0.03 0.08 0 gold_slave
6308 410 34431 11 0.00 0.32 0.36 0 osinfo-provider
6309 250 32865 7 0.00 0.02 0.04 0 oscore_p
6310 290 31649 9 0.00 0.00 0.25 0 netd
6311 950 33169 28 0.00 0.01 0.03 0 mem_mgmt
6312 320 24893 12 0.00 0.01 0.15 0 mgmte_tap
6313 810 58376 13 0.00 0.01 1.08 0 installer
6314 8430 49509 170 0.00 0.00 0.78 0 ffm
6315 24800 107452 230 0.00 0.44 0.79 0 eicored
6316 710 37704 18 0.00 0.00 0.02 0 dtmgr
6317 4840 33772 143 0.14 0.12 0.10 0 cpumemd
6323 430 24960 17 0.00 0.00 0.00 0 liin_tap
6337 2940 48601 60 0.00 2.96 0.25 0 cli_agent
6339 7270 70206 103 0.00 0.03 0.05 0 snmp_subagent
6341 310 33845 9 0.00 0.00 0.00 0 erm_p
6342 430 33985 12 0.00 0.00 0.19 0 ngdumper_provid
6343 450 33906 13 0.00 0.00 0.03 0 sysinfo_p
6354 90 4817 18 0.00 0.00 0.00 0 fs_cmd
8563 480 1400 342 0.00 0.00 0.00 0 rollback_timer.
8670 0 1391 0 0.00 0.00 0.00 0 rollback_timer.
8672 90 1394 64 0.00 0.00 0.00 0 xlogger
8675 0 1395 0 0.00 0.00 0.00 0 inotifywait
8873 170 1176 144 0.00 0.00 0.00 0 nova_sntp.sh
9024 0 1174 0 0.00 0.00 0.00 0 nova_sntp.sh
9025 160 1174 136 0.00 0.00 0.00 0 xlogger
9028 10 1180 8 0.00 0.00 0.00 0 sntp
9248 1090 75312 14 0.00 0.00 0.14 0 table_mgr
9249 90 1418 63 0.00 0.00 0.11 0 wnweb.sh
9250 700 35938 19 0.00 0.00 0.05 0 iifd
9251 256210 1316246 194 15.1 14.5 12.1 0 iosd
9252 820 39481 20 0.00 0.02 0.05 0 ha_mgr
10011 11810 66803 176 0.00 0.03 1.17 0 wnweb_paster.py
10012 360 1418 253 0.00 0.00 0.00 0 xlogger
10334 0 1486 0 0.00 0.00 0.00 0 sleep
------------------ show process cpu history ------------------
History information for system:
111111111111111111111111111111111111111111111111111111111111
666555559999966666555558888866666666665555555555555556666644
100
90
80
70
60
50
40
30
20 **********************************************************
10 ************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
11111111 11 1 49
8677779324223429
100 *
90 *
80 *
70 *
60 #
50 #
40 *#
30 *#
20 ######* *#
10 #######* ** * ##
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
100
90
80
70
60
50
40
30
20
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
History information for core 0:
111111112222211111111111111111111111111111111111111111111111
666333336666622222333335555555555555553333355555333336666677
100
90
80
70
60
50
40
30 *****
20 *** ***** *************** ***** *******
0 5 0 5 0 5 0 5 0 5
7898874401487530
100 *
90 *
80 **
70 **
60 *#
50 *#
40 *#
30 * *#
20 **###*** ** **##
10 ###########*####
0 5 0 5 0 5 0 5 0 5
100
90
80
70
60
50
40
30
20
History information for core 1:
333333333333333333333333333333333333333333333333333333333333
777222226666677777444442222244444444449999955555555553333300
100
90
80
70
60
50
40 *** ********** ***************
30 ************************************************************
20 ************************************************************
0 5 0 5 0 5 0 5 0 5
9910208722838120
100 *
90 *
80 *
70 **
60 *#
50 *#
40 **####* *#
30 ######* * *#
20 ####### * * *#
10 #######* ** * ##
0 5 0 5 0 5 0 5 0 5
100
90
80
70
60
50
40
30
20
History information for core 2:
11111
555999998888888888999999999999999111117777788888777779999977
100
90
80
70
60
50
40
30
20
0 5 0 5 0 5 0 5 0 5
1121000710036160
100 *
90 *
80 *
70 *
60 **
50 *#
40 *#
30 *#
20 * * *#
10 #######* ** * ##
0 5 0 5 0 5 0 5 0 5
100
90
80
70
60
50
40
30
20
History information for core 3:
11111
555555554444466666555558888844444555553333344444444445555533
100
90
80
70
60
50
40
30
20 *****
10 ******** *************** ***** *****
0 5 0 5 0 5 0 5 0 5
1 1 21 1 89
8676874656731449
100 *
90 *
80 **
70 **
60 **
50 *#
40 *#
30 * *#
20 * ** *#
10 #********** * ##
0 5 0 5 0 5 0 5 0 5
100
90
80
70
60
50
40
30
20
------------------ show switch detail ------------------
Switch/Stack Mac Address : 8890.8d1b.5900 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active 8890.8d1b.5900 1 V04 Ready
Stack Port Status Neighbors
Switch# Port 1 Port 2 Port 1 Port 2
1 DOWN DOWN None None
------------------ show platform oir states ------------------
Card # Type Provisioned State
1 16385 Yes COMPATIBLE
2 0 No CREATED_REMOTE
3 0 No CREATED_REMOTE
4 0 No CREATED_REMOTE
5 0 No CREATED_REMOTE
6 0 No CREATED_REMOTE
7 0 No CREATED_REMOTE
8 0 No CREATED_REMOTE
9 0 No CREATED_REMOTE
------------------ show platform ses states ------------------
Card # Card State
1 NG3K_SES_CARD_ADD_COMPLETED(51)
2 NG3K_SES_CARD_EMPTY(0)
3 NG3K_SES_CARD_EMPTY(0)
4 NG3K_SES_CARD_EMPTY(0)
5 NG3K_SES_CARD_EMPTY(0)
6 NG3K_SES_CARD_EMPTY(0)
7 NG3K_SES_CARD_EMPTY(0)
8 NG3K_SES_CARD_EMPTY(0)
9 NG3K_SES_CARD_EMPTY(0)
------------------ * rtu_license.sts - RTU show cmds added to show tech-support ------------------
------------------ * July 2012, Sunil Kumar G ------------------
------------------ * Copyright (c) 2012 by cisco Systems, Inc. ------------------
------------------ * All rights reserved. ------------------
------------------ show license right-to-use summary ------------------
License Name Type Count Period left
lanbase permanent N/A Lifetime
apcount base 0 Lifetime
apcount adder 0 Lifetime
License Level In Use: lanbase
License Level on Reboot: lanbase
Evaluation AP-Count: Disabled
Total AP Count Licenses: 0
AP Count Licenses In-use: 0
AP Count Licenses Remaining: 0
------------------ show license right-to-use ------------------
Slot# License name Type Count Period left
1 lanbase permanent N/A Lifetime
------------------ show license right-to-use usage ------------------
Slot# License Name Type usage-duration(y:m:d) In-Use EULA
1 ipservices permanent 0 :0 :0 no no
1 ipservices evaluation 0 :0 :0 no no
1 ipbase permanent 0 :0 :0 no no
1 ipbase evaluation 0 :0 :0 no no
1 lanbase permanent 1 :2 :5 yes yes
1 apcount evaluation 0 :0 :0 no no
1 apcount base 0 :0 :0 no no
1 apcount adder 0 :0 :0 no no
------------------ show license right-to-use mismatch ------------------
Slot# License Name Adder AP Count Base AP Count
------------------ show license right-to-use default ------------------
Slot# License Name Type Count
1 apcount base 0
------------------ show license right-to-use detail ------------------
Index 1: License Name: ipservices
Period left: Lifetime
License Type: permanent
License State: Not Activated
License Count: Non-Counted
License Location: Slot 1
Index 2: License Name: ipservices
Period left: 90
License Type: evaluation
Index 3: License Name: ipbase
Index 4: License Name: ipbase
Period left: 90
Index 5: License Name: lanbase
License State: Active, In use
Index 6: License Name: apcount
Period left: 90
License Count: 50
Index 7: License Name: apcount
License Type: base
License Count: 0
Index 8: License Name: apcount
License Type: adder
License Count: 0
------------------ show version running ------------------
Package: Base, version: 03.02.03.SE, status: active
File: cat3k_caa-base.SPA.03.02.03.SE.pkg, on: Switch1
Built: Mon Sep 23 18:32:45 PDT 2013, by: udonthi
Package: Drivers, version: 1.1, status: active
File: cat3k_caa-drivers.SSA.1.1.pkg, on: Switch1
Built: Tue Jul 23 19:11:34 PDT 2013, by: udonthi
Package: Infra, version: 03.02.03.SE, status: active
File: cat3k_caa-infra.SPA.03.02.03.SE.pkg, on: Switch1
Built: Mon Sep 23 18:33:46 PDT 2013, by: udonthi
Package: IOS, version: 150-1.EX3, status: active
File: cat3k_caa-iosd-universalk9.SPA.150-1.EX3.pkg, on: Switch1
Built: Mon Sep 23 18:35:18 PDT 2013, by: udonthi
Package: Platform, version: 03.02.03.SE, status: active
File: cat3k_caa-platform.SPA.03.02.03.SE.pkg, on: Switch1
Built: Mon Sep 23 18:34:36 PDT 2013, by: udonthi
Package: WCM, version: 10.0.120.0, status: active
File: cat3k_caa-wcm.SPA.10.0.120.0.pkg, on: Switch1
Built: Mon Sep 23 18:36:05 PDT 2013, by: udonthi
------------------ show processes cpu detailed ------------------
Core 0: CPU utilization for five seconds: 21%; one minute: 15%; five minutes: 17%
Core 1: CPU utilization for five seconds: 44%; one minute: 35%; five minutes: 31%
Core 2: CPU utilization for five seconds: 15%; one minute: 9%; five minutes: 10%
Core 3: CPU utilization for five seconds: 11%; one minute: 6%; five minutes: 8%
PID T C TID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 L 1640 1054 1555 0.00 0.00 0.00 0 init
2 L 0 124 0 0.00 0.00 0.00 0 kthreadd
3 L 0 1117 0 0.00 0.00 0.00 0 migration/0
4 L 0 3 0 0.00 0.00 0.00 0 sirq-high/0
5 L 780 99195 7 0.00 0.00 0.00 0 sirq-timer/0
6 L 0 10 0 0.00 0.00 0.00 0 sirq-net-tx/0
7 L 0 23 0 0.00 0.00 0.00 0 sirq-net-rx/0
8 L 250 3825 65 0.00 0.00 0.00 0 sirq-block/0
9 L 0 8 0 0.00 0.00 0.00 0 sirq-block-iopo
10 L 0 1309 0 0.00 0.00 0.00 0 sirq-tasklet/0
11 L 570 44014 12 0.00 0.00 0.00 0 sirq-sched/0
12 L 0 87 0 0.00 0.00 0.00 0 sirq-hrtimer/0
13 L 1940 91953 21 0.00 0.00 0.00 0 sirq-rcu/0
14 L 40 2280 17 0.00 0.00 0.00 0 desched/0
15 L 10 1087 9 0.00 0.00 0.00 0 migration/1
16 L 0 15 0 0.00 0.00 0.00 0 sirq-high/1
17 L 150 87588 1 0.00 0.00 0.00 0 sirq-timer/1
18 L 0 18 0 0.00 0.00 0.00 0 sirq-net-tx/1
19 L 0 40 0 0.00 0.00 0.00 0 sirq-net-rx/1
20 L 50 520 96 0.00 0.00 0.00 0 sirq-block/1
21 L 0 20 0 0.00 0.00 0.00 0 sirq-block-iopo
22 L 0 21 0 0.00 0.00 0.00 0 sirq-tasklet/1
23 L 30 37664 0 0.00 0.00 0.00 0 sirq-sched/1
24 L 0 48 0 0.00 0.00 0.00 0 sirq-hrtimer/1
25 L 320 81231 3 0.00 0.00 0.00 0 sirq-rcu/1
26 L 20 2302 8 0.00 0.00 0.00 0 desched/1
27 L 20 1590 12 0.00 0.00 0.00 0 migration/2
28 L 0 27 0 0.00 0.00 0.00 0 sirq-high/2
29 L 130 52562 2 0.00 0.00 0.00 0 sirq-timer/2
30 L 0 30 0 0.00 0.00 0.00 0 sirq-net-tx/2
31 L 0 85 0 0.00 0.00 0.00 0 sirq-net-rx/2
32 L 10 353 28 0.00 0.00 0.00 0 sirq-block/2
33 L 0 32 0 0.00 0.00 0.00 0 sirq-block-iopo
34 L 0 33 0 0.00 0.00 0.00 0 sirq-tasklet/2
35 L 40 14624 2 0.00 0.00 0.00 0 sirq-sched/2
36 L 0 71 0 0.00 0.00 0.00 0 sirq-hrtimer/2
37 L 20 50190 0 0.00 0.00 0.00 0 sirq-rcu/2
38 L 10 2859 3 0.00 0.00 0.00 0 desched/2
39 L 30 1363 22 0.00 0.00 0.00 0 migration/3
40 L 0 39 0 0.00 0.00 0.00 0 sirq-high/3
41 L 0 35728 0 0.00 0.00 0.00 0 sirq-timer/3
42 L 0 44 0 0.00 0.00 0.00 0 sirq-net-tx/3
43 L 0 64 0 0.00 0.00 0.00 0 sirq-net-rx/3
44 L 10 234 42 0.00 0.00 0.00 0 sirq-block/3
45 L 0 44 0 0.00 0.00 0.00 0 sirq-block-iopo
46 L 0 45 0 0.00 0.00 0.00 0 sirq-tasklet/3
47 L 0 17863 0 0.00 0.00 0.00 0 sirq-sched/3
48 L 0 59 0 0.00 0.00 0.00 0 sirq-hrtimer/3
49 L 0 35250 0 0.00 0.00 0.00 0 sirq-rcu/3
50 L 30 2686 11 0.00 0.00 0.00 0 desched/3
51 L 30 2921 10 0.00 0.00 0.00 0 events/0
52 L 10 1819 5 0.00 0.00 0.00 0 events/1
53 L 0 1562 0 0.00 0.00 0.00 0 events/2
54 L 0 1492 0 0.00 0.00 0.00 0 events/3
55 L 80 2964 26 0.00 0.00 0.00 0 khelper
58 L 0 55 0 0.00 0.00 0.00 0 netns
60 L 0 60 0 0.00 0.00 0.00 0 async/mgr
158 L 10 248 40 0.00 0.00 0.00 0 sync_supers
160 L 0 291 0 0.00 0.00 0.00 0 bdi-default
162 L 0 547 0 0.00 0.00 0.00 0 kblockd/0
163 L 0 156 0 0.00 0.00 0.00 0 kblockd/1
164 L 0 143 0 0.00 0.00 0.00 0 kblockd/2
165 L 0 96 0 0.00 0.00 0.00 0 kblockd/3
171 L 0 69 0 0.00 0.00 0.00 0 ata/0
172 L 0 68 0 0.00 0.00 0.00 0 ata/1
173 L 0 65 0 0.00 0.00 0.00 0 ata/2
174 L 0 66 0 0.00 0.00 0.00 0 ata/3
175 L 0 67 0 0.00 0.00 0.00 0 ata_aux
183 L 0 70 0 0.00 0.00 0.00 0 khubd
210 L 0 88 0 0.00 0.00 0.00 0 rpciod/0
211 L 0 88 0 0.00 0.00 0.00 0 rpciod/1
212 L 0 75 0 0.00 0.00 0.00 0 rpciod/2
213 L 0 78 0 0.00 0.00 0.00 0 rpciod/3
229 L 0 77 0 0.00 0.00 0.00 0 kswapd0
230 L 0 78 0 0.00 0.00 0.00 0 aio/0
231 L 0 79 0 0.00 0.00 0.00 0 aio/1
232 L 0 80 0 0.00 0.00 0.00 0 aio/2
233 L 0 81 0 0.00 0.00 0.00 0 aio/3
234 L 0 82 0 0.00 0.00 0.00 0 nfsiod
236 L 0 83 0 0.00 0.00 0.00 0 crypto/0
237 L 0 84 0 0.00 0.00 0.00 0 crypto/1
238 L 0 85 0 0.00 0.00 0.00 0 crypto/2
239 L 0 86 0 0.00 0.00 0.00 0 crypto/3
789 L 0 830 0 0.00 0.00 0.00 0 pata_octeon_cf
790 L 0 99 0 0.00 0.00 0.00 0 scsi_eh_0
796 L 1660 314 5286 0.00 0.00 0.00 0 mtdblockd
823 L 30 1330 22 0.00 0.00 0.00 0 octeon-ethernet
857 L 0 96 0 0.00 0.00 0.00 0 kstriped
859 L 0 97 0 0.00 0.00 0.00 0 ksnapd
937 L 310 1222 253 0.00 0.00 0.00 0 udevd
1252 L 0 340 0 0.00 0.00 0.00 0 flush-8:0
1534 L 160 4368 36 0.00 0.00 0.00 0 loop1
1559 L 110 4223 26 0.00 0.00 0.00 0 loop2
1584 L 10 2122 4 0.00 0.00 0.00 0 loop3
1609 L 30 2894 10 0.00 0.00 0.00 0 loop4
1634 L 30 1704 17 0.00 0.00 0.00 0 loop5
1679 L 10 559 17 0.00 0.00 0.00 0 loop6
2361 L 0 1001 0 0.00 0.00 0.00 0 udevd
2362 L 0 977 0 0.00 0.00 0.00 0 udevd
3274 L 150 1113 134 0.00 0.00 0.00 0 dbus-daemon
3652 L 130 1190 109 0.00 0.00 0.00 0 klogd
3664 L 0 977 0 0.00 0.00 0.00 0 portmap
3733 L 0 958 0 0.00 0.00 0.00 0 sshd
3745 L 0 949 0 0.00 0.00 0.00 0 xinetd
3749 L 0 950 0 0.00 0.00 0.00 0 xinetd
3783 L 0 112 0 0.00 0.00 0.00 0 lockd
3784 L 0 114 0 0.00 0.00 0.00 0 nfsd
3785 L 0 115 0 0.00 0.00 0.00 0 nfsd
3786 L 0 116 0 0.00 0.00 0.00 0 nfsd
3787 L 0 117 0 0.00 0.00 0.00 0 nfsd
3788 L 0 118 0 0.00 0.00 0.00 0 nfsd
3789 L 0 119 0 0.00 0.00 0.00 0 nfsd
3790 L 0 120 0 0.00 0.00 0.00 0 nfsd
3791 L 0 120 0 0.00 0.00 0.00 0 nfsd
3797 L 0 980 0 0.00 0.00 0.00 0 rpc.mountd
5347 L 880 19822 44 0.00 0.01 0.02 0 system_mgr
5347 L 0 5347 810 3286 0 0.00 0.01 0.01 0 system_mgr
5347 L 1 5648 20 1166 0 0.00 0.00 0.00 0 system_mgr
5347 L 0 5649 0 1134 0 0.00 0.00 0.00 0 system_mgr
5347 L 0 5650 10 2127 0 0.00 0.00 0.00 0 system_mgr
5347 L 1 5651 0 1138 0 0.00 0.00 0.00 0 SPI default ST
5347 L 2 7205 0 1120 0 0.00 0.00 0.00 0 system_mgr
5347 L 2 7206 0 1120 0 0.00 0.00 0.00 0 system_mgr
5347 L 2 7207 0 1120 0 0.00 0.00 0.00 0 system_mgr
5347 L 1 7268 40 2113 0 0.00 0.00 0.01 0 system_mgr
5347 L 1 7291 0 2114 0 0.00 0.00 0.00 0 system_mgr
5347 L 3 7292 0 1128 0 0.00 0.00 0.00 1088 system_mgr
5347 L 3 7293 0 1128 0 0.00 0.00 0.00 1088 system_mgr
5347 L 3 7294 0 1128 0 0.00 0.00 0.00 1088 system_mgr
5576 L 690 18215 37 0.00 0.00 0.00 1088 slproc
5576 L 0 5576 210 1123 0 0.00 0.00 0.00 1088 slproc
5576 L 2 5636 50 2173 0 0.00 0.00 0.00 1088 slproc
5576 L 0 5637 0 1212 0 0.00 0.00 0.00 1088 slproc
5576 L 3 5638 310 3963 0 0.00 0.00 0.00 1088 slproc
5576 L 1 5639 0 1112 0 0.00 0.00 0.00 1088 slproc
5576 L 1 5640 90 2983 0 0.00 0.00 0.00 1088 slproc
5576 L 0 5641 30 2321 0 0.00 0.00 0.00 1088 slproc
5576 L 3 5642 0 1107 0 0.00 0.00 0.00 1088 slproc
5576 L 1 5643 0 1113 0 0.00 0.00 0.00 1088 slproc
5576 L 3 5644 0 1108 0 0.00 0.00 0.00 1088 slproc
5652 L 67010 739331 90 0.84 0.89 0.93 1088 fed
5652 L 2 5652 32130 7746 0 0.00 0.00 0.28 1088 fed
5652 L 1 6093 6730 5163 0 0.00 0.04 0.04 1088 fed
5652 L 2 6094 30 1444 0 0.00 0.00 0.00 1088 fed
5652 L 3 6095 220 2228 0 0.00 0.00 0.00 1088 fed
5652 L 1 6096 40 2150 0 0.00 0.00 0.04 1088 fed
5652 L 1 6097 0 1149 0 0.00 0.00 0.00 0 SPI default TP
5652 L 2 6098 0 1332 0 0.00 0.00 0.00 0 SPI default TP
5652 L 3 6099 0 1237 0 0.00 0.00 0.00 0 SPI default TP
5652 L 1 6100 30 1325 0 0.00 0.00 0.00 0 SPI default TP
5652 L 1 6101 40 1304 0 0.00 0.00 0.00 0 SPI default TP
5652 L 1 6102 0 1258 0 0.00 0.00 0.00 0 fed
5652 L 0 6103 0 1288 0 0.00 0.00 0.00 0 fed
5652 L 3 6106 3040 15792 0 0.19 0.20 0.20 0 fed-ots-main
5652 L 0 6107 10 1246 0 0.00 0.00 0.00 0 fed-ots-mo
5652 L 2 6109 11860 2199 0 0.47 0.41 0.42 0 fed-ots-nfl
5652 L 2 6110 150 7296 0 0.00 0.01 0.03 0 fed
5652 L 1 6111 80 3762 0 0.00 0.00 0.02 0 pdslib thread
5652 L 0 6112 190 3505 0 0.00 0.02 0.00 0 SPI default ST
5652 L 0 6113 1040 41107 0 0.00 0.05 0.01 0 Timer
5652 L 1 6114 0 2773 0 0.00 0.00 0.00 0 fed
5652 L 2 6137 540 6556 0 0.00 0.01 0.00 0 IntrDrv
5652 L 1 6140 200 17273 0 0.00 0.01 0.03 0 LED
5652 L 3 7254 0 1162 0 0.00 0.00 0.00 0 fed
5652 L 3 7255 0 1162 0 0.00 0.00 0.00 0 fed
5652 L 2 7256 0 1173 0 0.00 0.00 0.00 0 fed
5652 L 0 7283 30 2149 0 0.00 0.00 0.02 0 fed
5652 L 0 7286 30 2149 0 0.00 0.00 0.02 0 fed
5652 L 3 7288 60 1631 0 0.00 0.00 0.00 0 fed
5652 L 3 7289 20 1213 0 0.00 0.00 0.00 0 fed
5652 L 3 7290 0 1163 0 0.00 0.00 0.00 0 fed
5652 L 2 9813 40 9100 0 0.00 0.00 0.00 0 Xcvr
5652 L 2 9815 8470 464537 0 0.09 0.18 0.21 0 Xcvr
5652 L 0 9839 180 10562 0 0.00 0.04 0.02 0 Replenish
5652 L 2 9840 0 7196 0 0.00 0.00 0.00 0 PdsEvent
5652 L 2 9841 400 9836 0 0.00 0.02 0.03 0 PunjectRx
5652 L 3 9842 260 8370 0 0.00 0.01 0.00 0 PunjectTx
5652 L 2 9843 10 7196 0 0.00 0.00 0.00 0 Consistency
5652 L 3 9844 0 7201 0 0.00 0.00 0.00 0 ShFwd
5652 L 3 9847 0 7244 0 0.00 0.00 0.00 0 eicore_bdn
5652 L 3 9848 0 7244 0 0.00 0.00 0.00 0 eicore_bdn
5652 L 2 9849 0 7243 0 0.00 0.00 0.00 0 eicore_bdn
5652 L 3 9852 30 7283 0 0.00 0.00 0.00 0 eicore_ipc
5652 L 3 9978 0 7741 0 0.00 0.00 0.00 0 fed
5652 L 0 9983 1150 37643 0 0.09 0.03 0.04 0 XcvrPoll
5653 L 4820 1990729 2 0.00 0.08 0.08 0 platform_mgr
5653 L 1 5653 1730 173534 0 0.00 0.00 0.01 0 platform_mgr
5653 L 0 6073 40 2192 0 0.00 0.00 0.02 0 platform_mgr
5653 L 0 6074 40 1217 0 0.00 0.00 0.00 0 platform_mgr
5653 L 1 6075 30 3331 0 0.00 0.01 0.04 0 platform_mgr
5653 L 2 6076 30 2149 0 0.00 0.00 0.00 0 platform_mgr
5653 L 3 6077 0 1204 0 0.00 0.00 0.00 0 SPI default TP
5653 L 0 6078 0 1194 0 0.00 0.00 0.00 0 SPI default TP
5653 L 3 6079 0 1196 0 0.00 0.00 0.00 0 SPI default TP
5653 L 0 6080 30 1182 0 0.00 0.00 0.00 0 SPI default TP
5653 L 3 6081 0 1136 0 0.00 0.00 0.00 0 SPI default TP
5653 L 2 6082 20 1245 0 0.00 0.00 0.00 0 platform_mgr
5653 L 2 6085 80 2659 0 0.00 0.01 0.00 0 SPI default ST
5653 L 0 6086 230 11815 0 0.00 0.01 0.02 0 LED
5653 L 2 6088 0 1264 0 0.00 0.00 0.00 0 platform_mgr
5653 L 3 6089 50 6333 0 0.00 0.01 0.03 0 platform_mgr
5653 L 1 6090 340 33209 0 0.00 0.04 0.02 0 Timer
5653 L 3 6091 0 1194 0 0.00 0.00 0.00 0 platform_mgr
5653 L 1 6115 1580 304099 0 0.00 0.03 0.04 0 RedEarthMgr
5653 L 0 6144 240 195229 0 0.00 0.00 0.00 0 platform_mgr
5653 L 0 7228 0 1150 0 0.00 0.00 0.00 0 platform_mgr
5653 L 0 7229 0 1150 0 0.00 0.00 0.00 0 platform_mgr
5653 L 0 7230 0 1150 0 0.00 0.00 0.00 0 platform_mgr
5653 L 1 7265 10 2138 0 0.00 0.00 0.00 0 platform_mgr
5653 L 0 7278 30 2139 0 0.00 0.01 0.03 0 platform_mgr
5653 L 0 7279 0 1203 0 0.00 0.00 0.00 0 platform_mgr
5653 L 3 7280 10 1159 0 0.00 0.00 0.00 0 platform_mgr
5653 L 3 7281 0 1153 0 0.00 0.00 0.00 0 platform_mgr
5653 L 0 9899 190 183180 0 0.00 0.00 0.03 0 USB
5653 L 2 9900 0 173496 0 0.00 0.00 0.00 0 eicore_bdn
5653 L 2 9901 0 173496 0 0.00 0.00 0.00 0 eicore_bdn
5653 L 2 9902 0 173495 0 0.00 0.00 0.00 0 eicore_bdn
5653 L 0 9905 20 173527 0 0.00 0.00 0.00 0 eicore_ipc
5653 L 0 9914 120 175005 0 0.00 0.01 0.03 0 Therm
5653 L 0 9955 0 173520 0 0.00 0.00 0.00 0 CfgMgr
5653 L 1 10304 0 2094 0 0.00 0.00 0.00 0 OBFL feature XD
5653 L 2 10341 0 2088 0 0.00 0.00 0.00 0 OBFL feature XD
5653 L 2 10352 0 2109 0 0.00 0.00 0.00 0 OBFL feature XD
5653 L 3 10354 0 2095 0 0.00 0.00 0.00 0 OBFL feature XD
5654 L 5450 81579 66 0.09 0.04 0.04 0 stack-mgr
5654 L 2 5654 3090 1452 0 0.00 0.00 0.00 0 stack-mgr
5654 L 0 6060 10 2198 0 0.00 0.00 0.00 0 stack-mgr
5654 L 1 6061 20 1264 0 0.00 0.00 0.00 0 stack-mgr
5654 L 3 6062 10 1293 0 0.00 0.03 0.04 0 stack-mgr
5654 L 0 6063 10 2156 0 0.00 0.02 0.04 0 stack-mgr
5654 L 2 6064 10 1203 0 0.00 0.00 0.00 0 SPI default TP
5654 L 0 6065 0 1222 0 0.00 0.00 0.00 0 SPI default TP
5654 L 0 6066 0 1167 0 0.00 0.00 0.00 0 SPI default TP
5654 L 1 6067 30 1225 0 0.05 0.05 0.05 0 SPI default TP
5654 L 0 6068 0 1144 0 0.00 0.00 0.00 0 SPI default TP
5654 L 2 6069 0 1255 0 0.00 0.00 0.00 0 stack-mgr
5654 L 0 6072 10 1249 0 0.00 0.00 0.01 0 SPI default ST
5654 L 2 6122 580 11563 0 0.00 0.04 0.02 0 stack-mgr-ots-m
5654 L 0 6123 850 15162 0 0.00 0.00 0.00 0 Timer
5654 L 0 6124 110 1506 0 0.00 0.02 0.04 0 stack-mgr-ots-n
5654 L 2 6125 10 1698 0 0.00 0.00 0.00 0 IntrDrv
5654 L 0 6128 600 5414 0 0.05 0.01 0.01 0 stack-mgr
5654 L 0 6129 0 1327 0 0.00 0.00 0.00 0 SIF
5654 L 0 6130 0 2344 0 0.00 0.00 0.00 0 pdslib thread
5654 L 0 6131 60 3390 0 0.00 0.01 0.00 0 Replenish
5654 L 1 6132 0 1319 0 0.00 0.00 0.00 0 OOBnd RX
5654 L 3 6133 0 1361 0 0.00 0.00 0.00 0 OOBnd TX
5654 L 3 6134 0 1341 0 0.00 0.00 0.00 0 SDP RX
5654 L 0 6135 0 1325 0 0.00 0.00 0.00 0 OobEv
5654 L 2 6222 0 1427 0 0.00 0.00 0.00 0 eicore_bdn
5654 L 2 6223 0 1427 0 0.00 0.00 0.00 0 eicore_bdn
5654 L 2 6224 0 1426 0 0.00 0.00 0.00 0 eicore_bdn
5654 L 3 7208 0 1159 0 0.00 0.00 0.00 0 stack-mgr
5654 L 3 7209 0 1159 0 0.00 0.00 0.00 0 stack-mgr
5654 L 3 7210 0 1159 0 0.00 0.00 0.00 0 stack-mgr
5654 L 0 7266 30 2151 0 0.00 0.00 0.02 0 stack-mgr
5654 L 0 7274 20 2152 0 0.00 0.01 0.03 0 stack-mgr
5654 L 3 7275 0 1166 0 0.00 0.00 0.00 0 stack-mgr
5654 L 3 7276 0 1166 0 0.00 0.00 0.00 0 stack-mgr
5654 L 3 7277 0 1166 0 0.00 0.00 0.00 0 stack-mgr
5654 L 1 9087 0 1443 0 0.00 0.00 0.00 0 eicore_ipc
6146 L 18910 5286 3577 0.00 0.01 0.57 0 idope.py
6146 L 1 6146 18740 1644 0 0.00 0.00 0.15 0 idope.py
6146 L 2 8815 170 3642 0 0.00 0.01 0.03 0 idope.py
6296 L 310 24153 12 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 3 6296 180 1243 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 0 7135 10 2253 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 0 7140 0 1344 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 1 7141 20 1266 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 0 7154 20 1280 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 3 7168 0 1251 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 0 7169 40 2231 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 3 7170 10 1253 0 0.00 0.00 0.00 0 SPI default ST
6296 L 0 7225 0 1255 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 0 7226 0 1255 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 0 7227 0 1255 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 1 7295 10 2245 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 1 7296 20 2245 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 3 7297 0 1259 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 3 7298 0 1259 0 0.00 0.00 0.00 0 ns_oir_proxy
6296 L 3 7299 0 1259 0 0.00 0.00 0.00 0 ns_oir_proxy
6297 L 410 32930 12 0.00 0.00 0.02 0 profiled
6297 L 3 6297 250 1266 0 0.00 0.00 0.00 0 profiled
6297 L 0 7343 30 2255 0 0.00 0.00 0.03 0 profiled
6297 L 1 7412 0 1345 0 0.00 0.00 0.00 0 profiled
6297 L 3 7613 20 1283 0 0.00 0.00 0.00 0 profiled
6297 L 2 7617 0 1261 0 0.00 0.00 0.00 0 profiled
6297 L 1 7618 30 2237 0 0.00 0.00 0.02 0 profiled
6297 L 0 7619 0 1252 0 0.00 0.00 0.00 0 SPI default TP
6297 L 0 7620 0 1253 0 0.00 0.00 0.00 0 SPI default TP
6297 L 2 7621 0 1260 0 0.00 0.00 0.00 0 SPI default TP
6297 L 2 7622 0 1260 0 0.00 0.00 0.00 0 SPI default TP
6297 L 2 7623 10 1260 0 0.00 0.00 0.00 0 SPI default TP
6297 L 3 7625 0 1258 0 0.00 0.00 0.00 0 eicore_bdn
6297 L 3 7626 0 1258 0 0.00 0.00 0.00 0 eicore_bdn
6297 L 3 7627 0 1258 0 0.00 0.00 0.00 0 eicore_bdn
6297 L 0 7649 0 1248 0 0.00 0.00 0.00 0 profiled
6297 L 0 7650 0 1248 0 0.00 0.00 0.00 0 profiled
6297 L 0 7651 0 1248 0 0.00 0.00 0.00 0 profiled
6297 L 2 7652 40 2234 0 0.00 0.01 0.03 0 profiled
6297 L 2 7653 30 2234 0 0.00 0.00 0.00 0 profiled
6297 L 0 7654 0 1248 0 0.00 0.00 0.00 0 profiled
6297 L 0 7655 0 1248 0 0.00 0.00 0.00 0 profiled
6297 L 0 7656 0 1248 0 0.00 0.00 0.00 0 profiled
6297 L 2 9106 0 1268 0 0.00 0.00 0.00 0 eicore_ipc
6298 L 240 1492 160 0.05 0.01 0.08 0 oom_poll.sh
6299 L 1410 53117 26 0.00 0.04 0.01 0 obfld
6299 L 3 6299 560 1390 0 0.05 0.01 0.02 0 obfld
6299 L 0 7713 120 3174 0 0.00 0.01 0.03 0 obfld
6299 L 0 7768 0 1397 0 0.00 0.00 0.00 0 obfld
6299 L 0 7931 560 1918 0 0.00 0.00 0.00 0 obfl async
6299 L 1 8052 30 1389 0 0.00 0.00 0.00 0 obfld
6299 L 0 8081 60 1930 0 0.00 0.00 0.00 0 obfld
6299 L 0 8082 10 2323 0 0.00 0.00 0.01 0 obfld
6299 L 1 8092 0 1342 0 0.00 0.00 0.00 0 SPI default TP
6299 L 1 8094 0 1343 0 0.00 0.00 0.00 0 SPI default TP
6299 L 1 8096 0 1354 0 0.00 0.00 0.00 0 SPI default TP
6299 L 1 8098 0 1354 0 0.00 0.00 0.00 0 SPI default TP
6299 L 1 8101 0 1354 0 0.00 0.00 0.00 0 SPI default TP
6299 L 1 8136 10 1345 0 0.00 0.00 0.00 0 eicore_bdn
6299 L 1 8137 0 1345 0 0.00 0.00 0.00 0 eicore_bdn
6299 L 1 8138 0 1345 0 0.00 0.00 0.00 0 eicore_bdn
6299 L 1 8142 0 1348 0 0.00 0.00 0.00 0 obfld
6299 L 1 8143 0 1348 0 0.00 0.00 0.00 0 obfld
6299 L 1 8144 0 1348 0 0.00 0.00 0.00 0 obfld
6299 L 2 8145 10 2332 0 0.00 0.00 0.00 0 obfld
6299 L 2 8146 10 2332 0 0.00 0.00 0.00 0 obfld
6299 L 1 8147 0 1348 0 0.00 0.00 0.00 0 obfld
6299 L 1 8148 0 1348 0 0.00 0.00 0.00 0 obfld
6299 L 1 8149 0 1348 0 0.00 0.00 0.00 0 obfld
6299 L 1 9062 0 1357 0 0.00 0.00 0.00 0 eicore_ipc
6299 L 3 10269 0 1697 0 0.00 0.00 0.02 0 OBFL feature XD
6299 L 1 10276 20 2239 0 0.00 0.00 0.01 0 PUBLIC XDM
6299 L 3 10305 10 1802 0 0.00 0.00 0.00 0 PUBLIC XDM
6299 L 1 10310 10 1642 0 0.00 0.00 0.00 0 OBFL feature XD
6299 L 1 10324 0 2138 0 0.00 0.00 0.00 0 PUBLIC XDM
6299 L 3 10331 0 1682 0 0.00 0.00 0.00 0 OBFL feature XD
6299 L 0 10355 0 1803 0 0.00 0.00 0.00 0 PUBLIC XDM
6299 L 0 10356 0 1702 0 0.00 0.00 0.00 0 OBFL feature XD
6300 L 310 33023 9 0.00 0.00 0.13 0 consoled
6300 L 2 6300 200 1278 0 0.00 0.00 0.00 0 consoled
6300 L 0 8269 30 2251 0 0.00 0.00 0.00 0 consoled
6300 L 0 8275 10 1343 0 0.00 0.00 0.00 0 consoled
6300 L 3 8319 20 1281 0 0.00 0.00 0.00 0 consoled
6300 L 2 8321 20 1264 0 0.00 0.00 0.00 0 consoled
6300 L 0 8323 0 2240 0 0.00 0.00 0.03 0 consoled
6300 L 0 8331 0 1259 0 0.00 0.00 0.00 0 SPI default TP
6300 L 1 8332 0 1260 0 0.00 0.00 0.00 0 SPI default TP
6300 L 1 8333 0 1263 0 0.00 0.00 0.00 0 SPI default TP
6300 L 2 8334 0 1266 0 0.00 0.00 0.00 0 SPI default TP
6300 L 2 8335 0 1267 0 0.00 0.00 0.00 0 SPI default TP
6300 L 3 8339 0 1251 0 0.00 0.00 0.00 0 consoled
6300 L 3 8340 0 1251 0 0.00 0.00 0.00 0 consoled
6300 L 3 8341 0 1251 0 0.00 0.00 0.00 0 consoled
6300 L 0 8342 10 2235 0 0.00 0.00 0.00 0 consoled
6300 L 0 8344 20 2235 0 0.00 0.00 0.02 0 consoled
6300 L 3 8345 0 1251 0 0.00 0.00 0.00 0 consoled
6300 L 3 8346 0 1251 0 0.00 0.00 0.00 0 consoled
6300 L 3 8347 0 1251 0 0.00 0.00 0.00 0 consoled
6300 L 3 8350 0 1265 0 0.00 0.00 0.00 0 eicore_bdn
6300 L 3 8351 0 1265 0 0.00 0.00 0.00 0 eicore_bdn
6300 L 3 8352 0 1265 0 0.00 0.00 0.00 0 eicore_bdn
6300 L 2 9049 0 1280 0 0.00 0.00 0.00 0 eicore_ipc
6301 L 570 24079 23 0.00 0.03 0.12 0 console_relay
6301 L 0 6301 490 2286 0 0.00 0.03 0.02 0 console_relay
6301 L 0 8336 30 2256 0 0.00 0.00 0.00 0 console_relay
6301 L 2 8338 0 1344 0 0.00 0.00 0.00 0 console_relay
6301 L 1 8367 10 1296 0 0.00 0.00 0.00 0 console_relay
6301 L 2 8378 10 1268 0 0.00 0.00 0.00 0 console_relay
6301 L 2 8379 10 2249 0 0.00 0.00 0.00 0 console_relay
6301 L 3 8380 0 1268 0 0.00 0.00 0.00 0 SPI default ST
6301 L 3 8387 0 1268 0 0.00 0.00 0.00 0 console_relay
6301 L 3 8388 0 1268 0 0.00 0.00 0.00 0 console_relay
6301 L 3 8389 0 1268 0 0.00 0.00 0.00 0 console_relay
6301 L 0 8390 0 2252 0 0.00 0.00 0.00 0 console_relay
6301 L 0 8391 20 2252 0 0.00 0.00 0.00 0 console_relay
6301 L 3 8392 0 1268 0 0.00 0.00 0.00 0 console_relay
6301 L 3 8393 0 1268 0 0.00 0.00 0.00 0 console_relay
6301 L 3 8394 0 1268 0 0.00 0.00 0.00 0 console_relay
6302 L 420 33005 12 0.00 0.00 0.02 0 csprovider
6302 L 3 6302 290 1276 0 0.00 0.00 0.00 0 csprovider
6302 L 0 7122 40 2253 0 0.00 0.04 0.04 0 csprovider
6302 L 0 7123 0 1344 0 0.00 0.00 0.00 0 csprovider
6302 L 1 7171 10 1286 0 0.00 0.00 0.00 0 csprovider
6302 L 3 7183 0 1261 0 0.00 0.00 0.00 0 csprovider
6302 L 1 7185 20 2236 0 0.00 0.00 0.00 0 csprovider
6302 L 3 7187 0 1261 0 0.00 0.00 0.00 0 SPI default TP
6302 L 0 7188 0 1253 0 0.00 0.00 0.00 0 SPI default TP
6302 L 0 7189 0 1253 0 0.00 0.00 0.00 0 SPI default TP
6302 L 3 7190 0 1261 0 0.00 0.00 0.00 0 SPI default TP
6302 L 3 7191 0 1261 0 0.00 0.00 0.00 0 SPI default TP
6302 L 2 7212 0 1260 0 0.00 0.00 0.00 0 eicore_bdn
6302 L 3 7213 0 1260 0 0.00 0.00 0.00 0 eicore_bdn
6302 L 3 7214 0 1260 0 0.00 0.00 0.00 0 eicore_bdn
6302 L 0 7231 0 1252 0 0.00 0.00 0.00 0 csprovider
6302 L 0 7232 0 1252 0 0.00 0.00 0.00 0 csprovider
6302 L 0 7233 0 1252 0 0.00 0.00 0.00 0 csprovider
6302 L 0 7267 30 2240 0 0.00 0.00 0.03 0 csprovider
6302 L 0 7282 20 2241 0 0.00 0.00 0.00 0 csprovider
6302 L 3 7284 0 1255 0 0.00 0.00 0.00 0 csprovider
6302 L 3 7285 0 1255 0 0.00 0.00 0.00 0 csprovider
6302 L 3 7287 0 1255 0 0.00 0.00 0.00 0 csprovider
6302 L 3 9036 10 1278 0 0.00 0.00 0.00 0 eicore_ipc
6303 L 450 33009 13 0.00 0.01 0.04 0 system_mgr_cli
6303 L 1 6303 340 1278 0 0.00 0.00 0.00 0 system_mgr_cli
6303 L 0 7151 10 2256 0 0.00 0.01 0.03 0 system_mgr_cli
6303 L 0 7155 0 1347 0 0.00 0.00 0.00 0 system_mgr_cli
6303 L 3 7339 30 1284 0 0.00 0.00 0.00 0 system_mgr_cli
6303 L 1 7362 0 1252 0 0.00 0.00 0.00 0 system_mgr_cli
6303 L 1 7363 0 1252 0 0.00 0.00 0.00 0 system_mgr_cli
6303 L 1 7364 0 1252 0 0.00 0.00 0.00 0 system_mgr_cli
6303 L 1 7388 0 2238 0 0.00 0.00 0.00 0 system_mgr_cli
6303 L 1 7389 30 2238 0 0.00 0.00 0.00 0 system_mgr_cli
6303 L 0 7390 0 1252 0 0.00 0.00 0.00 0 system_mgr_cli
6303 L 0 7391 0 1252 0 0.00 0.00 0.00 0 system_mgr_cli
6303 L 0 7392 0 1252 0 0.00 0.00 0.00 0 system_mgr_cli
6303 L 1 7393 10 1263 0 0.00 0.00 0.00 0 system_mgr_cli
6303 L 0 7394 10 2239 0 0.00 0.03 0.04 0 system_mgr_cli
6303 L 2 7396 0 1256 0 0.00 0.00 0.00 0 SPI default TP
6303 L 2 7397 0 1258 0 0.00 0.00 0.00 0 SPI default TP
6303 L 2 7398 0 1264 0 0.00 0.00 0.00 0 SPI default TP
6303 L 2 7399 0 1264 0 0.00 0.00 0.00 0 SPI default TP
6303 L 2 7400 20 1264 0 0.00 0.00 0.00 0 SPI default TP
6303 L 1 7429 0 1259 0 0.00 0.00 0.00 0 eicore_bdn
6303 L 1 7430 0 1259 0 0.00 0.00 0.00 0 eicore_bdn
6303 L 1 7431 0 1259 0 0.00 0.00 0.00 0 eicore_bdn
6303 L 2 9057 0 1271 0 0.00 0.00 0.00 0 eicore_ipc
6304 L 620 39730 15 0.00 0.04 0.00 0 plogd
6304 L 0 6304 550 5344 0 0.00 0.04 0.01 0 plogd
6304 L 0 7413 30 2255 0 0.00 0.00 0.00 0 plogd
6304 L 0 7432 0 1344 0 0.00 0.00 0.00 0 plogd
6304 L 1 7546 10 1311 0 0.00 0.00 0.00 0 plogd
6304 L 3 7549 0 1269 0 0.00 0.00 0.00 0 plogd
6304 L 0 7550 10 2237 0 0.00 0.00 0.00 0 plogd
6304 L 3 7561 0 1250 0 0.00 0.00 0.00 0 plogd
6304 L 3 7562 0 1250 0 0.00 0.00 0.00 0 plogd
6304 L 3 7563 0 1250 0 0.00 0.00 0.00 0 plogd
6304 L 0 7564 0 2236 0 0.00 0.00 0.00 0 plogd
6304 L 0 7565 10 2236 0 0.00 0.00 0.00 0 plogd
6304 L 3 7566 0 1250 0 0.00 0.00 0.00 0 plogd
6304 L 3 7567 0 1250 0 0.00 0.00 0.00 0 plogd
6304 L 3 7568 0 1250 0 0.00 0.00 0.00 0 plogd
6304 L 2 7571 10 1281 0 0.00 0.00 0.00 0 SPI default TP
6304 L 2 7572 0 1268 0 0.00 0.00 0.00 0 SPI default TP
6304 L 2 7573 0 1267 0 0.00 0.00 0.00 0 SPI default TP
6304 L 0 7574 0 1256 0 0.00 0.00 0.00 0 SPI default TP
6304 L 0 7575 0 1255 0 0.00 0.00 0.00 0 SPI default TP
6304 L 2 7594 0 1270 0 0.00 0.00 0.00 0 eicore_bdn
6304 L 2 7595 0 1270 0 0.00 0.00 0.00 0 eicore_bdn
6304 L 2 7596 0 1270 0 0.00 0.00 0.00 0 eicore_bdn
6304 L 3 9092 0 1287 0 0.00 0.00 0.00 0 eicore_ipc
6304 L 0 9222 0 1271 0 0.00 0.00 0.00 0 SPI default ST
6304 L 0 9492 0 1303 0 0.00 0.00 0.00 0 eicore_ipc
6305 L 380 32972 11 0.00 0.01 0.00 0 psdprov
6305 L 2 6305 290 1269 0 0.00 0.00 0.00 0 psdprov
6305 L 0 7158 10 2255 0 0.00 0.00 0.00 0 psdprov
6305 L 0 7173 0 1345 0 0.00 0.00 0.00 0 psdprov
6305 L 3 7387 20 1282 0 0.00 0.00 0.00 0 psdprov
6305 L 3 7395 10 1265 0 0.00 0.00 0.00 0 psdprov
6305 L 1 7423 10 2238 0 0.00 0.00 0.00 0 psdprov
6305 L 2 7438 0 1252 0 0.00 0.00 0.00 0 SPI default TP
6305 L 2 7439 0 1257 0 0.00 0.00 0.00 0 SPI default TP
6305 L 3 7440 0 1264 0 0.00 0.00 0.00 0 SPI default TP
6305 L 2 7441 0 1264 0 0.00 0.00 0.00 0 SPI default TP
6305 L 1 7442 0 1264 0 0.00 0.00 0.00 0 SPI default TP
6305 L 2 7466 0 1259 0 0.00 0.00 0.00 0 eicore_bdn
6305 L 2 7467 0 1259 0 0.00 0.00 0.00 0 eicore_bdn
6305 L 2 7468 0 1259 0 0.00 0.00 0.00 0 eicore_bdn
6305 L 0 7478 0 1249 0 0.00 0.00 0.00 0 psdprov
6305 L 0 7480 0 1249 0 0.00 0.00 0.00 0 psdprov
6305 L 0 7481 0 1249 0 0.00 0.00 0.00 0 psdprov
6305 L 0 7482 20 2235 0 0.00 0.00 0.00 0 psdprov
6305 L 2 7483 10 2235 0 0.00 0.01 0.03 0 psdprov
6305 L 0 7484 0 1249 0 0.00 0.00 0.00 0 psdprov
6305 L 0 7485 0 1249 0 0.00 0.00 0.00 0 psdprov
6305 L 0 7486 0 1249 0 0.00 0.00 0.00 0 psdprov
6305 L 3 9086 10 1276 0 0.00 0.00 0.00 0 eicore_ipc
6306 L 830 64676 12 0.00 0.04 0.02 0 pdsd
6306 L 1 6306 230 1274 0 0.00 0.00 0.00 0 pdsd
6306 L 0 7198 30 2258 0 0.00 0.04 0.04 0 pdsd
6306 L 0 7200 0 1344 0 0.00 0.00 0.00 0 pdsd
6306 L 0 7241 0 2258 0 0.00 0.00 0.00 0 pdslib thread
6306 L 3 7499 10 1288 0 0.00 0.00 0.00 0 pdsd
6306 L 1 7501 0 1265 0 0.00 0.00 0.00 0 pdsd
6306 L 3 7502 0 2240 0 0.00 0.00 0.00 0 pdsd
6306 L 3 7503 0 1257 0 0.00 0.00 0.00 0 SPI default TP
6306 L 3 7504 0 1257 0 0.00 0.00 0.00 0 SPI default TP
6306 L 1 7505 0 1265 0 0.00 0.00 0.00 0 SPI default TP
6306 L 1 7506 0 1265 0 0.00 0.00 0.00 0 SPI default TP
6306 L 1 7507 0 1265 0 0.00 0.00 0.00 0 SPI default TP
6306 L 0 7511 0 1260 0 0.00 0.00 0.00 0 eicore_bdn
6306 L 0 7512 0 1260 0 0.00 0.00 0.00 0 eicore_bdn
6306 L 0 7513 0 1260 0 0.00 0.00 0.00 0 eicore_bdn
6306 L 0 7532 0 1254 0 0.00 0.00 0.00 0 pdsd
6306 L 0 7533 0 1254 0 0.00 0.00 0.00 0 pdsd
6306 L 2 7534 0 1254 0 0.00 0.00 0.00 0 pdsd
6306 L 0 7535 10 2240 0 0.00 0.00 0.00 0 pdsd
6306 L 0 7536 10 2240 0 0.00 0.00 0.00 0 pdsd
6306 L 1 7537 0 1254 0 0.00 0.00 0.00 0 pdsd
6306 L 1 7538 0 1254 0 0.00 0.00 0.00 0 pdsd
6306 L 1 7539 0 1254 0 0.00 0.00 0.00 0 pdsd
6306 L 1 9104 0 1274 0 0.00 0.00 0.00 0 eicore_ipc
6306 L 0 9191 190 1771 0 0.00 0.00 0.04 0 pdsd
6306 L 2 9192 210 6466 0 0.00 0.00 0.00 0 pdsd
6306 L 0 9193 140 21145 0 0.00 0.04 0.01 0 pdsd
6307 L 850 30894 27 0.00 0.01 0.06 0 gold_slave
6307 L 1 6307 680 1297 0 0.00 0.00 0.00 0 gold_slave
6307 L 3 8037 10 2252 0 0.00 0.00 0.00 0 gold_slave
6307 L 0 8043 30 1308 0 0.00 0.00 0.00 0 gold_slave
6307 L 2 8057 10 1304 0 0.00 0.00 0.00 0 gold_slave
6307 L 1 8058 20 2237 0 0.00 0.00 0.00 0 gold_slave
6307 L 3 8059 0 1250 0 0.00 0.00 0.00 0 SPI default TP
6307 L 2 8060 0 1293 0 0.00 0.00 0.00 0 SPI default TP
6307 L 0 8061 0 1300 0 0.00 0.00 0.00 0 SPI default TP
6307 L 3 8062 0 1304 0 0.00 0.00 0.00 0 SPI default TP
6307 L 1 8063 10 1324 0 0.00 0.00 0.00 0 SPI default TP
6307 L 1 8085 0 1252 0 0.00 0.00 0.00 0 gold_slave
6307 L 1 8086 0 1252 0 0.00 0.00 0.00 0 gold_slave
6307 L 1 8087 0 1252 0 0.00 0.00 0.00 0 gold_slave
6307 L 0 8088 30 2236 0 0.00 0.00 0.00 0 gold_slave
6307 L 0 8089 20 2236 0 0.00 0.00 0.01 0 gold_slave
6307 L 1 8090 0 1252 0 0.00 0.00 0.00 0 gold_slave
6307 L 1 8097 0 1252 0 0.00 0.00 0.00 0 gold_slave
6307 L 1 8100 0 1252 0 0.00 0.00 0.00 0 gold_slave
6307 L 0 8172 10 1380 0 0.00 0.00 0.02 0 gold_slave
6307 L 2 8175 0 1300 0 0.00 0.00 0.00 0 SPI default ST
6307 L 3 8198 30 1361 0 0.00 0.01 0.04 0 DiagCard1/-1
6308 L 540 35142 15 0.00 0.18 0.32 0 osinfo-provider
6308 L 2 6308 250 1311 0 0.00 0.00 0.00 0 osinfo-provider
6308 L 0 7494 80 2720 0 0.00 0.02 0.04 0 os_info_p
6308 L 0 7514 20 1352 0 0.00 0.00 0.00 0 os_info_p
6308 L 2 7676 10 1304 0 0.00 0.00 0.00 0 osinfo-provider
6308 L 3 7677 0 1287 0 0.00 0.02 0.04 0 osinfo-provider
6308 L 1 7679 10 2248 0 0.00 0.00 0.00 0 osinfo-provider
6308 L 2 7681 0 1266 0 0.00 0.00 0.00 0 SPI default TP
6308 L 2 7682 0 1271 0 0.00 0.00 0.00 0 SPI default TP
6308 L 3 7683 0 1279 0 0.00 0.00 0.00 0 SPI default TP
6308 L 0 7684 10 1289 0 0.00 0.00 0.00 0 SPI default TP
6308 L 2 7685 0 1280 0 0.00 0.00 0.00 0 SPI default TP
6308 L 1 7700 0 1262 0 0.00 0.00 0.00 0 osinfo-provider
6308 L 1 7701 0 1262 0 0.00 0.00 0.00 0 osinfo-provider
6308 L 1 7702 0 1262 0 0.00 0.00 0.00 0 osinfo-provider
6308 L 0 7703 0 2247 0 0.00 0.00 0.00 0 osinfo-provider
6308 L 0 7704 10 2247 0 0.00 0.00 0.00 0 osinfo-provider
6308 L 1 7705 0 1262 0 0.00 0.00 0.00 0 osinfo-provider
6308 L 1 7706 0 1262 0 0.00 0.00 0.00 0 osinfo-provider
6308 L 1 7707 0 1262 0 0.00 0.00 0.00 0 osinfo-provider
6308 L 0 7717 0 1269 0 0.00 0.00 0.00 0 eicore_bdn
6308 L 0 7718 0 1269 0 0.00 0.00 0.00 0 eicore_bdn
6308 L 0 7719 0 1269 0 0.00 0.00 0.00 0 eicore_bdn
6308 L 1 9033 150 1371 0 0.00 0.13 0.24 0 eicore_ipc
6308 L 0 10339 0 1291 0 0.00 0.00 0.00 0 SPI default ST
6309 L 250 33027 7 0.00 0.01 0.03 0 oscore_p
6309 L 0 6309 170 1270 0 0.00 0.00 0.00 0 oscore_p
6309 L 0 7142 30 2260 0 0.00 0.01 0.03 0 oscore_p
6309 L 0 7159 0 1346 0 0.00 0.00 0.00 0 oscore_p
6309 L 3 7329 20 1294 0 0.00 0.00 0.00 0 oscore_p
6309 L 2 7345 0 1262 0 0.00 0.00 0.00 0 oscore_p
6309 L 1 7348 0 2241 0 0.00 0.00 0.00 0 oscore_p
6309 L 3 7350 0 1253 0 0.00 0.00 0.00 0 SPI default TP
6309 L 3 7351 0 1253 0 0.00 0.00 0.00 0 SPI default TP
6309 L 2 7352 0 1261 0 0.00 0.00 0.00 0 SPI default TP
6309 L 2 7353 0 1261 0 0.00 0.00 0.00 0 SPI default TP
6309 L 2 7354 0 1261 0 0.00 0.00 0.00 0 SPI default TP
6309 L 3 7382 0 1256 0 0.00 0.00 0.00 0 eicore_bdn
6309 L 3 7383 0 1256 0 0.00 0.00 0.00 0 eicore_bdn
6309 L 3 7384 0 1256 0 0.00 0.00 0.00 0 eicore_bdn
6309 L 3 7414 0 1258 0 0.00 0.00 0.00 0 oscore_p
6309 L 3 7415 0 1258 0 0.00 0.00 0.00 0 oscore_p
6309 L 3 7416 0 1258 0 0.00 0.00 0.00 0 oscore_p
6309 L 2 7417 20 2249 0 0.00 0.00 0.03 0 oscore_p
6309 L 0 7418 10 2249 0 0.00 0.00 0.00 0 oscore_p
6309 L 3 7419 0 1258 0 0.00 0.00 0.00 0 oscore_p
6309 L 3 7420 0 1258 0 0.00 0.00 0.00 0 oscore_p
6309 L 3 7421 0 1258 0 0.00 0.00 0.00 0 oscore_p
6309 L 2 9101 0 1272 0 0.00 0.00 0.00 0 eicore_ipc
6310 L 290 31814 9 0.00 0.00 0.22 0 netd
6310 L 3 6310 140 1270 0 0.00 0.00 0.21 0 netd
6310 L 1 7220 0 2259 0 0.00 0.00 0.00 0 netd
6310 L 0 7310 30 1292 0 0.00 0.00 0.00 0 netd
6310 L 2 7332 20 1303 0 0.00 0.00 0.00 0 netd
6310 L 1 7333 30 2239 0 0.00 0.00 0.00 0 netd
6310 L 0 7334 0 1252 0 0.00 0.00 0.00 0 SPI default TP
6310 L 0 7335 0 1253 0 0.00 0.00 0.00 0 SPI default TP
6310 L 0 7336 0 1256 0 0.00 0.00 0.00 0 SPI default TP
6310 L 0 7337 0 1256 0 0.00 0.00 0.00 0 SPI default TP
6310 L 0 7338 10 1262 0 0.00 0.00 0.00 0 SPI default TP
6310 L 1 7366 0 1250 0 0.00 0.00 0.00 0 netd
6310 L 1 7368 0 1250 0 0.00 0.00 0.00 0 netd
6310 L 1 7369 0 1250 0 0.00 0.00 0.00 0 netd
6310 L 0 7370 0 2241 0 0.00 0.00 0.00 0 netd
6310 L 1 7371 30 2241 0 0.00 0.00 0.00 0 netd
6310 L 1 7372 0 1250 0 0.00 0.00 0.00 0 netd
6310 L 1 7374 0 1250 0 0.00 0.00 0.00 0 netd
6310 L 1 7375 0 1250 0 0.00 0.00 0.00 0 netd
6310 L 1 7409 10 1356 0 0.00 0.00 0.00 0 netd
6310 L 3 7410 0 1263 0 0.00 0.00 0.00 0 OIR xdm
6310 L 0 7411 0 1294 0 0.00 0.00 0.00 0 SPI default ST
6310 L 0 7452 20 1298 0 0.00 0.00 0.02 0 netd
6311 L 970 33369 29 0.05 0.01 0.02 0 mem_mgmt
6311 L 3 6311 860 2331 0 0.00 0.02 0.04 0 mem_mgmt
6311 L 1 7807 40 2274 0 0.00 0.01 0.03 0 mem_mgmt
6311 L 3 8034 10 1320 0 0.00 0.00 0.00 0 mem_mgmt
6311 L 3 8044 0 1287 0 0.00 0.00 0.00 0 mem_mgmt
6311 L 0 8045 20 2272 0 0.00 0.00 0.00 0 mem_mgmt
6311 L 3 8064 0 1283 0 0.00 0.00 0.00 0 SPI default TP
6311 L 3 8065 0 1284 0 0.00 0.00 0.00 0 SPI default TP
6311 L 3 8066 0 1287 0 0.00 0.00 0.00 0 SPI default TP
6311 L 3 8067 0 1287 0 0.00 0.00 0.00 0 SPI default TP
6311 L 3 8068 10 1287 0 0.00 0.00 0.00 0 SPI default TP
6311 L 3 8069 0 1285 0 0.00 0.00 0.00 0 mem_mgmt
6311 L 3 8070 0 1285 0 0.00 0.00 0.00 0 mem_mgmt
6311 L 3 8071 0 1285 0 0.00 0.00 0.00 0 mem_mgmt
6311 L 0 8072 0 2274 0 0.00 0.00 0.00 0 mem_mgmt
6311 L 0 8073 30 2274 0 0.00 0.00 0.00 0 mem_mgmt
6311 L 2 8074 0 1285 0 0.00 0.00 0.00 0 mem_mgmt
6311 L 2 8075 0 1285 0 0.00 0.00 0.00 0 mem_mgmt
6311 L 2 8076 0 1285 0 0.00 0.00 0.00 0 mem_mgmt
6311 L 1 8125 0 1303 0 0.00 0.00 0.00 0 eicore_bdn
6311 L 1 8126 0 1303 0 0.00 0.00 0.00 0 eicore_bdn
6311 L 1 8127 0 1303 0 0.00 0.00 0.00 0 eicore_bdn
6311 L 2 9044 0 1313 0 0.00 0.00 0.00 0 eicore_ipc
6312 L 320 25097 12 0.00 0.01 0.13 0 mgmte_tap
6312 L 0 6312 210 1256 0 0.00 0.00 0.00 0 mgmte_tap
6312 L 0 8395 10 2256 0 0.00 0.00 0.00 0 mgmte_tap
6312 L 3 8397 0 1345 0 0.00 0.00 0.00 0 mgmte_tap
6312 L 0 8399 20 2256 0 0.00 0.00 0.02 0 pdslib thread
6312 L 0 8404 20 1282 0 0.00 0.00 0.00 0 mgmte_tap
6312 L 3 8409 20 1254 0 0.00 0.00 0.00 0 mgmte_tap
6312 L 1 8410 0 2234 0 0.00 0.00 0.00 0 mgmte_tap
6312 L 1 8411 0 1254 0 0.00 0.00 0.00 0 SPI default ST
6312 L 2 8416 0 1251 0 0.00 0.00 0.00 0 mgmte_tap
6312 L 2 8417 0 1251 0 0.00 0.00 0.00 0 mgmte_tap
6312 L 2 8418 0 1251 0 0.00 0.00 0.00 0 mgmte_tap
6312 L 3 8419 0 2240 0 0.00 0.00 0.00 0 mgmte_tap
6312 L 0 8420 40 2240 0 0.00 0.04 0.04 0 mgmte_tap
6312 L 2 8421 0 1251 0 0.00 0.00 0.00 0 mgmte_tap
6312 L 2 8422 0 1251 0 0.00 0.00 0.00 0 mgmte_tap
6312 L 2 8423 0 1251 0 0.00 0.00 0.00 0 mgmte_tap
6313 L 810 58538 13 0.00 0.00 0.94 0 installer
6313 L 2 6313 620 1347 0 1.72 1.72 0.04 0 installer
6313 L 0 8836 50 2252 0 0.00 0.00 0.02 0 installer
6313 L 3 8837 20 1332 0 0.00 0.00 0.00 0 installer
6313 L 1 8838 0 1322 0 0.00 0.00 0.00 0 installer
6313 L 1 8839 0 1252 0 0.00 0.00 0.00 0 installer
6313 L 1 8840 0 1253 0 0.00 0.00 0.00 0 installer
6313 L 1 8841 0 1253 0 0.00 0.00 0.00 0 installer
6313 L 0 8842 10 2238 0 0.00 0.00 0.00 0 installer
6313 L 0 8843 40 2238 0 0.00 0.00 0.00 0 installer
6313 L 1 8844 0 1255 0 0.00 0.00 0.00 0 installer
6313 L 2 8845 0 1256 0 0.00 0.00 0.00 0 installer
6313 L 2 8846 0 1256 0 0.00 0.00 0.00 0 installer
6313 L 0 8847 20 2245 0 0.00 0.00 0.00 0 installer
6313 L 1 8848 0 1309 0 0.00 0.00 0.00 0 SPI default TP
6313 L 1 8849 10 1341 0 0.00 0.00 0.00 0 SPI default TP
6313 L 2 8850 10 1334 0 0.05 0.05 0.05 0 SPI default TP
6313 L 1 8851 0 1328 0 0.00 0.00 0.00 0 SPI default TP
6313 L 0 8852 0 1266 0 0.00 0.00 0.00 0 SPI default TP
6313 L 0 8853 10 1371 0 0.00 0.00 0.00 0 installer
6313 L 2 8855 0 1282 0 0.00 0.00 0.00 0 installer
6313 L 2 8856 0 1282 0 0.00 0.00 0.00 0 installer
6313 L 2 8858 10 1289 0 0.00 0.00 0.00 0 SPI default ST
6313 L 2 8859 0 1291 0 0.00 0.00 0.00 0 OIR Client XDM
6313 L 1 8861 0 1294 0 0.00 0.00 0.00 0 eicore_bdn
6313 L 1 8862 0 1294 0 0.00 0.00 0.00 0 eicore_bdn
6313 L 1 8863 0 1293 0 0.00 0.00 0.00 0 eicore_bdn
6313 L 0 9063 10 1326 0 0.00 0.00 0.00 0 eicore_ipc
6313 L 2 9200 0 1308 0 0.00 0.00 0.00 0 Installer Provi
6313 L 2 9201 0 1308 0 0.00 0.00 0.00 0 Installer Provi
6313 L 2 9202 0 1308 0 0.00 0.00 0.00 0 Installer Provi
6313 L 2 9203 0 1308 0 0.00 0.00 0.00 0 Result Synthesi
6313 L 2 9204 0 1308 0 0.00 0.00 0.00 0 Result Synthesi
6313 L 2 9205 0 1308 0 0.00 0.00 0.00 0 Result Synthesi
6313 L 0 9826 0 1318 0 0.00 0.00 0.00 0 HALib Dispatch
6313 L 2 9827 0 1318 0 0.00 0.00 0.00 0 HALib Dispatch
6313 L 2 9828 0 1317 0 0.00 0.00 0.00 0 HALib Dispatch
6313 L 2 9831 10 1356 0 0.00 0.00 0.00 0 RF Slave Main T
6313 L 0 9832 0 1333 0 0.00 0.00 0.00 0 INSTALLER SERVI
6313 L 1 9834 0 1335 0 0.05 0.05 0.05 0 INSTALLER SERVI
6313 L 0 9895 0 1319 0 0.00 0.00 0.00 0 HALib Dispatch
6313 L 0 10224 0 1332 0 0.00 0.00 0.00 0 INSTALLER SERVI
6313 L 1 10225 0 1334 0 0.00 0.00 0.00 0 INSTALLER SERVI
6314 L 8440 49745 169 0.00 0.03 0.68 0 ffm
6314 L 0 6314 8160 2833 0 0.00 0.02 0.05 0 ffm
6314 L 2 8891 20 2336 0 0.00 0.00 0.00 0 ffm
6314 L 1 8898 10 1430 0 0.00 0.00 0.00 0 ffm
6314 L 1 8917 40 1561 0 0.00 0.00 0.00 0 ffm
6314 L 3 8922 0 1463 0 0.00 0.00 0.00 0 ffm
6314 L 3 8923 0 1463 0 0.00 0.00 0.00 0 ffm
6314 L 2 8924 0 1463 0 0.00 0.00 0.00 0 ffm
6314 L 0 8925 20 2445 0 0.00 0.00 0.00 0 ffm
6314 L 3 8926 10 2445 0 0.00 0.00 0.00 0 ffm
6314 L 1 8927 0 1463 0 0.00 0.00 0.00 0 ffm
6314 L 1 8928 0 1463 0 0.00 0.00 0.00 0 ffm
6314 L 1 8929 0 1463 0 0.00 0.00 0.00 0 ffm
6314 L 0 8932 0 1797 0 0.00 0.00 0.00 0 ffm
6314 L 0 8933 40 2448 0 0.00 0.02 0.04 0 ffm
6314 L 0 8936 0 1470 0 0.00 0.00 0.00 0 SPI default TP
6314 L 0 8937 0 1477 0 0.00 0.00 0.00 0 SPI default TP
6314 L 0 8938 0 1486 0 0.00 0.00 0.00 0 SPI default TP
6314 L 0 8939 0 1488 0 0.00 0.00 0.00 0 SPI default TP
6314 L 0 8940 0 1486 0 0.00 0.00 0.00 0 SPI default TP
6314 L 3 9001 0 1481 0 0.00 0.00 0.00 0 eicore_bdn
6314 L 3 9002 0 1481 0 0.00 0.00 0.00 0 eicore_bdn
6314 L 3 9003 0 1481 0 0.00 0.00 0.00 0 eicore_bdn
6314 L 0 9067 0 1498 0 0.00 0.00 0.00 0 eicore_ipc
6314 L 2 9083 30 1791 0 0.00 0.00 0.00 0 SPI default ST
6314 L 2 9159 0 1535 0 0.00 0.00 0.00 0 ffm
6314 L 2 9806 30 2010 0 0.00 0.00 0.00 0 ffm_reply aggre
6314 L 1 9807 0 1628 0 0.00 0.00 0.00 0 ffm
6314 L 1 9809 0 1636 0 0.00 0.00 0.00 0 ffm
6314 L 3 9878 90 1754 0 0.00 0.00 0.00 0 ffm
6315 L 25070 108023 232 0.28 0.29 0.70 0 eicored
6315 L 3 6315 11500 1580 0 0.00 0.00 0.85 0 eicored
6315 L 1 8318 400 2824 0 0.24 0.24 0.24 0 eicored
6315 L 0 8329 0 1358 0 0.00 0.00 0.00 0 eicored
6315 L 3 8442 30 1444 0 0.00 0.00 0.00 0 eicored
6315 L 2 8443 710 4267 0 0.14 0.05 0.05 0 eicored
6315 L 0 8444 0 2274 0 0.00 0.00 0.00 0 eicored
6315 L 0 8446 160 4100 0 0.00 0.00 0.00 0 SPI default TP
6315 L 3 8447 0 1346 0 0.00 0.00 0.00 0 SPI default TP
6315 L 3 8448 330 4242 0 0.05 0.05 0.05 0 SPI default TP
6315 L 1 8449 440 4520 0 0.14 0.14 0.03 0 SPI default TP
6315 L 2 8450 430 4488 0 0.48 0.06 0.05 0 SPI default TP
6315 L 1 8452 0 1294 0 0.00 0.00 0.00 0 eicored
6315 L 2 8453 0 1294 0 0.00 0.00 0.00 0 eicored
6315 L 1 8454 0 1294 0 0.00 0.00 0.00 0 eicored
6315 L 0 8455 40 2282 0 0.00 0.00 0.00 0 eicored
6315 L 0 8456 30 2282 0 0.00 0.00 0.00 0 eicored
6315 L 1 8457 0 1294 0 0.00 0.00 0.00 0 eicored
6315 L 1 8458 0 1294 0 0.00 0.00 0.00 0 eicored
6315 L 1 8459 0 1294 0 0.00 0.00 0.00 0 eicored
6315 L 3 8474 0 1312 0 0.00 0.00 0.00 0 eicore xdm
6315 L 3 8475 1670 1847 0 0.00 0.00 0.11 0 eicore push xdm
6315 L 3 8477 0 1319 0 0.00 0.00 0.00 0 eicore_bdn
6315 L 2 8478 0 1329 0 0.00 0.00 0.00 0 eicore_bdn
6315 L 2 8479 10 1339 0 0.00 0.00 0.00 0 eicore_bdn
6315 L 0 9031 0 1469 0 0.00 0.00 0.00 0 eicored
6315 L 3 9072 0 1341 0 0.00 0.00 0.00 0 eicore_bdn
6315 L 2 9073 0 1336 0 0.00 0.00 0.00 0 eicore_bdn
6315 L 2 9074 2500 4813 0 8.63 0.95 0.59 0 eicore_ipc
6315 L 1 9075 0 1513 0 0.00 0.00 0.00 0 eicore_ipc
6315 L 3 9077 0 1618 0 0.00 0.00 0.00 0 eicore_ipc
6315 L 2 9078 70 1572 0 0.00 0.00 0.00 0 eicore_ipc
6315 L 3 9079 30 1612 0 0.00 0.00 0.00 0 eicore_ipc
6315 L 1 9080 0 1318 0 0.00 0.00 0.00 0 eicore_bdn
6315 L 0 9103 0 1319 0 0.00 0.00 0.00 0 eicore_bdn
6315 L 2 9108 0 1318 0 0.00 0.00 0.00 0 eicore_bdn
6315 L 3 9109 10 1496 0 0.00 0.00 0.00 0 eicore em shim
6315 L 3 9114 0 1501 0 0.00 0.00 0.00 0 SPI default ST
6315 L 3 9127 8140 3959 0 0.00 0.00 0.06 0 eicore_ipc
6315 L 2 9130 140 4437 0 0.00 0.00 0.00 0 eicore_ipc
6315 L 2 9134 0 1522 0 0.00 0.00 0.00 0 eicore_ipc
6315 L 1 9135 0 1524 0 0.00 0.00 0.00 0 eicore_ipc
6315 L 2 9136 0 1554 0 0.00 0.00 0.00 0 eicore_ipc
6315 L 3 9145 360 5089 0 0.00 0.00 0.00 0 eicore_ipc
6315 L 0 9146 0 1309 0 0.00 0.00 0.00 0 eicore push xdm
6315 L 1 9150 0 1509 0 0.00 0.00 0.00 0 eicore_ipc
6315 L 1 9153 0 1509 0 0.00 0.00 0.00 0 eicore_ipc
6315 L 3 9155 0 1509 0 0.00 0.00 0.00 0 eicore_ipc
6315 L 2 9194 0 1560 0 0.00 0.00 0.00 0 EICORE_HA_PROG
6315 L 0 9207 0 1562 0 0.00 0.00 0.00 0 HALib Dispatch
6315 L 0 9208 0 1562 0 0.00 0.00 0.00 0 HALib Dispatch
6315 L 0 9209 0 1564 0 0.00 0.00 0.00 0 HALib Dispatch
6315 L 2 9217 20 1689 0 0.00 0.00 0.00 0 RF Slave Main T
6315 L 2 9220 0 1575 0 0.00 0.00 0.00 0 eicore iosd xd
6315 L 3 9500 0 1581 0 0.00 0.00 0.00 0 eicore_ipc
6315 L 0 9896 0 1562 0 0.00 0.00 0.00 0 HALib Dispatch
6316 L 720 37868 19 0.00 0.02 0.01 0 dtmgr
6316 L 3 6316 220 1287 0 0.00 0.00 0.00 0 dtmgr
6316 L 0 7103 70 2264 0 0.00 0.00 0.00 0 dtmgr
6316 L 1 7108 0 1346 0 0.00 0.00 0.00 0 dtmgr
6316 L 3 7222 10 1328 0 0.00 0.00 0.00 0 dtmgr
6316 L 1 7238 100 1852 0 0.00 0.00 0.00 0 dtmgr
6316 L 2 7240 20 2253 0 0.00 0.00 0.00 0 dtmgr
6316 L 2 7242 80 1614 0 0.00 0.00 0.00 0 SPI default TP
6316 L 1 7243 50 1563 0 0.00 0.00 0.00 0 SPI default TP
6316 L 2 7244 40 1593 0 0.00 0.00 0.00 0 SPI default TP
6316 L 1 7245 30 1468 0 0.00 0.00 0.00 0 SPI default TP
6316 L 2 7246 40 1505 0 0.00 0.00 0.00 0 SPI default TP
6316 L 3 7259 0 1268 0 0.00 0.00 0.00 0 dtmgr
6316 L 3 7260 0 1268 0 0.00 0.00 0.00 0 dtmgr
6316 L 3 7261 0 1268 0 0.00 0.00 0.00 0 dtmgr
6316 L 2 7269 10 2260 0 0.00 0.00 0.00 0 dtmgr
6316 L 0 7270 10 2260 0 0.00 0.00 0.00 0 dtmgr
6316 L 0 7271 0 1269 0 0.00 0.00 0.00 0 dtmgr
6316 L 0 7272 0 1269 0 0.00 0.00 0.00 0 dtmgr
6316 L 0 7273 0 1269 0 0.00 0.00 0.00 0 dtmgr
6316 L 2 7306 0 1268 0 0.00 0.00 0.00 0 eicore_bdn
6316 L 2 7307 0 1268 0 0.00 0.00 0.00 0 eicore_bdn
6316 L 2 7308 0 1268 0 0.00 0.00 0.00 0 eicore_bdn
6316 L 3 9084 0 1281 0 0.00 0.00 0.00 0 eicore_ipc
6316 L 0 9157 40 1316 0 0.00 0.02 0.04 0 dtmgr
6316 L 3 9158 0 1283 0 0.00 0.00 0.00 0 dtmgr
6317 L 5030 33974 148 0.14 0.12 0.10 0 cpumemd
6317 L 1 6317 4970 2262 0 0.09 0.11 0.09 0 cpumemd
6317 L 1 7199 30 2260 0 0.00 0.00 0.00 0 cpumemd
6317 L 2 7201 0 1346 0 0.00 0.00 0.00 0 cpumemd
6317 L 0 7219 10 1287 0 0.00 0.00 0.00 0 cpumemd
6317 L 3 7221 0 1258 0 0.00 0.00 0.00 0 cpumemd
6317 L 1 7239 30 2248 0 0.00 0.00 0.00 0 cpumemd
6317 L 3 7249 0 1259 0 0.00 0.00 0.00 0 SPI default TP
6317 L 3 7250 0 1259 0 0.00 0.00 0.00 0 SPI default TP
6317 L 0 7251 0 1260 0 0.00 0.00 0.00 0 SPI default TP
6317 L 0 7252 0 1260 0 0.00 0.00 0.00 0 SPI default TP
6317 L 0 7253 0 1260 0 0.00 0.00 0.00 0 SPI default TP
6317 L 0 7262 0 1255 0 0.00 0.00 0.00 0 cpumemd
6317 L 0 7263 0 1256 0 0.00 0.00 0.00 0 cpumemd
6317 L 0 7264 0 1255 0 0.00 0.00 0.00 0 cpumemd
6317 L 1 7314 0 2251 0 0.00 0.00 0.00 0 cpumemd
6317 L 0 7315 10 2251 0 0.00 0.00 0.00 0 cpumemd
6317 L 1 7316 0 1260 0 0.00 0.00 0.00 0 cpumemd
6317 L 1 7317 0 1260 0 0.00 0.00 0.00 0 cpumemd
6317 L 1 7318 0 1260 0 0.00 0.00 0.00 0 cpumemd
6317 L 0 7603 0 1248 0 0.00 0.00 0.00 0 eicore_bdn
6317 L 0 7604 0 1248 0 0.00 0.00 0.00 0 eicore_bdn
6317 L 0 7605 0 1248 0 0.00 0.00 0.00 0 eicore_bdn
6317 L 0 7607 0 1249 0 0.00 0.00 0.00 0 SPI default ST
6323 L 460 25164 18 0.00 0.03 0.04 0 liin_tap
6323 L 3 6323 270 1298 0 0.00 0.00 0.00 0 liin_tap
6323 L 0 7100 40 2260 0 0.00 0.00 0.00 0 liin_tap
6323 L 1 7115 0 1346 0 0.00 0.00 0.00 0 liin_tap
6323 L 0 7124 60 2260 0 0.00 0.03 0.04 0 pdslib thread
6323 L 0 9780 30 1282 0 0.00 0.00 0.00 0 liin_tap
6323 L 1 9781 0 1259 0 0.00 0.00 0.00 0 liin_tap
6323 L 1 9782 10 2225 0 0.00 0.00 0.00 0 liin_tap
6323 L 1 9783 10 1259 0 0.00 0.00 0.00 0 SPI default ST
6323 L 1 9784 0 1257 0 0.00 0.00 0.00 0 liin_tap
6323 L 1 9785 0 1257 0 0.00 0.00 0.00 0 liin_tap
6323 L 1 9786 0 1257 0 0.00 0.00 0.00 0 liin_tap
6323 L 0 9787 20 2229 0 0.00 0.00 0.00 0 liin_tap
6323 L 0 9788 30 2229 0 0.00 0.00 0.00 0 liin_tap
6323 L 1 9789 0 1257 0 0.00 0.00 0.00 0 liin_tap
6323 L 1 9790 0 1257 0 0.00 0.00 0.00 0 liin_tap
6323 L 1 9791 0 1257 0 0.00 0.00 0.00 0 liin_tap
6337 L 3200 50519 63 1.26 1.82 0.30 0 cli_agent
6337 L 1 6337 810 1282 0 0.00 1.79 0.16 0 cli_agent
6337 L 0 7906 460 3281 0 0.00 0.04 0.00 0 cli_agent
6337 L 1 7911 0 1351 0 0.00 0.00 0.00 0 cli_agent
6337 L 2 7932 30 1301 0 0.00 0.00 0.00 0 cli_agent
6337 L 2 7933 830 3175 0 0.00 0.08 0.09 0 cli_agent
6337 L 0 7934 20 2262 0 0.00 0.00 0.00 0 cli_agent
6337 L 0 7935 0 1275 0 0.00 0.00 0.00 0 SPI default TP
6337 L 2 7936 60 3602 0 0.00 0.00 0.00 0 SPI default TP
6337 L 0 7937 360 3138 0 0.00 0.00 0.00 0 SPI default TP
6337 L 0 7938 80 3324 0 0.00 0.00 0.00 0 SPI default TP
6337 L 3 7939 220 3189 0 0.00 0.03 0.04 0 SPI default TP
6337 L 0 7946 0 1278 0 0.00 0.00 0.00 0 cli_agent
6337 L 0 7963 0 1275 0 0.00 0.00 0.00 0 cli_agent
6337 L 0 7964 0 1275 0 0.00 0.00 0.00 0 cli_agent
6337 L 0 7966 0 1275 0 0.00 0.00 0.00 0 cli_agent
6337 L 0 7967 20 2265 0 0.00 0.00 0.00 0 cli_agent
6337 L 0 7968 10 2265 0 0.00 0.00 0.00 0 cli_agent
6337 L 0 7969 0 1275 0 0.00 0.00 0.00 0 cli_agent
6337 L 0 7970 0 1275 0 0.00 0.00 0.00 0 cli_agent
6337 L 0 7971 0 1275 0 0.00 0.00 0.00 0 cli_agent
6337 L 2 8116 30 1512 0 0.00 0.00 0.00 0 cli_agent
6337 L 1 8118 60 1509 0 0.00 0.00 0.00 0 SPI default ST
6337 L 3 9973 0 1285 0 0.00 0.00 0.00 0 eicore_bdn
6337 L 3 9974 0 1285 0 0.00 0.00 0.00 0 eicore_bdn
6337 L 2 9975 0 1284 0 0.00 0.00 0.00 0 eicore_bdn
6337 L 0 10335 0 1513 0 0.00 0.00 0.00 0 cli_agent
6337 L 2 10357 270 1543 0 0.19 0.19 0.19 0 cli_agent
6339 L 7270 70679 102 0.00 0.01 0.05 0 snmp_subagent
6339 L 1 6339 6890 1826 0 0.00 0.00 0.04 0 snmp_subagent
6339 L 0 7744 40 2264 0 0.00 0.02 0.04 0 snmp_subagent
6339 L 1 7745 0 1348 0 0.00 0.00 0.00 0 snmp_subagent
6339 L 0 7980 20 1336 0 0.00 0.00 0.00 0 snmp_subagent
6339 L 3 7989 20 1786 0 0.00 0.00 0.00 0 snmp_subagent
6339 L 2 7990 20 2263 0 0.00 0.01 0.03 0 snmp_subagent
6339 L 3 7991 0 1338 0 0.00 0.00 0.00 0 SPI default TP
6339 L 0 7992 30 1676 0 0.00 0.00 0.00 0 SPI default TP
6339 L 0 7993 0 1664 0 0.00 0.00 0.00 0 SPI default TP
6339 L 1 7994 0 1291 0 0.00 0.00 0.00 0 SPI default TP
6339 L 0 7995 70 1674 0 0.00 0.00 0.00 0 SPI default TP
6339 L 2 8003 0 1291 0 0.00 0.00 0.00 0 snmp_subagent
6339 L 2 8004 0 1291 0 0.00 0.00 0.00 0 snmp_subagent
6339 L 2 8005 0 1291 0 0.00 0.00 0.00 0 snmp_subagent
6339 L 1 8006 20 2281 0 0.00 0.00 0.00 0 snmp_subagent
6339 L 3 8007 30 2281 0 0.00 0.00 0.00 0 snmp_subagent
6339 L 0 8008 0 1291 0 0.00 0.00 0.00 0 snmp_subagent
6339 L 0 8009 0 1291 0 0.00 0.00 0.00 0 snmp_subagent
6339 L 0 8010 0 1291 0 0.00 0.00 0.00 0 snmp_subagent
6339 L 3 8031 0 1341 0 0.00 0.00 0.00 0 snmp_subagent
6339 L 0 8091 0 1329 0 0.00 0.00 0.00 0 HALib Dispatch
6339 L 0 8093 0 1329 0 0.00 0.00 0.00 0 HALib Dispatch
6339 L 0 8095 0 1329 0 0.00 0.00 0.00 0 HALib Dispatch
6339 L 0 8122 90 1463 0 0.00 0.00 0.00 0 SPI default ST
6339 L 0 8135 10 1387 0 0.00 0.00 0.00 0 RF Slave Main T
6339 L 0 8225 0 1332 0 0.00 0.00 0.00 0 eicore_bdn
6339 L 0 8226 0 1332 0 0.00 0.00 0.00 0 eicore_bdn
6339 L 0 8227 0 1332 0 0.00 0.00 0.00 0 eicore_bdn
6339 L 3 9779 0 1457 0 0.00 0.00 0.00 0 eicore_ipc
6339 L 3 9793 20 1879 0 0.00 0.00 0.00 0 eicore_ipc
6339 L 1 9796 10 1823 0 0.00 0.00 0.00 0 snmp_subagent
6339 L 2 9798 0 1826 0 0.00 0.00 0.00 0 SNMP SA CACHE
6339 L 2 9799 0 1826 0 0.00 0.00 0.00 0 SNMP SA CACHE
6339 L 2 9800 0 1826 0 0.00 0.00 0.00 0 SNMP SA CACHE
6339 L 2 9801 0 1826 0 0.00 0.00 0.00 0 xos_thread
6339 L 3 10328 0 3997 0 0.00 0.00 0.00 0 COMET_SUB_AGENT
6339 L 3 10329 0 3755 0 0.00 0.00 0.00 0 COMET_SUB_AGENT
6339 L 3 10349 0 3802 0 0.00 0.00 0.00 0 COMET_SUB_AGENT
6339 L 3 10351 0 3777 0 0.00 0.00 0.00 0 COMET_SUB_AGENT
6341 L 310 34048 9 0.00 0.00 0.00 0 erm_p
6341 L 1 6341 200 2273 0 0.00 0.00 0.00 0 erm_p
6341 L 0 7172 10 2262 0 0.00 0.00 0.00 0 erm_p
6341 L 2 7174 0 1348 0 0.00 0.00 0.00 0 erm_p
6341 L 3 7386 40 1283 0 0.00 0.00 0.00 0 erm_p
6341 L 2 7437 0 1264 0 0.00 0.00 0.00 0 erm_p
6341 L 1 7446 10 2242 0 0.00 0.00 0.00 0 erm_p
6341 L 3 7447 0 1255 0 0.00 0.00 0.00 0 SPI default TP
6341 L 3 7448 0 1255 0 0.00 0.00 0.00 0 SPI default TP
6341 L 2 7449 0 1262 0 0.00 0.00 0.00 0 SPI default TP
6341 L 2 7450 0 1262 0 0.00 0.00 0.00 0 SPI default TP
6341 L 2 7451 0 1262 0 0.00 0.00 0.00 0 SPI default TP
6341 L 3 7453 0 1257 0 0.00 0.00 0.00 0 erm_p
6341 L 3 7454 0 1257 0 0.00 0.00 0.00 0 erm_p
6341 L 3 7455 0 1257 0 0.00 0.00 0.00 0 erm_p
6341 L 1 7463 20 2248 0 0.00 0.00 0.00 0 erm_p
6341 L 0 7470 30 2250 0 0.00 0.00 0.00 0 erm_p
6341 L 0 7471 0 1259 0 0.00 0.00 0.00 0 erm_p
6341 L 0 7472 0 1259 0 0.00 0.00 0.00 0 erm_p
6341 L 0 7473 0 1259 0 0.00 0.00 0.00 0 erm_p
6341 L 0 7476 0 1262 0 0.00 0.00 0.00 0 eicore_bdn
6341 L 0 7477 0 1262 0 0.00 0.00 0.00 0 eicore_bdn
6341 L 0 7479 0 1262 0 0.00 0.00 0.00 0 eicore_bdn
6341 L 2 9111 0 1274 0 0.00 0.00 0.00 0 eicore_ipc
6342 L 430 34190 12 0.00 0.00 0.16 0 ngdumper_provid
6342 L 1 6342 290 2278 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 1 8573 20 2257 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 0 8574 0 1347 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 3 8600 30 1295 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 1 8602 0 1271 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 2 8603 10 2248 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 1 8604 0 1261 0 0.00 0.00 0.00 0 SPI default TP
6342 L 1 8605 0 1261 0 0.00 0.00 0.00 0 SPI default TP
6342 L 1 8606 0 1269 0 0.00 0.00 0.00 0 SPI default TP
6342 L 1 8607 0 1269 0 0.00 0.00 0.00 0 SPI default TP
6342 L 1 8608 10 1269 0 0.00 0.00 0.00 0 SPI default TP
6342 L 1 8610 0 1264 0 0.00 0.00 0.00 0 eicore_bdn
6342 L 1 8611 0 1264 0 0.00 0.00 0.00 0 eicore_bdn
6342 L 1 8612 0 1264 0 0.00 0.00 0.00 0 eicore_bdn
6342 L 1 8614 0 1268 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 1 8615 0 1268 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 1 8616 0 1268 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 2 8617 50 2255 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 0 8618 20 2255 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 1 8619 0 1268 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 1 8620 0 1268 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 1 8621 0 1268 0 0.00 0.00 0.00 0 ngdumper_provid
6342 L 1 9089 0 1279 0 0.00 0.00 0.00 0 eicore_ipc
6343 L 450 34108 13 0.00 0.00 0.02 0 sysinfo_p
6343 L 1 6343 340 2278 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 1 7783 20 2260 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 1 7792 0 1347 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 3 7860 20 1282 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 3 7863 0 1271 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 0 7866 20 2247 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 0 7867 0 1258 0 0.00 0.00 0.00 0 SPI default TP
6343 L 3 7868 0 1265 0 0.00 0.00 0.00 0 SPI default TP
6343 L 3 7869 0 1270 0 0.00 0.00 0.00 0 SPI default TP
6343 L 1 7870 0 1270 0 0.00 0.00 0.00 0 SPI default TP
6343 L 2 7871 0 1270 0 0.00 0.00 0.00 0 SPI default TP
6343 L 1 7874 0 1263 0 0.00 0.00 0.00 0 eicore_bdn
6343 L 1 7875 0 1263 0 0.00 0.00 0.00 0 eicore_bdn
6343 L 1 7876 0 1263 0 0.00 0.00 0.00 0 eicore_bdn
6343 L 0 7882 0 1258 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 0 7883 0 1258 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 0 7884 0 1258 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 2 7885 20 2248 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 1 7887 30 2248 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 0 7888 0 1258 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 0 7890 0 1258 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 0 7891 0 1258 0 0.00 0.00 0.00 0 sysinfo_p
6343 L 3 9039 0 1283 0 0.00 0.00 0.00 0 eicore_ipc
6354 L 90 4861 18 0.00 0.00 0.00 0 fs_cmd
6354 L 0 6354 80 1250 0 0.00 0.00 0.00 0 fs_cmd
6354 L 3 7076 10 2265 0 0.00 0.00 0.00 0 fs_cmd
6354 L 0 7085 0 1351 0 0.00 0.00 0.00 0 fs_cmd
8563 L 480 1400 342 0.00 0.00 0.00 0 rollback_timer.
8670 L 0 1391 0 0.00 0.00 0.00 0 rollback_timer.
8672 L 90 1394 64 0.00 0.00 0.00 0 xlogger
8675 L 0 1395 0 0.00 0.00 0.00 0 inotifywait
8873 L 170 1176 144 0.00 0.00 0.00 0 nova_sntp.sh
9024 L 0 1174 0 0.00 0.00 0.00 0 nova_sntp.sh
9025 L 160 1174 136 0.00 0.00 0.00 0 xlogger
9028 L 10 1180 8 0.00 0.00 0.00 0 sntp
9248 L 1110 76644 14 0.00 0.04 0.12 0 table_mgr
9248 L 0 9248 720 1341 0 0.00 0.00 0.00 0 table_mgr
9248 L 1 9490 10 2291 0 0.00 0.00 0.01 0 table_mgr
9248 L 0 9491 10 1391 0 0.00 0.00 0.00 0 table_mgr
9248 L 3 9505 30 1397 0 0.00 0.00 0.00 0 table_mgr
9248 L 0 9514 40 1390 0 0.00 0.00 0.00 0 table_mgr
9248 L 1 9515 30 2271 0 0.00 0.00 0.00 0 table_mgr
9248 L 1 9516 0 1301 0 0.00 0.00 0.00 0 SPI default TP
9248 L 2 9517 0 1312 0 0.00 0.00 0.00 0 SPI default TP
9248 L 2 9518 0 1327 0 0.00 0.00 0.00 0 SPI default TP
9248 L 3 9519 0 1325 0 0.00 0.00 0.00 0 SPI default TP
9248 L 2 9520 20 1330 0 0.00 0.00 0.00 0 SPI default TP
9248 L 1 9523 0 1300 0 0.00 0.00 0.00 0 table_mgr
9248 L 1 9524 0 1300 0 0.00 0.00 0.00 0 table_mgr
9248 L 3 9525 0 1305 0 0.00 0.00 0.00 0 table_mgr
9248 L 0 9526 0 2275 0 0.00 0.00 0.00 0 table_mgr
9248 L 0 9527 20 2275 0 0.00 0.00 0.00 0 table_mgr
9248 L 1 9528 0 1300 0 0.00 0.00 0.00 0 table_mgr
9248 L 1 9529 0 1300 0 0.00 0.00 0.00 0 table_mgr
9248 L 0 9530 0 1301 0 0.00 0.00 0.00 0 table_mgr
9248 L 1 9534 20 1363 0 0.00 0.00 0.00 0 tms-ots-event
9248 L 2 9536 0 1341 0 0.00 0.00 0.00 0 SPI default ST
9248 L 2 9554 0 1310 0 0.00 0.00 0.00 0 HALib Dispatch
9248 L 2 9555 0 1310 0 0.00 0.00 0.00 0 HALib Dispatch
9248 L 2 9556 0 1310 0 0.00 0.00 0.00 0 HALib Dispatch
9248 L 2 9564 10 1350 0 0.00 0.00 0.00 0 RF Slave Main T
9248 L 1 9568 0 1391 0 0.00 0.00 0.00 0 table_mgr
9248 L 3 9569 200 30428 0 0.05 0.04 0.05 0 Timer
9248 L 3 9570 0 1325 0 0.00 0.00 0.00 0 table_mgr
9248 L 3 9571 0 1325 0 0.00 0.00 0.00 0 Timer
9248 L 3 9611 0 1329 0 0.00 0.00 0.00 0 eicore_bdn
9248 L 3 9612 0 1329 0 0.00 0.00 0.00 0 eicore_bdn
9248 L 3 9613 0 1329 0 0.00 0.00 0.00 0 eicore_bdn
9248 L 0 9635 0 1343 0 0.00 0.00 0.00 0 eicore_ipc
9249 L 90 1418 63 0.00 0.00 0.10 0 wnweb.sh
9250 L 700 36102 19 0.00 0.00 0.04 0 iifd
9250 L 2 9250 470 1597 0 0.00 0.00 0.00 0 iifd
9250 L 0 9410 20 2296 0 0.00 0.00 0.02 0 iifd
9250 L 1 9413 0 1391 0 0.00 0.00 0.00 0 iifd
9250 L 2 9424 10 1336 0 0.00 0.00 0.00 0 iifd
9250 L 3 9425 70 1634 0 0.00 0.00 0.00 0 iifd
9250 L 1 9426 10 2271 0 0.00 0.00 0.00 0 iifd
9250 L 0 9428 0 1293 0 0.00 0.00 0.00 0 SPI default TP
9250 L 0 9429 0 1293 0 0.00 0.00 0.00 0 SPI default TP
9250 L 2 9430 0 1301 0 0.00 0.00 0.00 0 SPI default TP
9250 L 2 9431 0 1301 0 0.00 0.00 0.00 0 SPI default TP
9250 L 2 9432 0 1301 0 0.00 0.00 0.00 0 SPI default TP
9250 L 1 9433 100 1587 0 0.00 0.00 0.00 0 SPI default ST
9250 L 1 9445 0 1294 0 0.00 0.00 0.00 0 iifd
9250 L 1 9446 0 1294 0 0.00 0.00 0.00 0 iifd
9250 L 1 9447 0 1294 0 0.00 0.00 0.00 0 iifd
9250 L 1 9448 0 2269 0 0.00 0.00 0.00 0 iifd
9250 L 0 9449 20 2269 0 0.00 0.00 0.00 0 iifd
9250 L 1 9450 0 1294 0 0.00 0.00 0.00 0 iifd
9250 L 1 9451 0 1294 0 0.00 0.00 0.00 0 iifd
9250 L 1 9452 0 1294 0 0.00 0.00 0.00 0 iifd
9250 L 3 9479 0 1301 0 0.00 0.00 0.00 0 eicore_bdn
9250 L 3 9480 0 1301 0 0.00 0.00 0.00 0 eicore_bdn
9250 L 3 9481 0 1301 0 0.00 0.00 0.00 0 eicore_bdn
9250 L 2 9512 0 1314 0 0.00 0.00 0.00 0 eicore_ipc
9251 L 275120 1426388 192 14.7 14.3 12.4 0 iosd
9251 L 1 9251 87850 1350423 0 1.29 2.00 1.87 0 iosd
9251 L 2 9885 187970 79057 0 3.53 11.6 9.74 0 iosd.fastpath
9251 L 1 9886 120 2077 0 0.00 0.00 0.00 0 iosd.aux
1 I 0 13 0 0.00 0.00 0.00 0 Chunk Manager
2 I 0 191 0 0.00 0.00 0.00 0 Load Meter
3 I 10 10 0 0.00 0.00 0.00 0 RSMP Server
4 I 0 1 0 0.00 0.00 0.00 0 Retransmission of
5 I 0 1 0 0.00 0.00 0.00 0 IPC ISSU Dispatch
6 I 2560 240 0 0.00 0.22 0.22 0 Check heaps
7 I 0 17 0 0.00 0.00 0.00 0 Pool Manager
8 I 0 1 0 0.00 0.00 0.00 0 DiscardQ Backgrou
9 I 0 2 0 0.00 0.00 0.00 0 Timers
10 I 0 438 0 0.00 0.00 0.00 0 WATCH_AFS
11 I 0 2 0 0.00 0.00 0.00 0 DDR Timers
12 I 0 2 0 0.00 0.00 0.00 0 Dialer event
13 I 0 2 0 0.00 0.00 0.00 0 Serial Background
14 I 10 196 0 0.00 0.00 0.00 0 IOSD ipc task
15 I 0 1 0 0.00 0.00 0.00 0 IOSD chasfs task
16 I 0 1 0 0.00 0.00 0.00 0 IPC Bootstrap
17 I 0 487 0 0.00 0.00 0.00 0 IOSD heartbeat pr
18 I 0 65 0 0.00 0.00 0.00 0 IOSD taskmonitor
19 I 0 1 0 0.00 0.00 0.00 0 IPC Apps Task
20 I 90 18 0 0.00 0.00 0.00 0 RF Slave Main Thr
21 I 0 1 0 0.00 0.00 0.00 0 ifIndex Receive P
22 I 0 4 0 0.00 0.00 0.00 0 ARP Input
23 I 10 1031 0 0.00 0.00 0.00 0 ARP Background
24 I 0 1 0 0.00 0.00 0.00 0 AAA_SERVER_DEADTI
25 I 0 1 0 0.00 0.00 0.00 0 Policy Manager
26 I 10 7 0 0.00 0.00 0.00 0 Entity MIB API
27 I 0 1 0 0.00 0.00 0.00 0 IFS Agent Manager
28 I 0 199 0 0.00 0.00 0.00 0 IPC Event Notifie
29 I 0 944 0 0.00 0.00 0.00 0 IPC Mcast Pending
30 I 0 17 0 0.00 0.00 0.00 0 IPC Dynamic Cache
31 I 0 1 0 0.00 0.00 0.00 0 IPC Session Servi
32 I 1010 2733 0 0.11 0.11 0.00 0 SPI PL client app
33 I 0 944 0 0.00 0.00 0.00 0 IPC Periodic Time
34 I 0 944 0 0.00 0.00 0.00 0 IPC Deferred Port
35 I 0 1 0 0.00 0.00 0.00 0 IPC Process level
36 I 0 1 0 0.00 0.00 0.00 0 IPC Seat Manager
37 I 0 66 0 0.00 0.00 0.00 0 IPC Check Queue T
38 I 0 1 0 0.00 0.00 0.00 0 IPC Seat RX Contr
39 I 0 14 0 0.00 0.00 0.00 0 IPC Seat TX Contr
40 I 0 99 0 0.00 0.00 0.00 0 IPC Keep Alive Me
41 I 0 196 0 0.00 0.00 0.00 0 IPC Loadometer
42 I 20 28 0 0.00 0.00 0.00 0 PrstVbl
43 I 0 1 0 0.00 0.00 0.00 0 SERIAL A'detect
44 I 50 281 0 0.00 0.00 0.00 0 SL async process
45 I 0 1 0 0.00 0.00 0.00 0 SPI PL process
46 I 0 1 0 0.00 0.00 0.00 0 SPI PL FC process
47 I 0 1 0 0.00 0.00 0.00 0 SPI IPC Cleanup p
48 I 30 16 0 0.00 0.00 0.00 0 SPI Delayed Init
49 I 30 327 0 0.00 0.00 0.00 0 ARP Snoop
50 I 10 973 0 0.00 0.00 0.00 0 Dynamic ARP Inspe
51 I 0 1 0 0.00 0.00 0.00 0 IOSD signals IOS
52 I 20 29 0 0.00 0.00 0.00 0 SPI TMS MQIPC Ctr
53 I 410 3095 0 0.00 0.00 0.00 0 SPI TMS MQIPC Dat
54 I 20 973 0 0.00 0.00 0.00 0 pdslib stats task
55 I 0 1 0 0.00 0.00 0.00 0 AggMgr Process
56 I 0 1 0 0.00 0.00 0.00 0 SPI-FC IFM proc
57 I 0 1 0 0.00 0.00 0.00 0 client_entity_sen
58 I 0 950 0 0.00 0.00 0.00 0 GraphIt
59 I 0 1 0 0.00 0.00 0.00 0 Critical Bkgnd
60 I 20 1697 0 0.00 0.00 0.00 0 Net Background
61 I 0 2 0 0.00 0.00 0.00 0 IDB Work
62 I 0 25 0 0.00 0.00 0.00 0 Logger
63 I 10 946 0 0.00 0.00 0.00 0 TTY Background
64 I 0 1 0 0.00 0.00 0.00 0 NG3K StackEventSe
65 I 10 337 0 0.00 0.00 0.00 0 Net Input
66 I 20 97 0 0.00 0.00 0.00 0 Compute load avgs
67 I 260 33 0 0.00 0.00 0.00 0 Per-minute Jobs
68 I 10 1069 0 0.00 0.00 0.00 0 Per-Second Jobs
69 I 230 283 0 0.00 0.00 0.00 0 SPI PL client app
70 I 10 10 0 0.00 0.00 0.00 0 SPI PL client app
71 I 0 1 0 0.00 0.00 0.00 0 SPI PL client app
72 I 0 1 0 0.00 0.00 0.00 0 SPI PL client app
73 I 0 1 0 0.00 0.00 0.00 0 SPI PL client app
74 I 0 1 0 0.00 0.00 0.00 0 SPI-FC SEC_UTIL p
75 I 0 6 0 0.00 0.00 0.00 0 NGWC SECURITY pro
76 I 0 1 0 0.00 0.00 0.00 0 NGWC SPI Async Re
77 I 10 61 0 0.00 0.00 0.00 0 IF-MGR control pr
78 I 0 9 0 0.00 0.00 0.00 0 IF-MGR event proc
79 I 0 1 0 0.00 0.00 0.00 0 SPI-FC STATS proc
80 I 0 1 0 0.00 0.00 0.00 0 NGWC SPI Async Re
81 I 0 360 0 0.00 0.00 0.00 0 STATS SPI client
82 I 0 1 0 0.00 0.00 0.00 0 STATS stacking in
83 I 0 1 0 0.00 0.00 0.00 0 SPI-FC L2 Ctrl pr
84 I 0 2 0 0.00 0.00 0.00 0 L2 control proces
85 I 0 1 0 0.00 0.00 0.00 0 SPI-FC L2M proc
86 I 0 2 0 0.00 0.00 0.00 0 L2M Client SPI Pr
87 I 0 1 0 0.00 0.00 0.00 0 NGWC L2M STACKING
88 I 0 1 0 0.00 0.00 0.00 0 SPI-FC MATM proc
89 I 0 2 0 0.00 0.00 0.00 0 MATM SPI client p
90 I 0 1 0 0.00 0.00 0.00 0 SPI-FC PM proc
91 I 30 319 0 0.00 0.00 0.00 0 NGPM spi message
92 I 0 2 0 0.00 0.00 0.00 0 NG Backup Interfa
93 I 0 1 0 0.00 0.00 0.00 0 SPI-FC BACKUPIF p
94 I 0 1 0 0.00 0.00 0.00 0 SPI-FC PLAT-SPI p
95 I 0 2 0 0.00 0.00 0.00 0 PLAT-SPI message
96 I 0 1 0 0.00 0.00 0.00 0 SPI-FC PLATFORM p
97 I 130 1179 0 0.00 0.00 0.00 0 PLATFORM_MGR SPI
98 I 0 1 0 0.00 0.00 0.00 0 PLATFORM_MGR stac
99 I 0 1 0 0.00 0.00 0.00 0 SPI-FC SC proc
100 I 0 2 0 0.00 0.00 0.00 0 NGWC SC process
101 I 0 1 0 0.00 0.00 0.00 0 sw_idbman_nova II
102 I 0 1 0 0.00 0.00 0.00 0 NG3K OIR CC Proce
103 I 0 34 0 0.00 0.00 0.00 0 NG3K SM Process
104 I 0 1 0 0.00 0.00 0.00 0 SPI-FC SEC_CTRL p
105 I 0 3 0 0.00 0.00 0.00 0 NGWC Security Ctr
106 I 0 2 0 0.00 0.00 0.00 0 Parser SPI sever
107 I 0 2 0 0.00 0.00 0.00 0 PTH spi message p
108 I 0 1 0 0.00 0.00 0.00 0 SPI-FC L3M proc
109 I 0 2 0 0.00 0.00 0.00 0 L3M Client SPI Pr
110 I 0 140 0 0.00 0.00 0.00 0 REDUNDANCY FSM
111 I 0 1 0 0.00 0.00 0.00 0 PrstVbl IPC Msg P
112 I 0 1 0 0.00 0.00 0.00 0 SPI-FC EM-HA proc
113 I 0 2 0 0.00 0.00 0.00 0 EM-HA spi message
114 I 0 1 0 0.00 0.00 0.00 0 Smart Install HA
115 I 0 1 0 0.00 0.00 0.00 0 IP Admission HA P
116 I 0 2 0 0.00 0.00 0.00 0 cpf_msg_holdq_pro
117 I 0 1 0 0.00 0.00 0.00 0 cpf_msg_rcvq_proc
118 I 0 1 0 0.00 0.00 0.00 0 cpf_process_tpQ
119 I 0 2 0 0.00 0.00 0.00 0 IFM spi message p
120 I 0 1 0 0.00 0.00 0.00 0 MATM CF Flow Cont
121 I 20 31 0 0.00 0.00 0.00 0 NGWC Learning Pro
122 I 0 1 0 0.00 0.00 0.00 0 NGWC ILP CF Proce
123 I 0 3 0 0.00 0.00 0.00 0 NGWC Configuratio
124 I 0 1 0 0.00 0.00 0.00 0 IIF Bulk Sync pro
125 I 0 2 0 0.00 0.00 0.00 0 IP Host Track HA
126 I 0 1 0 0.00 0.00 0.00 0 Ng3k envvar sync
127 I 0 1 0 0.00 0.00 0.00 0 NG3K STACK MAC pr
128 I 0 2 0 0.00 0.00 0.00 0 QoS spi message p
129 I 0 1 0 0.00 0.00 0.00 0 CONSOLE helper pr
130 I 0 3 0 0.00 0.00 0.00 0 BACK CHECK
131 I 10 42 0 0.00 0.00 0.00 0 dbflags resync wi
132 I 0 2 0 0.00 0.00 0.00 0 SISF HA Process
133 I 0 972 0 0.00 0.00 0.00 0 REDUNDANCY peer m
134 I 30 9697 0 0.00 0.00 0.00 0 100ms check
135 I 0 1 0 0.00 0.00 0.00 0 RTTYS Process
136 I 0 1 0 0.00 0.00 0.00 0 RFS server proces
137 I 0 17 0 0.00 0.00 0.00 0 Standby Time
138 I 0 1 0 0.00 0.00 0.00 0 DHCPD HA
139 I 40 949 0 0.00 0.00 0.00 0 DHCPD Receive
140 I 0 4 0 0.00 0.00 0.00 0 ARP HA
141 I 50 38 0 0.00 0.00 0.00 0 EM_SHIM_TASK
142 I 30 12 0 0.00 0.00 0.00 0 EM_SHIM_NOTIFY_TA
143 I 0 1 0 0.00 0.00 0.00 0 Network-rf Notify
144 I 0 3 0 0.00 0.00 0.00 0 SSH Event handler
145 I 0 1 0 0.00 0.00 0.00 0 Transport Port Ag
146 I 0 195 0 0.00 0.00 0.00 0 HC Counter Timers
147 I 0 3 0 0.00 0.00 0.00 0 NGWC L2M
148 I 0 1 0 0.00 0.00 0.00 0 NGWC MATM Stack P
149 I 0 115 0 0.00 0.00 0.00 0 ngpm main process
150 I 0 7 0 0.00 0.00 0.00 0 NG Backup Interfa
151 I 0 17 0 0.00 0.00 0.00 0 MMN bkgrd process
152 I 80 243 0 0.00 0.00 0.00 0 FEP background pr
153 I 10 243 0 0.00 0.00 0.00 0 Thermal backgroun
154 I 20 3 0 0.00 0.00 0.00 0 NG3K Intif WCM SP
155 I 0 1 0 0.00 0.00 0.00 0 ACL Logging Proce
156 I 0 17 0 0.00 0.00 0.00 0 Call Home Timer P
157 I 10 1 0 0.00 0.00 0.00 0 NGWC DOT1X Proces
158 I 0 1 0 0.00 0.00 0.00 0 iosv_debug_trace
159 I 0 16 0 0.00 0.00 0.00 0 Crashinfo File Tr
160 I 0 6 0 0.00 0.00 0.00 0 PL3U bkgrd proces
161 I 0 52 0 0.00 0.00 0.00 0 EEM ED ND
162 I 0 2 0 0.00 0.00 0.00 0 EEM ED Identity
163 I 0 3 0 0.00 0.00 0.00 0 EEM ED MAT
164 I 10 9 0 0.00 0.00 0.00 0 MATM RP Shim Proc
165 I 20 1 0 0.00 0.00 0.00 0 CEF RP Background
166 I 0 194 0 0.00 0.00 0.00 0 MGMTE stats Proce
167 I 20 11 0 0.00 0.00 0.00 0 DiagCard1/-1
168 I 0 1 0 0.00 0.00 0.00 0 WSMA_NOTIFY
169 I 0 17 0 0.00 0.00 0.00 0 Port-Security
170 I 0 4 0 0.00 0.00 0.00 0 Auth Manager
171 I 10 1918 0 0.00 0.00 0.00 0 SVM UT Process
172 I 0 1 0 0.00 0.00 0.00 0 CMD HANDLER
173 I 0 2 0 0.00 0.00 0.00 0 Dot1x Mgr Process
174 I 0 2 0 0.00 0.00 0.00 0 CDP Forward Proce
175 I 0 3 0 0.00 0.00 0.00 0 802.1x switch
176 I 0 1 0 0.00 0.00 0.00 0 EAP Framework
177 I 0 1 0 0.00 0.00 0.00 0 EAP Test
178 I 10 69 0 0.00 0.00 0.00 0 DTP Protocol
179 I 0 2 0 0.00 0.00 0.00 0 PI MATM Aging Pro
180 I 20 68 0 0.00 0.00 0.00 0 Inline Power
181 I 0 30 0 0.00 0.00 0.00 0 NGWC led process
182 I 0 1 0 0.00 0.00 0.00 0 Switch Backup Int
183 I 0 2 0 0.00 0.00 0.00 0 IP Host Track Pro
184 I 20 11 0 0.00 0.00 0.00 0 VMATM Callback
185 I 0 2 0 0.00 0.00 0.00 0 worker thread
186 I 310 95465 0 0.00 0.00 0.00 0 Tunnel IOSd shim
187 I 0 97 0 0.00 0.00 0.00 0 Ethchnl
188 I 10 21 0 0.00 0.00 0.00 0 PKI/SSL SPI proce
189 I 0 2 0 0.00 0.00 0.00 0 AAA Server
190 I 0 1 0 0.00 0.00 0.00 0 AAA ACCT Proc
191 I 0 1 0 0.00 0.00 0.00 0 ACCT Periodic Pro
192 I 0 1 0 0.00 0.00 0.00 0 AAA System Acct P
193 I 0 1 0 0.00 0.00 0.00 0 Auth-proxy AAA Bk
194 I 0 1 0 0.00 0.00 0.00 0 Auth-proxy HTTP d
195 I 0 1 0 0.00 0.00 0.00 0 IP Admin SM Proce
196 I 0 1 0 0.00 0.00 0.00 0 EPM MAIN PROCESS
197 I 0 1 0 0.00 0.00 0.00 0 Timer Handler Pro
198 I 0 1 0 0.00 0.00 0.00 0 EPM Downlad Manag
199 I 0 1 0 0.00 0.00 0.00 0 EPM ACL PLUG-IN P
200 I 0 1 0 0.00 0.00 0.00 0 DCT Bkgd Process
201 I 10 200 0 0.00 0.00 0.00 0 CDP Protocol
202 I 0 1 0 0.00 0.00 0.00 0 SEP NODE PROC
203 I 0 2 0 0.00 0.00 0.00 0 ipc thread
204 I 0 2 0 0.00 0.00 0.00 0 AAA Dictionary Re
205 I 0 9 0 0.00 0.00 0.00 0 DHCP Snooping
206 I 0 1 0 0.00 0.00 0.00 0 DHCP Snooping db
207 I 0 4 0 0.00 0.00 0.00 0 IP ARP Adjacency
208 I 110 24029 0 0.00 0.00 0.00 0 IP ARP Retry Ager
209 I 40 155 0 0.00 0.00 0.00 0 IP Input
210 I 0 1 0 0.00 0.00 0.00 0 ICMP event handle
211 I 0 1823 0 0.00 0.00 0.00 0 IP ARP Track
212 I 0 1 0 0.00 0.00 0.00 0 IPv6 ping process
213 I 0 2 0 0.00 0.00 0.00 0 CEF switching bac
214 I 0 1 0 0.00 0.00 0.00 0 ADJ NSF process
215 I 4430 1968 0 0.33 0.11 0.22 0 Exec
216 I 0 1 0 0.00 0.00 0.00 0 SMI Director DB P
217 I 0 1 0 0.00 0.00 0.00 0 SMI CDP Update Ha
218 I 0 1 0 0.00 0.00 0.00 0 SMI Backup Proces
219 I 10 2 0 0.00 0.00 0.00 0 SMI IBC server pr
220 I 0 1 0 0.00 0.00 0.00 0 SMI IBC client pr
221 I 0 2 0 0.00 0.00 0.00 0 SMI IBC Download
222 I 150 1935 0 0.00 0.00 0.00 0 Spanning Tree
223 I 110 9471 0 0.00 0.00 0.00 0 UDLD
224 I 0 17 0 0.00 0.00 0.00 0 FRR Background Pr
225 I 10 19 0 0.00 0.00 0.00 0 CEF background pr
226 I 0 1 0 0.00 0.00 0.00 0 fib_fib_bfd_sb ev
227 I 0 1 0 0.00 0.00 0.00 0 IP IRDP
228 I 0 1 0 0.00 0.00 0.00 0 Critical Auth
229 I 0 1 0 0.00 0.00 0.00 0 AAA HA
230 I 0 1 0 0.00 0.00 0.00 0 AAA HA cleanup
231 I 0 2 0 0.00 0.00 0.00 0 Dot1x Supplicant
232 I 0 2 0 0.00 0.00 0.00 0 Dot1x Supplicant
233 I 0 2 0 0.00 0.00 0.00 0 Dot1x Supplicant
234 I 0 1 0 0.00 0.00 0.00 0 MAB Framework
235 I 0 1 0 0.00 0.00 0.00 0 XDR background pr
236 I 0 1 0 0.00 0.00 0.00 0 XDR mcast
237 I 0 1 0 0.00 0.00 0.00 0 XDR RP Ping Backg
238 I 0 1 0 0.00 0.00 0.00 0 XDR mcast rcv
239 I 0 17 0 0.00 0.00 0.00 0 XDR RP background
240 I 0 1 0 0.00 0.00 0.00 0 IPC LC Message Ha
241 I 0 1 0 0.00 0.00 0.00 0 XDR RP Test Backg
242 I 10 19 0 0.00 0.00 0.00 0 IGMPSN L2MCM
243 I 0 1 0 0.00 0.00 0.00 0 IGMPSN MRD
244 I 0 1 0 0.00 0.00 0.00 0 IGMPSN
245 I 0 1 0 0.00 0.00 0.00 0 IGMPQR
246 I 0 948 0 0.00 0.00 0.00 0 Socket Timers
247 I 0 2 0 0.00 0.00 0.00 0 L2TRACE SERVER
248 I 0 70 0 0.00 0.00 0.00 0 NGWC stack power
249 I 0 3 0 0.00 0.00 0.00 0 Flow Exporter Tim
250 I 0 1 0 0.00 0.00 0.00 0 NG3K punt Tx proc
251 I 0 18 0 0.00 0.00 0.00 0 MLDSN L2MCM
252 I 0 1 0 0.00 0.00 0.00 0 MRD
253 I 0 1 0 0.00 0.00 0.00 0 MLD_SNOOP
254 I 0 1 0 0.00 0.00 0.00 0 NGWC DHCP Snoopin
255 I 0 1 0 0.00 0.00 0.00 0 DAI Packet Proces
256 I 40 32 0 0.00 0.00 0.00 0 os_info_p provide
257 I 0 3 0 0.00 0.00 0.00 0 SNMP Timers
258 I 230 75 0 0.00 0.00 0.00 0 snmp_spi Process
259 I 10 1 0 0.00 0.00 0.00 0 IP SNMPV6
260 I 10 1 0 0.00 0.00 0.00 0 XTF Agent
261 I 0 8 0 0.00 0.00 0.00 0 DHCPD Timer
262 I 0 22 0 0.00 0.00 0.00 0 DHCPD Database
263 I 0 1 0 0.00 0.00 0.00 0 Nova RAW
264 I 0 1 0 0.00 0.00 0.00 0 Nova TCP
265 I 0 1 0 0.00 0.00 0.00 0 SEP NODE PROC
266 I 0 2 0 0.00 0.00 0.00 0 Routing Topology
267 I 0 6 0 0.00 0.00 0.00 0 IP RIB Update
268 I 10 18 0 0.00 0.00 0.00 0 IP Background
269 I 10 85 0 0.00 0.00 0.00 0 IP Connected Rout
270 I 150 548 0 0.00 0.00 0.00 0 CEF: IPv4 process
271 I 0 3 0 0.00 0.00 0.00 0 ADJ background
272 I 0 3 0 0.00 0.00 0.00 0 Collection proces
273 I 0 3 0 0.00 0.00 0.00 0 IPv6 RIB Event Ha
274 I 0 3 0 0.00 0.00 0.00 0 PDU DISPATCHER
275 I 10 952 0 0.00 0.00 0.00 0 NMSP SPI
276 I 0 1 0 0.00 0.00 0.00 0 IPv6 Access Contr
277 I 0 1 0 0.00 0.00 0.00 0 IGMPSN-HA
278 I 0 1 0 0.00 0.00 0.00 0 MLDSN-HA
279 I 0 2 0 0.00 0.00 0.00 0 XDR FOF process
280 I 0 1 0 0.00 0.00 0.00 0 DHCP Snooping HA
281 I 20 965 0 0.00 0.00 0.00 0 NGWC Ethernet Man
282 I 0 1 0 0.00 0.00 0.00 0 TCP Timer
283 I 0 1 0 0.00 0.00 0.00 0 TCP Protocols
284 I 10 7 0 0.00 0.00 0.00 0 HTTP CORE
285 I 0 1 0 0.00 0.00 0.00 0 Nova UDP
286 I 0 2 0 0.00 0.00 0.00 0 ADJ resolve proce
287 I 0 9 0 0.00 0.00 0.00 0 static
288 I 0 96 0 0.00 0.00 0.00 0 QoS stats process
289 I 0 6 0 0.00 0.00 0.00 0 DHCP IOSd Agent
290 I 0 2 0 0.00 0.00 0.00 0 AAA Cached Server
291 I 0 1 0 0.00 0.00 0.00 0 EM Background Pro
292 I 0 1 0 0.00 0.00 0.00 0 Key chain livekey
293 I 0 3 0 0.00 0.00 0.00 0 LOCAL AAA
294 I 0 2 0 0.00 0.00 0.00 0 ENABLE AAA
295 I 0 2 0 0.00 0.00 0.00 0 LINE AAA
296 I 0 3 0 0.00 0.00 0.00 0 SNMP ENGINE
297 I 0 2 0 0.00 0.00 0.00 0 TPLUS
298 I 0 3 0 0.00 0.00 0.00 0 LDAP process
299 I 0 35 0 0.00 0.00 0.00 0 AAA Proxy
300 I 0 2 0 0.00 0.00 0.00 0 crypto engine pro
301 I 0 4 0 0.00 0.00 0.00 0 Crypto CA
302 I 10 1 0 0.00 0.00 0.00 0 Crypto PKI-CRL
303 I 0 1 0 0.00 0.00 0.00 0 encrypt proc
304 I 390 26 0 0.00 0.00 0.00 0 crypto sw pk proc
305 I 0 12 0 0.00 0.00 0.00 0 VTP Trap Process
306 I 20 5 0 0.00 0.00 0.00 0 IP SNMP
307 I 0 1 0 0.00 0.00 0.00 0 Licensing MIB pro
308 I 0 1 0 0.00 0.00 0.00 0 SNMP ConfCopyProc
309 I 10 1822 0 0.00 0.00 0.00 0 PM Callback
310 I 0 1 0 0.00 0.00 0.00 0 NCD Process
311 I 0 77 0 0.00 0.00 0.00 0 dhcp snooping sw
312 I 0 2 0 0.00 0.00 0.00 0 DHCP Security Hel
313 I 0 1912 0 0.00 0.00 0.00 0 SPI IOSd Show
314 I 0 1 0 0.00 0.00 0.00 0 FFCP msg process
315 I 0 2 0 0.00 0.00 0.00 0 AAA SEND STOP EVE
316 I 0 1 0 0.00 0.00 0.00 0 Test AAA Client
317 I 0 25 0 0.00 0.00 0.00 0 EEM ED Syslog
318 I 0 2 0 0.00 0.00 0.00 0 EEM ED Routing
319 I 0 1 0 0.00 0.00 0.00 0 Syslog Traps
320 I 0 1 0 0.00 0.00 0.00 0 Online Diag EEM T
321 I 0 1 0 0.00 0.00 0.00 0 QoS TAM Request H
322 I 0 1 0 0.00 0.00 0.00 0 IOSD-ISSU commitv
323 I 0 17 0 0.00 0.00 0.00 0 FNF background pr
324 I 0 14 0 0.00 0.00 0.00 0 Syslog
325 I 0 52 0 0.00 0.00 0.00 0 EEM Server
326 I 0 2 0 0.00 0.00 0.00 0 EEM Policy Direct
327 I 0 1 0 0.00 0.00 0.00 0 SNMP Traps
328 I 0 2 0 0.00 0.00 0.00 0 EEM ED CLI
329 I 0 3 0 0.00 0.00 0.00 0 EEM ED Counter
330 I 0 3 0 0.00 0.00 0.00 0 EEM ED Interface
331 I 0 3 0 0.00 0.00 0.00 0 EEM ED IOSWD
332 I 0 3 0 0.00 0.00 0.00 0 EEM ED None
333 I 0 3 0 0.00 0.00 0.00 0 EEM ED OIR
334 I 0 8 0 0.00 0.00 0.00 0 EEM ED RF
335 I 0 3 0 0.00 0.00 0.00 0 EEM ED SNMP
336 I 0 30 0 0.00 0.00 0.00 0 EEM ED Timer
337 I 0 3 0 0.00 0.00 0.00 0 EEM ED SNMP Objec
338 I 0 2 0 0.00 0.00 0.00 0 EEM ED SNMP Noti
339 I 0 3 0 0.00 0.00 0.00 0 EEM ED Ipsla
340 I 0 2 0 0.00 0.00 0.00 0 Call Home process
341 I 0 3 0 0.00 0.00 0.00 0 EEM ED Test
342 I 0 3 0 0.00 0.00 0.00 0 EEM ED Config
343 I 0 3 0 0.00 0.00 0.00 0 EEM ED Env
344 I 0 3 0 0.00 0.00 0.00 0 EM ED GOLD
345 I 20 23 0 0.00 0.00 0.00 0 VLAN Manager
346 I 0 1 0 0.00 0.00 0.00 0 SPI-FC WCM_PLAT p
347 I 0 12 0 0.00 0.00 0.00 0 SpanTree Helper
9252 L 820 39645 20 0.00 0.01 0.04 0 ha_mgr
9252 L 0 9252 510 1356 0 0.00 0.00 0.00 0 ha_mgr
9252 L 0 9406 50 2292 0 0.00 0.00 0.00 0 ha_mgr
9252 L 0 9409 20 1379 0 0.00 0.00 0.00 0 ha_mgr
9252 L 0 9417 70 1674 0 0.00 0.00 0.00 0 ha_mgr
9252 L 1 9418 10 2277 0 0.00 0.00 0.00 0 ha_mgr
9252 L 0 9419 30 1544 0 0.00 0.00 0.00 0 SPI default TP
9252 L 0 9420 10 1511 0 0.00 0.00 0.00 0 SPI default TP
9252 L 0 9421 0 1370 0 0.00 0.00 0.00 0 SPI default TP
9252 L 0 9422 10 1502 0 0.00 0.00 0.00 0 SPI default TP
9252 L 2 9423 30 1523 0 0.00 0.00 0.00 0 SPI default TP
9252 L 3 9427 0 1302 0 0.00 0.00 0.00 0 ha_mgr
9252 L 1 9434 0 1302 0 0.00 0.00 0.00 0 ha_mgr
9252 L 1 9435 0 1302 0 0.00 0.00 0.00 0 ha_mgr
9252 L 0 9436 20 2277 0 0.00 0.01 0.03 0 ha_mgr
9252 L 0 9437 10 2277 0 0.00 0.00 0.00 0 ha_mgr
9252 L 1 9438 0 1302 0 0.00 0.00 0.00 0 ha_mgr
9252 L 1 9439 0 1302 0 0.00 0.00 0.00 0 ha_mgr
9252 L 1 9440 0 1302 0 0.00 0.00 0.00 0 ha_mgr
9252 L 0 9443 0 1407 0 0.00 0.00 0.00 0 ha_mgr
9252 L 2 9455 50 1464 0 0.00 0.00 0.00 0 RF Master Main
9252 L 2 9456 0 1336 0 0.00 0.00 0.00 0 RF Master Statu
9252 L 0 9462 0 1326 0 0.00 0.00 0.00 0 SPI default ST
9252 L 0 9507 0 1329 0 0.00 0.00 0.00 0 eicore_bdn
9252 L 0 9508 0 1329 0 0.00 0.00 0.00 0 eicore_bdn
9252 L 0 9509 0 1329 0 0.00 0.00 0.00 0 eicore_bdn
9252 L 2 9562 0 1349 0 0.00 0.00 0.00 0 eicore_ipc
10011 L 11820 67002 176 0.00 0.02 1.02 0 wnweb_paster.py
10011 L 0 10011 11760 3021 0 0.00 0.00 0.02 0 wnweb_paster.py
10011 L 3 10029 0 2017 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 2 10030 0 1997 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 2 10031 30 2898 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 2 10032 0 1995 0 0.00 0.00 0.00 0 SPI default TP
10011 L 3 10033 0 1999 0 0.00 0.00 0.00 0 SPI default TP
10011 L 3 10034 0 2016 0 0.00 0.00 0.00 0 SPI default TP
10011 L 0 10035 10 2006 0 0.00 0.00 0.00 0 SPI default TP
10011 L 2 10036 0 1987 0 0.00 0.00 0.00 0 SPI default TP
10011 L 3 10037 0 1987 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 3 10038 0 1987 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 3 10039 0 1987 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 1 10040 0 2900 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 1 10041 0 2900 0 0.00 0.04 0.04 0 wnweb_paster.py
10011 L 3 10042 0 1987 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 3 10043 0 1987 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 3 10044 0 1987 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 0 10045 0 1998 0 0.00 0.00 0.00 0 Transport Libra
10011 L 1 10046 0 1998 0 0.00 0.00 0.00 0 Transport Libra
10011 L 0 10047 0 1997 0 0.00 0.00 0.00 0 Transport Libra
10011 L 1 10048 20 2933 0 0.00 0.00 0.00 0 pdslib thread
10011 L 1 10049 0 2023 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 3 10050 0 2017 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 3 10051 0 2022 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 3 10052 0 2030 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 3 10053 0 2038 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 3 10054 0 2046 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 3 10055 0 2054 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 3 10056 0 2063 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 3 10057 0 2071 0 0.00 0.00 0.00 0 wnweb_paster.py
10011 L 3 10058 0 2079 0 0.00 0.00 0.00 0 wnweb_paster.py
10012 L 360 1418 253 0.00 0.00 0.00 0 xlogger
10359 L 10 1492 6 0.00 0.00 0.00 0 sleep
------------------ show processes ------------------
CPU utilization for five seconds: 16%; one minute: 16%; five minutes: 17%
PID TID Runtime(ms) Invoked uSecs Stacks Process
1 1640 1055 1554 88/8192 init
2 0 124 0 0/8192 kthreadd
3 0 1136 0 0/8192 migration/0
4 0 3 0 0/8192 sirq-high/0
5 1090 115487 9 0/8192 sirq-timer/0
6 0 10 0 0/8192 sirq-net-tx/0
7 0 23 0 0/8192 sirq-net-rx/0
8 250 3835 65 0/8192 sirq-block/0
9 0 8 0 0/8192 sirq-block-iopo
10 0 1580 0 0/8192 sirq-tasklet/0
11 750 50716 14 0/8192 sirq-sched/0
12 0 101 0 0/8192 sirq-hrtimer/0
13 2540 106022 23 0/8192 sirq-rcu/0
14 40 2322 17 0/8192 desched/0
15 10 1089 9 0/8192 migration/1
16 0 15 0 0/8192 sirq-high/1
17 180 100202 1 0/8192 sirq-timer/1
18 0 18 0 0/8192 sirq-net-tx/1
19 0 40 0 0/8192 sirq-net-rx/1
20 50 525 95 0/8192 sirq-block/1
21 0 20 0 0/8192 sirq-block-iopo
22 0 21 0 0/8192 sirq-tasklet/1
23 90 42535 2 0/8192 sirq-sched/1
24 0 53 0 0/8192 sirq-hrtimer/1
25 560 92560 6 0/8192 sirq-rcu/1
26 20 2306 8 0/8192 desched/1
27 20 1608 12 0/8192 migration/2
28 0 27 0 0/8192 sirq-high/2
29 130 63608 2 0/8192 sirq-timer/2
30 0 30 0 0/8192 sirq-net-tx/2
31 0 85 0 0/8192 sirq-net-rx/2
32 10 355 28 0/8192 sirq-block/2
33 0 32 0 0/8192 sirq-block-iopo
34 0 33 0 0/8192 sirq-tasklet/2
35 40 18995 2 0/8192 sirq-sched/2
36 0 78 0 0/8192 sirq-hrtimer/2
37 20 60702 0 0/8192 sirq-rcu/2
38 10 2895 3 0/8192 desched/2
39 30 1389 21 0/8192 migration/3
40 0 39 0 0/8192 sirq-high/3
41 0 42764 0 0/8192 sirq-timer/3
42 0 44 0 0/8192 sirq-net-tx/3
43 0 67 0 0/8192 sirq-net-rx/3
44 10 234 42 0/8192 sirq-block/3
45 0 44 0 0/8192 sirq-block-iopo
46 0 45 0 0/8192 sirq-tasklet/3
47 0 22928 0 0/8192 sirq-sched/3
48 0 62 0 0/8192 sirq-hrtimer/3
49 0 42178 0 0/8192 sirq-rcu/3
50 30 2737 10 0/8192 desched/3
51 30 3288 9 0/8192 events/0
52 10 1992 5 0/8192 events/1
53 0 1732 0 0/8192 events/2
54 0 1663 0 0/8192 events/3
55 80 2964 26 0/8192 khelper
58 0 55 0 0/8192 netns
60 0 60 0 0/8192 async/mgr
158 10 277 36 0/8192 sync_supers
160 0 326 0 0/8192 bdi-default
162 0 552 0 0/8192 kblockd/0
163 0 158 0 0/8192 kblockd/1
164 0 145 0 0/8192 kblockd/2
165 0 96 0 0/8192 kblockd/3
171 0 69 0 0/8192 ata/0
172 0 68 0 0/8192 ata/1
173 0 65 0 0/8192 ata/2
174 0 66 0 0/8192 ata/3
175 0 67 0 0/8192 ata_aux
183 0 70 0 0/8192 khubd
210 0 88 0 0/8192 rpciod/0
211 0 88 0 0/8192 rpciod/1
212 0 75 0 0/8192 rpciod/2
213 0 78 0 0/8192 rpciod/3
229 0 77 0 0/8192 kswapd0
230 0 78 0 0/8192 aio/0
231 0 79 0 0/8192 aio/1
232 0 80 0 0/8192 aio/2
233 0 81 0 0/8192 aio/3
234 0 82 0 0/8192 nfsiod
236 0 83 0 0/8192 crypto/0
237 0 84 0 0/8192 crypto/1
238 0 85 0 0/8192 crypto/2
239 0 86 0 0/8192 crypto/3
789 0 847 0 0/8192 pata_octeon_cf
790 0 99 0 0/8192 scsi_eh_0
796 1660 314 5286 0/8192 mtdblockd
823 30 1501 19 0/8192 octeon-ethernet
857 0 96 0 0/8192 kstriped
859 0 97 0 0/8192 ksnapd
937 310 1222 253 88/8192 udevd
1252 0 374 0 0/8192 flush-8:0
1534 160 4368 36 0/8192 loop1
1559 110 4231 25 0/8192 loop2
1584 10 2122 4 0/8192 loop3
1609 30 2894 10 0/8192 loop4
1634 30 1705 17 0/8192 loop5
1679 10 560 17 0/8192 loop6
2361 0 1001 0 88/8192 udevd
2362 0 977 0 88/8192 udevd
3274 150 1113 134 88/8192 dbus-daemon
3652 130 1190 109 88/8192 klogd
3664 0 977 0 88/8192 portmap
3733 0 958 0 88/8192 sshd
3745 0 949 0 88/8192 xinetd
3749 0 950 0 88/8192 xinetd
3783 0 112 0 88/8192 lockd
3784 0 114 0 88/8192 nfsd
3785 0 115 0 88/8192 nfsd
3786 0 116 0 88/8192 nfsd
3787 0 117 0 88/8192 nfsd
3788 0 118 0 0/8192 nfsd
3789 0 119 0 0/8192 nfsd
3790 0 120 0 0/8192 nfsd
3791 0 120 0 0/8192 nfsd
3797 0 980 0 88/8192 rpc.mountd
5347 920 20669 44 88/8192 system_mgr
5347 5347 850 3628 0 88/8192 system_mgr
5347 5648 20 1166 0 88/8192 system_mgr
5347 5649 0 1134 0 88/8192 system_mgr
5347 5650 10 2298 0 88/8192 system_mgr
5347 5651 0 1138 0 88/8192 system_mgr
5347 7205 0 1120 0 88/8192 system_mgr
5347 7206 0 1120 0 88/8192 system_mgr
5347 7207 0 1120 0 88/8192 system_mgr
5347 7268 40 2280 0 88/8192 system_mgr
5347 7291 0 2281 0 88/8192 system_mgr
5347 7292 0 1128 0 88/8192 system_mgr
5347 7293 0 1128 0 88/8192 system_mgr
5347 7294 0 1128 0 88/8192 system_mgr
5576 700 18403 38 88/4096 slproc
5576 5576 210 1123 0 88/4096 slproc
5576 5636 60 2344 0 88/4096 slproc
5576 5637 0 1229 0 88/4096 slproc
5576 5638 310 3963 0 88/4096 slproc
5576 5639 0 1112 0 88/4096 slproc
5576 5640 90 2983 0 88/4096 slproc
5576 5641 30 2321 0 88/4096 slproc
5576 5642 0 1107 0 88/4096 slproc
5576 5643 0 1113 0 88/4096 slproc
5576 5644 0 1108 0 88/4096 slproc
5652 72680 841698 86 92/4096 fed
5652 5652 32130 7746 0 92/4096 fed
5652 6093 6770 5334 0 92/4096 fed
5652 6094 30 1444 0 92/4096 fed
5652 6095 220 2266 0 92/4096 fed
5652 6096 50 2321 0 92/4096 fed
5652 6097 0 1149 0 92/4096 fed
5652 6098 0 1332 0 92/4096 fed
5652 6099 0 1237 0 92/4096 fed
5652 6100 30 1325 0 92/4096 fed
5652 6101 40 1304 0 92/4096 fed
5652 6102 0 1275 0 92/4096 fed
5652 6103 0 1300 0 92/4096 fed
5652 6106 3600 18173 0 92/4096 fed
5652 6107 10 1246 0 92/4096 fed
5652 6109 14050 2366 0 92/4096 fed
5652 6110 240 8320 0 92/4096 fed
5652 6111 80 3933 0 92/4096 fed
5652 6112 190 3526 0 92/4096 fed
5652 6113 1480 47492 0 92/4096 fed
5652 6114 0 2773 0 92/4096 fed
5652 6137 690 7501 0 92/4096 fed
5652 6140 260 18980 0 92/4096 fed
5652 7254 0 1162 0 92/4096 fed
5652 7255 0 1162 0 92/4096 fed
5652 7256 0 1173 0 92/4096 fed
5652 7283 40 2316 0 92/4096 fed
5652 7286 30 2316 0 92/4096 fed
5652 7288 60 1633 0 92/4096 fed
5652 7289 20 1213 0 92/4096 fed
5652 7290 0 1163 0 92/4096 fed
5652 9813 40 9100 0 92/4096 fed
5652 9815 10200 545100 0 92/4096 fed
5652 9839 220 11402 0 92/4096 fed
5652 9840 0 7196 0 92/4096 fed
5652 9841 470 10511 0 92/4096 fed
5652 9842 280 8666 0 92/4096 fed
5652 9843 10 7196 0 92/4096 fed
5652 9844 0 7201 0 92/4096 fed
5652 9847 0 7244 0 92/4096 fed
5652 9848 0 7244 0 92/4096 fed
5652 9849 0 7243 0 92/4096 fed
5652 9852 30 7283 0 92/4096 fed
5652 9978 0 7741 0 92/4096 fed
5652 9983 1410 44090 0 92/4096 fed
5653 5410 2023675 2 92/4096 platform_mgr
5653 5653 1730 173534 0 92/4096 platform_mgr
5653 6073 50 2363 0 92/4096 platform_mgr
5653 6074 40 1217 0 92/4096 platform_mgr
5653 6075 30 3654 0 92/4096 platform_mgr
5653 6076 30 2320 0 92/4096 platform_mgr
5653 6077 0 1204 0 92/4096 platform_mgr
5653 6078 0 1194 0 92/4096 platform_mgr
5653 6079 0 1196 0 92/4096 platform_mgr
5653 6080 30 1182 0 92/4096 platform_mgr
5653 6081 0 1136 0 92/4096 platform_mgr
5653 6082 20 1262 0 92/4096 platform_mgr
5653 6085 80 2876 0 92/4096 platform_mgr
5653 6086 280 13521 0 92/4096 platform_mgr
5653 6088 0 1276 0 92/4096 platform_mgr
5653 6089 60 7168 0 92/4096 platform_mgr
5653 6090 420 38414 0 92/4096 platform_mgr
5653 6091 0 1194 0 92/4096 platform_mgr
5653 6115 1900 325761 0 92/4096 platform_mgr
5653 6144 240 195229 0 92/4096 platform_mgr
5653 7228 0 1150 0 92/4096 platform_mgr
5653 7229 0 1150 0 92/4096 platform_mgr
5653 7230 0 1150 0 92/4096 platform_mgr
5653 7265 30 2305 0 92/4096 platform_mgr
5653 7278 30 2306 0 92/4096 platform_mgr
5653 7279 0 1203 0 92/4096 platform_mgr
5653 7280 10 1159 0 92/4096 platform_mgr
5653 7281 0 1153 0 92/4096 platform_mgr
5653 9899 230 184887 0 92/4096 platform_mgr
5653 9900 0 173496 0 92/4096 platform_mgr
5653 9901 0 173496 0 92/4096 platform_mgr
5653 9902 0 173495 0 92/4096 platform_mgr
5653 9905 20 173527 0 92/4096 platform_mgr
5653 9914 160 175271 0 92/4096 platform_mgr
5653 9955 0 173520 0 92/4096 platform_mgr
5653 10478 20 2180 0 92/4096 platform_mgr
5653 10485 0 2168 0 92/4096 platform_mgr
5653 10491 0 2177 0 92/4096 platform_mgr
5653 10494 0 2181 0 92/4096 platform_mgr
5654 5940 87616 67 88/4096 stack-mgr
5654 5654 3090 1452 0 88/4096 stack-mgr
5654 6060 20 2369 0 88/4096 stack-mgr
5654 6061 20 1264 0 88/4096 stack-mgr
5654 6062 10 1308 0 88/4096 stack-mgr
5654 6063 10 2327 0 88/4096 stack-mgr
5654 6064 10 1203 0 88/4096 stack-mgr
5654 6065 0 1222 0 88/4096 stack-mgr
5654 6066 0 1167 0 88/4096 stack-mgr
5654 6067 30 1225 0 88/4096 stack-mgr
5654 6068 0 1144 0 88/4096 stack-mgr
5654 6069 0 1272 0 88/4096 stack-mgr
5654 6072 10 1255 0 88/4096 stack-mgr
5654 6122 590 13274 0 88/4096 stack-mgr
5654 6123 1200 17514 0 88/4096 stack-mgr
5654 6124 110 1513 0 88/4096 stack-mgr
5654 6125 10 1753 0 88/4096 stack-mgr
5654 6128 700 6097 0 88/4096 stack-mgr
5654 6129 0 1327 0 88/4096 stack-mgr
5654 6130 10 2514 0 88/4096 stack-mgr
5654 6131 60 3733 0 88/4096 stack-mgr
5654 6132 0 1319 0 88/4096 stack-mgr
5654 6133 0 1361 0 88/4096 stack-mgr
5654 6134 0 1343 0 88/4096 stack-mgr
5654 6135 0 1325 0 88/4096 stack-mgr
5654 6222 0 1427 0 88/4096 stack-mgr
5654 6223 0 1427 0 88/4096 stack-mgr
5654 6224 0 1426 0 88/4096 stack-mgr
5654 7208 0 1159 0 88/4096 stack-mgr
5654 7209 0 1159 0 88/4096 stack-mgr
5654 7210 0 1159 0 88/4096 stack-mgr
5654 7266 40 2318 0 88/4096 stack-mgr
5654 7274 20 2319 0 88/4096 stack-mgr
5654 7275 0 1166 0 88/4096 stack-mgr
5654 7276 0 1166 0 88/4096 stack-mgr
5654 7277 0 1166 0 88/4096 stack-mgr
5654 9087 0 1443 0 88/4096 stack-mgr
6146 18960 5627 3369 116/4096 idope.py
6146 6146 18740 1644 0 116/4096 idope.py
6146 8815 220 3983 0 116/4096 idope.py
6296 340 24846 13 88/4096 ns_oir_proxy
6296 6296 180 1243 0 88/4096 ns_oir_proxy
6296 7135 20 2424 0 88/4096 ns_oir_proxy
6296 7140 0 1361 0 88/4096 ns_oir_proxy
6296 7141 20 1266 0 88/4096 ns_oir_proxy
6296 7154 20 1280 0 88/4096 ns_oir_proxy
6296 7168 0 1251 0 88/4096 ns_oir_proxy
6296 7169 40 2402 0 88/4096 ns_oir_proxy
6296 7170 10 1253 0 88/4096 ns_oir_proxy
6296 7225 0 1255 0 88/4096 ns_oir_proxy
6296 7226 0 1255 0 88/4096 ns_oir_proxy
6296 7227 0 1255 0 88/4096 ns_oir_proxy
6296 7295 20 2412 0 88/4096 ns_oir_proxy
6296 7296 30 2412 0 88/4096 ns_oir_proxy
6296 7297 0 1259 0 88/4096 ns_oir_proxy
6296 7298 0 1259 0 88/4096 ns_oir_proxy
6296 7299 0 1259 0 88/4096 ns_oir_proxy
6297 410 33622 12 88/4096 profiled
6297 6297 250 1266 0 88/4096 profiled
6297 7343 30 2426 0 88/4096 profiled
6297 7412 0 1363 0 88/4096 profiled
6297 7613 20 1283 0 88/4096 profiled
6297 7617 0 1261 0 88/4096 profiled
6297 7618 30 2408 0 88/4096 profiled
6297 7619 0 1252 0 88/4096 profiled
6297 7620 0 1253 0 88/4096 profiled
6297 7621 0 1260 0 88/4096 profiled
6297 7622 0 1260 0 88/4096 profiled
6297 7623 10 1260 0 88/4096 profiled
6297 7625 0 1258 0 88/4096 profiled
6297 7626 0 1258 0 88/4096 profiled
6297 7627 0 1258 0 88/4096 profiled
6297 7649 0 1248 0 88/4096 profiled
6297 7650 0 1248 0 88/4096 profiled
6297 7651 0 1248 0 88/4096 profiled
6297 7652 40 2400 0 88/4096 profiled
6297 7653 30 2400 0 88/4096 profiled
6297 7654 0 1248 0 88/4096 profiled
6297 7655 0 1248 0 88/4096 profiled
6297 7656 0 1248 0 88/4096 profiled
6297 9106 0 1268 0 88/4096 profiled
6298 250 1507 165 88/4096 oom_poll.sh
6299 1480 54403 27 88/4096 obfld
6299 6299 560 1390 0 88/4096 obfld
6299 7713 120 3345 0 88/4096 obfld
6299 7768 0 1414 0 88/4096 obfld
6299 7931 570 2018 0 88/4096 obfld
6299 8052 30 1389 0 88/4096 obfld
6299 8081 90 2033 0 88/4096 obfld
6299 8082 20 2494 0 88/4096 obfld
6299 8092 0 1342 0 88/4096 obfld
6299 8094 0 1343 0 88/4096 obfld
6299 8096 0 1354 0 88/4096 obfld
6299 8098 0 1354 0 88/4096 obfld
6299 8101 0 1354 0 88/4096 obfld
6299 8136 10 1345 0 88/4096 obfld
6299 8137 0 1345 0 88/4096 obfld
6299 8138 0 1345 0 88/4096 obfld
6299 8142 0 1348 0 88/4096 obfld
6299 8143 0 1348 0 88/4096 obfld
6299 8144 0 1348 0 88/4096 obfld
6299 8145 20 2499 0 88/4096 obfld
6299 8146 20 2499 0 88/4096 obfld
6299 8147 0 1348 0 88/4096 obfld
6299 8148 0 1348 0 88/4096 obfld
6299 8149 0 1348 0 88/4096 obfld
6299 9062 0 1357 0 88/4096 obfld
6299 10269 10 1770 0 88/4096 obfld
6299 10356 20 1755 0 88/4096 obfld
6299 10462 0 1689 0 88/4096 obfld
6299 10469 10 1931 0 88/4096 obfld
6299 10473 0 1951 0 88/4096 obfld
6299 10482 0 1695 0 88/4096 obfld
6299 10490 0 1985 0 88/4096 obfld
6299 10498 0 2319 0 88/4096 obfld
6300 340 33715 10 88/4096 consoled
6300 6300 200 1278 0 88/4096 consoled
6300 8269 30 2422 0 88/4096 consoled
6300 8275 10 1360 0 88/4096 consoled
6300 8319 20 1281 0 88/4096 consoled
6300 8321 20 1264 0 88/4096 consoled
6300 8323 10 2410 0 88/4096 consoled
6300 8331 0 1259 0 88/4096 consoled
6300 8332 0 1260 0 88/4096 consoled
6300 8333 0 1263 0 88/4096 consoled
6300 8334 0 1266 0 88/4096 consoled
6300 8335 0 1267 0 88/4096 consoled
6300 8339 0 1251 0 88/4096 consoled
6300 8340 0 1251 0 88/4096 consoled
6300 8341 0 1251 0 88/4096 consoled
6300 8342 30 2402 0 88/4096 consoled
6300 8344 20 2402 0 88/4096 consoled
6300 8345 0 1251 0 88/4096 consoled
6300 8346 0 1251 0 88/4096 consoled
6300 8347 0 1251 0 88/4096 consoled
6300 8350 0 1265 0 88/4096 consoled
6300 8351 0 1265 0 88/4096 consoled
6300 8352 0 1265 0 88/4096 consoled
6300 9049 0 1280 0 88/4096 consoled
6301 600 24946 24 88/4096 console_relay
6301 6301 520 2460 0 88/4096 console_relay
6301 8336 30 2427 0 88/4096 console_relay
6301 8338 0 1361 0 88/4096 console_relay
6301 8367 10 1296 0 88/4096 console_relay
6301 8378 10 1268 0 88/4096 console_relay
6301 8379 10 2420 0 88/4096 console_relay
6301 8380 0 1268 0 88/4096 console_relay
6301 8387 0 1268 0 88/4096 console_relay
6301 8388 0 1268 0 88/4096 console_relay
6301 8389 0 1268 0 88/4096 console_relay
6301 8390 0 2419 0 88/4096 console_relay
6301 8391 20 2419 0 88/4096 console_relay
6301 8392 0 1268 0 88/4096 console_relay
6301 8393 0 1268 0 88/4096 console_relay
6301 8394 0 1268 0 88/4096 console_relay
6302 420 33698 12 88/4096 csprovider
6302 6302 290 1276 0 88/4096 csprovider
6302 7122 40 2424 0 88/4096 csprovider
6302 7123 0 1361 0 88/4096 csprovider
6302 7171 10 1286 0 88/4096 csprovider
6302 7183 0 1261 0 88/4096 csprovider
6302 7185 20 2407 0 88/4096 csprovider
6302 7187 0 1261 0 88/4096 csprovider
6302 7188 0 1253 0 88/4096 csprovider
6302 7189 0 1253 0 88/4096 csprovider
6302 7190 0 1261 0 88/4096 csprovider
6302 7191 0 1261 0 88/4096 csprovider
6302 7212 0 1260 0 88/4096 csprovider
6302 7213 0 1260 0 88/4096 csprovider
6302 7214 0 1260 0 88/4096 csprovider
6302 7231 0 1252 0 88/4096 csprovider
6302 7232 0 1252 0 88/4096 csprovider
6302 7233 0 1252 0 88/4096 csprovider
6302 7267 30 2407 0 88/4096 csprovider
6302 7282 20 2408 0 88/4096 csprovider
6302 7284 0 1255 0 88/4096 csprovider
6302 7285 0 1255 0 88/4096 csprovider
6302 7287 0 1255 0 88/4096 csprovider
6302 9036 10 1278 0 88/4096 csprovider
6303 480 33703 14 88/4096 system_mgr_cli
6303 6303 340 1280 0 88/4096 system_mgr_cli
6303 7151 10 2427 0 88/4096 system_mgr_cli
6303 7155 10 1364 0 88/4096 system_mgr_cli
6303 7339 30 1284 0 88/4096 system_mgr_cli
6303 7362 0 1252 0 88/4096 system_mgr_cli
6303 7363 0 1252 0 88/4096 system_mgr_cli
6303 7364 0 1252 0 88/4096 system_mgr_cli
6303 7388 0 2405 0 88/4096 system_mgr_cli
6303 7389 50 2405 0 88/4096 system_mgr_cli
6303 7390 0 1252 0 88/4096 system_mgr_cli
6303 7391 0 1252 0 88/4096 system_mgr_cli
6303 7392 0 1252 0 88/4096 system_mgr_cli
6303 7393 10 1263 0 88/4096 system_mgr_cli
6303 7394 10 2409 0 88/4096 system_mgr_cli
6303 7396 0 1256 0 88/4096 system_mgr_cli
6303 7397 0 1258 0 88/4096 system_mgr_cli
6303 7398 0 1264 0 88/4096 system_mgr_cli
6303 7399 0 1264 0 88/4096 system_mgr_cli
6303 7400 20 1264 0 88/4096 system_mgr_cli
6303 7429 0 1259 0 88/4096 system_mgr_cli
6303 7430 0 1259 0 88/4096 system_mgr_cli
6303 7431 0 1259 0 88/4096 system_mgr_cli
6303 9057 0 1271 0 88/4096 system_mgr_cli
6304 670 41118 16 88/4096 plogd
6304 6304 600 6039 0 88/4096 plogd
6304 7413 30 2425 0 88/4096 plogd
6304 7432 0 1362 0 88/4096 plogd
6304 7546 10 1311 0 88/4096 plogd
6304 7549 0 1269 0 88/4096 plogd
6304 7550 10 2408 0 88/4096 plogd
6304 7561 0 1250 0 88/4096 plogd
6304 7562 0 1250 0 88/4096 plogd
6304 7563 0 1250 0 88/4096 plogd
6304 7564 0 2403 0 88/4096 plogd
6304 7565 10 2403 0 88/4096 plogd
6304 7566 0 1250 0 88/4096 plogd
6304 7567 0 1250 0 88/4096 plogd
6304 7568 0 1250 0 88/4096 plogd
6304 7571 10 1281 0 88/4096 plogd
6304 7572 0 1268 0 88/4096 plogd
6304 7573 0 1267 0 88/4096 plogd
6304 7574 0 1256 0 88/4096 plogd
6304 7575 0 1255 0 88/4096 plogd
6304 7594 0 1270 0 88/4096 plogd
6304 7595 0 1270 0 88/4096 plogd
6304 7596 0 1270 0 88/4096 plogd
6304 9092 0 1287 0 88/4096 plogd
6304 9222 0 1271 0 88/4096 plogd
6304 9492 0 1303 0 88/4096 plogd
6305 390 33665 11 88/4096 psdprov
6305 6305 290 1269 0 88/4096 psdprov
6305 7158 10 2426 0 88/4096 psdprov
6305 7173 0 1363 0 88/4096 psdprov
6305 7387 20 1282 0 88/4096 psdprov
6305 7395 10 1265 0 88/4096 psdprov
6305 7423 10 2408 0 88/4096 psdprov
6305 7438 0 1252 0 88/4096 psdprov
6305 7439 0 1257 0 88/4096 psdprov
6305 7440 0 1264 0 88/4096 psdprov
6305 7441 0 1264 0 88/4096 psdprov
6305 7442 0 1264 0 88/4096 psdprov
6305 7466 0 1259 0 88/4096 psdprov
6305 7467 0 1259 0 88/4096 psdprov
6305 7468 0 1259 0 88/4096 psdprov
6305 7478 0 1249 0 88/4096 psdprov
6305 7480 0 1249 0 88/4096 psdprov
6305 7481 0 1249 0 88/4096 psdprov
6305 7482 20 2402 0 88/4096 psdprov
6305 7483 20 2402 0 88/4096 psdprov
6305 7484 0 1249 0 88/4096 psdprov
6305 7485 0 1249 0 88/4096 psdprov
6305 7486 0 1249 0 88/4096 psdprov
6305 9086 10 1276 0 88/4096 psdprov
6306 950 70244 13 88/4096 pdsd
6306 6306 230 1274 0 88/4096 pdsd
6306 7198 30 2434 0 88/4096 pdsd
6306 7200 0 1362 0 88/4096 pdsd
6306 7241 0 2434 0 88/4096 pdsd
6306 7499 10 1288 0 88/4096 pdsd
6306 7501 0 1265 0 88/4096 pdsd
6306 7502 0 2415 0 88/4096 pdsd
6306 7503 0 1257 0 88/4096 pdsd
6306 7504 0 1257 0 88/4096 pdsd
6306 7505 0 1265 0 88/4096 pdsd
6306 7506 0 1265 0 88/4096 pdsd
6306 7507 0 1265 0 88/4096 pdsd
6306 7511 0 1260 0 88/4096 pdsd
6306 7512 0 1260 0 88/4096 pdsd
6306 7513 0 1260 0 88/4096 pdsd
6306 7532 0 1254 0 88/4096 pdsd
6306 7533 0 1254 0 88/4096 pdsd
6306 7534 0 1254 0 88/4096 pdsd
6306 7535 10 2412 0 88/4096 pdsd
6306 7536 20 2412 0 88/4096 pdsd
6306 7537 0 1254 0 88/4096 pdsd
6306 7538 0 1254 0 88/4096 pdsd
6306 7539 0 1254 0 88/4096 pdsd
6306 9104 0 1274 0 88/4096 pdsd
6306 9191 240 1859 0 88/4096 pdsd
6306 9192 250 7701 0 88/4096 pdsd
6306 9193 160 24657 0 88/4096 pdsd
6307 860 31636 27 88/4096 gold_slave
6307 6307 680 1297 0 88/4096 gold_slave
6307 8037 10 2428 0 88/4096 gold_slave
6307 8043 30 1308 0 88/4096 gold_slave
6307 8057 10 1310 0 88/4096 gold_slave
6307 8058 20 2413 0 88/4096 gold_slave
6307 8059 0 1250 0 88/4096 gold_slave
6307 8060 0 1303 0 88/4096 gold_slave
6307 8061 0 1304 0 88/4096 gold_slave
6307 8062 0 1310 0 88/4096 gold_slave
6307 8063 10 1333 0 88/4096 gold_slave
6307 8085 0 1252 0 88/4096 gold_slave
6307 8086 0 1252 0 88/4096 gold_slave
6307 8087 0 1252 0 88/4096 gold_slave
6307 8088 40 2408 0 88/4096 gold_slave
6307 8089 20 2408 0 88/4096 gold_slave
6307 8090 0 1252 0 88/4096 gold_slave
6307 8097 0 1252 0 88/4096 gold_slave
6307 8100 0 1252 0 88/4096 gold_slave
6307 8172 10 1398 0 88/4096 gold_slave
6307 8175 0 1300 0 88/4096 gold_slave
6307 8198 30 1375 0 88/4096 gold_slave
6308 2470 40757 60 88/4096 osinfo-provider
6308 6308 250 1311 0 88/4096 osinfo-provider
6308 7494 570 4908 0 88/4096 osinfo-provider
6308 7514 20 1370 0 88/4096 osinfo-provider
6308 7676 10 1304 0 88/4096 osinfo-provider
6308 7677 170 1918 0 88/4096 osinfo-provider
6308 7679 10 2424 0 88/4096 osinfo-provider
6308 7681 0 1266 0 88/4096 osinfo-provider
6308 7682 10 1862 0 88/4096 osinfo-provider
6308 7683 100 2082 0 88/4096 osinfo-provider
6308 7684 90 2027 0 88/4096 osinfo-provider
6308 7685 130 2015 0 88/4096 osinfo-provider
6308 7700 0 1262 0 88/4096 osinfo-provider
6308 7701 0 1262 0 88/4096 osinfo-provider
6308 7702 0 1262 0 88/4096 osinfo-provider
6308 7703 0 2419 0 88/4096 osinfo-provider
6308 7704 20 2419 0 88/4096 osinfo-provider
6308 7705 0 1262 0 88/4096 osinfo-provider
6308 7706 0 1262 0 88/4096 osinfo-provider
6308 7707 0 1262 0 88/4096 osinfo-provider
6308 7717 0 1269 0 88/4096 osinfo-provider
6308 7718 0 1269 0 88/4096 osinfo-provider
6308 7719 0 1269 0 88/4096 osinfo-provider
6308 9033 1550 2285 0 88/4096 osinfo-provider
6308 10339 0 1291 0 88/4096 osinfo-provider
6309 260 33720 7 88/4096 oscore_p
6309 6309 170 1270 0 88/4096 oscore_p
6309 7142 30 2431 0 88/4096 oscore_p
6309 7159 0 1363 0 88/4096 oscore_p
6309 7329 20 1294 0 88/4096 oscore_p
6309 7345 0 1262 0 88/4096 oscore_p
6309 7348 0 2411 0 88/4096 oscore_p
6309 7350 0 1253 0 88/4096 oscore_p
6309 7351 0 1253 0 88/4096 oscore_p
6309 7352 0 1261 0 88/4096 oscore_p
6309 7353 0 1261 0 88/4096 oscore_p
6309 7354 0 1261 0 88/4096 oscore_p
6309 7382 0 1256 0 88/4096 oscore_p
6309 7383 0 1256 0 88/4096 oscore_p
6309 7384 0 1256 0 88/4096 oscore_p
6309 7414 0 1258 0 88/4096 oscore_p
6309 7415 0 1258 0 88/4096 oscore_p
6309 7416 0 1258 0 88/4096 oscore_p
6309 7417 20 2416 0 88/4096 oscore_p
6309 7418 20 2416 0 88/4096 oscore_p
6309 7419 0 1258 0 88/4096 oscore_p
6309 7420 0 1258 0 88/4096 oscore_p
6309 7421 0 1258 0 88/4096 oscore_p
6309 9101 0 1272 0 88/4096 oscore_p
6310 310 32528 9 88/4096 netd
6310 6310 140 1270 0 88/4096 netd
6310 7220 20 2430 0 88/4096 netd
6310 7310 30 1292 0 88/4096 netd
6310 7332 20 1312 0 88/4096 netd
6310 7333 30 2409 0 88/4096 netd
6310 7334 0 1252 0 88/4096 netd
6310 7335 0 1253 0 88/4096 netd
6310 7336 0 1256 0 88/4096 netd
6310 7337 0 1256 0 88/4096 netd
6310 7338 10 1262 0 88/4096 netd
6310 7366 0 1250 0 88/4096 netd
6310 7368 0 1250 0 88/4096 netd
6310 7369 0 1250 0 88/4096 netd
6310 7370 0 2408 0 88/4096 netd
6310 7371 30 2408 0 88/4096 netd
6310 7372 0 1250 0 88/4096 netd
6310 7374 0 1250 0 88/4096 netd
6310 7375 0 1250 0 88/4096 netd
6310 7409 10 1373 0 88/4096 netd
6310 7410 0 1263 0 88/4096 netd
6310 7411 0 1300 0 88/4096 netd
6310 7452 20 1304 0 88/4096 netd
6311 1090 34214 31 88/4096 mem_mgmt
6311 6311 930 2502 0 88/4096 mem_mgmt
6311 7807 40 2445 0 88/4096 mem_mgmt
6311 8034 10 1320 0 88/4096 mem_mgmt
6311 8044 0 1287 0 88/4096 mem_mgmt
6311 8045 30 2443 0 88/4096 mem_mgmt
6311 8064 0 1283 0 88/4096 mem_mgmt
6311 8065 0 1284 0 88/4096 mem_mgmt
6311 8066 0 1287 0 88/4096 mem_mgmt
6311 8067 0 1287 0 88/4096 mem_mgmt
6311 8068 10 1287 0 88/4096 mem_mgmt
6311 8069 0 1285 0 88/4096 mem_mgmt
6311 8070 0 1285 0 88/4096 mem_mgmt
6311 8071 0 1285 0 88/4096 mem_mgmt
6311 8072 20 2441 0 88/4096 mem_mgmt
6311 8073 50 2441 0 88/4096 mem_mgmt
6311 8074 0 1285 0 88/4096 mem_mgmt
6311 8075 0 1285 0 88/4096 mem_mgmt
6311 8076 0 1285 0 88/4096 mem_mgmt
6311 8125 0 1303 0 88/4096 mem_mgmt
6311 8126 0 1303 0 88/4096 mem_mgmt
6311 8127 0 1303 0 88/4096 mem_mgmt
6311 9044 0 1313 0 88/4096 mem_mgmt
6312 330 25959 12 88/4096 mgmte_tap
6312 6312 210 1256 0 88/4096 mgmte_tap
6312 8395 10 2427 0 88/4096 mgmte_tap
6312 8397 0 1362 0 88/4096 mgmte_tap
6312 8399 30 2427 0 88/4096 mgmte_tap
6312 8404 20 1282 0 88/4096 mgmte_tap
6312 8409 20 1254 0 88/4096 mgmte_tap
6312 8410 0 2405 0 88/4096 mgmte_tap
6312 8411 0 1254 0 88/4096 mgmte_tap
6312 8416 0 1251 0 88/4096 mgmte_tap
6312 8417 0 1251 0 88/4096 mgmte_tap
6312 8418 0 1251 0 88/4096 mgmte_tap
6312 8419 0 2406 0 88/4096 mgmte_tap
6312 8420 40 2406 0 88/4096 mgmte_tap
6312 8421 0 1251 0 88/4096 mgmte_tap
6312 8422 0 1251 0 88/4096 mgmte_tap
6312 8423 0 1251 0 88/4096 mgmte_tap
6313 850 59282 14 88/4096 installer
6313 6313 620 1347 0 88/4096 installer
6313 8836 50 2423 0 88/4096 installer
6313 8837 20 1332 0 88/4096 installer
6313 8838 0 1322 0 88/4096 installer
6313 8839 0 1252 0 88/4096 installer
6313 8840 0 1253 0 88/4096 installer
6313 8841 0 1253 0 88/4096 installer
6313 8842 20 2405 0 88/4096 installer
6313 8843 50 2405 0 88/4096 installer
6313 8844 0 1255 0 88/4096 installer
6313 8845 0 1256 0 88/4096 installer
6313 8846 0 1256 0 88/4096 installer
6313 8847 20 2416 0 88/4096 installer
6313 8848 0 1309 0 88/4096 installer
6313 8849 10 1341 0 88/4096 installer
6313 8850 10 1334 0 88/4096 installer
6313 8851 0 1328 0 88/4096 installer
6313 8852 0 1266 0 88/4096 installer
6313 8853 20 1388 0 88/4096 installer
6313 8855 0 1282 0 88/4096 installer
6313 8856 0 1282 0 88/4096 installer
6313 8858 10 1289 0 88/4096 installer
6313 8859 0 1291 0 88/4096 installer
6313 8861 0 1294 0 88/4096 installer
6313 8862 0 1294 0 88/4096 installer
6313 8863 0 1293 0 88/4096 installer
6313 9063 10 1326 0 88/4096 installer
6313 9200 0 1308 0 88/4096 installer
6313 9201 0 1308 0 88/4096 installer
6313 9202 0 1308 0 88/4096 installer
6313 9203 0 1308 0 88/4096 installer
6313 9204 0 1308 0 88/4096 installer
6313 9205 0 1308 0 88/4096 installer
6313 9826 0 1318 0 88/4096 installer
6313 9827 0 1318 0 88/4096 installer
6313 9828 0 1317 0 88/4096 installer
6313 9831 10 1356 0 88/4096 installer
6313 9832 0 1333 0 88/4096 installer
6313 9834 0 1335 0 88/4096 installer
6313 9895 0 1319 0 88/4096 installer
6313 10224 0 1332 0 88/4096 installer
6313 10225 0 1334 0 88/4096 installer
6314 8460 50755 166 88/4096 ffm
6314 6314 8170 3007 0 88/4096 ffm
6314 8891 30 2507 0 88/4096 ffm
6314 8898 10 1447 0 88/4096 ffm
6314 8917 40 1561 0 88/4096 ffm
6314 8922 0 1463 0 88/4096 ffm
6314 8923 0 1463 0 88/4096 ffm
6314 8924 0 1463 0 88/4096 ffm
6314 8925 20 2612 0 88/4096 ffm
6314 8926 10 2612 0 88/4096 ffm
6314 8927 0 1463 0 88/4096 ffm
6314 8928 0 1463 0 88/4096 ffm
6314 8929 0 1463 0 88/4096 ffm
6314 8932 0 1836 0 88/4096 ffm
6314 8933 40 2618 0 88/4096 ffm
6314 8936 0 1470 0 88/4096 ffm
6314 8937 0 1477 0 88/4096 ffm
6314 8938 0 1486 0 88/4096 ffm
6314 8939 0 1488 0 88/4096 ffm
6314 8940 0 1486 0 88/4096 ffm
6314 9001 0 1481 0 88/4096 ffm
6314 9002 0 1481 0 88/4096 ffm
6314 9003 0 1481 0 88/4096 ffm
6314 9067 0 1498 0 88/4096 ffm
6314 9083 30 1826 0 88/4096 ffm
6314 9159 0 1535 0 88/4096 ffm
6314 9806 30 2079 0 88/4096 ffm
6314 9807 0 1628 0 88/4096 ffm
6314 9809 0 1636 0 88/4096 ffm
6314 9878 90 1754 0 88/4096 ffm
6315 29360 112096 261 88/4096 eicored
6315 6315 11500 1580 0 88/4096 eicored
6315 8318 420 3003 0 88/4096 eicored
6315 8329 0 1375 0 88/4096 eicored
6315 8442 30 1444 0 88/4096 eicored
6315 8443 710 4504 0 88/4096 eicored
6315 8444 20 2445 0 88/4096 eicored
6315 8446 160 4422 0 88/4096 eicored
6315 8447 0 1346 0 88/4096 eicored
6315 8448 340 4564 0 88/4096 eicored
6315 8449 520 4797 0 88/4096 eicored
6315 8450 450 4768 0 88/4096 eicored
6315 8452 0 1294 0 88/4096 eicored
6315 8453 0 1294 0 88/4096 eicored
6315 8454 0 1294 0 88/4096 eicored
6315 8455 40 2449 0 88/4096 eicored
6315 8456 40 2449 0 88/4096 eicored
6315 8457 0 1294 0 88/4096 eicored
6315 8458 0 1294 0 88/4096 eicored
6315 8459 0 1294 0 88/4096 eicored
6315 8474 0 1312 0 88/4096 eicored
6315 8475 1670 1847 0 88/4096 eicored
6315 8477 0 1319 0 88/4096 eicored
6315 8478 0 1329 0 88/4096 eicored
6315 8479 10 1339 0 88/4096 eicored
6315 9031 0 1469 0 88/4096 eicored
6315 9072 0 1341 0 88/4096 eicored
6315 9073 0 1336 0 88/4096 eicored
6315 9074 5460 5107 0 88/4096 eicored
6315 9075 0 1513 0 88/4096 eicored
6315 9077 0 1618 0 88/4096 eicored
6315 9078 70 1572 0 88/4096 eicored
6315 9079 30 1612 0 88/4096 eicored
6315 9080 0 1318 0 88/4096 eicored
6315 9103 0 1319 0 88/4096 eicored
6315 9108 0 1318 0 88/4096 eicored
6315 9109 10 1496 0 88/4096 eicored
6315 9114 0 1501 0 88/4096 eicored
6315 9127 8140 3962 0 88/4096 eicored
6315 9130 140 4443 0 88/4096 eicored
6315 9134 0 1522 0 88/4096 eicored
6315 9135 0 1524 0 88/4096 eicored
6315 9136 0 1554 0 88/4096 eicored
6315 9145 360 5096 0 88/4096 eicored
6315 9146 0 1309 0 88/4096 eicored
6315 9150 0 1509 0 88/4096 eicored
6315 9153 0 1509 0 88/4096 eicored
6315 9155 0 1509 0 88/4096 eicored
6315 9194 0 1560 0 88/4096 eicored
6315 9207 0 1562 0 88/4096 eicored
6315 9208 0 1562 0 88/4096 eicored
6315 9209 0 1564 0 88/4096 eicored
6315 9217 20 1689 0 88/4096 eicored
6315 9220 0 1575 0 88/4096 eicored
6315 9500 0 1581 0 88/4096 eicored
6315 9896 0 1562 0 88/4096 eicored
6316 740 38565 19 88/4096 dtmgr
6316 6316 220 1287 0 88/4096 dtmgr
6316 7103 70 2435 0 88/4096 dtmgr
6316 7108 0 1363 0 88/4096 dtmgr
6316 7222 10 1328 0 88/4096 dtmgr
6316 7238 100 1852 0 88/4096 dtmgr
6316 7240 20 2423 0 88/4096 dtmgr
6316 7242 80 1614 0 88/4096 dtmgr
6316 7243 50 1563 0 88/4096 dtmgr
6316 7244 40 1593 0 88/4096 dtmgr
6316 7245 30 1468 0 88/4096 dtmgr
6316 7246 40 1505 0 88/4096 dtmgr
6316 7259 0 1268 0 88/4096 dtmgr
6316 7260 0 1268 0 88/4096 dtmgr
6316 7261 0 1268 0 88/4096 dtmgr
6316 7269 30 2427 0 88/4096 dtmgr
6316 7270 10 2427 0 88/4096 dtmgr
6316 7271 0 1269 0 88/4096 dtmgr
6316 7272 0 1269 0 88/4096 dtmgr
6316 7273 0 1269 0 88/4096 dtmgr
6316 7306 0 1268 0 88/4096 dtmgr
6316 7307 0 1268 0 88/4096 dtmgr
6316 7308 0 1268 0 88/4096 dtmgr
6316 9084 0 1281 0 88/4096 dtmgr
6316 9157 40 1322 0 88/4096 dtmgr
6316 9158 0 1283 0 88/4096 dtmgr
6317 5880 34837 168 88/4096 cpumemd
6317 6317 5810 2432 0 88/4096 cpumemd
6317 7199 30 2431 0 88/4096 cpumemd
6317 7201 0 1363 0 88/4096 cpumemd
6317 7219 10 1287 0 88/4096 cpumemd
6317 7221 0 1258 0 88/4096 cpumemd
6317 7239 30 2418 0 88/4096 cpumemd
6317 7249 0 1259 0 88/4096 cpumemd
6317 7250 0 1259 0 88/4096 cpumemd
6317 7251 0 1260 0 88/4096 cpumemd
6317 7252 0 1260 0 88/4096 cpumemd
6317 7253 0 1260 0 88/4096 cpumemd
6317 7262 0 1255 0 88/4096 cpumemd
6317 7263 0 1256 0 88/4096 cpumemd
6317 7264 0 1255 0 88/4096 cpumemd
6317 7314 10 2418 0 88/4096 cpumemd
6317 7315 10 2418 0 88/4096 cpumemd
6317 7316 0 1260 0 88/4096 cpumemd
6317 7317 0 1260 0 88/4096 cpumemd
6317 7318 0 1260 0 88/4096 cpumemd
6317 7603 0 1248 0 88/4096 cpumemd
6317 7604 0 1248 0 88/4096 cpumemd
6317 7605 0 1248 0 88/4096 cpumemd
6317 7607 0 1249 0 88/4096 cpumemd
6323 480 26031 18 88/4096 liin_tap
6323 6323 270 1301 0 88/4096 liin_tap
6323 7100 40 2431 0 88/4096 liin_tap
6323 7115 0 1363 0 88/4096 liin_tap
6323 7124 60 2431 0 88/4096 liin_tap
6323 9780 30 1282 0 88/4096 liin_tap
6323 9781 0 1259 0 88/4096 liin_tap
6323 9782 10 2396 0 88/4096 liin_tap
6323 9783 10 1259 0 88/4096 liin_tap
6323 9784 0 1257 0 88/4096 liin_tap
6323 9785 0 1257 0 88/4096 liin_tap
6323 9786 0 1257 0 88/4096 liin_tap
6323 9787 20 2396 0 88/4096 liin_tap
6323 9788 40 2396 0 88/4096 liin_tap
6323 9789 0 1257 0 88/4096 liin_tap
6323 9790 0 1257 0 88/4096 liin_tap
6323 9791 0 1257 0 88/4096 liin_tap
6337 3280 49891 65 88/4096 cli_agent
6337 6337 810 1282 0 88/4096 cli_agent
6337 7906 640 3622 0 88/4096 cli_agent
6337 7911 0 1368 0 88/4096 cli_agent
6337 7932 30 1301 0 88/4096 cli_agent
6337 7933 840 3182 0 88/4096 cli_agent
6337 7934 40 2433 0 88/4096 cli_agent
6337 7935 0 1275 0 88/4096 cli_agent
6337 7936 60 3609 0 88/4096 cli_agent
6337 7937 360 3145 0 88/4096 cli_agent
6337 7938 80 3328 0 88/4096 cli_agent
6337 7939 290 3194 0 88/4096 cli_agent
6337 7946 0 1278 0 88/4096 cli_agent
6337 7963 0 1275 0 88/4096 cli_agent
6337 7964 0 1275 0 88/4096 cli_agent
6337 7966 0 1275 0 88/4096 cli_agent
6337 7967 30 2431 0 88/4096 cli_agent
6337 7968 10 2431 0 88/4096 cli_agent
6337 7969 0 1275 0 88/4096 cli_agent
6337 7970 0 1275 0 88/4096 cli_agent
6337 7971 0 1275 0 88/4096 cli_agent
6337 8116 30 1514 0 88/4096 cli_agent
6337 8118 60 1511 0 88/4096 cli_agent
6337 9973 0 1285 0 88/4096 cli_agent
6337 9974 0 1285 0 88/4096 cli_agent
6337 9975 0 1284 0 88/4096 cli_agent
6337 10335 0 1519 0 88/4096 cli_agent
6337 10501 0 1521 0 88/4096 cli_agent
6339 7300 72906 100 88/4096 snmp_subagent
6339 6339 6890 1826 0 88/4096 snmp_subagent
6339 7744 40 2435 0 88/4096 snmp_subagent
6339 7745 0 1365 0 88/4096 snmp_subagent
6339 7980 20 1336 0 88/4096 snmp_subagent
6339 7989 20 1786 0 88/4096 snmp_subagent
6339 7990 20 2434 0 88/4096 snmp_subagent
6339 7991 0 1338 0 88/4096 snmp_subagent
6339 7992 30 1676 0 88/4096 snmp_subagent
6339 7993 0 1664 0 88/4096 snmp_subagent
6339 7994 0 1291 0 88/4096 snmp_subagent
6339 7995 70 1674 0 88/4096 snmp_subagent
6339 8003 0 1291 0 88/4096 snmp_subagent
6339 8004 0 1291 0 88/4096 snmp_subagent
6339 8005 0 1291 0 88/4096 snmp_subagent
6339 8006 40 2447 0 88/4096 snmp_subagent
6339 8007 40 2447 0 88/4096 snmp_subagent
6339 8008 0 1291 0 88/4096 snmp_subagent
6339 8009 0 1291 0 88/4096 snmp_subagent
6339 8010 0 1291 0 88/4096 snmp_subagent
6339 8031 0 1341 0 88/4096 snmp_subagent
6339 8091 0 1329 0 88/4096 snmp_subagent
6339 8093 0 1329 0 88/4096 snmp_subagent
6339 8095 0 1329 0 88/4096 snmp_subagent
6339 8122 90 1463 0 88/4096 snmp_subagent
6339 8135 10 1387 0 88/4096 snmp_subagent
6339 8225 0 1332 0 88/4096 snmp_subagent
6339 8226 0 1332 0 88/4096 snmp_subagent
6339 8227 0 1332 0 88/4096 snmp_subagent
6339 9779 0 1457 0 88/4096 snmp_subagent
6339 9793 20 1879 0 88/4096 snmp_subagent
6339 9796 10 1823 0 88/4096 snmp_subagent
6339 9798 0 1826 0 88/4096 snmp_subagent
6339 9799 0 1826 0 88/4096 snmp_subagent
6339 9800 0 1826 0 88/4096 snmp_subagent
6339 9801 0 1826 0 88/4096 snmp_subagent
6339 10472 0 4272 0 88/4096 snmp_subagent
6339 10495 0 4248 0 88/4096 snmp_subagent
6339 10497 0 4192 0 88/4096 snmp_subagent
6339 10500 0 4166 0 88/4096 snmp_subagent
6341 330 34911 9 88/4096 erm_p
6341 6341 210 2443 0 88/4096 erm_p
6341 7172 20 2433 0 88/4096 erm_p
6341 7174 0 1365 0 88/4096 erm_p
6341 7386 40 1283 0 88/4096 erm_p
6341 7437 0 1264 0 88/4096 erm_p
6341 7446 10 2412 0 88/4096 erm_p
6341 7447 0 1255 0 88/4096 erm_p
6341 7448 0 1255 0 88/4096 erm_p
6341 7449 0 1262 0 88/4096 erm_p
6341 7450 0 1262 0 88/4096 erm_p
6341 7451 0 1262 0 88/4096 erm_p
6341 7453 0 1257 0 88/4096 erm_p
6341 7454 0 1257 0 88/4096 erm_p
6341 7455 0 1257 0 88/4096 erm_p
6341 7463 20 2415 0 88/4096 erm_p
6341 7470 30 2417 0 88/4096 erm_p
6341 7471 0 1259 0 88/4096 erm_p
6341 7472 0 1259 0 88/4096 erm_p
6341 7473 0 1259 0 88/4096 erm_p
6341 7476 0 1262 0 88/4096 erm_p
6341 7477 0 1262 0 88/4096 erm_p
6341 7479 0 1262 0 88/4096 erm_p
6341 9111 0 1274 0 88/4096 erm_p
6342 440 35051 12 88/4096 ngdumper_provid
6342 6342 300 2448 0 88/4096 ngdumper_provid
6342 8573 20 2428 0 88/4096 ngdumper_provid
6342 8574 0 1364 0 88/4096 ngdumper_provid
6342 8600 30 1295 0 88/4096 ngdumper_provid
6342 8602 0 1271 0 88/4096 ngdumper_provid
6342 8603 10 2419 0 88/4096 ngdumper_provid
6342 8604 0 1261 0 88/4096 ngdumper_provid
6342 8605 0 1261 0 88/4096 ngdumper_provid
6342 8606 0 1269 0 88/4096 ngdumper_provid
6342 8607 0 1269 0 88/4096 ngdumper_provid
6342 8608 10 1269 0 88/4096 ngdumper_provid
6342 8610 0 1264 0 88/4096 ngdumper_provid
6342 8611 0 1264 0 88/4096 ngdumper_provid
6342 8612 0 1264 0 88/4096 ngdumper_provid
6342 8614 0 1268 0 88/4096 ngdumper_provid
6342 8615 0 1268 0 88/4096 ngdumper_provid
6342 8616 0 1268 0 88/4096 ngdumper_provid
6342 8617 50 2422 0 88/4096 ngdumper_provid
6342 8618 20 2422 0 88/4096 ngdumper_provid
6342 8619 0 1268 0 88/4096 ngdumper_provid
6342 8620 0 1268 0 88/4096 ngdumper_provid
6342 8621 0 1268 0 88/4096 ngdumper_provid
6342 9089 0 1279 0 88/4096 ngdumper_provid
6343 460 34972 13 88/4096 sysinfo_p
6343 6343 350 2449 0 88/4096 sysinfo_p
6343 7783 20 2431 0 88/4096 sysinfo_p
6343 7792 0 1364 0 88/4096 sysinfo_p
6343 7860 20 1282 0 88/4096 sysinfo_p
6343 7863 0 1271 0 88/4096 sysinfo_p
6343 7866 20 2418 0 88/4096 sysinfo_p
6343 7867 0 1258 0 88/4096 sysinfo_p
6343 7868 0 1265 0 88/4096 sysinfo_p
6343 7869 0 1270 0 88/4096 sysinfo_p
6343 7870 0 1270 0 88/4096 sysinfo_p
6343 7871 0 1270 0 88/4096 sysinfo_p
6343 7874 0 1263 0 88/4096 sysinfo_p
6343 7875 0 1263 0 88/4096 sysinfo_p
6343 7876 0 1263 0 88/4096 sysinfo_p
6343 7882 0 1258 0 88/4096 sysinfo_p
6343 7883 0 1258 0 88/4096 sysinfo_p
6343 7884 0 1258 0 88/4096 sysinfo_p
6343 7885 20 2415 0 88/4096 sysinfo_p
6343 7887 30 2415 0 88/4096 sysinfo_p
6343 7888 0 1258 0 88/4096 sysinfo_p
6343 7890 0 1258 0 88/4096 sysinfo_p
6343 7891 0 1258 0 88/4096 sysinfo_p
6343 9039 0 1283 0 88/4096 sysinfo_p
6354 90 5049 17 88/4096 fs_cmd
6354 6354 80 1250 0 88/4096 fs_cmd
6354 7076 10 2436 0 88/4096 fs_cmd
6354 7085 0 1368 0 88/4096 fs_cmd
8563 480 1400 342 88/4096 rollback_timer.
8670 0 1391 0 88/4096 rollback_timer.
8672 90 1394 64 88/4096 xlogger
8675 0 1395 0 88/4096 inotifywait
8873 170 1176 144 88/8192 nova_sntp.sh
9024 0 1174 0 88/8192 nova_sntp.sh
9025 160 1174 136 88/8192 xlogger
9028 10 1180 8 88/8192 sntp
9248 1150 82382 13 88/4096 table_mgr
9248 9248 720 1341 0 88/4096 table_mgr
9248 9490 10 2461 0 88/4096 table_mgr
9248 9491 10 1408 0 88/4096 table_mgr
9248 9505 30 1397 0 88/4096 table_mgr
9248 9514 40 1390 0 88/4096 table_mgr
9248 9515 30 2441 0 88/4096 table_mgr
9248 9516 0 1301 0 88/4096 table_mgr
9248 9517 0 1312 0 88/4096 table_mgr
9248 9518 0 1327 0 88/4096 table_mgr
9248 9519 0 1325 0 88/4096 table_mgr
9248 9520 20 1330 0 88/4096 table_mgr
9248 9523 0 1300 0 88/4096 table_mgr
9248 9524 0 1300 0 88/4096 table_mgr
9248 9525 0 1305 0 88/4096 table_mgr
9248 9526 0 2442 0 88/4096 table_mgr
9248 9527 20 2442 0 88/4096 table_mgr
9248 9528 0 1300 0 88/4096 table_mgr
9248 9529 0 1300 0 88/4096 table_mgr
9248 9530 0 1301 0 88/4096 table_mgr
9248 9534 20 1363 0 88/4096 table_mgr
9248 9536 0 1341 0 88/4096 table_mgr
9248 9554 0 1310 0 88/4096 table_mgr
9248 9555 0 1310 0 88/4096 table_mgr
9248 9556 0 1310 0 88/4096 table_mgr
9248 9564 10 1350 0 88/4096 table_mgr
9248 9568 0 1402 0 88/4096 table_mgr
9248 9569 240 35462 0 88/4096 table_mgr
9248 9570 0 1325 0 88/4096 table_mgr
9248 9571 0 1325 0 88/4096 table_mgr
9248 9611 0 1329 0 88/4096 table_mgr
9248 9612 0 1329 0 88/4096 table_mgr
9248 9613 0 1329 0 88/4096 table_mgr
9248 9635 0 1343 0 88/4096 table_mgr
9249 90 1418 63 88/4096 wnweb.sh
9250 750 36793 20 88/4096 iifd
9250 9250 470 1597 0 88/4096 iifd
9250 9410 20 2467 0 88/4096 iifd
9250 9413 0 1408 0 88/4096 iifd
9250 9424 10 1336 0 88/4096 iifd
9250 9425 70 1634 0 88/4096 iifd
9250 9426 20 2442 0 88/4096 iifd
9250 9428 0 1293 0 88/4096 iifd
9250 9429 0 1293 0 88/4096 iifd
9250 9430 0 1301 0 88/4096 iifd
9250 9431 0 1301 0 88/4096 iifd
9250 9432 0 1301 0 88/4096 iifd
9250 9433 100 1587 0 88/4096 iifd
9250 9445 0 1294 0 88/4096 iifd
9250 9446 0 1294 0 88/4096 iifd
9250 9447 0 1294 0 88/4096 iifd
9250 9448 0 2436 0 88/4096 iifd
9250 9449 60 2436 0 88/4096 iifd
9250 9450 0 1294 0 88/4096 iifd
9250 9451 0 1294 0 88/4096 iifd
9250 9452 0 1294 0 88/4096 iifd
9250 9479 0 1301 0 88/4096 iifd
9250 9480 0 1301 0 88/4096 iifd
9250 9481 0 1301 0 88/4096 iifd
9250 9512 0 1314 0 88/4096 iifd
9251 346440 1827040 189 92/8192 iosd
9251 9251 102720 1733171 0 92/8192 iosd
9251 9885 245500 103100 0 92/8192 iosd
9251 9886 120 2077 0 92/8192 iosd
9252 860 40338 21 88/4096 ha_mgr
9252 9252 510 1358 0 88/4096 ha_mgr
9252 9406 50 2463 0 88/4096 ha_mgr
9252 9409 20 1379 0 88/4096 ha_mgr
9252 9417 70 1674 0 88/4096 ha_mgr
9252 9418 20 2448 0 88/4096 ha_mgr
9252 9419 30 1544 0 88/4096 ha_mgr
9252 9420 10 1511 0 88/4096 ha_mgr
9252 9421 0 1370 0 88/4096 ha_mgr
9252 9422 10 1502 0 88/4096 ha_mgr
9252 9423 30 1523 0 88/4096 ha_mgr
9252 9427 0 1302 0 88/4096 ha_mgr
9252 9434 0 1302 0 88/4096 ha_mgr
9252 9435 0 1302 0 88/4096 ha_mgr
9252 9436 20 2444 0 88/4096 ha_mgr
9252 9437 40 2444 0 88/4096 ha_mgr
9252 9438 0 1302 0 88/4096 ha_mgr
9252 9439 0 1302 0 88/4096 ha_mgr
9252 9440 0 1302 0 88/4096 ha_mgr
9252 9443 0 1424 0 88/4096 ha_mgr
9252 9455 50 1464 0 88/4096 ha_mgr
9252 9456 0 1336 0 88/4096 ha_mgr
9252 9462 0 1326 0 88/4096 ha_mgr
9252 9507 0 1329 0 88/4096 ha_mgr
9252 9508 0 1329 0 88/4096 ha_mgr
9252 9509 0 1329 0 88/4096 ha_mgr
9252 9562 0 1349 0 88/4096 ha_mgr
10011 11870 67847 174 236/4096 wnweb_paster.py
10011 10011 11800 3192 0 236/4096 wnweb_paster.py
10011 10029 0 2017 0 236/4096 wnweb_paster.py
10011 10030 0 1997 0 236/4096 wnweb_paster.py
10011 10031 30 3068 0 236/4096 wnweb_paster.py
10011 10032 0 1995 0 236/4096 wnweb_paster.py
10011 10033 0 1999 0 236/4096 wnweb_paster.py
10011 10034 0 2016 0 236/4096 wnweb_paster.py
10011 10035 10 2006 0 236/4096 wnweb_paster.py
10011 10036 0 1987 0 236/4096 wnweb_paster.py
10011 10037 0 1987 0 236/4096 wnweb_paster.py
10011 10038 0 1987 0 236/4096 wnweb_paster.py
10011 10039 0 1987 0 236/4096 wnweb_paster.py
10011 10040 0 3067 0 236/4096 wnweb_paster.py
10011 10041 10 3067 0 236/4096 wnweb_paster.py
10011 10042 0 1987 0 236/4096 wnweb_paster.py
10011 10043 0 1987 0 236/4096 wnweb_paster.py
10011 10044 0 1987 0 236/4096 wnweb_paster.py
10011 10045 0 1998 0 236/4096 wnweb_paster.py
10011 10046 0 1998 0 236/4096 wnweb_paster.py
10011 10047 0 1997 0 236/4096 wnweb_paster.py
10011 10048 20 3104 0 236/4096 wnweb_paster.py
10011 10049 0 2023 0 236/4096 wnweb_paster.py
10011 10050 0 2017 0 236/4096 wnweb_paster.py
10011 10051 0 2022 0 236/4096 wnweb_paster.py
10011 10052 0 2030 0 236/4096 wnweb_paster.py
10011 10053 0 2038 0 236/4096 wnweb_paster.py
10011 10054 0 2046 0 236/4096 wnweb_paster.py
10011 10055 0 2054 0 236/4096 wnweb_paster.py
10011 10056 0 2063 0 236/4096 wnweb_paster.py
10011 10057 0 2071 0 236/4096 wnweb_paster.py
10011 10058 0 2079 0 236/4096 wnweb_paster.py
10012 360 1418 253 88/4096 xlogger
10489 0 1508 0 88/4096 sleep
------------------ show redundancy history ------------------
00:00:00 *my state = INITIALIZATION(2) peer state = DISABLED(1)
00:00:00 RF_EVENT_INITIALIZATION(524) op=0 rc=0
00:00:00 *my state = NEGOTIATION(3) peer state = DISABLED(1)
00:00:01 client added: EICORE HA Client(20002) seq=4
00:00:01 client added: SNMP SA HA Client(20010) seq=24
00:00:02 client added: Table Manager Client(24001) seq=21
00:00:12 client added: Installer HA Client(20007) seq=27
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) First Slave(0) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(6313) op=0 rc=0
00:00:20 RF_EVENT_SLAVE_STATUS_DONE(523) First Slave(0) op=405 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(6315) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(6339) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(9248) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(9251) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) EICORE HA Client(20002) op=0 rc=0
00:00:20 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6315) op=405 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Table Manager Client(24001) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Installer HA Client(20007) op=0 rc=0
00:00:20 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(9248) op=405 rc=0
00:00:20 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6313) op=405 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SNMP SA HA Client(20010) op=0 rc=0
00:00:20 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6339) op=405 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Redundancy Mode RF(29) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IfIndex(139) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Persistent Variable(3300) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CHKPT RF(25) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IIF-shim(20005) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) QEMU Platform RF(10001) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Event Manager(77) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Network RF Client(22) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch VTP VLAN(501) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) XDR RRP RF Client(71) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CEF RRP RF Client(24) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) FFM RF(2900) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Config Sync RF client(5) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) NG3K OIR Rf client(10002) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) NG3K SES Rf client(10003) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) NGWC FEC Rf client(10007) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch Port Manager(502) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Mac address Table Manager(519) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCPD(101) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SNMP RF Client(34) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) History RF Client(35) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ARP(57) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Smart Install RF(1112) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Config Verify RF client(94) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Platform Inline Power(10005) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Platform Manager SPI(10008) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Inline Power rf client(505) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Port Security(508) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Switch IP Device Tracking(509) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SISF table(515) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CRYPTO RSA(130) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IP Admission RF Client(400) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ISSU Test Client(4005) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch PAgP/LACP(510) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ARCHIVE(4020) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ROLLBACK(4021) op=0 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Online Diag HA(4056) op=0 rc=0
00:00:20 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(9251) op=405 rc=0
00:00:20 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Last Slave(65000) op=0 rc=0
00:00:20 RF_EVENT_SLAVE_STATUS_DONE(523) Last Slave(65000) op=0 rc=0
00:00:21 client added: Redundancy Mode RF(29) seq=60
00:00:21 client added: IfIndex(139) seq=61
00:00:21 client added: Persistent Variable(3300) seq=62
00:00:21 client added: CHKPT RF(25) seq=68
00:00:21 client added: IIF-shim(20005) seq=74
00:00:21 client added: QEMU Platform RF(10001) seq=82
00:00:21 client added: Event Manager(77) seq=84
00:00:21 client added: Network RF Client(22) seq=109
00:00:21 client added: LAN-Switch VTP VLAN(501) seq=132
00:00:21 client added: XDR RRP RF Client(71) seq=134
00:00:21 client added: CEF RRP RF Client(24) seq=135
00:00:21 client added: FFM RF(2900) seq=136
00:00:21 client added: RFS RF(520) seq=157
00:00:21 client added: Config Sync RF client(5) seq=159
00:00:21 client added: NG3K OIR Rf client(10002) seq=161
00:00:21 client added: NG3K SES Rf client(10003) seq=162
00:00:21 client added: NGWC FEC Rf client(10007) seq=164
00:00:21 client added: LAN-Switch Port Manager(502) seq=176
00:00:21 client added: Mac address Table Manager(519) seq=178
00:00:21 client added: DHCPD(101) seq=221
00:00:21 client added: SNMP RF Client(34) seq=233
00:00:21 client added: History RF Client(35) seq=243
00:00:21 client added: ARP(57) seq=273
00:00:21 client added: Smart Install RF(1112) seq=294
00:00:21 client added: Config Verify RF client(94) seq=341
00:00:21 client added: Platform Inline Power(10005) seq=343
00:00:21 client added: Platform Manager SPI(10008) seq=344
00:00:21 client added: Inline Power rf client(505) seq=345
00:00:21 client added: Port Security(508) seq=348
00:00:21 client added: Switch IP Device Tracking(509) seq=349
00:00:21 client added: SISF table(515) seq=350
00:00:21 client added: CRYPTO RSA(130) seq=356
00:00:21 client added: IP Admission RF Client(400) seq=358
00:00:21 client added: ISSU Test Client(4005) seq=371
00:00:21 client added: Network RF 2 Client(93) seq=375
00:00:21 client added: LAN-Switch PAgP/LACP(510) seq=378
00:00:21 client added: DATA DESCRIPTOR RF CLIENT(141) seq=385
00:00:21 client added: IOS Config ARCHIVE(4020) seq=415
00:00:21 client added: IOS Config ROLLBACK(4021) seq=416
00:00:21 client added: Online Diag HA(4056) seq=461
00:00:21 client added: NG3K CFG MGR(10004) seq=462
00:00:24 RF_EVENT_GO_ACTIVE(512) op=0 rc=0
00:00:24 *my state = ACTIVE-FAST(9) peer state = DISABLED(1)
00:00:24 RF_PROG_ACTIVE_FAST(200) First Slave(0) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Slave(6313) op=0 rc=23
00:00:24 RF_PROG_ACTIVE_FAST(200) Slave(6315) op=0 rc=23
00:00:24 RF_PROG_ACTIVE_FAST(200) Slave(6339) op=0 rc=23
00:00:24 RF_PROG_ACTIVE_FAST(200) Slave(9248) op=0 rc=23
00:00:24 RF_PROG_ACTIVE_FAST(200) Slave(9251) op=0 rc=23
00:00:24 RF_PROG_ACTIVE_FAST(200) Redundancy Mode RF(29) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) IfIndex(139) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Persistent Variable(3300) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) CHKPT RF(25) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) IIF-shim(20005) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) QEMU Platform RF(10001) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Event Manager(77) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Installer HA Client(20007) op=0 rc=0
00:00:24 RF_EVENT_LOCAL_PROG_DONE(505) Installer HA Client(20007) op=200 rc=11
00:00:24 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6313) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) SNMP SA HA Client(20010) op=0 rc=0
00:00:24 RF_PROG_ACTIVE_FAST(200) Table Manager Client(24001) op=0 rc=0
00:00:24 RF_EVENT_LOCAL_PROG_DONE(505) SNMP SA HA Client(20010) op=200 rc=11
00:00:24 RF_EVENT_LOCAL_PROG_DONE(505) Table Manager Client(24001) op=200 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) EICORE HA Client(20002) op=0 rc=0
00:00:24 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6339) op=0 rc=11
00:00:24 RF_EVENT_SLAVE_PROG_DONE(522) Slave(9248) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Network RF Client(22) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) XDR RRP RF Client(71) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) CEF RRP RF Client(24) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) FFM RF(2900) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) RFS RF(520) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Config Sync RF client(5) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) NG3K OIR Rf client(10002) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) NG3K SES Rf client(10003) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) NGWC FEC Rf client(10007) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) LAN-Switch Port Manager(502) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Mac address Table Manager(519) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) DHCPD(101) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) SNMP RF Client(34) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) History RF Client(35) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) ARP(57) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Smart Install RF(1112) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Config Verify RF client(94) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Platform Inline Power(10005) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Platform Manager SPI(10008) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Inline Power rf client(505) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Port Security(508) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Switch IP Device Tracking(509) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) SISF table(515) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) CRYPTO RSA(130) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) IP Admission RF Client(400) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) ISSU Test Client(4005) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Network RF 2 Client(93) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) Online Diag HA(4056) op=0 rc=11
00:00:24 RF_PROG_ACTIVE_FAST(200) NG3K CFG MGR(10004) op=0 rc=11
00:00:24 RF_EVENT_SLAVE_PROG_DONE(522) Slave(9251) op=0 rc=11
00:00:25 RF_EVENT_LOCAL_PROG_DONE(505) EICORE HA Client(20002) op=200 rc=11
00:00:25 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6315) op=0 rc=11
00:00:25 RF_PROG_ACTIVE_FAST(200) Last Slave(65000) op=0 rc=11
00:00:25 *my state = ACTIVE-DRAIN(10) peer state = DISABLED(1)
00:00:25 RF_PROG_ACTIVE_DRAIN(201) First Slave(0) op=0 rc=11
00:00:25 RF_PROG_ACTIVE_DRAIN(201) Slave(6313) op=0 rc=23
00:00:25 RF_PROG_ACTIVE_DRAIN(201) Slave(6315) op=0 rc=23
00:00:25 RF_PROG_ACTIVE_DRAIN(201) Slave(6339) op=0 rc=23
00:00:25 RF_PROG_ACTIVE_DRAIN(201) Slave(9248) op=0 rc=23
00:00:25 RF_PROG_ACTIVE_DRAIN(201) Slave(9251) op=0 rc=23
00:00:25 RF_PROG_ACTIVE_DRAIN(201) EICORE HA Client(20002) op=0 rc=11
00:00:25 RF_PROG_ACTIVE_DRAIN(201) Installer HA Client(20007) op=0 rc=11
00:00:25 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6313) op=0 rc=11
00:00:25 RF_PROG_ACTIVE_DRAIN(201) Table Manager Client(24001) op=0 rc=11
00:00:25 RF_PROG_ACTIVE_DRAIN(201) SNMP SA HA Client(20010) op=0 rc=11
00:00:25 RF_EVENT_SLAVE_PROG_DONE(522) Slave(9248) op=0 rc=11
00:00:25 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6339) op=0 rc=11
00:00:27 client added: Auth Mgr(210) seq=158
00:00:27 client added: LLDP(208) seq=207
00:00:27 client added: Switch Backup Interface client(507) seq=324
00:00:27 client added: PASSWD RF Client(4058) seq=419
00:00:29 client added: AAA(69) seq=239
00:00:30 client added: IPROUTING NSF RF client(20) seq=218
00:00:30 client added: IOS Config SHELL(4022) seq=414
00:00:30 client added: Tableid HA(75) seq=125
00:00:30 client added: Spanning-Tree Protocol(503) seq=296
00:00:30 client added: Igmp Snooping(506) seq=347
00:00:30 client added: MLD Snooping(521) seq=452
00:00:31 client added: DHCP Snooping(105) seq=327
00:00:32 client added: SNMP HA RF Client(54) seq=271
00:00:32 client added: Call-Home RF(1510) seq=333
00:00:32 client added: FH_RF_Event_Detector_stub(50) seq=280
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Redundancy Mode RF(29) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) IfIndex(139) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Persistent Variable(3300) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) CHKPT RF(25) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) IIF-shim(20005) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) QEMU Platform RF(10001) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Event Manager(77) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Network RF Client(22) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Tableid HA(75) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) XDR RRP RF Client(71) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) CEF RRP RF Client(24) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) FFM RF(2900) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) RFS RF(520) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Auth Mgr(210) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Config Sync RF client(5) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) NG3K OIR Rf client(10002) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) NG3K SES Rf client(10003) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) NGWC FEC Rf client(10007) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch Port Manager(502) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Mac address Table Manager(519) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) LLDP(208) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) IPROUTING NSF RF client(20) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) DHCPD(101) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) SNMP RF Client(34) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) AAA(69) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) History RF Client(35) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) SNMP HA RF Client(54) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) ARP(57) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Smart Install RF(1112) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Spanning-Tree Protocol(503) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Switch Backup Interface client(507) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) DHCP Snooping(105) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Call-Home RF(1510) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Config Verify RF client(94) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Platform Inline Power(10005) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Platform Manager SPI(10008) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Inline Power rf client(505) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Igmp Snooping(506) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Port Security(508) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Switch IP Device Tracking(509) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) SISF table(515) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) CRYPTO RSA(130) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) IP Admission RF Client(400) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) ISSU Test Client(4005) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Network RF 2 Client(93) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) IOS Config SHELL(4022) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) PASSWD RF Client(4058) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) MLD Snooping(521) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Online Diag HA(4056) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) NG3K CFG MGR(10004) op=0 rc=11
00:00:32 RF_EVENT_SLAVE_PROG_DONE(522) Slave(9251) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_DRAIN(201) Last Slave(65000) op=0 rc=11
00:00:32 *my state = ACTIVE_PRECONFIG(11) peer state = DISABLED(1)
00:00:32 RF_PROG_ACTIVE_PRECONFIG(202) First Slave(0) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_PRECONFIG(202) Slave(6313) op=0 rc=23
00:00:32 RF_PROG_ACTIVE_PRECONFIG(202) Slave(6315) op=0 rc=23
00:00:32 RF_PROG_ACTIVE_PRECONFIG(202) Slave(6339) op=0 rc=23
00:00:32 RF_PROG_ACTIVE_PRECONFIG(202) Slave(9248) op=0 rc=23
00:00:32 RF_PROG_ACTIVE_PRECONFIG(202) Slave(9251) op=0 rc=23
00:00:32 RF_PROG_ACTIVE_PRECONFIG(202) Table Manager Client(24001) op=0 rc=11
00:00:32 RF_EVENT_SLAVE_PROG_DONE(522) Slave(9248) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_PRECONFIG(202) EICORE HA Client(20002) op=0 rc=11
00:00:32 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6315) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_PRECONFIG(202) Installer HA Client(20007) op=0 rc=11
00:00:32 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6313) op=0 rc=11
00:00:32 RF_PROG_ACTIVE_PRECONFIG(202) SNMP SA HA Client(20010) op=0 rc=11
00:00:32 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6339) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Redundancy Mode RF(29) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IfIndex(139) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Persistent Variable(3300) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CHKPT RF(25) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IIF-shim(20005) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) QEMU Platform RF(10001) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Event Manager(77) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Network RF Client(22) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Tableid HA(75) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) XDR RRP RF Client(71) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CEF RRP RF Client(24) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) FFM RF(2900) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) RFS RF(520) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Auth Mgr(210) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Config Sync RF client(5) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) NG3K OIR Rf client(10002) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) NG3K SES Rf client(10003) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) NGWC FEC Rf client(10007) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch Port Manager(502) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Mac address Table Manager(519) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LLDP(208) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IPROUTING NSF RF client(20) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) DHCPD(101) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) SNMP RF Client(34) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) AAA(69) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) History RF Client(35) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) SNMP HA RF Client(54) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) ARP(57) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Smart Install RF(1112) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Spanning-Tree Protocol(503) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Switch Backup Interface client(507) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) DHCP Snooping(105) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Call-Home RF(1510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Config Verify RF client(94) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Platform Inline Power(10005) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Platform Manager SPI(10008) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Inline Power rf client(505) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Igmp Snooping(506) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Port Security(508) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Switch IP Device Tracking(509) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) SISF table(515) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) CRYPTO RSA(130) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IP Admission RF Client(400) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) ISSU Test Client(4005) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Network RF 2 Client(93) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IOS Config SHELL(4022) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) PASSWD RF Client(4058) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) MLD Snooping(521) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Online Diag HA(4056) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) NG3K CFG MGR(10004) op=0 rc=11
00:00:33 RF_EVENT_SLAVE_PROG_DONE(522) Slave(9251) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_PRECONFIG(202) Last Slave(65000) op=0 rc=11
00:00:33 *my state = ACTIVE_POSTCONFIG(12) peer state = DISABLED(1)
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) First Slave(0) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Slave(6313) op=0 rc=23
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Slave(6315) op=0 rc=23
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Slave(6339) op=0 rc=23
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Slave(9248) op=0 rc=23
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Slave(9251) op=0 rc=23
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Table Manager Client(24001) op=0 rc=11
00:00:33 RF_EVENT_SLAVE_PROG_DONE(522) Slave(9248) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) SNMP SA HA Client(20010) op=0 rc=11
00:00:33 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6339) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Installer HA Client(20007) op=0 rc=11
00:00:33 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6313) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) EICORE HA Client(20002) op=0 rc=11
00:00:33 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6315) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Redundancy Mode RF(29) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IfIndex(139) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Persistent Variable(3300) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CHKPT RF(25) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IIF-shim(20005) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) QEMU Platform RF(10001) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Event Manager(77) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Network RF Client(22) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Tableid HA(75) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) XDR RRP RF Client(71) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CEF RRP RF Client(24) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) FFM RF(2900) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) RFS RF(520) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Auth Mgr(210) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Config Sync RF client(5) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) NG3K OIR Rf client(10002) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) NG3K SES Rf client(10003) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) NGWC FEC Rf client(10007) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch Port Manager(502) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Mac address Table Manager(519) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LLDP(208) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IPROUTING NSF RF client(20) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) DHCPD(101) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) SNMP RF Client(34) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) AAA(69) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) History RF Client(35) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) SNMP HA RF Client(54) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) ARP(57) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Smart Install RF(1112) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Spanning-Tree Protocol(503) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Switch Backup Interface client(507) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) DHCP Snooping(105) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Call-Home RF(1510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Config Verify RF client(94) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Platform Inline Power(10005) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Platform Manager SPI(10008) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Inline Power rf client(505) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Igmp Snooping(506) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Port Security(508) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Switch IP Device Tracking(509) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) SISF table(515) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) CRYPTO RSA(130) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IP Admission RF Client(400) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) ISSU Test Client(4005) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Network RF 2 Client(93) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IOS Config SHELL(4022) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) PASSWD RF Client(4058) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) MLD Snooping(521) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Online Diag HA(4056) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) NG3K CFG MGR(10004) op=0 rc=11
00:00:33 RF_PROG_ACTIVE_POSTCONFIG(203) Last Slave(65000) op=0 rc=11
00:00:33 *my state = ACTIVE(13) peer state = DISABLED(1)
00:00:33 RF_PROG_ACTIVE(204) First Slave(0) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Slave(6313) op=0 rc=23
00:00:33 RF_PROG_ACTIVE(204) Slave(6315) op=0 rc=23
00:00:33 RF_PROG_ACTIVE(204) Slave(6339) op=0 rc=23
00:00:33 RF_PROG_ACTIVE(204) Slave(9248) op=0 rc=23
00:00:33 RF_PROG_ACTIVE(204) Slave(9251) op=0 rc=23
00:00:33 RF_PROG_ACTIVE(204) EICORE HA Client(20002) op=0 rc=0
00:00:33 RF_PROG_ACTIVE(204) Table Manager Client(24001) op=0 rc=0
00:00:33 RF_PROG_ACTIVE(204) Installer HA Client(20007) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Installer HA Client(20007) op=204 rc=11
00:00:33 RF_PROG_ACTIVE(204) SNMP SA HA Client(20010) op=0 rc=0
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) SNMP SA HA Client(20010) op=204 rc=11
00:00:33 RF_EVENT_LOCAL_PROG_DONE(505) Table Manager Client(24001) op=204 rc=11
00:00:33 RF_PROG_ACTIVE(204) Redundancy Mode RF(29) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) IfIndex(139) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Persistent Variable(3300) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) CHKPT RF(25) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) IIF-shim(20005) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) QEMU Platform RF(10001) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Event Manager(77) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Network RF Client(22) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Tableid HA(75) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) LAN-Switch VTP VLAN(501) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) XDR RRP RF Client(71) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) CEF RRP RF Client(24) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) FFM RF(2900) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) RFS RF(520) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Auth Mgr(210) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Config Sync RF client(5) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) NG3K OIR Rf client(10002) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) NG3K SES Rf client(10003) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) NGWC FEC Rf client(10007) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) LAN-Switch Port Manager(502) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Mac address Table Manager(519) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) LLDP(208) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) IPROUTING NSF RF client(20) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) DHCPD(101) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) SNMP RF Client(34) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) AAA(69) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) History RF Client(35) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) SNMP HA RF Client(54) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) ARP(57) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Smart Install RF(1112) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Spanning-Tree Protocol(503) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Switch Backup Interface client(507) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) DHCP Snooping(105) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Call-Home RF(1510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Config Verify RF client(94) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Platform Inline Power(10005) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Platform Manager SPI(10008) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Inline Power rf client(505) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Igmp Snooping(506) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Port Security(508) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Switch IP Device Tracking(509) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) SISF table(515) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) CRYPTO RSA(130) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) IP Admission RF Client(400) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) ISSU Test Client(4005) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Network RF 2 Client(93) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) IOS Config SHELL(4022) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) IOS Config ARCHIVE(4020) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) IOS Config ROLLBACK(4021) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) PASSWD RF Client(4058) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) MLD Snooping(521) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) Online Diag HA(4056) op=0 rc=11
00:00:33 RF_PROG_ACTIVE(204) NG3K CFG MGR(10004) op=0 rc=11
00:00:34 RF_EVENT_LOCAL_PROG_DONE(505) EICORE HA Client(20002) op=204 rc=11
00:00:34 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6315) op=0 rc=11
00:00:34 RF_PROG_ACTIVE(204) Last Slave(65000) op=0 rc=11
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) First Slave(0) op=7 rc=0
00:00:41 RF_EVENT_SLAVE_STATUS_DONE(523) First Slave(0) op=405 rc=7
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(6313) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(6315) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(6339) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(9248) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(9251) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SNMP SA HA Client(20010) op=7 rc=0
00:00:41 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6339) op=405 rc=7
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Table Manager Client(24001) op=7 rc=0
00:00:41 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(9248) op=405 rc=7
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Installer HA Client(20007) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) EICORE HA Client(20002) op=7 rc=0
00:00:41 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6313) op=405 rc=7
00:00:41 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6315) op=405 rc=7
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Redundancy Mode RF(29) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IfIndex(139) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Persistent Variable(3300) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CHKPT RF(25) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IIF-shim(20005) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) QEMU Platform RF(10001) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Event Manager(77) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Network RF Client(22) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Tableid HA(75) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch VTP VLAN(501) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) XDR RRP RF Client(71) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CEF RRP RF Client(24) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) FFM RF(2900) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Auth Mgr(210) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Config Sync RF client(5) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) NG3K OIR Rf client(10002) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) NG3K SES Rf client(10003) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) NGWC FEC Rf client(10007) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch Port Manager(502) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Mac address Table Manager(519) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IPROUTING NSF RF client(20) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCPD(101) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SNMP RF Client(34) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) AAA(69) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) History RF Client(35) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ARP(57) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) FH_RF_Event_Detector_stub(50) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Smart Install RF(1112) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Spanning-Tree Protocol(503) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Switch Backup Interface client(507) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCP Snooping(105) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Call-Home RF(1510) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Config Verify RF client(94) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Platform Inline Power(10005) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Platform Manager SPI(10008) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Inline Power rf client(505) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Igmp Snooping(506) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Port Security(508) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Switch IP Device Tracking(509) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SISF table(515) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CRYPTO RSA(130) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IP Admission RF Client(400) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ISSU Test Client(4005) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch PAgP/LACP(510) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config SHELL(4022) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ARCHIVE(4020) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ROLLBACK(4021) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) PASSWD RF Client(4058) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MLD Snooping(521) op=7 rc=0
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Online Diag HA(4056) op=7 rc=0
00:00:41 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(9251) op=405 rc=7
00:00:41 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Last Slave(65000) op=7 rc=0
00:00:41 RF_EVENT_SLAVE_STATUS_DONE(523) Last Slave(65000) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) First Slave(0) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Slave(6313) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Slave(6315) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Slave(6339) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Slave(9248) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Slave(9251) op=7 rc=0
00:00:41 RF_EVENT_SLAVE_STATUS_DONE(523) First Slave(0) op=406 rc=7
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) EICORE HA Client(20002) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Installer HA Client(20007) op=7 rc=0
00:00:41 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6315) op=406 rc=7
00:00:41 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6313) op=406 rc=7
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Table Manager Client(24001) op=7 rc=0
00:00:41 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(9248) op=406 rc=7
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SNMP SA HA Client(20010) op=7 rc=0
00:00:41 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6339) op=406 rc=7
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Redundancy Mode RF(29) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IfIndex(139) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Persistent Variable(3300) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CHKPT RF(25) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IIF-shim(20005) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) QEMU Platform RF(10001) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Event Manager(77) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Network RF Client(22) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Tableid HA(75) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch VTP VLAN(501) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) XDR RRP RF Client(71) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CEF RRP RF Client(24) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) FFM RF(2900) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Auth Mgr(210) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Config Sync RF client(5) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) NG3K OIR Rf client(10002) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) NG3K SES Rf client(10003) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) NGWC FEC Rf client(10007) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch Port Manager(502) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Mac address Table Manager(519) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IPROUTING NSF RF client(20) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DHCPD(101) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SNMP RF Client(34) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) AAA(69) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) History RF Client(35) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ARP(57) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) FH_RF_Event_Detector_stub(50) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Smart Install RF(1112) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Spanning-Tree Protocol(503) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Switch Backup Interface client(507) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DHCP Snooping(105) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Call-Home RF(1510) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Config Verify RF client(94) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Platform Inline Power(10005) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Platform Manager SPI(10008) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Inline Power rf client(505) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Igmp Snooping(506) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Port Security(508) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Switch IP Device Tracking(509) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SISF table(515) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CRYPTO RSA(130) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IP Admission RF Client(400) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ISSU Test Client(4005) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch PAgP/LACP(510) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config SHELL(4022) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config ARCHIVE(4020) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config ROLLBACK(4021) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) PASSWD RF Client(4058) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MLD Snooping(521) op=7 rc=0
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Online Diag HA(4056) op=7 rc=0
00:00:41 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(9251) op=406 rc=7
00:00:41 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Last Slave(65000) op=7 rc=0
00:00:52 System initialization complete
------------------ show redundancy states ------------------
my state = 13 -ACTIVE
peer state = 1 -DISABLED
Mode = Simplex
Unit ID = 1
Redundancy Mode (Operational) = SSO
Redundancy Mode (Configured) = SSO
Redundancy State = Non Redundant
Manual Swact = disabled (system is simplex (no peer unit))
Communications = Down Reason: Simplex mode
client count = 60
client_notification_TMR = 360000 milliseconds
keep_alive TMR = 9000 milliseconds
keep_alive count = 0
keep_alive threshold = 9
RF debug mask = 0
------------------ show redundancy switchover history ------------------
------------------ show ipc nodes ------------------
There are 18 nodes in this IPC realm.
ID Type Name Last Last Bundle Support MTU
Sent Heard Session/Seat
1.900100 Local SEAT-10900100 0 0 off/off 1376
0.10000 Local IPC Master 0 0 on/on 4096
1.10000 Seat_to_Se IPC Master: -Zone#1 0 0 on/on 1376
1.900181 To-SERVER 0 0 on/off 1376
1.900B00 Seat_to_Se SPI MTS Seat 13 13 on/off 1376
1.900182 To-SERVER 0 0 on/off 1376
1.900183 To-SERVER 0 0 on/off 1376
1.900184 To-SERVER 0 0 on/off 1376
1.900185 To-SERVER 0 0 on/off 1376
1.900186 To-SERVER 0 0 on/off 1376
1.900187 To-SERVER 0 0 on/off 1376
1.900A00 Seat_to_Se SPI MTS Seat 2 2 on/off 1376
1.900188 To-SERVER 0 0 on/off 1376
1.900189 To-SERVER 0 0 on/off 1376
1.90018A To-SERVER 0 0 on/off 1376
1.90018B To-SERVER 0 0 on/off 1376
1.90018C To-SERVER 0 0 on/off 1376
1.90018D To-SERVER 0 0 on/off 1376
------------------ show ipc ports ------------------
IPC ACTIVE PORT TABLE
There are 28 ports defined.
Port ID Type Name (current/peak/total)
10000.1 unicast IPC Master:Zone
10000.2 unicast IPC Master:Echo
10000.3 unicast IPC Master:Control
10900100.2 unicast SEAT-10900100:Echo -Zone#1
10900100.3 unicast SEAT-10900100:Control -Zone#1
10010000.3 unicast IPC Master:Control -Zone#1
10000.4 unicast ERP Agent Port #0
10900100.4 multicast SPI:10900100:2423
10000.5 unicast ERP Agent Port #1
10000.6 unicast Master : TTY Server Port
10000.7 unicast RTTYEnh Master Port
10000.8 unicast Primary RFS Server Port
10000.9 unicast Primary Old RFS Server Port
10000.A unicast IPC-Apps:Active
10000.B unicast RF : Active
10000.C unicast Prst Vbl IPC: Active Port
10000.D unicast RED MODE: Active Port
10000.E unicast ifindex_sync_active_port
10000.F unicast CF : Active
10000.10 unicast FIB Master: DFS.process_level.msgs
10000.11 unicast FIB Master: DFS.interrupt.msgs
10000.12 unicast OBFL Master Port
10000.13 unicast Config Sync ISSU nego active
10000.14 unicast ISSU TEST::same port 1 0
10000.15 unicast ISSU TEST::shared msg port 1 0
10000.16 unicast ISSU TEST::same port 1 1
10000.17 unicast ISSU TEST::shared msg port 1 1
10000.18 unicast ISSU TEST::shared nego port 1 0
RPC packets: current/peak/total
0/1/15
IPC STANDBY PORT TABLE
There are 0 ports defined.
0/1/15
------------------ show ipc queue ------------------
There is 1 IPC message waiting for acknowledgement in the transmit queue.
There are 0 IPC messages waiting for a response.
There are 0 IPC messages waiting for additional fragments.
There are 0 IPC messages currently on the IPC inboundQ[0].
There are 0 IPC messages currently on the IPC inboundQ[1].
There are 0 IPC messages currently on the RX controller inboundQ.
There are 0 IPC messages currently on the TX controller inboundQ.
There are 0 IPC messages currently on the zone inboundQ.
Messages currently in use : 5
Message cache size : 6000
Maximum message cache usage : 6000
0 times message cache crossed 9000 [max]
Emergency messages currently in use : 0
There are 0 messages currently reserved for reply msg.
Cache low watermark [default/new]: [100/100]
No of low watermark reached : 0
Total get cache after low watermark : 0
No of times zero cache reached : 0
No of times one cache added : 0
No of times cache chunk added : 0
Max no of get cache between wake2grow : 0
IPC Retransmission Table:
Source Destination Size Tries Seq Msg
10900100.0 SEAT-10900100 10900100.84 Unknown 151 0 279 0x32F19EAC
------------------ show ipc status ------------------
IPC System Status
Time last IPC stat cleared all zones : 00:00:00
This processor is the IPC master server in zone 0 (default).
Do not drop output of IPC frames for test purposes.
6000 IPC Message Headers Cached.
Rx Side Tx Side
Total Frames 215 654
Total from Local Ports 15 639
Total Protocol Control Frames 0 15
Total Frames Dropped 0 0
Service Usage
Total via Unreliable Connection-Less Service 0 0
Total via Unreliable Sequenced Connection-Less Svc 0 0
Total via Reliable Connection-Oriented Service 15 530
Total Messages via Fragmentation 0 0
Total Fragments 0 0
Total Internal IPC Messages 0 0
Total Messages Flushed 0 0
IPC Protocol Version 0
Total Acknowledgements 200 15
Total Negative Acknowledgements 0 0
Device Drivers
Total via Local Driver 0 0
Total via Platform Driver 15 654
Total Frames Dropped by Platform Drivers 0 0
Total Frames Sent when media is quiesced 0
Reliable Tx Statistics
Re-Transmission 109
Re-Tx Timeout 0
Rx Errors Tx Errors
Unsupp IPC Proto Version 0 Tx Session Error 0
Corrupt Frame 0 Tx Seat Error 0
Duplicate Frame 0 Tx No Send Vector 0
Unrel Out-of-Seq Frame 0 Tx Driver Failed 0
Rx IPC Transform Errors 0 Tx IPC Transform Errors 0
Unable to Deliver Msg 0 Tx Test Drop 0
Rx Msg Callback Hog 0 Ack Alloc Failed 0
Rel Out-of-Seq Frame 0
Dest Port does Not Exist 0
Rx IPC Msg Alloc Failed 0
Rx IPC Frag Dropped 0
Rx Bootstrap Delivered 0
Rx Bootstrap Dropped 0
Buffer Errors Misc Errors
IPC Msg Alloc 0 IPC Open Port 2
Emer IPC Msg Alloc 0 No HWQ 0
IPC Frame PakType Alloc 0 Hardware Error 0
IPC Frame MemD Alloc 0 Invalid Messages 0
IPC Backup Open Port 0
IPC Fragment Errors 0
Message Timer Errors 0
Messages no xmt pending flag 0
Tx Driver Errors
No Transport 0
MTU Failure 0
Dest does not Exist 0
IPC Message Bundling Statistics
Seat-level Tx Bundling (bdl/sub/nonbdl/urgent/err) 0/0/639/0/0
Seat-level Rx Bundling (bdl/sub/nonbdl/err) 0/0/15/0
Session-level Tx Bundling (bdl/sub/nonbdl/urgent/err) 0/0/530/15/0
Session-level Rx Bundling (bdl/sub/nonbdl/err) 0/0/0/0
------------------ show pds buffergroup all ------------------
Global PDS buffergroups
Handle Name
3149824 oobnd_netdrv
3150080 dpd_oob_pds_group00
3150336 SM Buf Group TX
3150592 dpd_punject_pds_group00
3150848 FED PUNJECT RX Buffer Group 0
3151104 MMN Client
3151360 NG3K punt tx queue tag(65571)
3151616 NG3K punt tx queue tag(65572)
3151872 NG3K punt tx queue tag(65573)
3152128 NG3K punt tx queue tag(65574)
3152384 NG3K punt tx queue tag(65575)
3152640 NG3K punt tx queue tag(65576)
3152896 NG3K punt tx queue tag(65577)
3153152 NG3K punt tx queue tag(65578)
'*' denotes the buffergroup is reserved
------------------ show pds buffers ------------------
PDS public buffers
Public buffer pools:
PDS Buffer Pool 0, 2048 bytes (total 2048, permanent 2048, transient 0
peak 1071 @ 60188):
986 in free list (2048 max allowed)
7444 hits, 0 misses, 6382 free hits, 0 free misses
PDS Buffer Pool 1, 12288 bytes (total 341, permanent 341, transient 0):
341 in free list (341 max allowed)
0 hits, 0 misses, 0 free hits, 0 free misses
Header pools:
Packet Header Memory, 176 bytes (total 4681, permanent 4681, transient 0
peak 27 @ 60188):
4663 in free list (4681 max allowed)
14151 hits, 0 misses, 14133 free hits, 0 free misses
Buffer Header Memory, 88 bytes (total 16384, permanent 16384, transient 0
peak 1071 @ 60188):
15322 in free list (16384 max allowed)
------------------ show pds client all ------------------
PDS clients
Handle PID Desc HA Role Name
5770976 5652 44 ALWAYS GOLD Client
5795584 5654 62 ALWAYS oobnd_netdrv
5820192 5654 63 ALWAYS dpd_oob
5844800 5654 70 ALWAYS SM Client TX
5869408 6323 10 ALWAYS liin tap
5894016 6312 11 ALWAYS mgmte tap
5918624 6306 69 ALWAYS PDSd Pktrc Dump clnt
5943232 5652 116 ALWAYS dpd_punject
5967840 5652 121 ALWAYS FED PUNJECT Event Handling
5992448 5652 122 ALWAYS FED PUNJECT Rx Thread SRC Client
6017056 5652 125 ALWAYS FED PUNJECT Tx Low Latency Sink
6041664 5652 126 ALWAYS FED PUNJECT TXQ 0 Sink Client
6066272 5652 127 ALWAYS FED PUNJECT TXQ 1 Sink Client
6090880 5652 128 ALWAYS FED PUNJECT TXQ 2 Sink Client
6115488 5652 129 ALWAYS FED PUNJECT TXQ 3 Sink Client
6140096 5652 130 ALWAYS FED PUNJECT TXQ 4 Sink Client
6164704 5652 131 ALWAYS FED PUNJECT TXQ 5 Sink Client
6189312 5652 132 ALWAYS FED PUNJECT TXQ 6 Sink Client
6213920 5652 133 ALWAYS FED PUNJECT TXQ 7 Sink Client
6238528 5652 134 ALWAYS FED PUNJECT Show Forward Client
6263136 5652 135 ALWAYS Show Forward Client
6287744 5652 138 ALWAYS FNF distributed exporter
6312352 5652 151 ALWAYS MMN Client
6336960 9251 68 ACTIVE IOSd-PDS Client
6361568 9251 72 ACTIVE Punt Rx RPF Failed
6386176 9251 73 ACTIVE Punt Rx Mcast Data
6410784 9251 125 ACTIVE Punt Rx Mcast Snoop
6435392 9251 126 ACTIVE Punt Rx L2 Protocol
6460000 9251 127 ACTIVE Punt Rx STP
6484608 9251 128 ACTIVE Punt Rx Logging
6509216 9251 129 ACTIVE Punt Rx Learning
6533824 9251 130 ACTIVE Punt Rx ICMP Gen Redirect
6558432 9251 131 ACTIVE Punt Rx ICMP Gen TTL
6583040 9251 132 ACTIVE Punt Rx ICMP Gen Unreach
6607648 9251 133 ACTIVE Punt Rx L3MTU Fail
6632256 9251 134 ACTIVE Punt Rx V6Scope Fail
6656864 9251 135 ACTIVE Punt Rx Routing Protocol
6681472 9251 136 ACTIVE Punt Rx Forus Addr Reso Ctrl
6706080 9251 137 ACTIVE Punt Rx Host
6730688 9251 138 ACTIVE Sisf Intercept
6755296 9251 143 ACTIVE NG3K Punt Tx
6779904 9251 144 ACTIVE Resume Signal
6804512 9251 145 ACTIVE Punt Rx Sw Fwd
6829120 9251 146 ACTIVE Punt Rx Broadcast
6853728 9251 147 ACTIVE Punt Rx Proto Snoop
6878336 9251 149 ALWAYS Raw library
6902944 9251 150 ALWAYS TCP library
6927552 9251 151 ALWAYS UDP library
6952160 9251 154 ACTIVE Punt Rx Auth
6976768 10011 69 ALWAYS TCP Client Library
------------------ show pds memory ------------------
PDS memory
Header pools:
peak 27 @ 60188):
14203 hits, 0 misses, 14185 free hits, 0 free misses
peak 1071 @ 60188):
7468 hits, 0 misses, 6406 free hits, 0 free misses
Buffergroup Memory, 212 bytes (total 4096, permanent 4096, transient 0
peak 14 @ 18501):
4082 in free list (4096 max allowed)
14 hits, 0 misses, 0 free hits, 0 free misses
TLV Memory, 512 bytes (total 1927, permanent 1927, transient 0
peak 4 @ 102324):
1927 in free list (1927 max allowed)
12845 hits, 0 misses, 12845 free hits, 0 free misses
Event Memory, 72 bytes (total 4096, permanent 4096, transient 0):
4096 in free list (4096 max allowed)
Client Memory, 24576 bytes (total 127, permanent 127, transient 0
peak 50 @ 21978):
77 in free list (127 max allowed)
50 hits, 0 misses, 0 free hits, 0 free misses
Tag Memory, 212 bytes (total 4096, permanent 4096, transient 0
peak 45 @ 21978):
4051 in free list (4096 max allowed)
45 hits, 0 misses, 0 free hits, 0 free misses
Alloc Tracking Memory, 16 bytes (total 8192, permanent 8192, transient 0
peak 15 @ 21978):
8177 in free list (8192 max allowed)
15 hits, 0 misses, 0 free hits, 0 free misses
Pakhandle Memory, 8 bytes (total 16384, permanent 16384, transient 0):
16384 in free list (16384 max allowed)
Global Info Memory, 4096 bytes (total 0, permanent 0, transient 0):
0 in free list (0 max allowed)
------------------ show pds statistics ------------------
PDS global statistics
KLM version: 0-1-11
Basic statistics
Total PDS Clients : 50
Total PDS Clients cleanup : 0
Total PDS Tags (dynamic/total) : 1/45
Total PDS Buffergroups : 14
Source statistics
Total delivery attempts : 5825
Success delivery attempts : 5825
Total buffers sent : 5825
Total bytes sent : 470734
Failed attempts due to unregistered tag : 0
Failed attempts due to full queue : 0
Sink statistics
Total consumed count : 5825
Total buffers recv'd : 5825
Total bytes recv'd : 470734
Packets Received, No Signaling Required : 1927
Packets Received, Not signaled : 2480
Alloc statistics
Total buffer allocation count : 7482
Success buffer allocation count : 7482
Current buffer allocation count : 1062
Current bytes allocation count : 1886737
------------------ show pds tag all ------------------
'*' denotes the tag is dynamic
TDA: total delivery attempts
SDA: successful delivery attempts
FDA: failed delivery attempts
TBufD: total buffers delivered
TBytD: total bytes delivered
Active Client Client
Tags Handle Name TDA SDA FDA TBufD TBytD
65579 5770976 GOLD Client 0 0 0 0 0
14 5869408 liin tap 41 41 0 41 13260
10 5894016 mgmte tap 0 0 0 0 0
2 6017056 FED PUNJECT Tx Low Latency Sink 0 0 0 0 0
65571 6041664 FED PUNJECT TXQ 0 Sink Client 646 646 0 646 45593
65572 6066272 FED PUNJECT TXQ 1 Sink Client 0 0 0 0 0
65573 6090880 FED PUNJECT TXQ 2 Sink Client 0 0 0 0 0
65574 6115488 FED PUNJECT TXQ 3 Sink Client 0 0 0 0 0
65575 6140096 FED PUNJECT TXQ 4 Sink Client 0 0 0 0 0
65576 6164704 FED PUNJECT TXQ 5 Sink Client 0 0 0 0 0
65577 6189312 FED PUNJECT TXQ 6 Sink Client 0 0 0 0 0
65578 6213920 FED PUNJECT TXQ 7 Sink Client 1235 1235 0 1235 104145
65570 6238528 FED PUNJECT Show Forward Client 0 0 0 0 0
65545 6361568 Punt Rx RPF Failed 0 0 0 0 0
65547 6386176 Punt Rx Mcast Data 0 0 0 0 0
65542 6410784 Punt Rx Mcast Snoop 4 4 0 4 376
65537 6435392 Punt Rx L2 Protocol 78 78 0 78 16308
65536 6460000 Punt Rx STP 2550 2550 0 2550 167280
65544 6484608 Punt Rx Logging 0 0 0 0 0
65538 6509216 Punt Rx Learning 0 0 0 0 0
65559 6533824 Punt Rx ICMP Gen Redirect 0 0 0 0 0
65558 6558432 Punt Rx ICMP Gen TTL 0 0 0 0 0
65560 6583040 Punt Rx ICMP Gen Unreach 0 0 0 0 0
65556 6607648 Punt Rx L3MTU Fail 0 0 0 0 0
65557 6632256 Punt Rx V6Scope Fail 0 0 0 0 0
65546 6656864 Punt Rx Routing Protocol 503 503 0 503 61334
65548 6681472 Punt Rx Forus Addr Reso Ctrl 14 14 0 14 896
65539 6706080 Punt Rx Host 77 77 0 77 8229
27 6730688 Sisf Intercept 0 0 0 0 0
9 6336960 IOSd-PDS Client 0 0 0 0 0
13 6336960 IOSd-PDS Client 6 6 0 6 468
65580 6779904 Resume Signal 0 0 0 0 0
65540 6804512 Punt Rx Sw Fwd 0 0 0 0 0
65541 6829120 Punt Rx Broadcast 679 679 0 679 53427
65561 6853728 Punt Rx Proto Snoop 0 0 0 0 0
28 6878336 Raw library 0 0 0 0 0
29 6878336 Raw library 0 0 0 0 0
32 6878336 Raw library 0 0 0 0 0
33 6878336 Raw library 0 0 0 0 0
30 6902944 TCP library 0 0 0 0 0
31 6902944 TCP library 0 0 0 0 0
11 6927552 UDP library 0 0 0 0 0
12 6927552 UDP library 0 0 0 0 0
65551 6952160 Punt Rx Auth 0 0 0 0 0
* 131072 6976768 TCP Client Library 0 0 0 0 0
------------------ show stack-power ------------------
Power stack name: Powerstack-1
Stack mode: Power sharing
Stack topology: Standalone
Switch 1:
Power budget: 310
Low port priority value: 22
High port priority value: 13
Switch priority value: 4
Port 1 status: Not connected
Port 2 status: Not connected
Neighbor on port 1: 0000.0000.0000
Neighbor on port 2: 0000.0000.0000
------------------ show crypto key mypubkey rsa ------------------
% Key pair was generated at: 22:32:28 UTC Nov 16 2016
Key name: TP-self-signed-4273662774
Storage Device: private-config
Usage: General Purpose Key
Key is not exportable. Redundancy enabled.
Key Data:
30819F30 0D06092A 864886F7 0D010101 05000381 8D003081 89028181 00C675F6
E04EB5B0 C63CEE2A CDDB5598 E52F0A08 E53ADD10 CB324E7F 1DC362AA CAD9603F
6A88CF4B 267E3616 B6BFB920 CF2B6D4A 9558B0EF 4A814969 8B4AB1D0 EEF55570
B7679DE1 ACE5F0B5 1EF3E9B3 9BE0DE3F 1EACCD02 F40A8547 FFDEE479 CEF56C7C
5CACC70D 9DFC4EB4 E3AD06DA 0FC82504 179C2D87 084CFF78 97EB15B7 D9020301 0001
% Key pair was generated at: 22:56:28 UTC Nov 16 2016
Key name: TP-self-signed-4273662774.server
Temporary key
Usage: Encryption Key
Key Data:
307C300D 06092A86 4886F70D 01010105 00036B00 30680261 00B4DB2F 64FF1BBF
2D35C908 539AF331 D6B6C4FE 5AF02ACB 54862CAB 5214B0E3 3624D709 EBE4CEE5
532FE315 D96DA92F B809CBDC 1632F8A0 C0B1A84C DA6F5BBC 438F2FCC 56EC81BB
8271E2E4 1D9FFC9E 8A48DB59 D67FD8D5 F8F67D14 21460B99 F1020301 0001
% Key pair was generated at: 22:56:38 UTC Nov 16 2016
Key name: CISCO_IDEVID_SUDI
Storage Device: not specified
Key Data:
30819F30 0D06092A 864886F7 0D010101 05000381 8D003081 89028181 00B73CEB
62C4B403 1BCD0791 743E0C94 1262F902 47940E18 7D29B9AC 2253351D 494E582D
78C0FCD4 6D5C92EA 99263F57 0906739A A4A8583A 1C7F4371 DBA7A9DF 60D1E974
9C674356 05B44977 4BED217E 6BF6CA26 FA4F87B6 89580FF5 DB345377 BF30E2F2
1F0B79F1 BD8FA8FD F4B40E47 F9CA1FF9 5EA07A6C 51B880E5 7CF76A49 0F020301 0001
------------------ show buffers ------------------
PDS public buffers
peak 1071 @ 60188):
7548 hits, 0 misses, 6486 free hits, 0 free misses
Header pools:
peak 27 @ 60188):
14385 hits, 0 misses, 14367 free hits, 0 free misses
peak 1071 @ 60188):
IOSd private buffers:
Buffer elements:
945 in free list (500 max allowed)
2988 hits, 0 misses, 617 created
Small buffers, 104 bytes (total 600, permanent 600):
600 in free list (100 min, 1250 max allowed)
1461 hits, 0 misses, 0 trims, 0 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 450, permanent 450):
450 in free list (50 min, 1000 max allowed)
150 hits, 0 misses, 0 trims, 0 created
Big buffers, 1536 bytes (total 451, permanent 450, peak 451 @ 00:21:55):
451 in free list (25 min, 1500 max allowed)
157 hits, 0 misses, 0 trims, 1 created
VeryBig buffers, 4520 bytes (total 11, permanent 10, peak 11 @ 00:21:55):
11 in free list (0 min, 300 max allowed)
0 hits, 0 misses, 0 trims, 1 created
Large buffers, 5024 bytes (total 11, permanent 10, peak 11 @ 00:21:55):
11 in free list (0 min, 30 max allowed)
VeryLarge buffers, 8232 bytes (total 50, permanent 50):
50 in free list (0 min, 150 max allowed)
Huge buffers, 18024 bytes (total 6, permanent 5, peak 6 @ 00:21:55):
6 in free list (0 min, 13 max allowed)
Interface buffer pools:
ng3k_rx25 buffers, 1 bytes (total 1, permanent 1):
1 in free list (0 min, 1 max allowed)
0 hits, 0 misses
ng3k_rx13 buffers, 5 bytes (total 5, permanent 5):
5 in free list (0 min, 5 max allowed)
0 hits, 0 misses
CF Small buffers, 104 bytes (total 101, permanent 100, peak 101 @ 00:22:06):
101 in free list (100 min, 200 max allowed)
BIPC small buffers, 128 bytes (total 251, permanent 250, peak 251 @ 00:22:06):
251 in free list (250 min, 250 max allowed)
123 hits, 0 misses, 22 trims, 23 created
BIPC middle buffers, 600 bytes (total 301, permanent 300, peak 301 @ 00:22:06):
301 in free list (300 min, 300 max allowed)
65 hits, 0 misses, 22 trims, 23 created
CF Middle buffers, 600 bytes (total 101, permanent 100, peak 101 @ 00:22:06):
Syslog ED Pool buffers, 600 bytes (total 133, permanent 132, peak 133 @ 00:21:52):
101 in free list (132 min, 132 max allowed)
56 hits, 0 misses
CF Big buffers, 1536 bytes (total 26, permanent 25, peak 26 @ 00:22:06):
26 in free list (25 min, 50 max allowed)
ng3k_rx6 buffers, 1600 bytes (total 96, permanent 96):
96 in free list (0 min, 96 max allowed)
0 hits, 0 misses
ng3k_rx7 buffers, 1600 bytes (total 96, permanent 96):
0 hits, 0 misses
ng3k_rx9 buffers, 1600 bytes (total 768, permanent 768):
768 in free list (0 min, 768 max allowed)
12 hits, 0 misses
ng3k_rx10 buffers, 1600 bytes (total 512, permanent 512):
512 in free list (0 min, 512 max allowed)
79 hits, 0 misses
ng3k_rx11 buffers, 1600 bytes (total 1024, permanent 1024):
1024 in free list (0 min, 1024 max allowed)
2575 hits, 0 misses
ng3k_rx12 buffers, 1600 bytes (total 96, permanent 96):
0 hits, 0 misses
ng3k_rx14 buffers, 1600 bytes (total 16, permanent 16):
16 in free list (0 min, 16 max allowed)
0 hits, 0 misses
ng3k_rx15 buffers, 1600 bytes (total 16, permanent 16):
0 hits, 0 misses
ng3k_rx16 buffers, 1600 bytes (total 16, permanent 16):
0 hits, 0 misses
ng3k_rx17 buffers, 1600 bytes (total 16, permanent 16):
0 hits, 0 misses
ng3k_rx18 buffers, 1600 bytes (total 16, permanent 16):
0 hits, 0 misses
ng3k_rx19 buffers, 1600 bytes (total 512, permanent 512):
506 hits, 0 misses
ng3k_rx20 buffers, 1600 bytes (total 512, permanent 512):
14 hits, 0 misses
ng3k_rx21 buffers, 1600 bytes (total 2048, permanent 2048):
2048 in free list (0 min, 2048 max allowed)
77 hits, 0 misses
ng3k punt fallback pool buffers, 1600 bytes (total 1500, permanent 1500):
1500 in free list (0 min, 0 max allowed)
0 hits, 0 misses
ng3k_rx26 buffers, 1600 bytes (total 128, permanent 128):
128 in free list (0 min, 128 max allowed)
0 hits, 0 misses
ng3k_rx27 buffers, 1600 bytes (total 128, permanent 128):
688 hits, 0 misses
ng3k_rx28 buffers, 1600 bytes (total 512, permanent 512):
0 hits, 0 misses
ng3k_rx30 buffers, 1600 bytes (total 512, permanent 512):
0 hits, 0 misses
ng3k_rx22 buffers, 2048 bytes (total 1024, permanent 1024):
0 hits, 0 misses
BIPC buffers, 4096 bytes (total 2, permanent 2):
2 in free list (1 min, 8 max allowed)
CF VeryBig buffers, 4520 bytes (total 3, permanent 2, peak 3 @ 00:22:06):
3 in free list (2 min, 4 max allowed)
CF Large buffers, 5024 bytes (total 2, permanent 1, peak 2 @ 00:22:06):
2 in free list (1 min, 2 max allowed)
ng3k punt jumbo pool buffers, 9300 bytes (total 128, permanent 128):
128 in free list (0 min, 0 max allowed)
0 hits, 0 misses
BIPC Medium buffers, 16384 bytes (total 6, permanent 5, peak 6 @ 00:22:06):
6 in free list (5 min, 5 max allowed)
0 hits, 0 misses, 22 trims, 23 created
BIPC Large buffers, 65535 bytes (total 3, permanent 2, peak 3 @ 00:22:06):
3 in free list (2 min, 2 max allowed)
IPC small buffers, 128 bytes (total 1200, permanent 1200):
1196 in free list (400 min, 1200 max allowed)
35 hits, 0 fallbacks, 0 trims, 0 created
0 max cache size, 0 in cache
0 hits in cache, 0 misses in cache
IPC middle buffers, 600 bytes (total 1200, permanent 1200):
1200 in free list (400 min, 1200 max allowed)
5521 hits, 0 fallbacks, 0 trims, 0 created
IPC Emergency buffers, 4096 bytes (total 301, permanent 300, peak 301 @ 00:22:06):
IPC buffers, 4096 bytes (total 1200, permanent 1200):
1199 in free list (400 min, 1200 max allowed)
1159 hits, 0 fallbacks, 0 trims, 0 created
IPC Medium buffers, 16384 bytes (total 40, permanent 40):
40 in free list (20 min, 40 max allowed)
77 hits, 0 fallbacks, 0 trims, 0 created
Private Huge IPC buffers, 18024 bytes (total 1, permanent 0, peak 1 @ 00:22:07):
1 in free list (0 min, 4 max allowed)
Private Huge buffers, 65280 bytes (total 1, permanent 0, peak 1 @ 00:22:07):
IPC Large buffers, 65535 bytes (total 105, permanent 104, peak 105 @ 00:22:06):
103 in free list (20 min, 104 max allowed)
6 hits, 0 misses, 0 trims, 1 created
Header pools:
Header buffers, 0 bytes (total 266, permanent 256, peak 266 @ 00:21:06):
10 in free list (10 min, 512 max allowed)
253 hits, 3 misses, 0 trims, 10 created
256 max cache size, 256 in cache
Particle Clones:
1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 384, permanent 384):
128 in free list (128 min, 1024 max allowed)
256 hits, 0 misses, 0 trims, 0 created
Normal buffers, 512 bytes (total 512, permanent 512):
384 in free list (128 min, 1024 max allowed)
128 hits, 0 misses, 0 trims, 0 created
128 max cache size, 128 in cache
------------------ show inventory ------------------
NAME: "c3xxx Stack", DESCR: "c3xxx Stack"
PID: WS-C3850-48P , VID: V04 , SN: FCW1912C0MB
NAME: "Switch 1", DESCR: "WS-C3850-48P"
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C1-350WAC , VID: V01 , SN: DCB1922H1E
NAME: "Switch 1 FRU Uplink Module 0", DESCR: "4x1G Uplink Module"
PID: C3850-NM-4-1G , VID: V01 , SN: FOC191108X0
NAME: "GigabitEthernet1/1/1", DESCR: "1000BaseLX SFP"
PID: , VID: , SN: AGC1630V02Q
------------------ show region ------------------
Region Manager:
Start End Size(b) Class Media Name
0x100484F0 0x12E48D43 48236628 IText R/W text
0x13DDE5B0 0x1433436F 5594560 IData R/W data
0x14334370 0x14F0ACEF 12413312 IBss R/W bss
0x2B31B000 0x2B33A207 127496 IText R/W /lib/ld.so.1
0x2B34AD30 0x2B34BD03 4052 IData R/W /lib/ld.so.1
0x2B34C000 0x2B41F8EB 866540 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libmatm.so
0x2B430000 0x2B4467AF 92080 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libmatm.so
0x2B447000 0x2B5A2543 1422660 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngpm.so
0x2B5B3000 0x2B5E6EB7 212664 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngpm.so
0x2B5E7000 0x2B69BA0B 739852 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libifm_ctrl.so
0x2B6AC000 0x2B6BD9D3 72148 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libifm_ctrl.so
0x2B6BE000 0x2B6F4E83 224900 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngthermal.so
0x2B705000 0x2B70B1F3 25076 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngthermal.so
0x2B70C000 0x2B73FE5B 212572 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_capwap.so
0x2B750000 0x2B755A57 23128 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_capwap.so
0x2B756000 0x2B77243B 115772 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libl2_control.so
0x2B78243C 0x2B784ABF 9860 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libl2_control.so
0x2B785000 0x2B7F3B73 453492 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libbackup_int.so
0x2B804000 0x2B8105B7 50616 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libbackup_int.so
0x2B811000 0x2B866783 350084 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngspan.so
0x2B877000 0x2B880B3F 39744 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngspan.so
0x2B881000 0x2B889E23 36388 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng_cdp.so
0x2B89A000 0x2B89B4F7 5368 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng_cdp.so
0x2B89C000 0x2B8A4EA3 36516 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng_udld.so
0x2B8B5000 0x2B8B64F7 5368 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng_udld.so
0x2B8B7000 0x2B8BFEA3 36516 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng_lldp.so
0x2B8D0000 0x2B8D14F7 5368 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng_lldp.so
0x2B8D2000 0x2B8F1E63 130660 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_dai.so
0x2B8F2000 0x2B8F6E03 19972 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_dai.so
0x2B8F7000 0x2B9B673B 784188 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libl2m.so
0x2B9B7000 0x2B9CD99F 92576 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libl2m.so
0x2B9CE000 0x2B9FC783 190340 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libedison_dhcpsn.so
0x2BA0C784 0x2BA13D23 30112 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libedison_dhcpsn.so
0x2BA14000 0x2BA3E77B 173948 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_ipsg.so
0x2BA4F000 0x2BA53B27 19240 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_ipsg.so
0x2BA54000 0x2BA97123 274724 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libsecurity_ctrl.so
0x2BAA7124 0x2BAAB82F 18188 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libsecurity_ctrl.so
0x2BAAC000 0x2BAC67EB 108524 IText R/W /tmp/sw/rp/0/0/drivers/mount/usr/binos/lib/libbspconfig.so
0x2BAD67EC 0x2BB30D23 369976 IData R/W /tmp/sw/rp/0/0/drivers/mount/usr/binos/lib/libbspconfig.so
0x2BB31000 0x2BC032C3 860868 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_dtls.so
0x2BC14000 0x2BC25E87 73352 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_dtls.so
0x2BC26000 0x2BCC3EE3 646884 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_stats.so
0x2BCD4000 0x2BCE6227 74280 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_stats.so
0x2BCE7000 0x2BD075A3 132516 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/liblearning.so
0x2BD18000 0x2BD1AC17 11288 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/liblearning.so
0x2BD1B000 0x2BD7248B 357516 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_sc.so
0x2BD8248C 0x2BD8AA87 34300 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_sc.so
0x2BD8B000 0x2BE386AB 710316 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_security_utils.so
0x2BE486AC 0x2BE599DF 70452 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_security_utils.so
0x2BE5A000 0x2BE8B6EB 202476 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libpths.so
0x2BE9C000 0x2BEA0BAF 19376 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libpths.so
0x2BEA1000 0x2BF2114B 524620 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libiosd_qos.so
0x2BF3114C 0x2BF3E657 54540 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libiosd_qos.so
0x2BF3F000 0x2BF7DD73 257396 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_l3m.so
0x2BF8E000 0x2BF937D7 22488 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_l3m.so
0x2BF94000 0x2BFF90EB 413932 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_sm.so
0x2C0090EC 0x2C011D2B 35904 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_sm.so
0x2C012000 0x2C04A65B 231004 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_lic_hbl.so
0x2C05A65C 0x2C05ECEB 18064 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_lic_hbl.so
0x2C05F000 0x2C075ADB 92892 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libtm_monitor.so
0x2C086000 0x2C087E6F 7792 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libtm_monitor.so
0x2C088000 0x2C09F4C3 95428 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libem_ha.so
0x2C0B0000 0x2C0B1F2F 7984 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libem_ha.so
0x2C0B2000 0x2C0FA1FB 295420 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngplatform_mgr.so
0x2C10A1FC 0x2C10FC4F 23124 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngplatform_mgr.so
0x2C110000 0x2C141A93 203412 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngplatform_mgr_misc.so
0x2C152000 0x2C1576F3 22260 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngplatform_mgr_misc.so
0x2C158000 0x2C199003 266244 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngilp.so
0x2C1A9004 0x2C1B1273 33392 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngilp.so
0x2C1B2000 0x2C1BF8DB 55516 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngcfg_mgr.so
0x2C1D0000 0x2C1D1B4F 6992 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngcfg_mgr.so
0x2C1D2000 0x2C1F3A43 137796 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libpm_ifm_ctrl.so
0x2C204000 0x2C207F93 16276 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libpm_ifm_ctrl.so
0x2C208000 0x2C2783CB 459724 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngfep.so
0x2C2883CC 0x2C293997 46540 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngfep.so
0x2C294000 0x2C2A2383 58244 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngusb.so
0x2C2B2384 0x2C2B3BD3 6224 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngusb.so
0x2C2B4000 0x2C2EDA5B 236124 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng3k_wireless.so
0x2C2FE000 0x2C303CC7 23752 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng3k_wireless.so
0x2C304000 0x2C350793 313236 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngstkpwr.so
0x2C360794 0x2C368F2F 34716 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngstkpwr.so
0x2C369000 0x2C38459B 112028 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngled.so
0x2C395000 0x2C397F8B 12172 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngled.so
0x2C398000 0x2C3A3CBB 48316 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngplatform_mgr_ha.so
0x2C3B4000 0x2C3B566B 5740 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngplatform_mgr_ha.so
0x2C3B6000 0x2C3CD9A3 96676 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libplatform.so
0x2C3DE000 0x2C3DFF3B 7996 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libplatform.so
0x2C3E0000 0x2C3E3A33 14900 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libsdm.so
0x2C3F4000 0x2C3F47FF 2048 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libsdm.so
0x2C3F5000 0x2C40CB2B 97068 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngemp.so
0x2C41D000 0x2C41F87B 10364 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngemp.so
0x2C420000 0x2C421A7B 6780 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/librtu_lic.so
0x2C431A7C 0x2C431D67 748 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/librtu_lic.so
0x2C432000 0x2C477CCB 285900 IText R/W /usr/lib32/libssl.so
0x2C487CCC 0x2C48ED0F 28740 IData R/W /usr/lib32/libssl.so
0x2C48F000 0x2C5F8C93 1481876 IText R/W /usr/lib32/libcrypto.so
0x2C609000 0x2C63D84F 215120 IData R/W /usr/lib32/libcrypto.so
0x2C63E000 0x2C642CCB 19660 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuld.so
0x2C653000 0x2C665ADF 76512 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuld.so
0x2C666000 0x2C66891B 10524 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinitcii.so
0x2C67891C 0x2C678CFF 996 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinitcii.so
0x2C679000 0x2C67D5F3 17908 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcrashinfo.so
0x2C68D5F4 0x2C68EBBF 5580 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcrashinfo.so
0x2C68F000 0x2C694AFB 23292 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuiutil.so
0x2C6A4AFC 0x2C6A4F8F 1172 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuiutil.so
0x2C6A5000 0x2C6CBF2B 159532 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuipeer.so
0x2C6DC000 0x2C6E542F 37936 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuipeer.so
0x2C6E6000 0x2C7165A3 198052 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcdlcore.so
0x2C7265A4 0x2C72C6B7 24852 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcdlcore.so
0x2C72D000 0x2C7357C3 34756 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbinos.so
0x2C7457C4 0x2C74B9FF 25148 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbinos.so
0x2C74C000 0x2C74CAE3 2788 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libobjref.so
0x2C75CAE4 0x2C77CC13 131376 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libobjref.so
0x2C77D000 0x2C77DC4B 3148 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtppiosrp.so
0x2C78DC4C 0x2C78DD1F 212 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtppiosrp.so
0x2C78E000 0x2C796B7B 35708 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmcp_msg.so
0x2C7A6B7C 0x2C7A7CBF 4420 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmcp_msg.so
0x2C7A8000 0x2C7BF5EB 95724 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmgmte.so
0x2C7D0000 0x2C7D2C4B 11340 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmgmte.so
0x2C7D3000 0x2C805CA3 208036 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmgmte_relay.so
0x2C816000 0x2C81AD1B 19740 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmgmte_relay.so
0x2C81B000 0x2C82165B 26204 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcpumem.so
0x2C83165C 0x2C831C3F 1508 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcpumem.so
0x2C833000 0x2C834B8B 7052 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcpumem_spi.so
0x2C844B8C 0x2C844D5F 468 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcpumem_spi.so
0x2C845000 0x2C8ACFEB 425964 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libif_common.so
0x2C8BD000 0x2C8CA4DB 54492 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libif_common.so
0x2C8CB000 0x2C902303 226052 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libccb_commands.so
0x2C912304 0x2C91896B 26216 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libccb_commands.so
0x2C919000 0x2C993B8B 502668 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libgold.so
0x2C9A3B8C 0x2C9AFD9F 49684 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libgold.so
0x2C9B1000 0x2C9C825B 94812 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmcp_diag_test.so
0x2C9D825C 0x2C9DAEAF 11348 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmcp_diag_test.so
0x2C9DB000 0x2C9FF4CB 148684 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cce_msg.so
0x2CA0F4CC 0x2CA1375F 17044 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cce_msg.so
0x2CA14000 0x2CB5A95B 1337692 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_qos.so
0x2CB6B000 0x2CB8EEBF 147136 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_qos.so
0x2CB8F000 0x2CB97DA3 36260 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_cefmfi.so
0x2CBA8000 0x2CBA950F 5392 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_cefmfi.so
0x2CBAB000 0x2CBB25A3 30116 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef.so
0x2CBC25A4 0x2CBC368F 4332 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef.so
0x2CBC4000 0x2CBEE2FB 172796 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef_messages.so
0x2CBFF000 0x2CC03F7F 20352 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef_messages.so
0x2CC04000 0x2CC1DFB3 106420 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ha.so
0x2CC2E000 0x2CC3127B 12924 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ha.so
0x2CC32000 0x2CC362B3 17076 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_mfi.so
0x2CC462B4 0x2CC46A4F 1948 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_mfi.so
0x2CC48000 0x2CC5A9C3 76228 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_mfi_messages.so
0x2CC6A9C4 0x2CC6CBAF 8684 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_mfi_messages.so
0x2CC6D000 0x2CD01573 607604 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_cef.so
0x2CD11574 0x2CD219AF 66620 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_cef.so
0x2CD22000 0x2CD33D4B 73036 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_cef_common.so
0x2CD43D4C 0x2CD45D7F 8244 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_cef_common.so
0x2CD46000 0x2CD4AFAB 20396 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_common.so
0x2CD5B000 0x2CD5B9AF 2480 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_common.so
0x2CD5D000 0x2CD7452B 95532 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_obj.so
0x2CD8452C 0x2CD8556F 4164 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_obj.so
0x2CD86000 0x2CE6FA5B 957020 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l2target.so
0x2CE80000 0x2CE9D6EF 120560 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l2target.so
0x2CE9E000 0x2CED0953 207188 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_l2target.so
0x2CEE1000 0x2CEE789F 26784 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_l2target.so
0x2CEE8000 0x2D3E32D3 5223124 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_classify.so
0x2D3F4000 0x2D479F17 548632 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_classify.so
0x2D47B000 0x2D4C005B 282716 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l3intf.so
0x2D4D005C 0x2D4D798F 31028 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l3intf.so
0x2D4D8000 0x2D4F2CB3 109748 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_l3intf.so
0x2D503000 0x2D505BC7 11208 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_l3intf.so
0x2D506000 0x2D50BADB 23260 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ack_types.so
0x2D51C000 0x2D51CAAF 2736 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ack_types.so
0x2D51D000 0x2D52388B 26764 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_stat_types.so
0x2D534000 0x2D53483F 2112 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_stat_types.so
0x2D536000 0x2D562A9B 182940 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_reply_service.so
0x2D573000 0x2D57787F 18560 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_reply_service.so
0x2D578000 0x2D5B765B 259676 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_urpf.so
0x2D5C765C 0x2D5CEDD7 30588 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_urpf.so
0x2D5CF000 0x2D5E458B 87436 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_urpf.so
0x2D5F458C 0x2D5F6FDF 10836 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_urpf.so
0x2D5F7000 0x2D61D06B 155756 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_acl.so
0x2D62D06C 0x2D633433 25544 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_acl.so
0x2D635000 0x2D785CB3 1379508 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_acl_sdo.so
0x2D796000 0x2D7C0B2F 174896 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_acl_sdo.so
0x2D7C1000 0x2D7D3283 74372 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_punt_acl.so
0x2D7E3284 0x2D7E55FF 9084 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_punt_acl.so
0x2D7E6000 0x2D83DF73 360308 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_pbr.so
0x2D84E000 0x2D857D1B 40220 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_pbr.so
0x2D858000 0x2D88548B 185484 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_tun.so
0x2D89548C 0x2D89A867 21468 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_tun.so
0x2D89C000 0x2D8C7693 177812 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_tun.so
0x2D8D7694 0x2D8DBDF3 18272 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_tun.so
0x2D8DC000 0x2D900333 148276 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm.so
0x2D910334 0x2D91693F 26124 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm.so
0x2D917000 0x2D92432B 54060 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_source_spi.so
0x2D935000 0x2D935DDF 3552 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_source_spi.so
0x2D936000 0x2D94D20B 94732 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpeer_reg.so
0x2D95D20C 0x2D95FE8B 11392 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpeer_reg.so
0x2D961000 0x2D997B13 224020 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_om.so
0x2D9A8000 0x2D9AED4F 27984 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_om.so
0x2D9AF000 0x2D9DD133 188724 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libupexp.so
0x2D9ED134 0x2D9F4907 30676 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libupexp.so
0x2D9F5000 0x2DA3ECEB 302316 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuiexp.so
0x2DA4F000 0x2DA59CAF 44208 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuiexp.so
0x2DA5A000 0x2DA7DD0B 146700 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libaccess_policy.so
0x2DA8E000 0x2DA94D87 28040 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libaccess_policy.so
0x2DA96000 0x2DAD8D93 273812 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libvty_mgt.so
0x2DAE9000 0x2DAF0513 29972 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libvty_mgt.so
0x2DAF1000 0x2DB02AAB 72364 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcrypto_types.so
0x2DB13000 0x2DB14E83 7812 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcrypto_types.so
0x2DB15000 0x2DB5FB1B 305948 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuipeer_comm_ui.so
0x2DB6FB1C 0x2DB79E2F 41748 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuipeer_comm_ui.so
0x2DB7A000 0x2DBFDF0B 540428 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libui.so
0x2DC0E000 0x2DC1F6DF 71392 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libui.so
0x2DC21000 0x2DC4F093 188564 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libui_shr.so
0x2DC5F094 0x2DC639C7 18740 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libui_shr.so
0x2DC64000 0x2DC9EE43 241220 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libfru_stats.so
0x2DCAF000 0x2DCB3F87 20360 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libfru_stats.so
0x2DCB4000 0x2DCE03E3 181220 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmem_stats_ui.so
0x2DCF03E4 0x2DCF6457 24692 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmem_stats_ui.so
0x2DCF7000 0x2DD6E82B 489516 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmcp_comm.so
0x2DD7F000 0x2DD8BE27 52776 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmcp_comm.so
0x2DD8D000 0x2DDAAAEB 121580 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsvc_defs.so
0x2DDBAAEC 0x2DDBDF33 13384 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsvc_defs.so
0x2DDBE000 0x2DDC9BF3 48116 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcisco_tunnel.so
0x2DDDA000 0x2DDDBAD7 6872 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcisco_tunnel.so
0x2DDDC000 0x2DDE5603 38404 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc.so
0x2DDF5604 0x2DDF6D2F 5932 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc.so
0x2DDF7000 0x2DE0F493 99476 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc_messages.so
0x2DE20000 0x2DE22E6F 11888 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc_messages.so
0x2DE24000 0x2DE6ACDB 290012 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuism.so
0x2DE7B000 0x2DE836FB 34556 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuism.so
0x2DE84000 0x2DEB3623 194084 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libipc_ack.so
0x2DEC3624 0x2DEC9953 25392 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libipc_ack.so
0x2DECA000 0x2DECFF83 24452 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbsess.so
0x2DEDFF84 0x2DEE0FDF 4188 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbsess.so
0x2DEE1000 0x2DEED78B 51084 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libapp_sess.so
0x2DEFD78C 0x2DEFEE63 5848 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libapp_sess.so
0x2DF00000 0x2DF79B13 498452 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuidc.so
0x2DF8A000 0x2DF968A3 51364 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuidc.so
0x2DF97000 0x2DF9C6DB 22236 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuismrp.so
0x2DFAD000 0x2DFADC6F 3184 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuismrp.so
0x2DFAE000 0x2E02762B 497196 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbshell.so
0x2E038000 0x2E047FB7 65464 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbshell.so
0x2E048000 0x2E077593 193940 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libapp_sess_ios.so
0x2E087594 0x2E08CABB 21800 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libapp_sess_ios.so
0x2E08E000 0x2E1729E3 936420 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libethernet.so
0x2E1829E4 0x2E19ACD3 99056 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libethernet.so
0x2E19B000 0x2E1BA853 129108 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libiosrp_ui.so
0x2E1CA854 0x2E1CEE77 17956 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libiosrp_ui.so
0x2E1CF000 0x2E1F2FAB 147372 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libplogd_msgs.so
0x2E203000 0x2E2064AB 13484 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libplogd_msgs.so
0x2E207000 0x2E23602B 192556 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrace.so
0x2E24602C 0x2E24CAD7 27308 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrace.so
0x2E24E000 0x2E28FD4B 269644 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libprocmib_slave.so
0x2E29FD4C 0x2E2A6E2F 28900 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libprocmib_slave.so
0x2E2A7000 0x2E2B6453 62548 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libhwcfg.so
0x2E2B7000 0x2E2B8E0B 7692 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libhwcfg.so
0x2E2B9000 0x2E2B9AD7 2776 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libip_match_entry.so
0x2E2C9AD8 0x2E2C9BAF 216 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libip_match_entry.so
0x2E2CA000 0x2E2ED89B 145564 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libiif.so
0x2E2FE000 0x2E300DDF 11744 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libiif.so
0x2E302000 0x2E31395B 72028 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libxtf.so
0x2E32395C 0x2E324F1F 5572 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libxtf.so
0x2E325000 0x2E3260C3 4292 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcilogger.so
0x2E3360C4 0x2E33621F 348 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcilogger.so
0x2E337000 0x2E4086E3 857828 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libecho.so
0x2E419000 0x2E429C6F 68720 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libecho.so
0x2E42A000 0x2E452BCB 166860 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libecho2.so
0x2E463000 0x2E4668F3 14580 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libecho2.so
0x2E468000 0x2E478323 66340 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libappparam_test.so
0x2E488324 0x2E48976F 5196 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libappparam_test.so
0x2E48A000 0x2E49A3F3 66548 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libappparam_test2.so
0x2E4AA3F4 0x2E4AB83F 5196 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libappparam_test2.so
0x2E4AC000 0x2E55206B 680044 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpltest.so
0x2E56206C 0x2E56F347 53980 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpltest.so
0x2E570000 0x2E84FC63 3013732 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libentity_manager.so
0x2E850000 0x2E894ABB 281276 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libentity_manager.so
0x2E896000 0x2E92AF13 610068 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libif_manager.so
0x2E93B000 0x2E94951F 58656 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libif_manager.so
0x2E94A000 0x2E998683 321156 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liboirservice.so
0x2E9A8684 0x2E9AF8EF 29292 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liboirservice.so
0x2E9B0000 0x2E9D1E8B 138892 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liblcsrservice.so
0x2E9E2000 0x2E9E527F 12928 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liblcsrservice.so
0x2E9E6000 0x2EA26C6B 265324 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstaller_cmn.so
0x2EA37000 0x2EA3E86F 30832 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstaller_cmn.so
0x2EA40000 0x2EA7A893 239764 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstaller_client.so
0x2EA8B000 0x2EA8EB3F 15168 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstaller_client.so
0x2EA8F000 0x2EB39BDB 699356 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstaller_iosd.so
0x2EB4A000 0x2EB59A93 64148 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstaller_iosd.so
0x2EB5A000 0x2EC1A7A3 788388 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpki_ssl.so
0x2EC2B000 0x2EC3BF1F 69408 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpki_ssl.so
0x2EC3C000 0x2ECC2D7B 552316 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libehttps.so
0x2ECD3000 0x2ECDFC4B 52300 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libehttps.so
0x2ECE1000 0x2ED0FABB 191164 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libdhcp_ipc.so
0x2ED1FABC 0x2ED23E17 17244 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libdhcp_ipc.so
0x2ED24000 0x2ED6F0CB 307404 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libnmsp_spi.so
0x2ED7F0CC 0x2ED85C57 27532 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libnmsp_spi.so
0x2ED86000 0x2EFC41F3 2351604 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/librsmp.so
0x2EFD41F4 0x2F010543 246608 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/librsmp.so
0x2F011000 0x2F055E93 282260 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtactic_nova.so
0x2F066000 0x2F06C723 26404 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtactic_nova.so
0x2F06E000 0x2F1EF68B 1578636 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libqos_tam.so
0x2F1FF68C 0x2F2256C7 155708 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libqos_tam.so
0x2F226000 0x2F30B633 939572 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcdb_ios.so
0x2F31C000 0x2F330EDF 85728 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcdb_ios.so
0x2F331000 0x2F3C786B 616556 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcs_ios.so
0x2F3D8000 0x2F3E5E5F 56928 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcs_ios.so
0x2F3E6000 0x2F3FC4DB 91356 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcmntp.so
0x2F40D000 0x2F40EDBB 7612 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcmntp.so
0x2F410000 0x2F493DA3 540068 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libdtls_ios.so
0x2F4A3DA4 0x2F4AEF8F 45548 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libdtls_ios.so
0x2F4AF000 0x2F510F4B 401228 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libaaa.so
0x2F521000 0x2F5268CF 22736 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libaaa.so
0x2F527000 0x2F5D7D1B 724252 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libauth_mgr.so
0x2F5E8000 0x2F5F7AFF 64256 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libauth_mgr.so
0x2F5F8000 0x2F64D06B 348268 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmcast_wcm.so
0x2F65D06C 0x2F665CBB 35920 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmcast_wcm.so
0x2F667000 0x2F763F8B 1036172 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libeicli_spi.so
0x2F774000 0x2F78B523 95524 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libeicli_spi.so
0x2F78C000 0x2F7A8D33 118068 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libeicore_ipc.so
0x2F7B9000 0x2F7BB66B 9836 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libeicore_ipc.so
0x2F7BC000 0x2F7F83C3 246724 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libfiletrans_svc.so
0x2F8083C4 0x2F80E547 24964 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libfiletrans_svc.so
0x2F80F000 0x2F827D13 101652 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libeicore_event_ipc.so
0x2F838000 0x2F839FEB 8172 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libeicore_event_ipc.so
0x2F83B000 0x2F8A10DB 418012 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libdebugflag.so
0x2F8B10DC 0x2F8B9CCB 35824 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libdebugflag.so
0x2F8BA000 0x2F93EBE3 543716 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcapwap.so
0x2F94F000 0x2F95BB37 52024 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcapwap.so
0x2F95C000 0x2F99F68B 276108 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcapwap_fed.so
0x2F9AF68C 0x2F9B5737 24748 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcapwap_fed.so
0x2F9B6000 0x2F9DE63B 165436 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libdemo.so
0x2F9EE63C 0x2F9F1A57 13340 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libdemo.so
0x2F9F3000 0x2FA0BFB3 102324 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha.so
0x2FA1C000 0x2FA1F11F 12576 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha.so
0x2FA20000 0x2FAE4EF3 806644 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha_msif.so
0x2FAF5000 0x2FB096FF 83712 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha_msif.so
0x2FB0A000 0x2FBAF35B 676700 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha_plif.so
0x2FBBF35C 0x2FBCF5AB 66128 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha_plif.so
0x2FBD0000 0x2FC5027B 524924 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha_library_cli.so
0x2FC6027C 0x2FC6AFCF 44372 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha_library_cli.so
0x2FC6C000 0x2FCDD1AB 463276 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libepm.so
0x2FCED1AC 0x2FCF67F7 38476 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libepm.so
0x2FCF7000 0x2FD638BB 444604 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsnmp.so
0x2FD74000 0x2FD7ADBF 28096 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsnmp.so
0x2FD7B000 0x300A6A33 3324468 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liblicense_service.so
0x300B7000 0x300FD62B 288300 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liblicense_service.so
0x300FE000 0x3011AF63 118628 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libshutdown.so
0x3012B000 0x3012D7F7 10232 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libshutdown.so
0x3012F000 0x30151863 141412 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ip_traffic_stats.so
0x30162000 0x30165ACF 15056 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ip_traffic_stats.so
0x30166000 0x3016B22B 21036 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ip_traffic_stats_types.so
0x3017B22C 0x3017BBDF 2484 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ip_traffic_stats_types.so
0x3017C000 0x301812EB 21228 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_ip_traffic_stats.so
0x301912EC 0x30191C9F 2484 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_ip_traffic_stats.so
0x30192000 0x301C0213 188948 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libplatform_ha_role.so
0x301D0214 0x301D3E0F 15356 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libplatform_ha_role.so
0x301D5000 0x301E1E73 52852 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libipc_transport.so
0x301F2000 0x301F2C2B 3116 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libipc_transport.so
0x301F3000 0x302DBF6B 954220 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libobfl.so
0x302EC000 0x303028E3 92388 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libobfl.so
0x30303000 0x303317CB 190412 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libparser_spi.so
0x303417CC 0x30344ECF 14084 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libparser_spi.so
0x30345000 0x303859B3 264628 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcm_fed.so
0x30396000 0x3039BB7F 23424 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcm_fed.so
0x3039D000 0x303D581B 231452 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcm_platform.so
0x303E581C 0x303EAC8F 21620 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcm_platform.so
0x303EB000 0x3040B733 132916 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libosinfo.so
0x3041B734 0x3041E7DB 12456 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libosinfo.so
0x3041F000 0x30429E3B 44604 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsysmgr.so
0x3043A000 0x3043B53F 5440 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsysmgr.so
0x3043C000 0x3050097B 805244 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsysmgr_cl.so
0x3051097C 0x30521EAF 70964 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsysmgr_cl.so
0x30523000 0x30533B93 68500 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libconsole_relay.so
0x30544000 0x3054551B 5404 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libconsole_relay.so
0x30546000 0x30550DD3 44500 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libwcmha.so
0x30561000 0x30561BCF 3024 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libwcmha.so
0x30562000 0x305A998B 293260 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libfnf_fed_spi.so
0x305B998C 0x305BFF5F 26068 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libfnf_fed_spi.so
0x305C0000 0x306029BB 272828 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpds_perftest.so
0x30613000 0x3061865F 22112 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpds_perftest.so
0x3061A000 0x306338D3 104660 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsystem_config.so
0x306438D4 0x30645C3F 9068 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsystem_config.so
0x30646000 0x3065B173 86388 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtdllib.so
0x3066B174 0x3066DF8F 11804 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtdllib.so
0x3066E000 0x3066F5F3 5620 IText R/W /usr/binos/lib/libbsdlib.so
0x3067F5F4 0x3067F74F 348 IData R/W /usr/binos/lib/libbsdlib.so
0x30680000 0x30685613 22036 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcdllib.so
0x30695614 0x30695B0F 1276 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcdllib.so
0x30697000 0x3069990B 10508 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcdlutil.so
0x306A990C 0x306A9B4F 580 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcdlutil.so
0x306AA000 0x306BFBAB 89004 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libevlib.so
0x306D0000 0x306D1C4F 7248 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libevlib.so
0x306D2000 0x306E1953 63828 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libevutil.so
0x306F1954 0x306F6F7F 22060 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libevutil.so
0x306F7000 0x3070C80B 88076 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmts.so
0x3071C80C 0x3071E8E7 8412 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmts.so
0x30720000 0x3073461B 83484 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmqipc.so
0x3074461C 0x30746A2F 9236 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmqipc.so
0x30747000 0x3074DCA3 27812 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbipc.so
0x3075E000 0x3075E7AF 1968 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbipc.so
0x3075F000 0x3076306B 16492 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtdllib_c.so
0x3077306C 0x3077350F 1188 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtdllib_c.so
0x30774000 0x30774C77 3192 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libvs_lock.so
0x30784C78 0x30784DCF 344 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libvs_lock.so
0x30786000 0x30789AF3 15092 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_avl.so
0x30799AF4 0x30799E9F 940 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_avl.so
0x3079A000 0x3079EB5B 19292 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libvista.so
0x307AF000 0x307AF677 1656 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libvista.so
0x307B0000 0x307B74A3 29860 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libfile_alloc.so
0x307C74A4 0x307C7E0F 2412 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libfile_alloc.so
0x307C8000 0x307CE5C3 26052 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libchasfs.so
0x307DE5C4 0x307DEE7F 2236 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libchasfs.so
0x307E0000 0x307EE48B 58508 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbinos_svcs.so
0x307FE48C 0x307FFACF 5700 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbinos_svcs.so
0x30800000 0x3080125F 4704 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsystime.so
0x30811260 0x3081146F 528 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsystime.so
0x30812000 0x3081D5F3 46580 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbtrace.so
0x3082D5F4 0x3083BDCF 59356 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbtrace.so
0x3083C000 0x308407B3 18356 IText R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libflash.so
0x30851000 0x30851EBF 3776 IData R/W /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libflash.so
0x30853000 0x30856CD3 15572 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libplatform_flashlib.so
0x30867000 0x3086A8FF 14592 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libplatform_flashlib.so
0x3086B000 0x308722CB 29388 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtime.so
0x308822CC 0x30882F8F 3268 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtime.so
0x30883000 0x308C0FA3 253860 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libpds.so
0x308D1000 0x308D547F 17536 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libpds.so
0x308D6000 0x308D6DA7 3496 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmemdbg_stubs.so
0x308E6DA8 0x308E6FBF 536 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmemdbg_stubs.so
0x308E8000 0x308E8D63 3428 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcfsp.so
0x308F8D64 0x308F8E7F 284 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcfsp.so
0x308F9000 0x30902CB3 40116 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstallerlib.so
0x30913000 0x30913FBF 4032 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstallerlib.so
0x30914000 0x30914823 2084 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsyspage.so
0x30924824 0x309248DF 188 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsyspage.so
0x30925000 0x3095763B 206396 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libiosd_unix.so
0x30968000 0x309B4D9B 314780 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libiosd_unix.so
0x309B6000 0x309EFDBB 236988 IText R/W /lib32/libgcc_s.so.1
0x30A00000 0x30A00DBF 3520 IData R/W /lib32/libgcc_s.so.1
0x30A01000 0x30B59983 1411460 IText R/W /lib32/libc.so.6
0x30B6A030 0x30B77FBF 57232 IData R/W /lib32/libc.so.6
0x30B78000 0x30C16E43 650820 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libspilib.so
0x30C27000 0x30C308B7 39096 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libspilib.so
0x30C31000 0x30C3E873 55412 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cce_common.so
0x30C4F000 0x30C508DB 6364 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cce_common.so
0x30C52000 0x30C5D9EB 47596 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ha_types.so
0x30C6E000 0x30C6F6BF 5824 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ha_types.so
0x30C70000 0x30D5101B 921628 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cce_types.so
0x30D6101C 0x30D7971F 100100 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cce_types.so
0x30D7A000 0x30E1EACB 674508 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_qos.so
0x30E2F000 0x30E40BD7 72664 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_qos.so
0x30E41000 0x30E7A903 235780 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_qos_types.so
0x30E8A904 0x30E90BF7 25332 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_qos_types.so
0x30E92000 0x30EC0C73 191604 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_adj_macstr_common.so
0x30ED1000 0x30ED681F 22560 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_adj_macstr_common.so
0x30ED7000 0x30F3A8EB 407788 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef_types.so
0x30F4B000 0x30F558B3 43188 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef_types.so
0x30F56000 0x3102D75B 882524 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l2target_types.so
0x3103D75C 0x31051FFF 84132 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l2target_types.so
0x31052000 0x3106991B 96540 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l3intf_types.so
0x3107991C 0x3107BE7F 9572 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l3intf_types.so
0x3107D000 0x310A738B 172940 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_urpf_types.so
0x310B738C 0x310BBC67 18652 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_urpf_types.so
0x310BC000 0x3113DF0B 532236 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_acl_types.so
0x3114E000 0x3115DA8F 64144 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_acl_types.so
0x3115E000 0x3116F563 71012 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_punt_acl_config.so
0x31180000 0x31181E37 7736 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_punt_acl_config.so
0x31182000 0x3119581B 79900 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_pbr.so
0x311A581C 0x311A7B9F 9092 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_pbr.so
0x311A9000 0x311D8DAB 196012 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_pbr_types.so
0x311E8DAC 0x311EDE4B 20640 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_pbr_types.so
0x311EE000 0x3122E1E3 262628 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_tun_types.so
0x3123E1E4 0x31245423 29248 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_tun_types.so
0x31246000 0x312646DB 124636 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_ipmc.so
0x312746DC 0x31277F1F 14404 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_ipmc.so
0x31278000 0x312A140B 168972 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc_types.so
0x312B140C 0x312B5E3B 18992 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc_types.so
0x312B7000 0x312C1643 42564 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_vrf_types.so
0x312D1644 0x312D295F 4892 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_vrf_types.so
0x312D3000 0x312DAF3B 32572 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_vrf_msg.so
0x312EB000 0x312EBC0F 3088 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_vrf_msg.so
0x312EC000 0x31315E63 171620 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_wccp.so
0x31326000 0x3132AA9F 19104 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_wccp.so
0x3132B000 0x3138B69B 394908 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_wccp_types.so
0x3139B69C 0x313A5F57 43196 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_wccp_types.so
0x313A7000 0x313C40DB 119004 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_wccp_msg.so
0x313D40DC 0x313D72AF 12756 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_wccp_msg.so
0x313D8000 0x31447A93 457364 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf_types.so
0x31448000 0x31454717 50968 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf_types.so
0x31455000 0x31472343 119620 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf_msg.so
0x31482344 0x314856BF 13180 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf_msg.so
0x31486000 0x3152ED43 691524 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsnmp_db.so
0x3153F000 0x3154F7DF 67552 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsnmp_db.so
0x31551000 0x3156236B 70508 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libfman_rp_obj.so
0x31573000 0x31573E0F 3600 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libfman_rp_obj.so
0x31574000 0x3157545B 5212 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcef_config_common.so
0x3158545C 0x3158563F 484 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcef_config_common.so
0x31586000 0x315866AF 1712 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_queue.so
0x315966B0 0x3159672F 128 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_queue.so
0x31597000 0x31598113 4372 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_hash.so
0x315A8114 0x315A829F 396 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_hash.so
0x315AA000 0x315AA6AF 1712 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_rb.so
0x315BA6B0 0x315BA72F 128 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_rb.so
0x315BB000 0x315C4C53 40020 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libslclient.so
0x315D5000 0x315D5CCF 3280 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libslclient.so
0x315D6000 0x316209C3 305604 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libxos.so
0x316309C4 0x3163A9FF 41020 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libxos.so
0x3163B000 0x317738F3 1280244 IText R/W /usr/lib32/libxml2.so.2
0x31784000 0x31789A63 23140 IData R/W /usr/lib32/libxml2.so.2
0x3178B000 0x3178DBEB 11244 IText R/W /usr/binos/lib/lib4arglib.so
0x3179E000 0x317A293F 18752 IData R/W /usr/binos/lib/lib4arglib.so
0x317A5000 0x317BAD5B 89436 IText R/W /lib32/libpthread.so.0
0x317CB43C 0x317CE3FF 12228 IData R/W /lib32/libpthread.so.0
0x317CF000 0x317D8CBB 40124 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libngd.so
0x317E9000 0x317EAE0F 7696 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libngd.so
0x317EC000 0x317F42E3 33508 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libds.so
0x318042E4 0x3180568F 5036 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libds.so
0x31806000 0x3180706B 4204 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liberrmsg.so
0x3181706C 0x318171AF 324 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liberrmsg.so
0x31818000 0x3181ACCB 11468 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbmalloc.so
0x3182ACCC 0x3182CDEF 8484 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbmalloc.so
0x3182D000 0x31836FD3 40916 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libavl.so
0x31847000 0x318478DB 2268 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libavl.so
0x31849000 0x3184A99B 6556 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstallerlite.so
0x3185A99C 0x3185AB5F 452 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstallerlite.so
0x3185B000 0x3186186B 26732 IText R/W /usr/binos/lib/libjson.so
0x31872000 0x31872B0F 2832 IData R/W /usr/binos/lib/libjson.so
0x31873000 0x31873EFB 3836 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libobjref_posix.so
0x31884000 0x3188416F 368 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libobjref_posix.so
0x31886000 0x3189BE33 89652 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_common.so
0x318AC000 0x318AE7C7 10184 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_common.so
0x318B0000 0x318B4D2B 19756 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_qos_common.so
0x318C5000 0x318C578F 1936 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_qos_common.so
0x318C6000 0x318CBAFB 23292 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_dwtv.so
0x318DC000 0x318DCAAF 2736 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_dwtv.so
0x318DD000 0x31994733 751412 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef_tables.so
0x319A4734 0x319B985F 86316 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef_tables.so
0x319BB000 0x319E3D93 167316 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_fed_api_mfi.so
0x319F4000 0x319F870F 18192 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_fed_api_mfi.so
0x319F9000 0x31A224AB 169132 IText R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_mfi_tables.so
0x31A324AC 0x31A3658F 16612 IData R/W /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_mfi_tables.so
0x31A39000 0x31A471D3 57812 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_recv_types.so
0x31A571D4 0x31A58D1B 6984 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_recv_types.so
0x31A59000 0x31B1195B 756060 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc_tables.so
0x31B22000 0x31B36F43 85828 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc_tables.so
0x31B38000 0x31B3DCF3 23796 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_vrf.so
0x31B4E000 0x31B4EA83 2692 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_vrf.so
0x31B4F000 0x31B6EAA3 129700 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_vrf_tbl.so
0x31B6F000 0x31B72943 14660 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_vrf_tbl.so
0x31B73000 0x31C24EEB 728812 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_wccp_tbl.so
0x31C35000 0x31C489D7 80344 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_wccp_tbl.so
0x31C49000 0x31C5D143 82244 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_recv.so
0x31C6D144 0x31C6F5A7 9316 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_recv.so
0x31C71000 0x31C8290B 71948 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_uth.so
0x31C93000 0x31C94F7F 8064 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_uth.so
0x31C95000 0x31C9AE73 24180 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_incomplete_target.so
0x31CAB000 0x31CABA2F 2608 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_incomplete_target.so
0x31CAC000 0x31CB8F6B 53100 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_incomplete_target.so
0x31CC9000 0x31CCA87B 6268 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_incomplete_target.so
0x31CCB000 0x31D0FF53 282452 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_fnf.so
0x31D20000 0x31D2754F 30032 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_fnf.so
0x31D29000 0x31DE3F93 765844 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf_table.so
0x31DF4000 0x31E0917F 86400 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf_table.so
0x31E0A000 0x31E0F29B 21148 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf.so
0x31E1F29C 0x31E1FC5F 2500 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf.so
0x31E20000 0x31E42823 141348 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_test_obj.so
0x31E53000 0x31E56C2F 15408 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_test_obj.so
0x31E57000 0x31E6A78B 79756 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_test_obj_types.so
0x31E7B000 0x31E7CF4F 8016 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_test_obj_types.so
0x31E7E000 0x31EA7593 169364 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_test_obj.so
0x31EB7594 0x31EBBC57 18116 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_test_obj.so
0x31EBE000 0x31ED8E0B 110092 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinfra.so
0x31EE9000 0x31EED5B7 17848 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinfra.so
0x31EF0000 0x31F80E6B 593516 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libaaacommon.so
0x31F91000 0x31FA2583 71044 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libaaacommon.so
0x31FA5000 0x31FADB43 35652 IText R/W /lib32/librt.so.1
0x31FBDDB4 0x31FC901F 45676 IData R/W /lib32/librt.so.1
0x31FCB000 0x31FD4523 38180 IText R/W /usr/lib32/libunwind.so.7
0x31FE4524 0x3201FB3B 243224 IData R/W /usr/lib32/libunwind.so.7
0x32020000 0x32021E0B 7692 IText R/W /lib32/libdl.so.2
0x32031FE4 0x320320EF 268 IData R/W /lib32/libdl.so.2
0x32036000 0x320478F3 71924 IText R/W /usr/lib32/libz.so.1
0x320578F4 0x32057B2F 572 IData R/W /usr/lib32/libz.so.1
0x32058000 0x3212B0FB 864508 IText R/W /lib32/libm.so.6
0x3213BFEC 0x3213C7DF 2036 IData R/W /lib32/libm.so.6
0x3213D000 0x3214711B 41244 IText R/W /usr/lib32/libsafelibc.so
0x3215711C 0x3215789F 1924 IData R/W /usr/lib32/libsafelibc.so
0x3215A000 0x3217B3CB 136140 IText R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmemdbg.so
0x3218B3CC 0x3218E49F 12500 IData R/W /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmemdbg.so
0x32400000 0x523FFFFF 536870912 Local R/W heap
0x52400008 0x53400007 16777216 Local R/W IOS Process stack
0x7F645000 0x7F65AFFF 90112 Local R/W stack
Free Region Manager:
TBRSCODSW05#
TBRSCODSW05#
TBRSCODSW05#
TBRSCODSW05#
TBRSCODSW05#
TBRSCODSW05#
TBRSCODSW05#
TBRSCODSW05#
TBRSCODSW05#
TBRSCODSW05#
TBRSCODSW05#
TBRSCODSW05#sh cdp ne
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
SEP501CBFFCDC85 Gig 1/0/12 159 H P M IP Phone Port 1
SEP501CBFFCDCF6 Gig 1/0/19 144 H P M IP Phone Port 1
TBRSCOM_COR01 Gig 1/1/1 155 R S I WS-C4500X Ten 1/12
TBRSCODSW05#sh cdp ne de
Device ID: SEP501CBFFCDC85
Entry address(es):
IP address: 10.24.31.31
Platform: Cisco IP Phone 9951, Capabilities: Host Phone Two-port Mac Relay
Interface: GigabitEthernet1/0/12, Port ID (outgoing port): Port 1
Holdtime : 155 sec
Second Port Status: Down
Version :
sip9951.9-4-2-13
advertisement version: 2
Duplex: full
Power drawn: 13.546 Watts
Power request id: 34270, Power management id: 3
Power request levels are:13546 0 0 0 0
Management address(es):
Device ID: SEP501CBFFCDCF6
Entry address(es):
Interface: GigabitEthernet1/0/19, Port ID (outgoing port): Port 1
Holdtime : 140 sec
Version :
sip9951.9-4-2-13
Duplex: full
Power drawn: 11.997 Watts
Power request id: 63198, Power management id: 2
Power request levels are:11997 13546 0 0 0
Device ID: TBRSCOM_COR01
Entry address(es):
IP address: 10.24.10.254
Platform: cisco WS-C4500X-16, Capabilities: Router Switch IGMP
Interface: GigabitEthernet1/1/1, Port ID (outgoing port): TenGigabitEthernet1/12
Holdtime : 151 sec
Version :
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 15.1(1)SG2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 24-Oct-12 00:32 by prod_rel_team
VTP Management Domain: ''
Native VLAN: 1
Duplex: full
TBRSCODSW05# sh po
TBRSCODSW05# sh pow
TBRSCODSW05# sh power ?
inline Show inline power status
| Output modifiers
<cr>
TBRSCODSW05# sh power in
TBRSCODSW05# sh power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 30.0 27.1 2.9
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/1 auto off 0.0 n/a n/a 30.0
Gi1/0/2 auto off 0.0 n/a n/a 30.0
Gi1/0/3 auto off 0.0 n/a n/a 30.0
Gi1/0/4 auto off 0.0 n/a n/a 30.0
Gi1/0/5 auto off 0.0 n/a n/a 30.0
Gi1/0/6 auto off 0.0 n/a n/a 30.0
Gi1/0/7 auto off 0.0 n/a n/a 30.0
Gi1/0/8 auto off 0.0 n/a n/a 30.0
Gi1/0/9 auto off 0.0 n/a n/a 30.0
Gi1/0/10 auto off 0.0 n/a n/a 30.0
Gi1/0/11 auto off 0.0 n/a n/a 30.0
Gi1/0/12 auto on 13.5 IP Phone 9951 3 30.0
Gi1/0/13 auto off 0.0 n/a n/a 30.0
Gi1/0/14 auto off 0.0 n/a n/a 30.0
Gi1/0/15 auto off 0.0 n/a n/a 30.0
Gi1/0/16 auto off 0.0 n/a n/a 30.0
(Watts)
Gi1/0/17 auto off 0.0 n/a n/a 30.0
Gi1/0/18 auto off 0.0 n/a n/a 30.0
Gi1/0/19 auto on 13.5 IP Phone 9951 3 30.0
Gi1/0/20 auto off 0.0 n/a n/a 30.0
Gi1/0/21 auto off 0.0 n/a n/a 30.0
Gi1/0/22 auto off 0.0 n/a n/a 30.0
Gi1/0/23 auto off 0.0 n/a n/a 30.0
Gi1/0/24 auto off 0.0 n/a n/a 30.0
Gi1/0/25 auto off 0.0 n/a n/a 30.0
Gi1/0/26 auto off 0.0 n/a n/a 30.0
Gi1/0/27 auto off 0.0 n/a n/a 30.0
Gi1/0/28 auto off 0.0 n/a n/a 30.0
Gi1/0/29 auto off 0.0 n/a n/a 30.0
Gi1/0/30 auto off 0.0 n/a n/a 30.0
Gi1/0/31 auto off 0.0 n/a n/a 30.0
Gi1/0/32 auto off 0.0 n/a n/a 30.0
Gi1/0/33 auto off 0.0 n/a n/a 30.0
Gi1/0/34 auto off 0.0 n/a n/a 30.0
Gi1/0/35 auto off 0.0 n/a n/a 30.0
Gi1/0/36 auto off 0.0 n/a n/a 30.0
Gi1/0/37 auto off 0.0 n/a n/a 30.0
Gi1/0/38 auto off 0.0 n/a n/a 30.0
Gi1/0/39 auto off 0.0 n/a n/a 30.0
(Watts)
Gi1/0/40 auto off 0.0 n/a n/a 30.0
Gi1/0/41 auto off 0.0 n/a n/a 30.0
Gi1/0/42 auto off 0.0 n/a n/a 30.0
Gi1/0/43 auto off 0.0 n/a n/a 30.0
Gi1/0/44 auto off 0.0 n/a n/a 30.0
Gi1/0/45 auto off 0.0 n/a n/a 30.0
Gi1/0/46 auto off 0.0 n/a n/a 30.0
Gi1/0/47 auto off 0.0 n/a n/a 30.0
Gi1/0/48 auto off 0.0 n/a n/a 30.0
TBRSCODSW05#$ do wr
do wr
% Invalid input detected at '^' marker.
TBRSCODSW05#wr
Building configuration...
ā11-19-2016 04:44 AM
1 30.0 27.1 2.9
WTF. There's not enough PoE allowance.
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C1-350WAC , VID: V01 , SN: DCB1922H1E
350w Power supply??? Really?
So who's the "genius" who shoved a 350w power supply into a 48-port PoE switch?
For a PoE switch, 750w is the MINIMUM required power supply.
ā11-19-2016 05:05 AM
Thanks My brother Leo Laohoo for your respond
Now i am needing to change the power supply only from 350 to 750 W to support full POE
