Cisco TDR question
Good morning,
I have a little understanding how Cisco cable-diagnostics TDR works, but I had a simple question.  I have an AP that is using PoE on port 27, and when I run the test is say 55 which I assume that means 55m away?  Should that be a concern since the AP is only 24 feet away?
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/27  1000M Pair A     55   +/- 10 meters Pair B      Normal
                            Pair B     55   +/- 10 meters Pair A      Normal
                            Pair C     55   +/- 10 meters Pair D      Normal
                            Pair D     55   +/- 10 meters Pair C      Normal
Leo Laohoo
Technically, it is not "55 metres away" but "at the end of 55 metres of cable".
Leo Laohoo
Hi Leo,
Thank you for the quick reply.  Should I be concerned?
No, I am not.
The TDR result are ideal (all are "Normal").
NOTE:  If this TDR is taken from an IOS-XE switch, post the complete output to the command "sh version".
IOS version 15.2(4)E10 -- I can "trust" the output from this version.
I have stopped "trusting" TDR output from switches on IOS-XE version 16.12.X because of several unfixed bugs which can cause the TDR output provide fictitious output.
