cisco switch ios upgradation
anupam.kumar51
how can I upgrade cisco 2960s switch's ios.
what commands will be used for it
Nikhil Kapoor
Hello Anupam,
1. You need to copy the IOS from CCO.
2. The same IOS needs to copied on to the flash.
#copy tftp : flash
#tftp ip address <x.x.x.x>
3. I would suggest before upgrading the IOS. Please verify the MD5 checksum and confirm with CCO that it matches. This confirms that while copying the image didnt get corrupt.
#verify /md5 Flash:<IOSimage>.bin
4. Once you see the IOS in flash. Please configure below.
boot-start-marker
boot system flash <IOS image name>.bin
boot-end-marker
5. Save the confguration.
#wr
6. reload the router. Post reload you can run " show version" to check if device has come up with new IOS.
HTH,
Nikhil
