Cisco Switch L3 with 4SFP and 16-port
sadagala
Hello. please help me to find cisco switch with 4SFP and 16-ports It shoud need to me a layer 3
5 Replies 5
Seb Rupik
Hi there,
Take a look at the 3560 :
WS-C3650-48TQ-S
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3650-series-switches/data_sheet-c78-729449.html
Or slightly cheaper, and with a closer number of fixed RJ45 switchports:
SG350X-24
https://www.cisco.com/c/en/us/products/collateral/switches/350x-series-stackable-managed-switches/datasheet-c78-735986.html
cheers,
Seb.
Thank you, brother. but I need a 16ports and 4Sfp switch.
both the Cisco Catalyst 2960X-24PS-L and the Cisco Catalyst 2960X-24TS-L have 24 10/100/1000 Ethernet ports (you cannot get 16, 24 is the minimum) and 4 SFP uplink interfaces.
Below is the datasheet:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/datasheet_c78-728232.html
Thank you. I got it.
The Meraki MS120 with 24 RJ-45 and 4 x 1GbE SFP ports would be an option,too:
https://meraki.cisco.com/lib/pdf/meraki_datasheet_ms_family.pdf
