Cisco Switch Capability Matrix
foysol_bgd
Level 2
Level 2
Hi Experts,
Looking for a link in Cisco website about the Cisco switch feature matrix by model. Any help will be great.
Here is an example.
Features296037004500650070009000
MPLS    Yes
VLAN    yes
BGP
OSPF
Ganesh Hariharan
Hi Experts,
Here is an example.
Features
2960
3700
4500
6500
7000
9000
MPLS
Yes
VLAN
yes
BGP
OSPF
IOS feature set describe the supporting functionality of all services and definitely the resource with hardware to support large number of routing table or heavy network.
Below are the packages which supports services when installed in different Layer 3 or Routers.
Advance IP services IOS :- Supports IS-IS,MPLS,L2/L3 VPN's, Mobile SUpport,IP SLA etc.
Enterprise services IOS :- Supports IS-IS , L3 Routed Protcols, Mobile Support, IBM services etc.
IP Services IOS :- All layer 3 routing protocol excluding MPLS, VRF Lite ,Multicast etc.
IP Base IOS :- RIP, VRRP/HSRP,EIGRP STub , Stad.Multicast etc.
Hope that Helps...
-GI
Rate if it Helps..
Hi Ganesh,
Thank you for your reply. So any switch model, whether 2960 or 6500 with IP services IOS will support full layer 3 MPLS VPN?
Here is the link for 3850 switch
http://www.cisco.com/c/en/us/products/switches/catalyst-3850-series-switches/models-comparison.html#services
Here is the link for Nexus 7000 series and I am looking same thing for 6500 and 3850 as well. Any help will be great.
http://www.cisco.com/c/en/us/products/switches/nexus-7000-series-switches/models-comparison.html#~tab-b
