Cisco switch 6500 series: Temperature alarm
migsfagyan
Hi all
We have a alarm at least 1 per day for some of our switch.
Info 04/20/2011 08:55:24 <switch> Temperature State: normal
Severe 04/20/2011 08:54:20 <Switch> Temperature State: notPresent
check on the airconditioning system seems to be ok (i have requested for actual test for the temperature in the room).
<swicth>#show env temperature
  VTT 1 outlet temperature: 27C
  VTT 2 outlet temperature: 21C
  VTT 3 outlet temperature: 20C
  module 1 outlet temperature: 23C
  module 1 inlet temperature: 22C
  module 1 device-1 temperature: 20C
  module 1 device-2 temperature: 23C
  module 2 outlet temperature: 25C
  module 2 inlet temperature: 23C
  module 2 device-1 temperature: 20C
  module 2 device-2 temperature: 25C
  module 3 outlet temperature: 24C
  module 3 inlet temperature: 23C
  module 3 device-1 temperature: 20C
  module 3 device-2 temperature: 24C
  module 4 outlet temperature: 24C
  module 4 inlet temperature: 23C
  module 4 device-1 temperature: 20C
  module 4 device-2 temperature: 23C
  module 5 outlet temperature: 24C
  module 5 inlet temperature: 23C
  module 5 device-1 temperature: 20C
  module 5 device-2 temperature: 24C
  module 6 outlet temperature: 23C
  module 6 inlet temperature: 22C
  module 6 device-1 temperature: 20C
  module 6 device-2 temperature: 22C
  module 7 outlet temperature: 24C
  module 7 inlet temperature: 21C
  module 7 device-1 temperature: 27C
  module 7 device-2 temperature: 23C
  module 7 aux-1 temperature: N/A
  module 7 asic-1 (HYPERION-1) temp: 20C
  module 7 RP outlet temperature: 28C
  module 7 RP inlet temperature: 28C
  module 7 EARL outlet temperature: 31C
  module 7 EARL inlet temperature: 19C
  module 8 outlet temperature: 27C
  module 8 inlet temperature: 22C
  module 8 device-1 temperature: 28C
  module 8 device-2 temperature: 23C
  module 8 aux-1 temperature: N/A
  module 8 asic-1 (HYPERION-1) temp: 20C
  module 8 RP outlet temperature: 30C
  module 8 RP inlet temperature: 29C
  module 8 EARL outlet temperature: 32C
  module 8 EARL inlet temperature: 19C
  module 13 outlet temperature: 24C
  module 13 inlet temperature: 23C
  module 13 device-1 temperature: 20C
  module 13 device-2 temperature: 24C
  module 13 VDB outlet temperature: 20C
  module 13 VDB inlet temperature: 22C
  module 13 VDB device-1 temperature: 22C
does any one have an idea what causes the alarm, thank you
regards
Migs
migsfagyan
Hi again
does anyone have an idea what causes the alarm? i really appreciate any idea / feedback from you all. thanks
regards
migs
Though it may not reveal the cause of your problem, here is some info that will help you understand what it means:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&typeName=CiscoEnvMonState
Look for notPresent(5)
Please rate if helpful.
