CISCO switch not upgraded even after reload
I tried to upgrade the 2960L switch with latest IOS release but even after reload it not upgraded. What was the reason for same?
PFB logs:
#sh ver | i IOS
Cisco IOS Software, C2960L Software (C2960L-UNIVERSALK9-M), Version 15.2(7)E6, RELEASE SOFTWARE (fc2)
#sh boot
BOOT path-list : flash:/c2960l-universalk9-mz.152-7.E7.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : yes
Manual Boot : no
Allow Dev Key : yes
HELPER path-list :
Boot optimization : disabled
NVRAM/Config file
buffer size: 524288
Timeout for Config
Download: 0 seconds
Config Download
via DHCP: disabled (next boot: disabled)
#sh ver | i up
uptime is 26 minutes
Power supply part number : 341-100606-01
Power supply serial number : DCC2328F01P
#dir
Directory of flash:/
513 -rwx 2072 Feb 7 2023 04:16:51 +00:00 multiple-fs
749 drwx 2048 Sep 1 2019 06:08:54 +00:00 dc_profile_dir
258 -rwx 33 Dec 3 2019 10:42:45 +00:00 pnp-tech-time
259 -rwx 3781 Dec 3 2019 10:42:47 +00:00 pnp-tech-discovery-summary
770 -rwx 16250880 Sep 14 2022 07:14:30 +00:00 c2960l-universalk9-mz.152-7.E6.bin
514 -rwx 15986688 Jan 25 2023 06:43:11 +00:00 c2960l-universalk9-mz.152-7.E7.bin
257 -rwx 47 Jan 17 2020 10:17:21 +00:00 dhcpdb.txt
263 -rwx 1216 Dec 3 2019 12:32:03 +00:00 vlan.dat
1026 -rwx 10813 Feb 7 2023 04:15:33 +00:00 config.text
515 -rwx 3908 Feb 7 2023 04:15:33 +00:00 private-config.text
2 drwx 2048 Mar 1 1993 00:00:02 +00:00 lost+found
244711424 bytes total (208650240 bytes free)
Leo Laohoo
I can almost guarantee the15.2(7)E7 BIN file is corrupt.  Just look at the file sizes between 15.2(7)E6 and 15.2(7)E7 -- The newer version is smaller (which should not be the case).
Mark Elsen
  - Check the boot variable in the startup config and verify the config register setting ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
pieterh
try removing the "/" in the boot variable
BOOT path-list : flash:c2960cx-universalk9-mz.152-7.E5.bin
