Cisco switch replacement and issue with iSCSI vlan
konix
HI,
I wanted recently replace 2 x 2960-x stacked switches with 2 x 3850-x stacked switches, I "copied" configuration from 2960 to 3850, however after booting up iSCSI interfaces didn't come up (however all interfaces were green) , I restarted switches all interfaces were green (VM, mgmt) but not iSCSI (amber). Is there anything that I can do from networking perspective or the problem is on SAN site and how to resolve this ? We scanned Host bus adapters but it didn't help
thank you
5 Replies 5
balaji.bandi
what is the version of the code on 3850 and what License you have?
can you post both 29XX and 38XX configuraiton to look
also show interface x/x output
BB
Reza Sharifi
It might be that you are running to a speed mismatch with the iSCSI devices. You may want to hard-set the speed and suplex on the switch side and test again.
Reza can I ask you, have you seen this issue between SAN and switch before or it is only suggestion ?
konix
 Hi Guys, thanks for reply
On 3850 there is Cisco IOS XE Fuji 16.9.6 , IPBase
at this moment we've put back 2960x so I can't paste interface output
Configurations files are the same on both switches , on 2960x interface speed is not hard coded, maybe in fact 3850x is more picky then 2960x ?
I don't recall seeing this issue with this model. I am just making a suggestion because you noted that the status light stays amber on the 3850.
I think this is a physical layer issue but then again I could be completely wrong.
